 Old 09-04-2009, 01:37 PM   #1
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
Default Compression check on Laloosh's motor
The guy who has Laloosh's car did a compression check and got these results.
185/179/165/190 psi
Im not an expert but that looks pretty good right? 185 is great I think, what about is that cylinder 3 165 normal?
 Old 09-04-2009, 01:44 PM   #2
Laloosh's Avatar
Posts: 5,166   (View Stats)
Groans: 57
how do you know? I see no thread on 247.
 Old 09-04-2009, 01:49 PM   #3
gsrtype1's Avatar
Groans: 102
I pm the dude trying to be nice cause everyone was giving him a hard time and told him I knew about your thorough break in procedure(Just referring to what I remember reading) and how your engine never burned oil as mine doesn't and hes probably fine with your car. So he pms me with updates on that latest...
 Old 09-04-2009, 01:51 PM   #4
Laloosh's Avatar
Groans: 57
165 is border line imo. Usually they should be within 20-30 of each other. However i havnt seen any compression tests for this car
 Old 09-04-2009, 01:57 PM   #5
gsrtype1's Avatar
Groans: 102
I was thinking about doing a test on mine to see after 61,000 miles.
 Old 09-04-2009, 01:59 PM   #6
Laloosh's Avatar
Groans: 57
does the dude burn or any oil or coolant? I traded her in iwth 37-38 and the only coolant/oil lost was from turbo installs/uninstalls, otherwise, not a drop was burned.
 Old 09-04-2009, 02:02 PM   #7
gsrtype1's Avatar
Groans: 102
Yeah he said the oil looked perfect, same with my car it has never burned a drop of oil.
 Old 09-04-2009, 02:07 PM   #8
SilverDemon's Avatar
Posts: 3,034   (View Stats)
I did a compression test on mine before the turbo install......185 across the board
 Old 09-04-2009, 02:08 PM   #9
Hoangy's Avatar
Posts: 344   (View Stats)
Hoangy is the leader of the worldHoangy is the leader of the worldHoangy is the leader of the worldHoangy is the leader of the worldHoangy is the leader of the worldHoangy is the leader of the worldHoangy is the leader of the worldHoangy is the leader of the worldHoangy is the leader of the worldHoangy is the leader of the worldHoangy is the leader of the world
Normally with a compression test, if the cylinder compression is between 10-20% you're good. Cylinder 3 looks a little low imo. Was this done as a cold start, or the engine was already warm?
Hoangy is offline   Reply With Quote
 Old 09-04-2009, 03:20 PM   #10
gsrtype1's Avatar
Groans: 102
Im not sure it it was warmed up good or not. I might do this this weekend.
 Old 09-04-2009, 03:26 PM   #11
SharkDiver's Avatar
Posts: 969   (View Stats)
SharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the world
Groaned at 7 Times in 6 Posts
You want to do it with a warm engine..
Ill try to find my thread about when I did my compression check..
I found it and it looks like I was between 172-180psi,i should test it again with my new bottom end rebuild.
http://www.mazdaspeedforums.org/foru...test-done.html
Pauter rods,Cp pistons 9.5:1 @ .020 over,ARP head & main studs,DNP ceramic coated exhaust mani.,TXS Dp,TXS Tp with high flow cat,PG reworked turbo,Cobb sri,Cobb fmic,Cobb Ap,Cobb inlet,HPFP,BSD,ACT street disk with light flywheel,TWM shifter bushing,rear MM,Oil CC and 1 step colder plugs and more
http://videos.streetfire.net/profile/SharkDiver.htm
http://www.youtube.com/user/sharkdiverjohn
SharkDiver is offline   Reply With Quote
 Old 09-04-2009, 03:53 PM   #12
jhershorin's Avatar
Posts: 2,087   (View Stats)
jhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the world
Groans: 31
Groaned at 86 Times in 65 Posts
The numbers aren't terrible. I have shit compression showing 160, 148-152, 180, 185.
He'll be fine. 160+ is fine but its getting border line low.
-JEWBERT
jhershorin is offline   Reply With Quote
 Old 09-04-2009, 04:04 PM   #13
Hoangy's Avatar
Yeah, just make sure your engine is warmed up, I have a project 95 del sol s, that I had to do a compression test to see if my rings aren't blown and it hasn't been started for the longest time (and still hasn't, been trouble shooting for the last month or so), so I knew with a cold engine that the compression wasn't going to be right.
 Old 09-04-2009, 05:45 PM   #14
Fux Wit It
Darksun280's Avatar
Posts: 9,213   (View Stats)
Groans: 175
Yeah jake is a low compression master by now lol.
Tell that guy to start busting out the 0 weight high mileage oil..
Carry on citizens....
Pump Gas Champ 10.9 @ 128
10.7 @ 133 auto 1G DSM
 Old 09-04-2009, 06:16 PM   #15
gsrtype1's Avatar
Groans: 102
It looks super easy and cheap to do. Everybody should do it just to see...
 Old 09-04-2009, 09:34 PM   #16
Laloosh's Avatar
Groans: 57
not exactly super easy, you gotta force the TB to open up
 Old 09-04-2009, 09:47 PM   #17
mexicant's Avatar
Posts: 867   (View Stats)
mexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the world
Groans: 147
Groaned at 34 Times in 29 Posts
bring that bmw out to az, you wanna get burned by a $100 dsm?
"08, I hate to break it to you, but if it gives kevin a boner, its porn"
NATOR PERFORMANCE
Nylon washer sponsered
mexicant is offline   Reply With Quote
 Old 09-04-2009, 09:49 PM   #18
Laloosh's Avatar
Groans: 57
yea ill be right there....leaving in 5 minutes. Idiot
 Old 09-04-2009, 09:56 PM   #19
mexicant's Avatar
Groans: 147
I will alert border patrol
" let the guido in"
NATOR PERFORMANCE
 Old 09-04-2009, 10:08 PM   #20
Laloosh's Avatar
Groans: 57
too bad im not italian
Should you be standing on the corner waiting for some1 to pick u up so you can dig a hole in their backyard?
 Old 09-05-2009, 01:26 PM   #21
Scatt Nasty's Avatar
Posts: 1,204   (View Stats)
Scatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the world
Groans: 94
Groaned at 43 Times in 33 Posts
lol @ home depot/guido jokes
321 HP/348TQ-- 13.940 @ 106 /3kft ASL
Scatt Nasty is offline   Reply With Quote
 Old 09-05-2009, 05:52 PM   #22
gsrtype1's Avatar
Groans: 102
I was referring too u tube how too lol. thought it looked pretty straight forward.
 Old 09-05-2009, 07:39 PM   #23
jhershorin's Avatar
Groans: 31
Compression checks are extremely easy to do. In the mazdaspeeds all you have to do is pull all four plugs and step on the gas while stepping on the clutch and turn the key and hold for a few seconds. Its programmed in the ecu that when you have the clutch and gas depressed all the way at startup the throttle will open and the injectors wont pulse so no gas. If you don't believe me (your dumb haha) but go out and try to start your car doing that. It wont start.
-JEWBERT
The Following 2 Users Say Thank You to jhershorin For This Useful Post:
06Speed6 (09-06-2009), gsrtype1 (09-05-2009)
 Old 09-05-2009, 07:49 PM   #24
gsrtype1's Avatar
Groans: 102
awsome info bro!
 Old 09-05-2009, 08:29 PM   #25
Fux Wit It
Darksun280's Avatar
Groans: 175
Told you he's a compression masta
 Old 09-06-2009, 10:45 AM   #26
Buildabong's Avatar
Buildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the world
Groans: 213
Groaned at 274 Times in 187 Posts
Also pull the fuse for the fuel pump. We did a test on johns car back in the day
Buildabong is offline   Reply With Quote
The Following User Says Thank You to Buildabong For This Useful Post:
gsrtype1 (09-06-2009)
 Old 09-06-2009, 06:10 PM   #27
gsrtype1's Avatar
Groans: 102
yep lol
 Old 09-06-2009, 06:25 PM   #28
ptperformance's Avatar
Posts: 4,123   (View Stats)
ptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the world
More than 10% between cly's is dookie and you have close to 20% from the highest to lowest (double dookie). We build a motor with oil dropped per cly if there is more then 7% change between cylinders. You should never have more than 3% on a properly broken in newer motor.
ptperformance is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/compression-check-laloosh-s-motor-37143/
Failtastic Weekend :( This thread Refback 09-25-2009 09:31 AM
Compression test done.. SharkDiver MazdaSpeed 3 - Engine, Transmission & Driveline 3 03-25-2009 03:28 PM
engine compression? bombdotcom Mazdaspeed3/6 General Discussion 12 09-23-2008 03:06 AM
Copyright 2008 ; 2014 Cymru Internet Services LLC | FYHN Autosports HQ
Page generated in 0.44410 seconds with 30 queries
