 Old 10-22-2009, 09:47 AM   #1
SharkDiver's Avatar
Posts: 969   (View Stats)
SharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the world
Groaned at 7 Times in 6 Posts
Default Compression test on built motor
Just thought I would let you guys know what kinda compression im getting on my built motor. I have about 8k miles on it since the build and running about 19-22psi of boost. I got the car warmed up to about 165 degrees (coolent temp) and did the test. Ill start from the pulley side of the motor first,I cant remember if thats #4 or #1.
183 180 179 181
That is all for now..
Pauter rods,Cp pistons 9.5:1 @ .020 over,ARP head & main studs,DNP ceramic coated exhaust mani.,TXS Dp,TXS Tp with high flow cat,PG reworked turbo,Cobb sri,Cobb fmic,Cobb Ap,Cobb inlet,HPFP,BSD,ACT street disk with light flywheel,TWM shifter bushing,rear MM,Oil CC and 1 step colder plugs and more
http://videos.streetfire.net/profile/SharkDiver.htm
http://www.youtube.com/user/sharkdiverjohn
SharkDiver is offline   Reply With Quote
The Following 3 Users Say Thank You to SharkDiver For This Useful Post:
djuosnteisn (10-23-2009), E4Performance (10-22-2009), gsrtype1 (10-22-2009)
 Old 10-22-2009, 09:52 AM   #2
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
Sweet! that looks great right?
 Old 10-22-2009, 10:23 AM   #3
SharkDiver's Avatar
Its within spec.,I was thinking it would be closer to 190psi but this is still good.
 Old 10-22-2009, 12:49 PM   #4
clos561's Avatar
Posts: 1,172   (View Stats)
clos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the world
how much diff is that from stock.
7-Inch Jensen Flip Out Touch Screen, HKS SSQ, MS CAI, Prosport Premium Amber/White Boost Gauge,2nd Cat Gutted, Delrin TRZ MM,16 inch FD rims,TWM shifter Bushings,COBB Turbo Inlet, 28psi, rebuilt stock block, custom rods and piston heads/gaskets, underdrive pulleys, big cams, big oil filter, stage4 clutch, stage4 DISI injectors, Fuel Pump, 4inch Catless TBE with screamer pipe, external wastegate spring modification,Methanol direct twin port duty cycle injection. Tuned by Nator Performance
clos561 is offline   Reply With Quote
 Old 10-22-2009, 12:52 PM   #5
wassup61's Avatar
Posts: 1,232   (View Stats)
Groans: 29
i CT'ed at 185 across the board on arias 8.8:1. You really should compression test when the car is piping hot (op temp of 190* for 10 minutes). stock compression i had 190s across the board.
All wagon, No traction
 Old 10-22-2009, 03:48 PM   #6
SharkDiver's Avatar
My stock #s were: 180 172 175 173
Compression test done..
Compression check on Laloosh's motor gsrtype1 MazdaSpeed 3 - Engine, Transmission & Driveline 27 09-06-2009 07:25 PM
has anyone with built motor broke a rod cbspeed3 MazdaSpeed 3 - Engine, Transmission & Driveline 41 08-05-2009 12:24 PM
built motor ms3boost MazdaSpeed 3 - Engine, Transmission & Driveline 17 05-20-2009 10:22 AM
Compression test done.. SharkDiver MazdaSpeed 3 - Engine, Transmission & Driveline 3 03-25-2009 04:28 PM
Who Has A Built Motor? Need Impressions Haltech MazdaSpeed 3 - Engine, Transmission & Driveline 99 12-22-2008 08:51 AM
Page generated in 0.27274 seconds with 23 queries
