 Old 03-25-2009, 09:53 AM   #1
SharkDiver's Avatar
Posts: 969   (View Stats)
SharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the world
Groaned at 7 Times in 6 Posts
Default Compression test done..
I did a compression test yesterday just to see how it is.I cant remember the cyclinder order so I will just go from sri side across to the timing belt side.On the cylinder closest to the sri I got 180psi,then 172,175,173.These numbers seem about right altough I thought they where suppose to be from 180-200psi but I may be wrong.
Maybe someone can tell me the what it should be and what the cyclinder numbers really are.I think the cylinder closest to the sri is #1 then #3,#2,#4 but I may be wrong.
I wish I had a leakdown test gauge becuase that is what I would like to do next.I may have to pay someone to do that or I could just go buy the gauge and do it myself.
Anyways how do these #s look?
Pauter rods,Cp pistons 9.5:1 @ .020 over,ARP head & main studs,DNP ceramic coated exhaust mani.,TXS Dp,TXS Tp with high flow cat,PG reworked turbo,Cobb sri,Cobb fmic,Cobb Ap,Cobb inlet,HPFP,BSD,ACT street disk with light flywheel,TWM shifter bushing,rear MM,Oil CC and 1 step colder plugs and more
http://videos.streetfire.net/profile/SharkDiver.htm
http://www.youtube.com/user/sharkdiverjohn
SharkDiver is offline   Reply With Quote
The Following User Says Thank You to SharkDiver For This Useful Post:
802MS3 (03-25-2009)
 Old 03-25-2009, 02:57 PM   #2
SRTCE142's Avatar
Posts: 95   (View Stats)
SRTCE142 has a reputation beyond reputeSRTCE142 has a reputation beyond reputeSRTCE142 has a reputation beyond reputeSRTCE142 has a reputation beyond reputeSRTCE142 has a reputation beyond reputeSRTCE142 has a reputation beyond reputeSRTCE142 has a reputation beyond reputeSRTCE142 has a reputation beyond reputeSRTCE142 has a reputation beyond reputeSRTCE142 has a reputation beyond reputeSRTCE142 has a reputation beyond repute
standard is 185.65 psi
Min is 130
Max difference between cylinders 28.5
And the numbering is 1-4 starting with the passenger side cylinder
SRTCE142 is offline   Reply With Quote
The Following 2 Users Say Thank You to SRTCE142 For This Useful Post:
SharkDiver (03-25-2009), xhymer (06-06-2011)
 Old 03-25-2009, 03:15 PM   #3
jhershorin's Avatar
Posts: 2,087   (View Stats)
jhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the world
Groans: 31
Groaned at 86 Times in 65 Posts
Your golden. Im fighting mazda right now because mine is crap.
-JEWBERT
jhershorin is offline   Reply With Quote
The Following User Says Thank You to jhershorin For This Useful Post:
 Old 03-25-2009, 03:28 PM   #4
SharkDiver's Avatar
Thanks for the replys...Wow 130 psi seems pretty low...Are you going to rebuild?
engine compression? bombdotcom Mazdaspeed3/6 General Discussion 12 09-23-2008 03:06 AM
First Test: 2009 Nissan GT-R Track Test Video Haltech Automotive News 0 04-02-2008 04:50 PM
Page generated in 0.40716 seconds with 22 queries
