-   -   Coolant type help please (http://www.mazdaspeedforums.org/forum/f10/coolant-type-help-please-113313/)
Koenig 07-15-2013 03:23 PM
Originally Posted by BigBoostMS3 (Post 2159709)
Yea I found it on at least one of their websites but when I went they had never heard of it. I went to oreillys, autozone, and advance with the same results. Keep in mind the parts guys around here are all good old boys. Ford was closer than napa so I never did check there.
NAPA is around the corner for me. Was $12.99 (13.99?) Each when I bought it. If they have to order it comes within a day. Saves me $15 bucks over Ford/Mazda. Or I get 2 for the cost of 1 Motor craft.
I did a full drain and flush, used 2 gallons.
~finger tap dancin' on my Galaxy S III
tbutts333 11-17-2014 09:51 AM
Okay well after driving the car around and breaking it in the cel light came on bad 02 sensor. I must have touched it accidentally. But my question is now the car is getting bad mpg like 20-22mpg it used to get 28 easy. What could cause this?? Thanks guys
HawkeyeGeoff 11-17-2014 10:27 AM
AN 02 sensor could do that.
tbutts333 11-17-2014 10:44 AM
Ohh thank you damn didn't wanna have to replace that thing!!!
BACKYARDKUSTOMZ 09-23-2017 02:02 PM
If you guys need the Motorcraft Specialty Green (FL-22) and live in Georgia go to Parts Authority. They have a few locations throughout the state.
CaristoV2 10-17-2017 10:05 AM
Originally Posted by kingbird72 (Post 1408039)
good day everyone, I've searched to death but couldn't find an definitive answer, I have a 07 speed 3 since brand new, and now I'm thinking about changing the factory filled coolant, the question is what type of coolant was used at the factory line??? I've checked the cap and the reservoir and no where does it indicate "FL22" anywhere.... i've read the owner's manual, the mazda shop manual, also called the dealer... even pulled up Mazda service bulletin 01-033/07( which doesn't apply to Canada).....nobody could give me an answer. Finally I called Mazda Canada this morning and the rep spoke to a "Mazda Engineer", and according to the engineer, he has confirmed that during 06-07 there were both type coolant used, however if there were no sticker indicating the use of "FL22" or the cap doesn't indicate"FL 22", than back in Japan it was factory filled with regular coolant.....I thought I will share this for folks in Canada, also if anyone could please confirm if the "Mazda Engineer" did not BS me....
I had the same issue. couldn't seem to find the right coolant for my speed 3. the cap says "FL22" though.. I couldn't find any FL22 anywhere and ended up using regular green coolant, and haven't had any problems.
Page generated in 0.18237 seconds with 11 queries
