-   -   Could my car be slower after fuel pump internals? (http://www.mazdaspeedforums.org/forum/f10/could-my-car-slower-after-fuel-pump-25803/)
jamesthebikeguy 04-17-2009 08:23 AM
I have an almost stock (just a Cobb SRI) 09 speed 3.
I installed the Carpe Diem Max Flow Fuel pump internals, and after a few hundred miles i have come to the conclusion that the butt dyno says i have lost some power.
Is it fair for me to conclude i have lost some power because the car is running richer?
Lex 04-17-2009 08:26 AM
No unless the pump is not working as expected. You must get a device to datalog fuel pressure.
gsrtype1 04-17-2009 08:26 AM
Have you data logged your fuel pressure?
ms3jake 04-17-2009 08:41 AM
Why did you upgrade the fuel pump internals if you are near stock?
Bravnik 04-17-2009 08:44 AM
Because he probably had stutter or some other abnormality and the FIRST thing people do is tell people....OMG YOU NEED FP Upgrade!!!!!! Which is total horse shit 99% of the time.
gsrtype1 04-17-2009 08:56 AM
U prob didn't need a upgrade with yur mods. But it shoulld't feel less powerful, my car felt smother and more powerful after installing pg internals. U should borrow a dasshawk if u don't have one and log yur fuel pressure in a 3rg gear wot run. It should never go below 1700psi.
glocK23 04-17-2009 08:57 AM
QFT!!!!!!!!!...
:werd:
jamesthebikeguy 04-17-2009 12:51 PM
Im going to order a Dashhawk very very soon.
I know with my mods i dont need a fuel pump, but coming from a bmw tuning community prior to this car i like to mod safely first.
Before installing a down pipe or anything else i wanted to make sure that i have a fuel pump and OCC taken care of, dont want my 09 popping.
glocK23 04-17-2009 01:47 PM
Did you get version 1 or version 2 of the fuel pump internals?
remember, the first batch was machined incorrectly, the second batch is fine however.
jamesthebikeguy 04-17-2009 05:14 PM
both version one and two were recalled. However mine went through the recall process so no worries and I talked to... John... i think at Carpe Diem and he said he personally checked it.
However this thread is just and inquiry to find out if i would be running richer now with higher fuel pressure.
ms3jake 04-18-2009 08:19 AM
Nothing wrong with playing it safe. I dont think a couple bolt ons like a DP and intake are gonna blow your motor. If this motor is gonna pop its gonna pop. Of coarse blindy turning up the boost or flooring it up a steep hill in 6th gear at 1500 rpms on a cold engine may be part of the story people have left out on these random blown engines. "I dont know what happened I was driving along not in boost at 2500 rpms and BOOM!" Like judge Judy says: " If the story doesnt make sense its probably a lie.":deal:
86AmishMs3 04-19-2009 02:44 AM
well you'll have to datalog, if you're running richer but were'nt knockin' in the first place then you might have lost a little power. But if you were someone who was knocking a lot and timing had to be cut back, then there is power to be gained from the extra fuel. Leaner=hotter burn= more efficient, which it sounds like you know that. At least you can sleep better at night. But I would check to see if your hunch is true
Page generated in 0.17713 seconds with 11 queries
