Like Tree18Likes
 Old 05-31-2014, 09:39 AM   #1
Turbo_Steve's Avatar
Posts: 944   (View Stats)
Turbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the world
Default Could it really be this easy? Crc intake valve cleaner for gdi engines!
So while grabbing some carburetor cleaner for my weed trimmer at AutoZone today I noticed this little can. I think the picture explains it all.
Could clean valves really be this simple? It may work , but can't say without testing so I purchased a can. I have about 10,000 miles since my last cleaning when I installed my tig. I think it's a good idea for a product if it works. The instructions say to remove the air filter, raise idle to 2000 rpm, insert straw past the maf sensor and spray for 30 seconds at a time till the can is empty. Then it says to rev engine to 3500 rpm 2-3 times let idle for 1 minute then shut off. Install air filter, let car sit for 1 hour then drive car at highway speed for 10 minutes.
Says it's safe to spray through intercooler and turbos.
I'll give it a try and report back.
Mauro_Penguin likes this.
The Car - 08.5 True Red MS3 GT - MODS -Cp-e nano sri, HTP 3" tip, Autotech internals, Custom fmic 28x8x3.5 cx core, Cobb ap, Autolite XP5263, Turbo_Steve SHIFT HAMMER SSP, TRZ rear mount. Atp Downpipe and custom catted mid pipe. JBR TIG, tb gasket & egr delete, XS POWER V2 turbo manifold, Aem 30-3000 WMI Kit, Ported intake By Turbo_Steve. ADAPTED PERFORMANCE SHIFT HAMMER SSP - ADAPTED PERFORMANCE ENGINE COVERS
Soon to come.
WHO KNOWS? A.D.D. FTW!
Turbo_Steve is offline   Reply With Quote
The Following 10 Users Say Thank You to Turbo_Steve For This Useful Post:
ABolewski (06-02-2014), ArmanRus (05-31-2014), blackms3_71 (05-31-2014), jack_hammer (12-10-2014), maisonvi (05-31-2014), Mauro_Penguin (06-01-2014), redneck4Christ (12-10-2014), sidekick (06-02-2014), speed23 (05-31-2014), torquemaniac (06-03-2014)
 Old 05-31-2014, 09:40 AM   #2
maisonvi's Avatar
Posts: 3,490   (View Stats)
maisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the world
Groans: 75
Interesting. Subbed for results. Too bad its suck a pain to remove the mainifold. I would love to see before and after pics.
Franken Turbo, built motor, meth.
DIY parts: Shift Knob, Shift Plate, Shift Bushings, Battery Tray, EBCS, RSB, probably more.
"Your signature should just say, I'm the shit." -LynzeC
maisonvi is offline   Reply With Quote
The Following 2 Users Say Thank You to maisonvi For This Useful Post:
HawkeyeGeoff (06-01-2014), Mauro_Penguin (06-01-2014)
 Old 05-31-2014, 09:41 AM   #3
blackms3_71's Avatar
Posts: 2,250   (View Stats)
blackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the world
Seems kool i would try it. If anything its like a seaform but maybe better
COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned
blackms3_71 is offline   Reply With Quote
 Old 05-31-2014, 09:42 AM   #4
Ireland's Avatar
Posts: 1,419   (View Stats)
Ireland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the world
Groaned at 119 Times in 22 Posts
Subbed for results
2013 Tech Package // NVS tuned // 35% e85
DYNOCOM eddy current chassis dyno @ 332hp 400lbft
Ireland is offline   Reply With Quote
 Old 05-31-2014, 09:45 AM   #5
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
Why not just spray it down into the nipple (blue clip) on the IM by the fans? Cuts out all the travel time from the intake.
The Following 4 Users Say Thank You to pzr2874 For This Useful Post:
Darth_Nuruodo (05-31-2014), Easter Bunny (05-31-2014), jm211 (06-01-2014), maisonvi (05-31-2014)
 Old 05-31-2014, 10:17 AM   #6
maisonvi's Avatar
Groans: 75
I was thinking the same thing, you might have vacuum issues running though. I have a spot on my hot pipe I could use to at least skip the turbo. Someone with pre TB meth bungs might be able to use those as well.
 Old 05-31-2014, 10:46 AM   #7
I would worry about the spray not getting at all the valves evenly if spraying directly in the manifold. I know this is a downfall to seafoam. I think it's best to be done pre throttle body for proper atomization.
Soon to come.
 Old 05-31-2014, 10:48 AM   #8
JgamB's Avatar
Posts: 2,566   (View Stats)
Going to buy some right meow. Nice find, just watched their video explaining the voodoo. I'm a little apprehensive as I've seen all kinds of shit tossed at the valves but usually ending up using a pick to get them clean.
The Following User Says Thank You to JgamB For This Useful Post:
 Old 05-31-2014, 11:11 AM   #9
pzr2874's Avatar
Groans: 146
Have you seen Mazda Zoom cleaner at work before?
I use it and spray a half can into that nipple .... Not sure it works but it cleans up my idle a little bit. I can't see it NOT working being that close to the intake valves.
Good point
Last edited by pzr2874; 05-31-2014 at 11:11 AM. Reason: MSF Database - Automerged Doublepost
 Old 05-31-2014, 11:29 AM   #10
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
This looks fun.
 Old 05-31-2014, 12:50 PM   #11
ust tRied it i will let u know how it works.
The Following User Says Thank You to blackms3_71 For This Useful Post:
 Old 05-31-2014, 12:56 PM   #12
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Agent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the world
Groans: 665
Groaned at 76 Times in 40 Posts
So who's gonna be the one to pull the IM and take before & after pics?
Agent_Orange is offline   Reply With Quote
The Following 13 Users Say Thank You to Agent_Orange For This Useful Post:
ABolewski (06-02-2014), chaser27 (06-02-2014), Crarrs (06-02-2014), Donut (06-02-2014), Easter Bunny (05-31-2014), Fatguy729 (05-31-2014), Mauro_Penguin (06-01-2014), mxlplx71 (06-02-2014), pzr2874 (05-31-2014), Raider (05-31-2014), speed23 (05-31-2014), speed3sailor (05-31-2014), WetzMS3 (06-02-2014)
 Old 05-31-2014, 01:07 PM   #13
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
Not sure that stuff is safe for throttle bodies though.
 Old 05-31-2014, 01:07 PM   #14
JgamB's Avatar
I might be able to be persuaded to take the TB off and use a bore scope - if it'll get past the VCTS. I don't plan to pull the IM until I've got TIGs in hand.
My car probably isn't all that dirty though with only 18k on the odo.
 Old 05-31-2014, 01:12 PM   #15
Raider's Avatar
Groans: 856
Oh, it is dirty.
The Following 8 Users Say Thank You to Raider For This Useful Post:
Agent_Orange (05-31-2014), Fatguy729 (05-31-2014), jack_hammer (12-10-2014), JgamB (05-31-2014), Mauro_Penguin (06-01-2014), mr.speedy3 (05-31-2014), RhoadBlock (01-20-2015), Vansquish (05-31-2014)
 Old 05-31-2014, 01:17 PM   #16
Groans: 665
Oh, it is dirty.
Yeah, 18k with no OCC = dirty as fuck.
 Old 05-31-2014, 01:24 PM   #17
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
it would have to be if you use it at the air filter, wouldn't it?
Sent from my LG-MS770 using Tapatalk
it's fun to do bad things
 Old 05-31-2014, 01:35 PM   #18
Snyeed's Avatar
Posts: 743   (View Stats)
Snyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the world
Groaned at 8 Times in 4 Posts
I ran across this product on a website.
Injected Engineering - Direct Injection Intake DE-Carbon kit
2010ms4-1 likes this.
417whp 428tq 12.037@117.2mph
Snyeed is offline   Reply With Quote
 Old 05-31-2014, 01:38 PM   #19
Raider's Avatar
Groans: 856
Oh, I thought I read MAP sensor, not MAF.
 Old 05-31-2014, 03:31 PM   #20
Groans: 549
This sure looks like a hypertech
http://injectedstore.com/collections...sel-titanium-1
 Old 05-31-2014, 04:06 PM   #21
speed23's Avatar
Posts: 1,480   (View Stats)
I wish this worked, but the website says "removes up to 23% of deposits...", so realistically, its gonna remove 10-15%? Thats not really much...
 Old 05-31-2014, 04:17 PM   #22
Ireland's Avatar
Hahaha just repeat...7 times
The Following 2 Users Say Thank You to Ireland For This Useful Post:
rfinkle2 (05-31-2014), speed23 (05-31-2014)
 Old 05-31-2014, 06:38 PM   #23
Well did this today and car feels smoother and idle is better. As far as cleaning the vavles??? I doubt it but ill enjoy the smoother ride
 Old 05-31-2014, 06:54 PM   #24
rfinkle2's Avatar
Groans: 298
You can just tilt the mani back enough to see the valves if anyone wanted to try it that way.
I cheated and put in my thermal intake gasket in like that.
The Following 6 Users Say Thank You to rfinkle2 For This Useful Post:
Agent_Orange (05-31-2014), chaser27 (06-02-2014), jack_hammer (06-01-2014), JgamB (05-31-2014), Mauro_Penguin (06-01-2014), pzr2874 (05-31-2014)
 Old 05-31-2014, 07:20 PM   #25
pzr2874's Avatar
Groans: 146
I'm pretty sure it works, I have 131k and I SF'd my car every 1k till about 115-120K (started on about 70K) and I've noticed a little diff since I've stopped.
Placebo, I don't think so. Then again, I go through plugs once a year if not earlier. Just save a set of plugs for the treatments. my 2¢
 Old 05-31-2014, 07:39 PM   #26
ArmanRus's Avatar
Posts: 1,566   (View Stats)
ArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the world
Groans: 42
113k, valves never been touched lol. Even that 23% would be huge for me. @Opdahl; we should try this.
ArmanRus is offline   Reply With Quote
 Old 05-31-2014, 09:02 PM   #27
Kyle-609's Avatar
Posts: 142   (View Stats)
Kyle-609 has a reputation beyond reputeKyle-609 has a reputation beyond reputeKyle-609 has a reputation beyond reputeKyle-609 has a reputation beyond reputeKyle-609 has a reputation beyond reputeKyle-609 has a reputation beyond reputeKyle-609 has a reputation beyond reputeKyle-609 has a reputation beyond reputeKyle-609 has a reputation beyond reputeKyle-609 has a reputation beyond reputeKyle-609 has a reputation beyond repute
I don't even wanna know what my valves look like with 75k never being touched.
corksport spings and struts. cobb intake. at internals. damond rmm. cnt exhaust. ebay test pipe. evo x wheels 235/40 w/ g-force comp2 a/s hypnotic tuned
Kyle-609 is offline   Reply With Quote
 Old 06-01-2014, 11:05 AM   #28
jm211's Avatar
jm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the world
Groans: 52
Seems like a smart move for someone with low miles and at every oil change or so. NEED before and after pics, for sure.
Black Mica 2006 Speed6 GT | 62,000 Miles
Cobb AP | Stratified Tune Stage 1 OTS | JBR Stage II Intake | cp-e 3'' Straight Exhaust | JBR RMM | SURE AGS 600 Gram Shift Knob | SURE Anchors | SURE Return | SURE SSP/Weight | All Redline Fluids | Shell T6 | Forge V1
ms6db.com I'm Registered. Are You?
jm211 is offline   Reply With Quote
 Old 06-01-2014, 05:19 PM   #29
ArmanRus's Avatar
Groans: 42
Okay I just used a can, and after the 3,500 RPM my car belched white smoke lol. So I guess it kinda removed some carbon build up? Or somehow this stuff blew my turbo lol.
The Following User Says Thank You to ArmanRus For This Useful Post:
Mauro_Penguin (06-02-2014)
 Old 06-01-2014, 05:41 PM   #30
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
HawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the world
Subbed.
Silver 2007 Speed3 GT
Xona Rotor 6156, Port Injection w/ E85...Bunch of other stuff. I make some power.
Titanium Grey Mazdaspeed6 GTX3071, DD
HawkeyeGeoff is offline   Reply With Quote
 Old 06-02-2014, 11:40 AM   #31
nekret's Avatar
Posts: 421   (View Stats)
nekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the world
Hopeful for before&after pics!
2011 Mazdaspeed3 non-tech package
Drivetrain
CorkSport 3.5" MAF & TIP | CP-E FMIC | Synapse BPV | CorkSport EBCS (Interrupt) | Bosch 3 bar MAP | CorkSport HPFP Internals | CP-E Catted Downpipe | CP-E Triton 3" CBE | JBR Stage 2 OCC | Kozmic Primary EGR Delete | JBR Secondary EGR delete | NGK 6510 | TB coolant Bypass | JBR IM & TB Gaskets | Damond RMM, PMM, & TMM | JBR light shift weight | TWM Full Replacement Shifter | Cobb AccessPort V3 | FreekTune
Chassis
JBR Front & Rear Sway Bars | JBR Billet Rear Sway Bar Brackets | Whiteline Adjustable Front&Rear sway bar links | JBR Coilovers | Corksport BBK | Corksport Lower Tie Bar | Corksport Mid Chasis Brace
Rice
LED bumper reflectors | Morimoto LED Fog lights | VLEDs LED Highbeams | Independent Fogs | AP Engine & HPFP cover | CorkSport Pulleys | Corksport Leather Shift Knob | Corksport Steering Wheel | Damond front plate mount | Lukas LK-9750 2ch dashcam | Eonon GA7163 | thespeedline.com blue mirrors | thespeedline.com hood dampers
nekret is offline   Reply With Quote
 Old 06-02-2014, 11:44 AM   #32
Jason43's Avatar
Posts: 310   (View Stats)
Jason43 is the leader of the worldJason43 is the leader of the worldJason43 is the leader of the worldJason43 is the leader of the worldJason43 is the leader of the worldJason43 is the leader of the worldJason43 is the leader of the worldJason43 is the leader of the worldJason43 is the leader of the worldJason43 is the leader of the worldJason43 is the leader of the world
Groaned at 7 Times in 5 Posts
White smoke doesn't = burnt intake deposits.
2010 LSM
e85|cs intake/tip|cp-e tmic|internals|catless dp|magnaflow cb|forge bpv|cs rmm/inserts|cs springs|damond shift plate|ap|cs front lip|freektune|stuff...
Jason43 is offline   Reply With Quote
 Old 06-02-2014, 11:49 AM   #33
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
Sprays thru intake... Thru turbo... Thru piping... Thru intercooler... Past manifold and hits the valves strong enough to actually clean anything... Any one who has actually tried cleaning their valves by hand will see where this "miracle cure" falls flat on its face in such a ridiculous manner.
Inforfuckedturbosealsandmafsensors
Livingframe likes this.
TEAM LUXURY
Sid3wayS is offline   Reply With Quote
The Following 3 Users Say Thank You to Sid3wayS For This Useful Post:
Agent_Orange (06-02-2014), Jason43 (06-02-2014), Mauro_Penguin (06-02-2014)
 Old 06-02-2014, 12:16 PM   #34
Jason43's Avatar
This. Valve deposits on these cars are nasty. Soaking them overnight in B12 hardly softens the outer crust. Having a cleaner pour over the valves for a split second isn't doing anything. Stop wasting money.
jwgstang likes this.
2010 LSM
The Following 5 Users Say Thank You to Jason43 For This Useful Post:
chaser27 (06-02-2014), Mauro_Penguin (06-02-2014), MSMS3 (06-02-2014), robbspeed (10-25-2015), Sid3wayS (06-02-2014)
 Old 06-02-2014, 12:41 PM   #35
squilliam's Avatar
Posts: 266   (View Stats)
squilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the world
in4results
2009 CWP MS3: CP-E FMIC / CP-E RMM / Cobb SRI / Cobb TIP / Cobb AP V3/ HKS BOV / PTP HPFP Internals / UR V1 Catted DP / UR Racepipe / Cobb SS Catback Exhaust / Swift Spec-R Lowering Springs w/Koni Yellow
squilliam is offline   Reply With Quote
 Old 06-02-2014, 12:50 PM   #36
dark_matter's Avatar
Posts: 193   (View Stats)
dark_matter has a reputation beyond reputedark_matter has a reputation beyond reputedark_matter has a reputation beyond reputedark_matter has a reputation beyond reputedark_matter has a reputation beyond reputedark_matter has a reputation beyond reputedark_matter has a reputation beyond reputedark_matter has a reputation beyond reputedark_matter has a reputation beyond reputedark_matter has a reputation beyond reputedark_matter has a reputation beyond repute
This tread is worthless without pictures(before and after).
Sent from my Republic Wireless Moto X using Tapatalk
Sparkling Graphite Metallic E90 330i 6speed ZSP
RIP: くろ ひめ BlackMica SPEED3
dark_matter is offline   Reply With Quote
 Old 06-02-2014, 01:08 PM   #37
Vader's Avatar
Posts: 1,651   (View Stats)
Groans: 45
Take a before and after log...
Would that not prove (in a small way) less obstruction?
Seems easier than removing IM.
Originally Posted by mikelevi View Post
...When you have 600 lbs of faggot in your car, you are much slower than someone with 10 lbs of dick.
Vader is offline   Reply With Quote
The Following 3 Users Say Thank You to Vader For This Useful Post:
littleloogy (06-03-2014), Mauro_Penguin (06-02-2014), rfinkle2 (06-02-2014)
 Old 06-02-2014, 02:04 PM   #38
Drive By Fire's Avatar
Posts: 448   (View Stats)
Drive By Fire is the leader of the worldDrive By Fire is the leader of the worldDrive By Fire is the leader of the worldDrive By Fire is the leader of the worldDrive By Fire is the leader of the worldDrive By Fire is the leader of the worldDrive By Fire is the leader of the worldDrive By Fire is the leader of the worldDrive By Fire is the leader of the worldDrive By Fire is the leader of the worldDrive By Fire is the leader of the world
I can see this being helpful on a brand new car OR on one that had the valves cleaned, as preventative maintenance. Say once every oil change should (could) help prevent build up.
Other than that would you want and huge, sticky clump of carbon poo going through the combustion chamber and turbo?
I may be misunderstanding the properties of this can of cleaner though.
redneck4Christ likes this.
NJ NATOR
Drive By Fire is offline   Reply With Quote
 Old 06-02-2014, 04:39 PM   #39
MSMS3's Avatar
Posts: 2,834   (View Stats)
Groans: 157
My experience too. Chemtool B12 is strong shit. I had to soak each valve and then scrub with a 12 gauge shotgun wire bore brush, flush out with gasoline, repeat B12, repear scrub, reflush, and blow dry with compressed air x 4 cylinders. About 4 hours of work on top of the R&R of the manifold.
No brief chemical flush is going to do much good. The carbon is very hard.
 Old 06-02-2014, 04:39 PM   #40
pzr2874's Avatar
Groans: 146
^that's the point... you don't wants chunks going into those areas.
The Following User Says Thank You to pzr2874 For This Useful Post:
FSRRM (04-25-2017)
Intake Valve Cleaning using valve overlap and DI injection window shift Vansquish MazdaSpeed 3/6 - ECU Computer Tuning 33 05-06-2014 07:00 PM
Keep your Engine Running Cleaner and Better with the CorkSport Aluminum Oil Catch Can and Drain Valve Kit CorkSport CorkSport 24 08-31-2013 07:17 AM
DISI Valve&fuel cleaner zx2man MazdaSpeed 3 - Engine, Transmission & Driveline 0 02-20-2012 01:03 PM
Page generated in 0.57435 seconds with 44 queries
