CP-E CBE, CP-E CAI, and Turbosmart BOV Help/Questions I plan on ordering these parts today or tomorrow but want to install them myself so I can save hundreds on labor. Im 80% sure I know how to install these parts but I want to go in there very confident that I can complete the work 100% wise. Does anyone know any threads, how-to's, or links that I can go to that give instructions on how to install these mods? Yes, I am a noob so please work with me. Thanks I appreciate the help. ( TURBOSMART BOV) http://www.streetunit.com/SU_Turbosm...mzrtsbovbb.htm (CP-E CBE) http://www.cp-e.com/content/mazdaspe...exhaust-system (CP-E CAI) http://www.cp-e.com/content/mazdaspe...old-air-intake |
if you can change your oil you can swap out these parts. If i do recall they come with instructions. |
Just follow directions that come with each. Very straight forward. Having the right tools for the job is the biggest thing |
Yea oil changes are the easiest things to do and I already have all the tools. Heard a rumor about how instructions come with it, just wasn't sure. Thanks alot guys I really appreciate it. I already know that it voids the warranty but is there anything else I should know like how to's or instructions on how to do them? |
I think you should do some more research op. Other than the cai, you're wasting your money. The CBE and BOV are both sound upgrades... And the BOV will mak your car run like shit because our cars are tuned for a BPV. |
You won't void shit. As stated, only the CAI will net noticeable gains. But since it's yours, do as you please. |
How would it run like shit? Like details if it was on VTA setting. Would there be a noticeable sound difference if I put in on recert setting then compared to the stock bpv? |
one tool they dont tell you to get his alcohol, you will need this |
The stock BPV is plenty loud if you have an intake. But honestly, you're going to catch a lot of flack on here for being a ricer. |
Honestly i would stick a SRI unless you live out where its really hot and doesn't rain a lot. I had a CAI with a hydro shield and i just didn't like the fact that my car could suck up water if i hit a puddle. FYI you going to get flamed for asking about VTA. Save money and just cut out the resonator out of your exhaust. |
The weather where I live is honestly retarded. It gets freezing cold during the Fall and Winter and burning hot during the spring and summer. I'm defiantly going with the CAI tho. If its on VTA would it throw any CEL's or mess with the MAS? Just to play safe Ill go with the recirt but I want to at least be able to hear the bpv cause the stock piece of s%*t isnt doing it and never will. What do yall recomend? HKS SSQV? MazdaSPEED3 HKS Blowoff Valve Kit | Custom Performance Engineering |
y u no read? stock bpv is fvcking loud with just an intake you ricer |
Clearly you aren't experienced with multiple turbo cars... It isn't load enough and the quality of it is pitiful. I am reading all of this great information, if you are gonna be a pain in the ass get the f&*k off the thread. |
clearly you arent experienced on how to use the fucking search button.. everything you are asking has been panned out multiple times and if you dont like that you can get the fuck off the boards |
If the stock valve does its job and holds boost, why upgrade it? For what it's worth, I ran an HKS SSQV III and it made my car afterfire a lot. Put the stocker on and she ran like a champ. Sold the HKS. I can hear the stock valve with my SRI. Is it as pretty sounding as the HKS? No. But it does its job, so I'm sticking with it. Fordza1 was running stock BPV with nearly 30PSI until he went boom. The CBE may net you 5 HP. For a fraction of the cost, you can pick up a test pipe and replace the second cat. You'll get an increase in exhaust noise and will probably gain more HP than with an aftermarket CBE. As stated, remove a resonator and you'll have all the noise you need without going with a DP. As for the CAI, I'm not a huge fan as the MAF is still in the stock location, thus, the air it reads will have been warmed up a bit since it entered at the filter. A SRI is easier to install and performance between the two is negligible (much like that of a TP and CBE). Spend a fraction of the money to get nearly the same gains. |
sorry i may have been a little harsh... this thread was just the last straw on the camels back... if your stock BPV is leaking, of course another unit will help... forge v1/v2, turbosmart, synapse etc .... a forge v1 can be had for $75 right now in the for sale section. but if noise is all you are after, go VTA but be prepared for driveability issues |
Gonna get the CP-E exhuast and CAI because Im a fan of them and I like their quality of their products. My stock BPV is not leaking at all, in fact its running great, the upgrade would be mostly for sound. That is all true about what you said about the SRI so before I make any purchase Ill defiantly look into it. Thanks for the advice. |
You'll be happy with the CBE. Next to CorkSport, CP-E's sounds the best. You'll definitely pay a premium, but the parts I have from them are nothing but quality. You can probably find it cheaper, however, from one of the vendors. |
RICE! |
Thankyou to everyone that helped me out on this thread, learned alot and found great information. Also thankyou for your patiance, I know dealing with noobs can be frustrating (trust me I play Call of Duty) but thanks for helping me out with the info. Best of luck to all of you |
OP- In case you were wondering why the BOV VTA would give you driveability issues this is why: (don't have my MS3 yet but it sounds like the MZR runs using a MAF/Hotwire setup) What happens is the MAF calculates the amount of air going into the engine. When you blow off, the MAF & ECU has already accounted for lets say 10 pcs of air. But now there's only 4 pcs left in the intake system. Then you will see your AFR's shoot to rich and stuttering and flames etc. Good luck! |
Damn that clears it all up for me, thanks alot for that info. I do have a question tho, if I install the CP-E CAI and install the CP-E HKS SSQV BOV and have it set for 100% recirt..would I be able to hear it? Like the stock bpv but just want to increase the volume of that noise. |
With an HKS unit and intake you'll get a louder "woosh" of air. |
You are truly a ricer. |
WTF? MSF is getting soft? got a ricer here that wont search for shit even if his life depended on it. All these topics have been beaten to death. Then he insults a fellow MSF member to get the Fuck out of his thread. WOW, im shocked OP, obviously, you dont know shit about this car. SEARCH, its not gonna kill you I have a SRI and a HKS BOV 100% recirc, and its loud. And no im not gonna post any videos to help you out. |
1. Buy a SRI you dont need CAI (temperature difference is not that mch and your turbo that air is getting cooled down even more when it runs through your InterCOOLER) 2. DO NOT BUY BOV/BPV. Your stock BPV will be loud once you install what I mentioned above. Also, it will hold fine until you buy AP and raise the boost then MAYBE you will have to upgrade to a BPV, you hear that?? BPV I say it again! 3. Just cut out your second cat and weld in a straight pipe. If you want more sound cut out your resonator and weld a straight pipe, for more sound, cut out both resonators and straight pipe it. Please Please Please use the search up top. These ppl on MSF told you what I just said millions of time in this thread alone and you still ignore and want that loud PSSHHHHH noise. That wont get you chicks, nor make you look cool seriously. I think you belong with the target crowd right @08.5MS3 ?? lol but for real I am not trying to be a dick bro, just a couple helpful hints. You wont throw any CEL from any of the mentioned above so your safe :) Quote:
Thats what im saying, as I was reading through this I felt like MSF wasn't....well MSF lol. They actually pointed the OP in the right direction but the OP insisted on geting that loud noise. Common, the rules should be an exception once it gets to this point no? If there was no rules, the OP would prolly be crying right about now :silly: |
specially in the Gen one section. I bet this guy wont even donate! Talking about how he knows about dealing with noobs cause of COD. LMAO, thats a fucking game. MS3s are real my friend, and when shit blows up, well, i guess we'll know who the noob is. In before "i got a CEL, will it void my warranty?" |
I tried to be nice and help. But OP, you kept digging deeper and deeper. Now I'm pissed because you don't listen to ANYONE who has tried to help! YOU DON'T NEED AN AFTERMARKET BPV!!!!!!! SHUT THE FUCK UP ABOUT IT. |
Lol |
Don't know much about MS3's but I do know engines/ecu's. 1. I would go SRI for safety. You don't want to suck up water and hydrolock your motor. (Rods and pistons etc. Outside the engine block) What you should do instead is make a heat shield to keep rad heat away from your filter. Air temp rises exponentialy whenit is compressed. 2. Cutting th cat out and putting a test pipe WILL give you a CEL.unless you wire in an O2 simulator or put in an O2 bung extender. Or if the AP will get rid of this CEL permanently. |
| All times are GMT -7. The time now is 07:08 AM. |
