-   -   CP Piston ring gap (http://www.mazdaspeedforums.org/forum/f10/cp-piston-ring-gap-194860/)
senor blanco ms3 10-28-2015 12:08 AM
CP Piston ring gap
Finally building my engine and wanted to check if there was a recommended ring gap other than what CP provides in their documentation.
Sent from my Nexus 7 using Tapatalk
silvapain 10-28-2015 10:33 AM
CP Piston ring gap
Depends on what your plans are for the engine.
On my first build I was planning on lots & lots of boost with 10.4:1 compression, so I went with larger gaps of 0.018" & 0.022"
On my second build I went back to stock compression and was shooting for lower boost, so went with smaller gaps of 0.016" & 0.018".
senor blanco ms3 10-28-2015 10:38 AM
I have a 5858 looking for 500+ which is probably around 30psi.
Sent from my SAMSUNG-SM-N920A using Tapatalk
silvapain 10-28-2015 10:56 AM
I can't give you hard numbers to use, but I'll lay some theory down for you:
Ideally a piston ring doesn't have a gap, as that's best for compression. However, as the cylinder, piston, and ring heats up, the gap closes. What you want is a gap as small as possible, but big enough so that when the ring is at its hottest, the ring ends don't touch. If they do, it could damage the cylinder wall, or crack the piston ring lands.
That said, Wiseco has a little calculation on their FAQ about ring gaps:
Attachment 215183
My numbers posted earlier were determined by talking to my machinist about my goals, and he made the call based on his experience.
My thought is something on the higher side close to what I ran on my first build would be what you want.
Page generated in 0.16682 seconds with 11 queries
