Responding to an earlier post in this thread: Yes, raising idle rpm to +200 will do wonders for taming the increased NVH (vibes) that come with stiffer mounts. Also helps to reduce risk of "smoking turbo" if running the stock turbo. |
I've always wondered by our idle is this low, I've seen it dip down towards ~500rpm imaginary mark. |
The tuna set my idle at 850 (due to 3.5" intake) and it did not appear to change my fuel economy, or at least not appreciably. Frankly it didn't really appreciably change the vibes either, but my setup is pretty soft for aftermarket so it wouldn't be real surprising for it to be not noticeable. |
Did you eat it after it finished your idle? |
Sent from my Moto G (4) using Tapatalk |
Hey y'all, if you guys are wondering why there hasn't been any update on my experience with the Damond PMM, it's because they're out of stock for (at least) the next two weeks. |
Honestly, I was a bit annoyed because there's nothing on their website that says they're out of stock. Also, they did not tell me they're out of stock until I asked them about my order 3 days after it's been sitting idle. Not impressed with Damond Motorsports' customer service at all. |
But you couldn't let your customers know? You had to wait for them to ask just what happened to their money and why the order is sitting the idly? |
I haven't faulted them for running out of stock. Sometimes you don't get all of the necessary components to assemble a quality part, nothing wrong with that. But informing potential customers, and displaying an *OUT OF STOCK* disclaimer is not hard at all. I mean, they managed to set up an entire, fully functional website, haven't they? Oh ok, so sure, you can't display an "OUT OF STOCK" disclaimer. How are customers supposed to know they won't receive a delivery within the appropriate amount of time? Oh I know, let's email these people who placed an order, and inform them of the situation! No? Let's just keep our mouths shut until they contact us about what happened to their money days/weeks later. Sounds like a good business plan Damond Motorsports. |
So far I've noticed all the vendors sites operate this way. A few times I ordered from Corksport (part was on backorder but I didn't know) and went ahead and placed my order. The next day I received a call from them letting me know it would be a few weeks. I canceled at that point. When I ordered their turbo it was the same deal, but I wasn't in a rush so I was cool with the 3-4 week wait. But I always got a call within 24-48 hours letting me part was backordered, so I can understand your frustration. I also said the same thing to CS about adding a quantity counter on their parts for their website. |
I had to call them after nearly a week of zero communications from them. It was only then that they told me the PMM is out of stock. However, unlike your previous situation, my PMM has failed, that's why I wanted the part ASAP. |
I might play a bit of a devils advocate for a minute here as I just replaced my Stage 2 RMM after 4 years as the bushing had developed a tear. It was nice to have a compliant vibration-free mount, but the engine was moving as much as the OEM mount by the time I replaced it. I asked CP-e if I could just buy a replacement bushing but they weren't much help so I just bought a whole new (Stage 1) one. This gives me quite a history of rear engine mounts over the last 7 years. OEM - Corksport Inserts (IMO, highly underrated) - SURE REM (Replaced after all the failures that happened, mine was fine) - CP-e Stage 2 (Bushing failed) - CP-e Stage 1 55 duro (Installed yesterday) I have now swapped back to a stage 1 RMM for a couple of reasons. Mainly, after I installed the stage 2 RMM I found my car started popping out of 4th gear under heavy downhill braking at the racetrack. This also coincided with a switch to semi slick tyres so I never genuinely had a chance to prove that this was the cause, but my mechanic made a good point that since the bushing orientation had changed, it may have altered the way the entire engine moves on its mounts. The design may seem to make much more sense on paper, but there are reasons why the manufacturers do things the way they do. I know it's an unproven theory but it resonated with me. And now that I am back running a S1, we will be able to test this theory properly real soon. Here is a video of what happens when you pop out of 4th gear and have no power to pick up the weight transfer on corner exit. Just watch the gearstick. https://www.youtube.com/watch?v=QtDV7yhr2Qw Also here are some pics of my Stage 2 RMM that I just pulled off my car. Bought it in 2013, it's done 60 000km and about 25 track days. It's served me well but I am happy to go back to the way the gods (designers) intended. This design is sold on the premise that the bushing will last forever but that's clearly not the case. So if I am gonna be replacing parts, I would rather keep it cheaper. http://i.imgur.com/wtmdIjAh.jpg http://i.imgur.com/MWpHhvIh.jpg |
Thanks for the reply, it seems you experienced exactly what I was in that it seemed like there was no difference in engine play. Do you have the other mounts upgraded or just this one? I do like the idea of the S2 and it makes a lot of sense to have it over the OEM one but the full benefit isn't happening for me. I don't track/autox this car yet because it's my only car but I'd like to get out there. I was expecting a lot more from this mount. I've read the inserts have a lot of vibration and I really didn't want that since I have to drive this every day. |
It's an engine mount. I don't know what you want from it exactly but it was never going to change the world. All aftermarket ones cause vibrations but they also settle down with time as the mount beds in. I just have the rear one rest are oem. |
Yea I'm inclined to agree, that's why I didn't replace it for 4 years. Hopefully my new turbo setup will be done by the end of the month and I'll be able to test it on the 1st of September. |
Once I removed it I unscrewed the flange and the bushing came out by hand very easily so even if it does need a press it probably doesn't need a very powerful one. My money is on a big vice being enough. In the end it just became too difficult. |
Checked in with Damond Motorsports and emailed them about my 2 WEEKS OLD order. Loving the lack of communications from them. |
| All times are GMT -7. The time now is 07:54 AM. |
