Cracked a piston Cylinder 1 piston is busted. Gotta buil the motor. Luckily the rods are still ok and right where they should be. Not gonna be cheap but could be worse i suppose :/:irked: |
Mods. How. |
Why is it that everyone who kerplodes almost never post details? |
I also love all these blowup posts on the 1st post. |
Dunno how it happened or when. Its holdin 85% compression still. Haven't driven the car hard in awhile cuz i was under the impression my turbo was goin bad again cuz of smoking. Turns out it was oil leakin by the piston and the dead give away was all the oil that sprayed all over my engine bay after the pcv check valve blew apart on monday. My mods are turbo xs tbe, cobb fmic, cp-e nano and inlet, nrg bpv, 1 step colder plugs, occ, mr lil guy fuel pump, bsd and oil pan baffle, and a custom tune from surgeline tuning. |
:hmmm: |
I really should borescope my motor. I have compression issues but im fairly positive i just have worn rings and scored cylinder walls. |
^ whats your compression at? |
ehh joined yesterday, first post is about blowing up. Too convenient. Probably just to stir the pot. |
Either way, it's a great name. |
im seeing 155, 145, 174, 178 i haven't done it in about 2 months so i dont know what iti is now. |
I'm just gonna go forged. I don't wanna pay out my ass but while the motor is out i might as well make er safe Think i'm gonna go with wiseco and pauter. If anyone cares to chime on other options i'm listenin. Thanks guys |
Donate and you'll never have to steal another turd again. |
atleast it was a piston, and not a rod. LOL |
Atleast you have a workable block! haha |
This just keeps gettin more and more expensive!!! Probably gonna touch 6 grand! |
lol perfect avatar, turd burglar! |
Where you located turd - if your near where I am moving I"ll turn some wrenches to save you some dough. |
Located in good ol albany oregon . But the damage has already been done lol by that i mean the motor has been pulled broken down and sent off to the machine shop already thanks alot though man |
haha. driving it is fine. compression hasn't changed in 6 months. it is just worn cylinder walls / piston rings. motors not gonna pop - can't build enough cylinder pressure :) if i ever feel the motivation to build another car i will with the same head i had on my turbo 3 and a higher compression bottom end with a 3076. i doubt i will. i'll probably buy my buddies TL off him or my brothers g35. I've had a fast car. I like comfy now. My ms6 has a flawless fully JL Audio top of the line system in it (gotta love being a JL dealer) and a pioneer z3 so its a blast for road trips. With the weight of the ms6 and the shitty rear end i have no interest at this point in making it as fast as my last car - or even trying. but who knows - maybe i'll get bored and want to turn a wrench again |
Quick question guys should i get some new coated bearings on this build or just reuse the oe bearings? Its my dd and i don't plan on ever racin this thing on any sort of consistent basis so should i save my money elsewhere? Thanks |
I would look into a coated set of OE bearings. Don't mess around with different sized ones. |
Ok thanks guys. More questions will undoubtedly be comin lol this all got forced on me way too quick!!! Edit by Darksun: Bad burglar, Bad boy.... |
hmmm r u sure??? do a compression check with it warm???? u could have a leaky injector seal causing that 85% on #1. u need to pull your drain plug and look for chunks of ringlands and shit to verify its the piston. and borrow wanna those tools so you can send a small camera into the cylinder and actually inspect the piston. dont jump the gun and tear down your motor for no reason, make sure first |
Your PCV blew apart from oil pressure on it? You mean compression pressure because the piston was cracked? Got any pics? |
No pics don't even have the motor its sittin in a machine shop right now. When it happened oil blew out my exhaust all over the hatch and the entire passenger side of my engine bay from the radiator to the front axle was covered in oil lol shitty |
^ Be careful, not doing your homework just begs to get taken advantage of. |
sorry man. good luck with the build. |
| All times are GMT -7. The time now is 06:51 AM. |
