 Old 08-10-2009, 02:26 PM   #41
vbt101's Avatar
Posts: 733   (View Stats)
vbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the world
shop cock ftl.
vbt101 is offline   Reply With Quote
 Old 08-10-2009, 05:33 PM   #42
turd burglar's Avatar
Posts: 1,895   (View Stats)
Groans: 39
Haha well today i was told i do have a leaky injector also a fucked up intake valve and they have more lookin around to do still. I haven't ordered any parts yet even but at this point i'm wonderin if i should go forged or if my rods and pistons check out to just fix it up and sell this fucking piece of shit. I'm SO discouraged with this car anymore its always somethin fuckin up!!!!
__________________________________________________ ________________________________________________
Opinions guys to forge or not to forge?!!! I'm already droppin a grip for labor might as well go for the gusto. So you guys either talk me down from the ledge or push me off
NO! No way am I havin a dick made outta hamburger!
stocking out, buy my big turbo shit here, http://www.mazdaspeedforums.org/forum/f229/bye-bye-big-turbo-dreams-82241/ more to come as stock shit arrives
Last edited by turd burglar; 08-10-2009 at 09:02 PM. Reason: MSF Database - Automerged Doublepost
 Old 08-10-2009, 09:23 PM   #43
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
You is a fool you can get a stock motor in there for 3200 installed sell your old motor for 1k-1500 Then trade in the car. Thats the cheapest solution and you can be back on the road in 2 weeks tops
Carry on citizens....
10.7 @ 133 auto 1G DSM
 Old 08-11-2009, 07:59 PM   #44
Groans: 39
I'm already a few grand deep in labor whats another couple g's right lol ouch!!
 Old 08-14-2009, 09:13 PM   #45
Groans: 39
Well 5 grand later and no forged internals it'll be done
 Old 08-14-2009, 09:18 PM   #46
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
Let me get this straight.
You didnt put a hole in the block.
You didnt use forged internals.
And you are paying $5K....... so far.
Tell me it was more than just a hole in a piston.
What do you expect when you say "do what ya need to do tell me what i need to buy i just don't wanna think about it" ??
You are getting the "do what ya need to do I dont want to think about it" tax
Suspension:
jwdp54 (08-14-2009)
 Old 08-15-2009, 12:23 PM   #47
Groans: 39
Labor alone is 4500 between pullin the block breakin it down fixin the seal and intake valve readjusting the valve guides and all the other cleaning and prep before reassembling the motor. Yeah fucking ridiclulous i know. The 5 hundred is from new bearings, gasket set, the valve and new rings thats it. I'm not too happy but hey live and fuckin learn
the pistons are fine. The leaking injector seal and messed up intake valve caused the compression issue. Pullin the block is runnin me 2300 and the motor work is 1900. And parts are 500. So if hearin $4700 makes u feel any better thats where it stands.
Last edited by turd burglar; 08-15-2009 at 12:26 PM. Reason: MSF Database - Automerged Doublepost
 Old 08-16-2009, 02:47 AM   #48
Fux Wit It
Darksun280's Avatar
Groans: 175
eeek what ever im not gonna give you a lecture your obviously just trying to put this all behind you.
 Old 08-16-2009, 11:38 AM   #49
Groans: 39
Thanks man
 Old 08-20-2009, 12:32 AM   #50
Groans: 39
Shittiest thing is for all those guys who are forged whats to stop an injector seal from leakin and causin shit for them strong internals or not ya know. Weak shit mazda
 Old 08-20-2009, 08:12 AM   #51
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Dude that's some CRAZY labor charges. Even at $100 and hour which is ridiculous, they would have to spend 45 hours on your car to hit $4500... Unless the mechanic is blind and retarded there is no way it took that long...
 Old 08-20-2009, 06:29 PM   #52
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
+1 That is way too much.
On a side note, I am begining to wonder if the injector seals are fine and it is just a weak rail that cant hold the injectors in place well enough to seal. I have a rail sitting here and I really dont think it can handle those kind of pressures without flexing. Along that same line of thought, the Ecotech which Ford is running uses a very similar DISI system and they had to redesign the fuel rail because it was flexing and causing injector seal leaks.
2006 Mazdaspeed 6
djuosnteisn (08-21-2009)
 Old 08-20-2009, 07:15 PM   #53
Groans: 39
Well it was 2300 to pull the motor and break it down then put it together and throw it back in. The machine shop labor is 1880 so yeah its a little less than 4500 but i rounded up lol either way shitty. Lesson learned i guess... For now
 Old 08-20-2009, 07:18 PM   #54
Speeeeeed
06Speed6's Avatar
At $100/hr they are charging you for 23hr of labor lol, it shouldnt take them that long if they have lifts, proper tools, and training.
2006 Mazdaspeed 6
 Old 08-21-2009, 12:02 PM   #55
devils10's Avatar
Posts: 149   (View Stats)
devils10 has much to be proud ofdevils10 has much to be proud ofdevils10 has much to be proud ofdevils10 has much to be proud ofdevils10 has much to be proud ofdevils10 has much to be proud ofdevils10 has much to be proud ofdevils10 has much to be proud ofdevils10 has much to be proud of
Groaned at 45 Times in 24 Posts
my piston went also .. said i had to much boostt
devils10 is offline   Reply With Quote
 Old 08-21-2009, 06:28 PM   #56
Groans: 39
My pistons and shit are fine. That was just the initial diagnosis due to the 1st cylinder showin low compression. But sorry to hear that man oh well time for forged right lol
Piston ring end gap? Jarods7920 MazdaSpeed 6 - Engine, Transmission & Driveline 1 04-24-2009 12:48 PM
checking piston heights for bent rod SharkDiver MazdaSpeed 3 - Engine, Transmission & Driveline 10 04-11-2009 03:47 AM
Page generated in 0.33800 seconds with 26 queries
