 Old 11-22-2011, 05:26 PM   #41
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
Touchè
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 11-22-2011, 05:34 PM   #42
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
I know you see what I'm saying.
It's the tensioners job to take up any slack, but if it can't, it would be the same for pinned and non pinned cams. It's not like our non pinned ones are floating/self adjusting.
Stretching a chain just plain sucks for all involved.
I need to get the dcr and do mine.
I really don't want to though.
"Exclusivity" - CP-enis
Demodded.
The Seals
djuosnteisn (11-22-2011)
 Old 11-22-2011, 06:18 PM   #43
Tabasco69's Avatar
Posts: 554   (View Stats)
Tabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the world
the ARP crank bolt is not ttyl, you can reuse and retorque the shit out of it, and wtf the ms3 has 2 separate sprockets, reg mzr has a one piece dual sprocket....yeah most definitely shitty engineering
Tabasco69 is offline   Reply With Quote
The Following User Says Thank You to Tabasco69 For This Useful Post:
djuosnteisn (11-23-2011)
 Old 11-22-2011, 06:21 PM   #44
Tokay444's Avatar
Groans: 793
But with the arp bolt you follow the same TTY procedure?
Demodded.
The Seals
 Old 11-22-2011, 06:31 PM   #45
Tabasco69's Avatar
Yes you follow the same torque proceedures as stated in the factory manual, but do not be alarmed when you can not get the full 90 degrees beyond the inital ftlbs, the arp crank bolt is a stout mother fucker compare to the oem ttyl crank fastener, the most I was able to get was 40 degrees
Guess what....remember when I said cosworth stopped making keyed sprockets, well I guess they started making them again although they are charging twice as much as they used to, just bought one, I'll use it on my second engine I' am building.
The Following 3 Users Say Thank You to Tabasco69 For This Useful Post:
Alpha (04-28-2012), djuosnteisn (11-23-2011), SKiZ0TT (11-23-2011)
 Old 11-22-2011, 07:38 PM   #46
pinkcheese's Avatar
Posts: 339   (View Stats)
pinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the world
The amount of force required for the ARP bolt to reach that 90 should only be done with a flywheel lock and the engine on the ground not a stand. otherwise do as tobasco did and do the 40 degrees. IT is a very stout bolt and can and will break the SST pin or an engine stand if you try and force it to the full 90degrees without the above mentioned procedure.
For those doing the keyway I just torque mine down to 155ft/lbs and call it a day. Had a nice talk with a ARP tech about this and with a keyed crankshaft there is no need for all that torque anymore. I haven't had a problem with it yet and have retorqued it atleast 6 times sense the initial use.
Disclaimer: anything done outside of the mazda OEM service manual with non standard factory equipment is done at your own risk.
pinkcheese is offline   Reply With Quote
The Following 2 Users Say Thank You to pinkcheese For This Useful Post:
 Old 11-23-2011, 03:56 AM   #47
Tokay444's Avatar
Groans: 793
Hahaha.
That goes for YOU big turbo DJ.
Demodded.
The Seals
 Old 11-23-2011, 09:41 AM   #48
Captain
Groans: 79
Hahaha.
Lol, what?
Maybe i missed something.
I failed at measuring the I.D. of the sprocket. Ended up working late, and then had to run home to fab a dump tube for a 20g mr2. I won't have time to swing by my mom's house (where the sprockets are) tonight either, but i have a spare motor in my garage at my house.... so i'll pull the crank pulley and measure the crank shaft.
www.permtuning.com
Tokay444 (11-23-2011)
 Old 11-23-2011, 10:17 AM   #49
Tokay444's Avatar
Groans: 793
You missed the disclaimer right before my post apparently.
Doing things outside the manual(like big turbo) are done at own risk
Demodded.
The Seals
 Old 11-23-2011, 10:20 AM   #50
Captain
Groans: 79
Lol, i kinda thought that was it.
www.permtuning.com
 Old 11-23-2011, 02:00 PM   #51
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Im about to goto the storage unit to ship some parts, i have a pully and crank that I can measure. You guys just need the id and od?
2006 Mazdaspeed 6
 Old 11-23-2011, 02:13 PM   #52
Captain
Groans: 79
Yup, I.D. of the crank sprockets. Might not hurt to get a tooth count too i guess... but i sincerely doubt that would be any different.
Just take a pic with your phone and the micrometers
www.permtuning.com
 Old 11-23-2011, 02:17 PM   #53
Speeeeeed
06Speed6's Avatar
You got it.
2006 Mazdaspeed 6
 Old 11-23-2011, 05:22 PM   #54
Speeeeeed
06Speed6's Avatar
Here ya go
2006 Mazdaspeed 6
The Following 4 Users Say Thank You to 06Speed6 For This Useful Post:
Alpha (04-28-2012), djuosnteisn (11-23-2011), Tokay444 (11-23-2011), Tomas (11-23-2011)
 Old 11-23-2011, 05:44 PM   #55
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Any reason why I couldn't use a gen2 short block on a gen1? This thing with the key on the crank pulley is the only difference I've seen so far.
A new gen2 short block for $2160 is really not so bad. And it's $300 LESS than a gen1. shuuu. wtf.
 Old 11-23-2011, 05:55 PM   #56
Tabasco69's Avatar
MS3 DISI engine regardless of gen 1 or 2 are the exact same I' am like almost 100% sure of this, now the mzr engines- gen2 are what was changed radically, keyed forge crankshaft, rotating assembly is still cheap ass cast crap, the stroke was increased to go from 2.3 to 2.5 displacement, so different crank throw (longer) and longer rods.
I do not think you disi guys would have anything to gain from taking ms3 gen2 engine parts cause they are the same, the chasis platform represent the difference between gen 1 and 2 for your cars
Side note I think it is fucking horseshit that import mags do buyers guides and rate the ms3 head and shoulder above all else in the fwd catergory ie dsport in particular yet they turn their noses up at them, sick and fucking tired of reading about feature honda eg and dg's.
djuosnteisn (11-23-2011), rfinkle2 (11-29-2011), Tokay444 (11-24-2011)
 Old 11-23-2011, 07:16 PM   #57
Captain
Groans: 79
MSF takes way too long to show attached pics when i click em... i just measured the diameter on the block in my garage, with ghetto ass measuring tape... and it was right at one inch.
Is that what your dial shows marcus?
Hahaha, yeah, i thought that article was funny two. Huge spread on the ms3.
www.permtuning.com
 Old 11-23-2011, 09:02 PM   #58
LiEast's Avatar
Posts: 582   (View Stats)
LiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the world
wish i read this thread before i blew up my valves but awesome disscussion
awesome knowledge to add to the bank
2008 RED MS3 GT>>>T3 GT35R .82 A/R>>>Tial 44 EWG dumping>>>SteedSpeed T3 Mani>>>Built Motor
PERM!
LiEast is offline   Reply With Quote
The Following User Says Thank You to LiEast For This Useful Post:
djuosnteisn (11-24-2011)
 Old 11-23-2011, 11:24 PM   #59
Speeeeeed
06Speed6's Avatar
ID is 1.044"
OD is 1.046"
2006 Mazdaspeed 6
 Old 11-24-2011, 03:54 AM   #60
Tokay444's Avatar
Groans: 793
2 thou clearance?
Seems like a lot.
Demodded.
The Seals
 Old 11-24-2011, 08:16 AM   #61
Speeeeeed
06Speed6's Avatar
Its about what I expected, after torquing that bolt down I dont think it makes a difference.
2006 Mazdaspeed 6
 Old 11-28-2011, 02:37 PM   #62
11cruzito11's Avatar
Posts: 824   (View Stats)
11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world
Groaned at 5 Times in 2 Posts
Do you have a part # for the ARP replacement bolt for the speed3?
Cobb AP, 504whp 492wtq
11cruzito11 is offline   Reply With Quote
The Following User Says Thank You to 11cruzito11 For This Useful Post:
djuosnteisn (11-28-2011)
 Old 11-28-2011, 10:00 PM   #63
Tabasco69's Avatar
I would call ARP directly and ask them .....but I 'm pretty sure it would be the same as the mzr...meh still call to verify part no.251-2501
http://www.summitracing.com/parts/AR...2501/?rtype=10
11cruzito11 (11-29-2011), djuosnteisn (11-28-2011), Tokay444 (11-29-2011)
 Old 11-28-2011, 10:09 PM   #64
Captain
Groans: 79
Originally Posted by pinkcheese View Post
Yes when you get a chance please take a ID measurement of that sprocket for me.
@pinkcheese
Can you confirm Marcus's measurements are either the same or different than the duratec?
www.permtuning.com
 Old 11-29-2011, 06:00 AM   #65
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
Ok maybe we could make a New post about this idea ..
Some guys on here have had the timming slip or bolt come loose.
I would like to know what you guys did wrong .
As in ..
Was the tourque enought
Did u do the 1/4 turn
New bolt
new washers
I would like to know wear you went wrong .
Maybe a stickey for referance on not what to do .
Just a idea ..
I think It may be time for my VVT/ chain/ tentioner to be done and I an scared as hell !
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
The Following User Says Thank You to jracer For This Useful Post:
Alpha (04-28-2012)
 Old 11-29-2011, 06:42 AM   #66
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
It is quite interesting that I missed this thread, and this past weekend came to the conclusion while helping tune @oldognewtriks car. The conclusion (without seeing this thread) was that the crank pulley slipped and lost timing with the crank
The Following User Says Thank You to socks For This Useful Post:
jracer (11-29-2011)
 Old 11-29-2011, 07:50 AM   #67
oldognewtriks's Avatar
Posts: 133   (View Stats)
oldognewtriks has much to be proud ofoldognewtriks has much to be proud ofoldognewtriks has much to be proud ofoldognewtriks has much to be proud ofoldognewtriks has much to be proud ofoldognewtriks has much to be proud ofoldognewtriks has much to be proud ofoldognewtriks has much to be proud ofoldognewtriks has much to be proud ofoldognewtriks has much to be proud of
We will know Saturday socks. I am buying a new bolt and possibly installing the stck crank pulley instead of the aftermarket one.
oldognewtriks is offline   Reply With Quote
 Old 11-29-2011, 08:29 AM   #68
Captain
Groans: 79
As in ..
New bolt
new washers
Just a idea ..
Most issues arise from re-using the stock crank bolt, and / or not replacing the friction washers that go between the crank sprockets.... as well as not torquing properly.
As long as you do it right, you shouldn't have issues imo.
www.permtuning.com
The Following 4 Users Say Thank You to djuosnteisn For This Useful Post:
Alpha (04-28-2012), jracer (11-29-2011), laxplayermjd (11-29-2011), rfinkle2 (11-29-2011)
 Old 11-29-2011, 08:42 AM   #69
jracer's Avatar
Groans: 89
thanks DJ..
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
djuosnteisn (11-29-2011)
 Old 11-29-2011, 11:48 AM   #70
pinkcheese's Avatar
Sorry been a little MIA lately
Duratec measurements off a spare 2.3L sprocket I have/
I.D. 1.047"
O.D. 1.484"
taken with a digital micrometer.
djuosnteisn (11-29-2011), jracer (11-29-2011)
 Old 11-29-2011, 12:04 PM   #71
Captain
Groans: 79
Originally Posted by 06Speed6 View Post
ID is 1.044"
OD is 1.046"
I.D. 1.047"
O.D. 1.484"
O.D's are off quite a bit.... how is that possible? Or was it supposed to be 1.048, pink?
www.permtuning.com
 Old 11-29-2011, 12:51 PM   #72
Speeeeeed
06Speed6's Avatar
There is no way thats right, the crank i measured off of had some surface rust on the snout so it nay be a couple thousandths off.
2006 Mazdaspeed 6
 Old 11-29-2011, 01:43 PM   #73
pinkcheese's Avatar
These are sprocket dimensions. I do not have a spare crank to measure.
 Old 11-29-2011, 01:53 PM   #74
Speeeeeed
06Speed6's Avatar
Ohhh you measured the outside part of the sprocket not the crank. Mine was 1.455 but I dont think that is a critical measurement.
2006 Mazdaspeed 6
 Old 11-29-2011, 02:07 PM   #75
Captain
Groans: 79
At this point... i guess it's safe to say the keyed products from cosworth would indeed work on the DISI MZR's.... eh?
www.permtuning.com
 Old 11-29-2011, 07:07 PM   #76
Tokay444's Avatar
Groans: 793
If they have the same amount of teeth, pitch and pressure angle.
Demodded.
The Seals
 Old 11-29-2011, 07:50 PM   #77
pinkcheese's Avatar
The Cosworth is a 19 teeth sprocket and a 38 teeth cam gear with a 8 MM chain.
The Following User Says Thank You to pinkcheese For This Useful Post:
djuosnteisn (11-30-2011)
 Old 11-30-2011, 08:27 AM   #78
Captain
Groans: 79
I have to run to my mum's house in a bit, and that's where i have a tore down motor. I'll bring my calipers with me, and snap a few pics.
www.permtuning.com
 Old 11-30-2011, 12:18 PM   #79
Captain
Groans: 79
Looks like we have a 40 tooth cam gear:
And 0.162" (4.12mm) cam gear width:
0.19" (4.83mm) inner chain gap:
0.451" (11.46mm) outter chain (including a pin, i was rushed and just grabbed some quick measurements):
And for giggles, here's my crank sprocket I.D., 1.048" (26.63mm), and it's a 20 tooth sprocket (i think this could possibly be the oil chain sprocket, so i'll double check next time i'm over there... again i was rushed):
And since the DISI crank sprockets are 2 piece, where the duratec are 1 piece, here's our spacing, 0.601" (15.26mm):
Overall combined crank sprockets depth, 0.9315" (23.66mm), eye balled, but accurate enough IMO (also, no friction washers between sprockets for the hair splitters out there):
www.permtuning.com
socks (11-30-2011)
 Old 11-30-2011, 07:21 PM   #80
Tabasco69's Avatar
the basic dimension are close but look at the teeth, looks to be a different profile, pitch and depth.
cos=cosworth part fyi
the disi cam chain teeth, assuming that I'am talking about the right ones seems to be of a lesser width, 4.83@ this one is cos: 4.93@
oil pump tooth width is cos: 2.74
overall sprocket depth is cos: .933mm versus .9315/but you didn't include the washer/spacer, so I would assume the 2 to be of the same depth
inside diameter cos: 1.043 disi: 1.048
djuosnteisn (12-01-2011)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/crank-bolt-talk-96620/
Turbo duratec 73 Pinto - Page 2 - Turbo Ranger Forums This thread Refback 01-15-2014 06:02 AM
New CS LW Crank Pulley Review >>> Alpha MazdaSpeed 6 - Engine, Transmission & Driveline 58 02-07-2013 04:13 PM
MS3 LW Crank Pulley Alpha CorkSport 3 04-22-2011 12:07 PM
Corksport Crank pulley? Mazdanspeed3 MazdaSpeed 3 - Engine, Transmission & Driveline 12 02-23-2011 11:14 PM
Mazda3 Crank vs Speed3 Crank relenger MazdaSpeed 3 - Engine, Transmission & Driveline 36 12-19-2010 08:22 AM
Page generated in 0.57486 seconds with 31 queries
