Like Tree8Likes
 Old 08-24-2018, 09:09 AM   #81
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
Just a note...I replaced my original axles with two new DTA axles from ebay and...they are clicking like crazy. Worse than the 10-year old axles that they replaced. I'm pretty pissed. I have less than 700 miles on them probably. I messaged the seller on ebay, hopefully they offer some compensation or something.
'08 CWP MS3 w/ T3 3071r
 Old 03-07-2019, 02:20 PM   #82
5280speed3's Avatar
Posts: 1   (View Stats)
5280speed3 is an unknown quantity at this point
Default Front end fix up
Hi everybody. Got me a 2012 ms3 82,000 miles on her and just wondering if anybody has any advice for what kind of cv axle and upper and lower control arm to get to
Just put more force on the ground any ideas would be
Greatly appreciated.
5280speed3 is offline   Reply With Quote
 Old 03-07-2019, 02:56 PM   #83
MSMS3's Avatar
Posts: 2,746   (View Stats)
Groans: 154
Do not do it if nothing is broken or making noise. The OEM CV joints are quite strong and most aftermarket ones wear out fast. If you must do it, the only safe bet I know is to go OEM. BTW, they are NOT the same as for the regular Mazda 3.
5280speed3 likes this.
 Old 03-07-2019, 05:25 PM   #84
SeeMeGovan's Avatar
Posts: 945   (View Stats)
SeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the world
This. OEM aren't cheap but I was able to get my local stealership to price match an online price, which allowed me to get the core charge back without paying for shipping.
Sent from my SM-N910T using Tapatalk
NATOR-WA 'GOVAN'
'07 Sunlight Silver Mica MS3 GT
JBR SRI + TIP + 88a RMM + SSP + SSB + Giant red knob + Reverse lock-out guide
Michelin Pilot Sport A/S 3 215/45 R18 | Damond OCC | ebay Catless TP
Defi Red Racer 52mm boost gauge | Torque Pro Android App Dash Install
ebay All white LED bulbs + Custom LED strip hatch lights | 15% Tint + 5% Visor
Pending installs: JBR EGR Delete + TB TIG | Stealthbox w/ Kicker & amp | Ford magical tranny jizz
SeeMeGovan is offline   Reply With Quote
 Old 03-08-2019, 03:44 PM   #85
MSMS3's Avatar
Groans: 154
One additional thought: If you are getting a clicking or similar repetitive noise at slow speed tight turns, listen closely to where it is coming from. If it is definitely from the left or right side it may be a CV joint.
But . . . there is another source and the fix is easy. If the sound is coming from under the center of the car halfway between the front wheels, it may be the limited slip differential in the transaxle.
If so the fix is usually easy. First check to see if the diff fluid is full. Next, know that our type of limited slip needs a friction modifier added to the diff fluid. Over time, it tends to lose its ability to do its job. It just eventually wears out. You need to add new friction modifier.
A four ounce bottle of Red Line friction modifier is all that is needed. I think it is less than $10 and worth every penny.
If your diff is full, you may need to drain out a bit to make room, or this might be a good time to drain and refill. If so, put the friction modifier in first, so you can then top off with the diff fluid.
And it is a 15 minute job, 30 max ,if you need to completely drain and refill with diff fluid.
So, listen carefully to where the sound is coming from before you automatically assume you need an expensive OEM CV joint plus the removal and installation time or expense.
Db09ms3 (03-08-2019)
 Old 12-02-2019, 06:07 PM   #86
Lex2007's Avatar
Posts: 569   (View Stats)
I'm getting an oscillating / subtle clanking noise at highway speeds but only when on the gas. Its not totally speed dependent. It only happens at 45-55 + when on throttle and oscillating noise increases with speed but only to a point.
Both my front wheel bearings were changed at 100k. Im at 143k now. One of my axles is DTA. The other is the original. Im thinking it might be the axle carrier bearing.
Either he carrier bearing or a bearing in the trans or perhaps one of the CV joints. Impossible to isolate at speed. One of my CV joints has been making a whirring noise at low speed sharp turns for like 70k miles but all boots are intact.
Anyone had an axle carrier bearing fail? IF so what were your symptoms?
Abilor Guide Help for VT SpeedRebirth MazdaSpeed 3/6 - ECU Computer Tuning 10 04-08-2013 02:50 PM
ATR Idle guide tokoam MazdaSpeed 3/6 - ECU Computer Tuning 4 01-22-2013 07:51 AM
My maintenance guide cham87 Gen2 MS3 General Discussion 8 10-31-2012 07:30 PM
American Axle opens truck axle plant in Lancaster, Pa. Haltech Automotive News 0 03-25-2010 10:00 PM
Useful Conversion Guide Crossbow Mazdaspeed3/6 General Discussion 0 04-13-2009 06:48 AM
Page generated in 0.27730 seconds with 25 queries
