  • 1 Post By gt5
 Old 03-27-2010, 06:00 AM   #1
gt5
gt5's Avatar
Posts: 273   (View Stats)
gt5 is the leader of the worldgt5 is the leader of the worldgt5 is the leader of the worldgt5 is the leader of the worldgt5 is the leader of the worldgt5 is the leader of the worldgt5 is the leader of the worldgt5 is the leader of the worldgt5 is the leader of the worldgt5 is the leader of the worldgt5 is the leader of the world
Default Cylinder 2 misfire Help!!!
Hey guys I got a check engine light and the code is for cylinder 2 misfire and low fuel pressure. I erased the code and it has not come back but i was wondering if there is a way to fix this by changing the spark plugs on cylinder 1 and 2. If anyone has any ideas please let me know.
gt5 is offline   Reply With Quote
 Old 03-27-2010, 06:12 AM   #2
SSinstaller's Avatar
Posts: 3,927   (View Stats)
Groans: 55
Swap the coils on cylinders 1 and 2.. If your misfire moves the coil is bad, if it doesn't replace your injectors(all 4).
Not much you can do about the FP MIL, do you have a log of your actuall pressure??
Soon to be installed:
PaPaSpeed (03-27-2010)
 Old 03-27-2010, 07:38 AM   #3
gt5
gt5's Avatar
which is cylinder is 1 and 2 i know its a dumb question but i want to make sure i change the right cylinder
Zoomspeed likes this.
 Old 03-27-2010, 07:42 AM   #4
Groans: 55
see attached:
At least your asking the right dumb questions...LOL
I rather see 100 posts like yours than one more "how much HP will I make?", but there will be ten more of those by the end of the day..
The Following 3 Users Say Thank You to SSinstaller For This Useful Post:
gt5 (03-27-2010), labikesrcool (03-29-2017), Zoomer_Esiason (06-14-2017)
 Old 03-27-2010, 07:47 AM   #5
FearUndersteer's Avatar
Posts: 189   (View Stats)
FearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the world
I also know of another member offline who asked me to check a CEL. He was getting random misfire and misfire on cylinder 4.
He claims the car has been driving fine and the code shows up after shutting down and restarting. I have cleared the code and it has not returned yet but he might have a bad coil as well.
2009 MazdaSpeed3 | True Red
35% Tint
CP-E Engine Mount - CP-E XCel Intake - COBB AP - CP-E TMIC
FearUndersteer is offline   Reply With Quote
 Old 03-27-2010, 08:06 AM   #6
darth vader's Avatar
Posts: 665   (View Stats)
Swapping coils and checking plugs is a good idea but, the low FP needs looking into. I seriously doubt you need to replace the injectors. More likely it's early signs of the CDFP going bye-bye.
That said, a code that disappears and doesn't recur is possible. The ECU has chucked a few CELs on this car without there actually being any issue. Car ran perfectly and, dump the code and no return. It's the peril of sophisticated engine management that there are alot more failure modes possible in just the managemnt.
The Following User Says Thank You to darth vader For This Useful Post:
gt5 (03-27-2010)
 Old 03-27-2010, 08:56 AM   #7
speed23's Avatar
Posts: 1,477   (View Stats)
I got this check engine light last year. Cleared it and havent had it come back.
 Old 03-27-2010, 02:55 PM   #8
gt5
gt5's Avatar
The car only did this when it was cold first starting it and it turned on and turn right off about 5 times and after it stayed on thats when it turn on the check engine light. I had the guy at the auto parts store erase the codes after i found out what they were but the code has not come back. I checked the spark plugs they looked some what black but ok and i switch coil number 2 with 4 to see if i get the check engine light again tommor to see what happens. But if you guys have any other ideas please let me know.
misfire rodrigo MazdaSpeed 3/6 - Troubleshoot/Diagnostics 23 10-28-2011 09:37 PM
If you have had misfire issues...here was my solution kgb MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 11-30-2009 04:22 PM
P0300 misfire CEL Mazdaspeed E MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 07-29-2009 04:20 PM
Anyone experiences popping/misfire when hitting 22 psi? Silo MazdaSpeed 3/6 - Turbo Induction 10 12-03-2008 11:23 AM
random cylinder misfire - p0300 p300 phillyb MazdaSpeed 3 - Engine, Transmission & Driveline 17 09-26-2008 02:50 PM
Page generated in 0.29052 seconds with 25 queries
