-   -   Dammit, broke a valve cover bolt (http://www.mazdaspeedforums.org/forum/f10/dammit-broke-valve-cover-bolt-96922/)
theurgy 11-12-2011 07:26 PM
Hey guys,
So I installed a polished valve cover today, and with everything, I followed as much of the Service Manual as I could and got everything down to the to point where I was torquing down the valve cover bolts.
As recommended I set my Inch Pound torque wrench to 80 In/Lbs (8.0-10.5 N-m).
Well I got down to the last one (in the order specified by the manual) and snap!
The bolt head comes off.
The bolt in question is on the driver's side corner further from the driver (if that makes sense).
Anyhow, I'm wondering if this is something I can leave like this for a little while as I get my hands on an extractor and replacement bolt.
Let me know what you guys think.
pinkcheese 11-12-2011 09:10 PM
Yes you can get away with having one busted bolt and not have to many issues. Nice thing about the valve cover on these cars is there are plenty of bolts. Just keep an eye on it and make sure you don't see oil seeping out the corner.
801MS3 11-12-2011 09:39 PM
You sure you didn't set it to 80 ft lbs?
Always have to be careful when tightening anything into aluminum.
Basic back out kit should fix it up.
theurgy 11-12-2011 09:45 PM
LOL I specially bought an Inch Lbs torque wrench for this specific job.
theurgy 11-12-2011 10:40 PM
Anyone know that the Mazda part number is for that bolt.
I'll be borrowing an extractor from a friend soon, I'd like to have a bolt I can replace it with.
Hectik1 11-12-2011 10:53 PM
That sucks!
Torqued mine down to good enough. Didn't even care about torque.:tongue:
MZR165 11-12-2011 10:57 PM
Contact your local Mazda dealer for the bolt and have one ordered for you.
Shouldn't cost more than a couple of bucks
theurgy 11-12-2011 11:03 PM
Doesn't anyone have a list of the parts and such I would use?
TWOptSL0W 11-13-2011 09:39 PM
You need to drill a small hole in the bolt and the. Use the extractor in it. Drill bit will depend on size of extractor. Make sure you don't get one that is too big. It will say the bit size on the extractor packaging.
As for the bolt, just ask local stealership, they'll have that for you
theurgy 12-22-2011 07:27 AM
Just a heads up, the part number for the valve cover bolt is:
LFBL-10-237
bcmurphy87 11-16-2012 12:31 PM
wow that 8 bucks each, and yes i just revived this dinosaur because of part number
breakfstincluded 11-16-2012 04:55 PM
+1 on that 8 bucks each, I'll just re-use the stock bolts lol
theurgy 11-16-2012 08:08 PM
LOL Yeah I was annoyed at the price, but when you end up breaking one, I guess you'll have to bend over and take it from the dealership.
And considering the bolts have that proprietary gasket and washer built in you can't just use any old bolt :-(
Either way, I wonder if you could find out the manufacturer of that bolt and not pay $8 (I paid $12 CDN) a piece.
That way I could replace all of my rusty bolts with new ones.
bcmurphy87 11-16-2012 08:11 PM
Yea I would like to replace all mine but it seems excessive
06Speed6 11-16-2012 09:30 PM
You can probably send the old ones to my chrome plater and get them plated for cheaper lol.
GOAT 11-13-2014 06:25 PM
When replacing my engine i noticed that the newly replaced hpfp gasket started leaking. Squirting oil everywhere. I think i may possibly have an additional leak from two of these bolts as well. However strangely the new engine gasket set did not come with a new set of grommets.
Anyone had issues of the bolt o-ring leaking??? $12 in my area per bolt.
Page generated in 0.17137 seconds with 11 queries
