![]() | | #1 | ![]() |
| Alittle Faster ![]() ![]() Join Date: May 2008 Location: Cape Coral, FL
Rep Power: 6078 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,006
(Thread Starter) | Not Ranked : 0 score First off what a PITA on both mounts! Both are slightly off from top mounting to bottom.Make sure you support your tranny so it doesn't move. Mine didn't move that much probably cause of the other 3 mounts I already have installed lol. PTP on left, Medieval on right. PTP has thicker plates, Medieval has better welds. PTP on bottom, Medieval on top. Medieval comes with a short main bolt, PTP comes with a longer main bolt w/ washers and a shorter bolt & washer for the tranny bolt. PTP on right, Medieval on left. PTP comes with a Passenger side mount insert. After you get the battery, ecu, battery tray out of the way. Move one shifter cable (closest to the driver's fender) by using needle nose, squeeze and pull up. Stock stuff removed, you will reuse the intake/harness/battery platform plate. (The bottom left thingy). On the Medieval you will need to use washers or spacer, used 5 washer to take up space of the stock cast piece. The remaining space will be filled by the bracket plate. On both the Medieval and PTP you will need to pry the tranny back and forth and jack up and down the tranny to line everything up. The easiest way is to have everything loose and bolted before you tighten down, but that makes it harder to tighten the bottom bolt and nuts. So it's up to you. Here is the PTP bolt supplied by PTP vs stock bolt, it is shorter to take up space. PTP almost installed. Medieval almost installed. I also had to elongate the battery tray mounting holes to keep it off my intlet tube. Last edited by bioevolve; 01-06-2009 at 06:59 PM. |
| The Following 19 Users Say Thank You to bioevolve For This Useful Post: | 802MS3 (01-03-2009), aaronc7 (01-03-2009), badams118 (01-08-2009), Betelgeuse (01-16-2009), booya620 (01-06-2009), Breakdown81 (01-07-2009), Darksun280 (01-04-2009), doubleflusher (03-13-2009), Ferdball (01-03-2009), Fobio (01-04-2009), gsrtype1 (01-05-2009), madvillain (01-15-2009), mouse0330 (01-04-2009), MS3 Ventura (01-04-2009), ms3=evokilla (01-27-2009), RayRayBauder (02-12-2009), skeeter149 (01-03-2009), Smokehouse (01-31-2009), Zeya (01-04-2009) |
| Banned ![]() Join Date: Dec 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 131
| Not Ranked : 0 score question: the stock mount has a bend in the top plate, and the battery tray mount thinger has a step down in it as well. it looks as tho these 2 manufacturers did not do a step down. does that mean your battery tray is now not level? good write up, thank you. |
![]() Join Date: Aug 2008 Location: Cerritos, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 222
Groaned at 9 Times in 5 Posts
| Not Ranked : 0 score holy crap! great pictures...which mount did you end up using? ptp or dsms? do you have driving impressions of both? which is easier to install and better quality overall? |
![]() | | #4 | ![]() |
![]() Join Date: Jun 2008 Location: lancaster, ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,297
Groans: 91
| Not Ranked : 0 score hmmm looks good... so what is the final verdict on the dark star? lookin at em side by side the dsm looks damn better then i thought. like 100 times better. i might have to sway for it. and hell those welds on the dsm are top notch. but having them which seems like it will get the job done? that is all i care about at the end of the day not putting this thing on the floor.
__________________ "Go find your own enterprise, and get the fuck off my bridge!" 2008 Speed 3 GT- Cobb SRI, Cobb TIP, AQ Motorsports DP (Turboxs Adapter Plate), TurboXS FMIC, GReddy CBE, GReddy BPV, 3P Flange, GReddy TT, GReddy Boost Gauge, Vent Pod, GReddy Shift Knob, SU Shifter Bushings, AWR RMM, Cobb RSB, Cobb AP, Cobb Shifter Weight, Autotech FP Internals, Corksport Exhaust Hangers. "parked hard" 1996 200sx SE-R- Injen CAI, GReddy SP CBE, Tein Basic Coilovers, Progress FSB, Clutch Masters Flywheel, Progress RSB, Cusco FSTB, Progress LCAB, Prothane MM, JWT POP Program, JWT S4 Cams, Mishimoto Radiator, GoodRidge SS Brake Lines, Powerslot Rotors, Nismo CF Shift Knob. "back in action" |
![]() | | #5 | ![]() |
![]() Join Date: Mar 2008 Location: Jacksonville, NC
Rep Power: 2469 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 810
Groans: 60
| Not Ranked : 0 score I like the bushing orientation on the PTP better, it seems like the mount could pivot on the bolt passing through the bushing in the DSMS..
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks |
![]() | | #6 | ![]() |
PTP is $99 and DSMS is $75. Medieval is about 30% easier to install. I will let you decide.
The PTP positioning of the bushing with engine movement front to back, stress is less on the bushing. Movement with the bolt. The Medieval postioning of the bushing with engine movement front to back, stress is on the bushing more. Movement against the bolt. I have to say that PTP's top plate is stronger than the DSMS's. PTP is a solid plate and DSMS is thinner and has the hole in it which would make it weaker. I would say: (just a guess) PTP = Stress of 500-up whp Medieval = Stress of 350-450whp Don't know the warranties on these, hope each one will chime in on that. Last edited by bioevolve; 01-06-2009 at 07:00 PM. | ||||
| The Following 5 Users Say Thank You to bioevolve For This Useful Post: | 802MS3 (01-03-2009), FCmaniac (01-05-2009), Fobio (01-04-2009), MS3 Ventura (01-04-2009), skeeter149 (01-04-2009) |
![]() | | #7 | ![]() |
| rabble rabble ![]() Join Date: Aug 2008 Location: Delawhere
Rep Power: 3168 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,400
Groans: 221
| Not Ranked : 0 score nice write up
__________________ '08 CWP MS3 w/ T3 3071r |
![]() | | #8 | ![]() |
| Banned ![]() Join Date: Jun 2008 Location: misery
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,510
Groans: 1,940
| Not Ranked : 0 score how does one tighten the bolt for the ptp mount? |
| The Following User Says NO Thank You to phillyb For This Un-useful Post: |
![]() | | #9 | ![]() |
(Thread Starter) | Not Ranked : 0 score 3/8" Rachet with 6" extension & short 19mm socket on the bolt head (to hold in place) and 1/2" Rachet with 6" extension with swivel/universal joint & regular/deep well 19mm socket on the nut. Would be easier with two people lol. |
| The Following User Says Thank You to bioevolve For This Useful Post: | phillyb (01-03-2009) |
![]() | | #10 | ![]() |
(Thread Starter) | Not Ranked : 0 score Oh forgot, used blue Loc-tite on the nuts and bolts. 50 more miles on it: The tranny noise is now amplified. Clutch friction and whine are heard more. I can hear in the cabin with windows up, louder than before. BUT...when you go, you go. No hesitation from pedal to ground. No delay. The car feels more solid now, meaning power to the ground. Have not tried to make it wheels hop yet. With four mounts I should have very little wheel hop, but still want traction bars. |
![]() | | #11 | ![]() |
![]() Join Date: Mar 2008 Location: Navarre, FL
Rep Power: 4957 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,585
Groans: 370
| Not Ranked : 0 score great write up, will definitely use this later when I get mine |
![]() | | #12 | ![]() |
![]() Join Date: Apr 2008 Location: San Diego, CA
Rep Power: 493 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 666
| Not Ranked : 0 score Yeah, I feel that too. I think it might even be a little easier to shift, now that the tranny isn't flopping around. |
![]() | | #13 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score So how bad are the vibes? Very noticeable? |
![]() | | #14 | ![]() |
![]() Join Date: Jul 2008 Location: PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 30
Groaned at 16 Times in 8 Posts
| Not Ranked : 0 score an upgraded rear mount improved shifting characteristic, i'm sure these would be an awesome combination. +1 on traction bars. they are great for fwd. |
![]() | | #15 | ![]() |
| Not Ranked : 0 score |
![]() | | #16 | ![]() |
Groans: 91
| Not Ranked : 0 score thanks bioevolve i am going darkstarmotorsports on this one. i am gonna be realistic and tell you my car will never see north of 310whp if even that. that mount looks plenty beefy to me, the welds are sex, and i like the price for sure . well thank you for the awesome pics and info dsm is what i choose so as soon as i get 75 buck i know what i am ordering lol.
| The Following User Says Thank You to skeeter149 For This Useful Post: | darkstarmotorsports (01-05-2009) |
![]() | | #17 | ![]() |
| Not Ranked : 0 score so you say the DSMS is 30% easier to install because of the motor mount being accessible from top...whereas the PTP, it's below the plate and you have to go by "feel" not "sight"? there are a few members on mazda247 that has problems with the DSMS mount...saying it doesn't line up right...here is the link Mazda Forums - View Single Post - GB; Mazdaspeed 3 Transmission Mount-$80 SHIPPED |
| The Following User Says Thank You to steven88 For This Useful Post: | bioevolve (01-05-2009) |
![]() | | #18 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: On this planet (Washington)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
Lifttime on the mount, 2 years on the bushings. That would be for the warranty. Thanks for the great write up, let me know what you think about our mount after you get it installed, keep me informed on the vibe changes as well. Thanks again. | |
| The Following User Says Thank You to ptperformance For This Useful Post: | bioevolve (01-04-2009) |
![]() | | #19 | ![]() |
![]() | | #20 | ![]() |
| Not Ranked : 0 score One thing that I wanted to add is we have the threw welds also. If you see the little pucks on both the back sides of the mount base plates. Those welds are there to keep things in check and make the base plate as we whole work with the mount. I will work on making the welds look a little better but I am always shooting for function over looks when it comes to things like this. Prettier welds should not be a problem with future mounts. |
| The Following 2 Users Say Thank You to ptperformance For This Useful Post: | Darksun280 (01-04-2009), phillyb (01-04-2009) |
![]() | | #21 | ![]() |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
| Not Ranked : 0 score Mental Addiction makes awesome parts when they actually deliver them to people... |
![]() | | #22 | ![]() |
Update: Just checked mine and it looks the same as the one on M247. Bottom of the bushing is sticking out cause of either the top plate and/or bottom bracket is not lined up correctly. Just got an email from DSMS: Medieval is sending me another top plate and/or whole mount kit to fix the problem. Seems like only the first batch (they are sending those people new top plates and/or whole kits) is not lining up and they already have the fix for the second batch. It didn't look wrong when the tranny was jacked up for lining up, but did after driving and settling in. Last edited by bioevolve; 01-04-2009 at 10:14 AM. | |
![]() | | #23 | ![]() |
| Driver ![]() Join Date: May 2008 Location: Toronto
Rep Power: 1986 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,158
Groans: 44
| Not Ranked : 0 score thanks for the great info and writeup...
__________________ ![]() DONE . Cobb AP 22-psi Self-Tuned . ATP GT3071 . CP-e 3.25" MAF+4" inlet . Denso ITV-24 . CP-e HPFP . CP-e FMIC . Turbosmart Ultimate BPV . 50/50 Meth w/ M5 nozzle . PTP IM Spacer+EGR delete . GrimmSpeed EBCS 3-port . SteedSpeed Mani . CP-e TBE . Greddy OCC w/ 2nd PCV valve . F2 BSD + oil-pan baffle . Hawk HP+ pads . Goodridge SS brake lines w/ Ford Super Dot 4 . Cobb Springs+FSB . Tri-Point RSB+Endlinks . Koni Yellows . KMAC Camber Plates . 60mm Boost Gauge . TWM Complete Shifter w/ JBR SSP+weight . CP-e RMM+PTP trans+kicker mount . Sparco Harness Bar w/ MOMO 4-pt harness . Rays/Volks 57F 18x8.5" +45mm 235/40/18 Hankook V12 . BBS RK 17x8" +45mm 235/45/17 RA1/R6 . OEM Snowflakes w/ 215/50/17 Nitto NT-SN1 . 3rd in CSCS 2009 Time Attack Championship - Super Street FWD . 360whp/390wtrq . SOON . 3-bar MAP sensor . MSpeed Tuning & Diagnostics - The Street Lab is ALWAYS OPEN FOR BUSINESS "It is amazing how many drivers, even at the Formula One Level, think that the brakes are for slowing the car down." -- Mario Andretti -- |
![]() | | #24 | ![]() |
![]() Join Date: Mar 2008 Location: Miami, FL
Groaned at 4 Times in 2 Posts
| Not Ranked : 0 score I got the passenger side mount insert with my PT-P mount but don't know much about it. I have the darkstar passenger mount so probably won't need it? Can someone elaborate on this?
__________________ Cobb SRI // Cobb Shifter Weight // TWM Bushings // TWM STS // TWM type R weighted shift knob // Medieval Rear Mount // Darkstar Passenger Mount |
![]() | | #25 | ![]() |
![]() | | #26 | ![]() |
Groans: 60
| Not Ranked : 0 score It's interesting the you liked the pretty mount, which happens to be defective....better than the PTP mount, which isn't.
| The Following 2 Users Say Thank You to SSinstaller For This Useful Post: | bioevolve (01-05-2009), ptperformance (01-04-2009) |
![]() | | #27 | ![]() |
| Not Ranked : 0 score You should be able to use it. See if it fits between the forward leading edge of the new mount, thin part up top and thcker part between the mount and the mount bracket. Hope this helps. |
| The Following User Says Thank You to ptperformance For This Useful Post: | Betelgeuse (01-05-2009) |
![]() | | #28 | ![]() |
Groans: 91
| Not Ranked : 0 score where was it defective in that whole post?
![]() | | #29 | ![]() |
Groans: 1,940
| Not Ranked : 0 score do shed light on what you mean by defective. i have the top speed (from darkstar) pass mount. |
![]() | | #30 | ![]() |
Groans: 60
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks | |
![]() | | #31 | ![]() |
Groans: 1,940
| Not Ranked : 0 score oh, we're talking tranny side |
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score Ok, today I felt a DIFFERENT VIBRATION! Deceleration vibs. It a very noticable feeling than the normal vibration. So I decide to take Medieval mount out, see for yourself: See how the angle being off causes the the bushing to cock. Out of the vehicle untouched. Another reason for the cocking beside mis-alignment is it is a 2-piece bushing setup, it nees to be a solid one piece. Well a 2-piece needs both plate ends to fully flush on the outsides of the bushing, so mainly alignment problem. PTP Tranny mount is back in now. ![]() +1 for PTP.Last edited by bioevolve; 01-06-2009 at 07:02 PM. |
| The Following User Says Thank You to bioevolve For This Useful Post: | phillyb (01-05-2009) |
![]() | | #33 | ![]() |
| Not Ranked : 0 score That's just unreal man. Sorry about your troubles, but that shit needs to come off. I think mine lines up okay. The vibes are actually starting to go away slightly. Did you buy both mounts for the same car or do you have them installed on different cars? ![]() Mine Yours |
![]() | | #34 | ![]() |
Groans: 1,940
| Not Ranked : 0 score damn...i can't wait to get my ptp mount in there |
![]() | | #35 | ![]() |
(Thread Starter) | Not Ranked : 0 score Reason why I picked Medieval over PTP was I had other parts from both companies and at the time before this, it was DSMS +1 (pass mm) and PTP 0 (test pipe). Now it is even again. PTP +1 and DSMS +1. Anyways, I will give a driving result on the PTP tomorrow. Last edited by bioevolve; 01-06-2009 at 07:02 PM. |
![]() | | #36 | ![]() |
Bought both mounts on one car lol. | |
![]() | | #37 | ![]() |
![]() Join Date: Oct 2008 Location: Rockville, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17
| Not Ranked : 0 score great thread. keep us updated on how the ptp hold up
__________________ bent rod |
![]() | | #38 | ![]() |
| Banned ![]() Join Date: Oct 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 568
Groaned at 6 Times in 2 Posts
| Not Ranked : 0 score Okay, a I'm starting to see everyone worries about the tranny mount. first of all, it includes a LIFE TIME WARRANTY on every part of the mount. As for the busing not lining up and squeezing out the side like that. The kits are missing the hardware portion of them, which medieval did not send me. a smaller bolt so you won't have to use washers on that one tranny bolt And spacers for the base plate to even out the angle on the bushing. AGAIN, I"M SO SORRY ABOUT THIS FELLAS! This has been brought up the Medieval when the first case was presented to us. They wil be sending the hardware kits directly to everyone who has order the monts from the GB. This is a great product, I just hope you guys don't mind letting us fix our error to no cost to you. |
| The Following 5 Users Say Thank You to darkstarmotorsports For This Useful Post: | aaronc7 (02-02-2009), bioevolve (01-05-2009), Breakdown81 (01-07-2009), gsrtype1 (01-05-2009), phillyb (01-05-2009) |
![]() | | #39 | ![]() |
![]() | | #40 | ![]() |
| Not Ranked : 0 score no, under the the base plate under the battery to correct the bad angle on the bushing. You can use washers if you rather not wait. It's what a local guy did out here in San deigo. they, eveything will be fine. And he LOVES the mount! |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/darkstar-ptp-tranny-mounts-18368/ | ||||
| Medieval Transmission & Passenger Mount Review - TorontoMazda3 | This thread | Refback | 03-08-2009 11:23 AM | |
| Tranny pix | franciscoescn | MSP - Engine, Transmission & Driveline | 12 | 09-26-2012 04:24 PM |
| DarkStar Passenger Mount | bioevolve | MazdaSpeed 3 - Engine, Transmission & Driveline | 53 | 01-01-2009 08:26 PM |
| TRZ side mounts? | kopf | Mazdaspeed3/6 General Discussion | 55 | 12-18-2008 04:45 PM |
| Has anyone seen or tried these yet? - SU tranny and passenger side mounts. | Betelgeuse | MazdaSpeed 3 - Engine, Transmission & Driveline | 7 | 07-24-2008 11:17 AM |
