Darkstar & PTP Tranny Mounts
Bookmark and Share LinkBack Thread Tools Display Modes
 Old 01-05-2009, 04:06 PM   #41
Do It Right!
Ferdball's Avatar
Posts: 292   (View Stats)
Ferdball has a reputation beyond reputeFerdball has a reputation beyond reputeFerdball has a reputation beyond reputeFerdball has a reputation beyond reputeFerdball has a reputation beyond reputeFerdball has a reputation beyond reputeFerdball has a reputation beyond reputeFerdball has a reputation beyond reputeFerdball has a reputation beyond reputeFerdball has a reputation beyond reputeFerdball has a reputation beyond repute
Groaned at 6 Times in 4 Posts
Activity Longevity
4/20 19/20
Today Posts
1/7 ssssss292
Originally Posted by darkstarmotorsports View Post
no, under the the base plate under the battery to correct the bad angle on the bushing. You can use washers if you rather not wait. It's what a local guy did out here in San deigo. they, eveything will be fine.
And he LOVES the mount!
Huh?
First of all, are you talking about me? I'm in San Diego.
Is this the bottom piece, the top piece or the battery tray?
Ferdball is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!
 Old 01-05-2009, 04:18 PM   #42
Alittle Faster
bioevolve's Avatar
Posts: 3,249   (View Stats)
Activity Longevity
2/20 18/20
Today Posts
0/7 sssss3249
I think DS is talking about the top plate. Guessing spacers under the motor side and none on the fender side of the top plate.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
bioevolve is offline
 Old 01-05-2009, 05:17 PM   #43
darkstarmotorsports's Avatar
darkstarmotorsports is the leader of the worlddarkstarmotorsports is the leader of the worlddarkstarmotorsports is the leader of the worlddarkstarmotorsports is the leader of the worlddarkstarmotorsports is the leader of the worlddarkstarmotorsports is the leader of the worlddarkstarmotorsports is the leader of the worlddarkstarmotorsports is the leader of the worlddarkstarmotorsports is the leader of the worlddarkstarmotorsports is the leader of the worlddarkstarmotorsports is the leader of the world
Groaned at 6 Times in 2 Posts
Activity Longevity
0/20 15/20
Today Posts
0/7 ssssss631
Send a message via Yahoo to darkstarmotorsports
yes the top piece. This will help correct the angle.
Also some people are having probelms with the bushing being squeeze out the top once the engine load is on it, becasue there is a little bit of a gap, where the bushing mets with the other mount.
If you place 1 or 2 washers in there, this will sovle that issue too and take up the extra room. Try to use a large diameter washer.
AGAIN, I'm sorry for this everyone. I'm a huge believer in customer serivce, and if I receive this mount and had these same problems I would want a fix ASAP.
I hope this helps everyone out! I'll be near the computer for the rest of the evening, so if anyone else has any more questions or concerns, please PM or email me.
For the FASTEST Customer Service....
darkstarmotorsports is offline
The Following User Says Thank You to darkstarmotorsports For This Useful Post:
bioevolve (01-05-2009)
 Old 01-05-2009, 07:19 PM   #44
Do It Right!
Ferdball's Avatar
Activity Longevity
4/20 19/20
Today Posts
1/7 ssssss292
Ferdball is offline
The Following User Says Thank You to Ferdball For This Useful Post:
phillyREPOphail (01-06-2009)
 Old 01-06-2009, 01:07 PM   #45
Alittle Faster
bioevolve's Avatar
Activity Longevity
2/20 18/20
Today Posts
0/7 sssss3249
PTP mount feels like it has alittle less vibration or I have gotten used to both of them lol.
I still have my odd deceleration vibration, but it doesn't happen all the time. Several times I tried to make it virbrate upon deceleration and by pushing the clutch in it goes away. Possible bad clutch?!?!?! Might not be because I didn't feel this vibration until I installed these mounts. I think both mounts pull the tranny up alittle higher than the stock mount. I can't confirm that yet.
 Old 01-06-2009, 01:35 PM   #46
SSinstaller's Avatar
Posts: 2,191   (View Stats)
Activity Longevity
12/20 20/20
Today Posts
3/7 sssss2191
My AWR tranny mount also added a vibration on deceleration. It's normal..
My car has issues....
SSinstaller is online now
 Old 01-06-2009, 01:48 PM   #47
Alittle Faster
bioevolve's Avatar
Activity Longevity
2/20 18/20
Today Posts
0/7 sssss3249
It's not constant, it's two different vibrations right now. The normal vibs, then is the more strong random vibs. I can't realy explain it, you have to feel it. It didn't start until after 50 miles with the Medieval mount and is still there with the PTP mount. Axle angles have changed?!?!?!
Anyways here are some more pics of the PTP in the car, I didn't feel like taking it apart lol. Anyone know if the PTP is a 2-part bushing or a single one?
 Old 01-06-2009, 01:56 PM   #48
Activity Longevity
12/20 20/20
Today Posts
3/7 sssss2191
It's not constant, it's two different vibrations right now. The normal vibs, then is the more strong random vibs. I can't realy explain it, you have to feel it. It didn't start until after 50 miles with the DSMS mount and is still there with the PTP mount. Axle angles have changed?!?!?!
I know exactly what your talking about...
There is a normal vibration that you get at or near idle that gradually lessens as the rpms rise(there is also some significant gear whine)..
There is also a different vibration that's much stronger than the other that will only happen under deceleration and under certain conditions. I could almost make it happen at will with the AWR mount. It seems to depend on the load that's on the motor when you get off the gas..
bioevolve (01-06-2009)
 Old 01-06-2009, 02:22 PM   #49
Alittle Faster
bioevolve's Avatar
Activity Longevity
2/20 18/20
Today Posts
0/7 sssss3249
So it's basically a load and harmonics vibs dependent on certain conditions? So we are feeling an unbalanced form of vibs from a supposingly balanced setup lol? Well it's not balanced anymore lol.
But you are right on, I just couldn't explain it like you just did, Thanks!
 Old 01-06-2009, 02:28 PM   #50
phillyREPOphail's Avatar
Posts: 10,523   (View Stats)
phillyREPOphail is the leader of the worldphillyREPOphail is the leader of the worldphillyREPOphail is the leader of the worldphillyREPOphail is the leader of the worldphillyREPOphail is the leader of the worldphillyREPOphail is the leader of the worldphillyREPOphail is the leader of the worldphillyREPOphail is the leader of the worldphillyREPOphail is the leader of the worldphillyREPOphail is the leader of the worldphillyREPOphail is the leader of the world
Groans: 1,421
Groaned at 660 Times in 488 Posts
Activity Longevity
18/20 18/20
Today Posts
7/7 ssss10523
bio, did you need the washers for the ptp mount?
oem part numbers -
donations to the site -
creating an avatar -
do you own a miata? post in the miata section -
phillyREPOphail is online now
 Old 01-06-2009, 02:33 PM   #51
Alittle Faster
bioevolve's Avatar
Activity Longevity
2/20 18/20
Today Posts
0/7 sssss3249
If you are refering to the 3 extra silver washers, I thought it needed. You can try it without the extra washers and see if it bottoms out, the bronze color one is supplied by PTP. Actually they supplied 3 of them, I used the other 2 on the ends of the main bushing bolt.
The Following User Says Thank You to bioevolve For This Useful Post:
 Old 01-06-2009, 02:37 PM   #52
Groans: 1,421
Activity Longevity
18/20 18/20
Today Posts
7/7 ssss10523
is that the stock bolt you used?
oem part numbers -
 Old 01-06-2009, 02:43 PM   #53
Alittle Faster
bioevolve's Avatar
Activity Longevity
2/20 18/20
Today Posts
0/7 sssss3249
Nope, it's the one PTP supplied alittle shorter than the stock bolt.
Here is the PTP bolt supplied by PTP vs stock bolt, it is shorter to take up space.
If I'm remembering correctly, stock is 17mm and PTP is 19mm head sizes.
 Old 01-06-2009, 03:01 PM   #54
Betelgeuse's Avatar
Posts: 343   (View Stats)
Betelgeuse has a brilliant futureBetelgeuse has a brilliant futureBetelgeuse has a brilliant futureBetelgeuse has a brilliant futureBetelgeuse has a brilliant futureBetelgeuse has a brilliant futureBetelgeuse has a brilliant futureBetelgeuse has a brilliant futureBetelgeuse has a brilliant futureBetelgeuse has a brilliant futureBetelgeuse has a brilliant future
Groaned at 4 Times in 2 Posts
Activity Longevity
1/20 20/20
Today Posts
0/7 ssssss343
Bio, do you have upgraded passenger and rear mounts as well? Also, it takes some time for the vibes to settle according to ptp so you may need to drive it a while more (they said 1500 miles in the instructions).
Cobb SRI // Cobb Shifter Weight // TWM Bushings // TWM STS // TWM type R weighted shift knob // Medieval Rear Mount // Darkstar Passenger Mount
Betelgeuse is offline
 Old 01-06-2009, 03:29 PM   #55
Alittle Faster
bioevolve's Avatar
Activity Longevity
2/20 18/20
Today Posts
0/7 sssss3249
Yeah:
Top Speed Passenger
SU Rear Lower
Turbine Tech Front
I now all about that lol, just giving intial review of the vibs.
 Old 01-06-2009, 04:34 PM   #56
killa cam's Avatar
Posts: 446   (View Stats)
killa cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the world
Activity Longevity
0/20 14/20
Today Posts
0/7 ssssss446
Originally Posted by killa cam View Post
question: the stock mount has a bend in the top plate, and the battery tray mount thinger has a step down in it as well. it looks as tho these 2 manufacturers did not do a step down. does that mean your battery tray is now not level?
ahh now i see it. your battery tray is not level anymore, and that is why you had to slot the battery box holes, because it was leaning towards your intake.
killa cam is offline
 Old 01-06-2009, 04:45 PM   #57
Do It Right!
Ferdball's Avatar
Activity Longevity
4/20 19/20
Today Posts
1/7 ssssss292
Yeah:
DSMS Passenger
SU Rear Lower
Turbine Tech Front
Did you get the Top Speed, or the Medieval passenger mount? What is a Turbine Tech Front?
Ferdball is offline
 Old 01-06-2009, 05:57 PM   #58
Alittle Faster
bioevolve's Avatar
Activity Longevity
2/20 18/20
Today Posts
0/7 sssss3249
Bingo!
Top Speed Passenger Mount
http://www.mazdaspeedforums.org/foru...fmm-oc-sp.html
Turbine Tech Front Engine Mount: MAZDASPEED 3
___________________________
Come to think of it.
I wanna correct something:
Darkstar is a Vendor not the Manufacturer of this mount. This is not a negative shot at Darkstar.
I should have titled this Medieval & PTP Tranny Mount. I guess I saw Darkstar as a Manufacturer, Sorry man.
Corrected my wrong lol.
 Old 01-07-2009, 08:20 AM   #59
killa cam's Avatar
Activity Longevity
0/20 14/20
Today Posts
0/7 ssssss446
when you look at it, is it visible? can you tell the thing is angled towards the motor? that would piss me off. i hate when things do not line up and are not symmetrical...
the TRZ has that jog bend in it, correct?
 Old 01-07-2009, 09:05 AM   #60
Alittle Faster
bioevolve's Avatar
Activity Longevity
2/20 18/20
Today Posts
0/7 sssss3249
I didn't pay any attention to the way the battery stance looked, just looked at the ecu housing touching the inlet pipe and adjusted accordingly.
 Old 01-07-2009, 09:59 AM   #61
medieval's Avatar
Posts: 151   (View Stats)
medieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the world
Activity Longevity
0/20 14/20
Today Posts
0/7 ssssss151
All Medieval motor mounts come with a life time warranty. As for these issues that are being shown here, this is due to the hardware kit not being installed. When we sent DS his shipment it was a mistake on our part. The tranny mount comes with 2 x 2" washers and a bolt. The 2" washers are meant to be placed on each side of the bushing. This will eliminate the issues you see in these pictures. We here are very sorry about this and have received all the address from DS and are sending off hardware kits. If anyone has any issues or concerns, please fell free to email us at sales@medievalllc.com
medieval is offline
The Following 3 Users Say Thank You to medieval For This Useful Post:
bioevolve (01-07-2009), darkstarmotorsports (01-07-2009), FCmaniac (01-16-2009)
 Old 01-07-2009, 01:32 PM   #62
Activity Longevity
0/20 15/20
Today Posts
0/7 ssssss631
Medieval has sent me a pic of all the hardware kits that were shipped out. So that you guys will have edvidence that you are getting you correct pieces.
The Following 2 Users Say Thank You to darkstarmotorsports For This Useful Post:
bioevolve (01-07-2009), skeeter149 (01-07-2009)
 Old 01-07-2009, 01:40 PM   #63
Alittle Faster
bioevolve's Avatar
Activity Longevity
2/20 18/20
Today Posts
0/7 sssss3249
I see mine there lol.
 Old 01-07-2009, 02:31 PM   #64
Activity Longevity
12/20 20/20
Today Posts
3/7 sssss2191
I hope your not one of the bottom two envelopes, because I'm about to steal both their identities....
The Following 2 Users Say Thank You to SSinstaller For This Useful Post:
bioevolve (01-07-2009), phillyREPOphail (01-07-2009)
 Old 01-07-2009, 03:29 PM   #65
Groans: 1,421
Activity Longevity
18/20 18/20
Today Posts
7/7 ssss10523
d00d, i like you, but you can't be posting that picture man. that shit has addresses in there.
word
oem part numbers -
The Following User Says Thank You to phillyREPOphail For This Useful Post:
 Old 01-07-2009, 03:46 PM   #66
Hater!
ptperformance's Avatar
ptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the world
Groaned at 74 Times in 46 Posts
Activity Longevity
6/20 20/20
Today Posts
0/7 sssss4046
It bothered me as well. Problem being bending or form fitting a .250 thick piece of plate steel takes tooking that costs into the $100's of thousands of dollars. We could get them form fitted but it would have taken the mount up to $400 per unit. The offset is very minimal, if you have a case of OCD it might bother you a good amount. We are taking a look at putting one bend in it or adding some spacers to the corners to level the mount out a little better. There is just so much you can do until you start running into problems with cost. Keep us updated on the mount and we will be in here to answer any questions that we can. Thanks.
To make a purchase please go to
Shop hours are 9am to 7pm Monday-Saturday
Shop number 253-277-3843, Shop cell 253-653-3843
href="showthread.php?p=553626#post553626" rel="nofollow">
Hahahaha...not that this post will stay up because I am sure John will delete it. But the reason people aren't trying these is because they can't stand you. They think your a gimick man who can't make parts worth a damn. Thats why someone else got on this and they are waiting for him. I happen to think you finally made a part that works. 1 out 55 is a pretty decent ratio I guess. These seals actually seem to be working on Tims car and I created the tune to be pretty aggressive (as much as tuning on the street can do). Its just too bad they come from a company who is viewed as a joke on most platforms.
ptperformance is offline
 Old 01-07-2009, 04:35 PM   #67
Alittle Faster
bioevolve's Avatar
Activity Longevity
2/20 18/20
Today Posts
0/7 sssss3249
HAHAHAHA, it would be hard to get anything out of my identity. But DSMS should blur them out.
 Old 01-07-2009, 07:19 PM   #68
Rotary inside
redrocketz's Avatar
Posts: 955   (View Stats)
redrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond repute
Activity Longevity
0/20 20/20
Today Posts
0/7 ssssss955
Seriously? Hundreds of thousands of dollars? My dad does this shit all day that would take 10 seconds to do and maybe 50cents a piece over the initial costs. The trz doesn't cost $200-300 a unit.
redrocketz is offline
 Old 01-07-2009, 08:49 PM   #69
Pay Me The Money I'm Owed
skeeter149's Avatar
Posts: 2,453   (View Stats)
Groans: 60
Activity Longevity
13/20 18/20
Today Posts
3/7 sssss2453
i wouldnt know but if your right damn!
1996 200SX SE-R-Injen, JWT, Unorthodox Racing, Progress, GReddy, Nismo, Weapon-R, Prothane
2008.5 Mazdaspeed 3-Cobb, GReddy, AWR, Racing Brake, Street Unit
skeeter149 is offline
 Old 01-07-2009, 09:37 PM   #70
that.dude's Avatar
Posts: 36   (View Stats)
that.dude will become famous soon enough
Activity Longevity
0/20 14/20
Today Posts
0/7 sssssss36
bending shit is pretty cheap dude... redrocket is right, it wouldn't add much to the cost of the part to do it. while it may cost more than competitors, some will appreciate the attention to detail and perfect fit
wouldn't you start running out of thread on the nuts? it seems to me that once you add the thickness of the material and spacers, you would not have much thread to screw onto...
that.dude is offline
 Old 01-07-2009, 10:02 PM   #71
Activity Longevity
12/20 20/20
Today Posts
3/7 sssss2191
Even with the spacers it shouldn't be any thicker than the stock cast mount, so there shouldn't be any issue...
darkstarmotorsports (01-09-2009)
 Old 01-07-2009, 11:12 PM   #72
that.dude's Avatar
Activity Longevity
0/20 14/20
Today Posts
0/7 sssssss36
the piece in question is the piece with the bushing in it. it is made out of heavy sheet metal, but not 1\4 inch stuff. i'm wondering, with the added thickness of metal and spacers, and without putting the bend in there, is there enough thread left?
 Old 01-08-2009, 12:32 PM   #73
Activity Longevity
12/20 20/20
Today Posts
3/7 sssss2191
the piece in question is the piece with the bushing in it. it is made out of heavy sheet metal, but not 14 inch stuff. i'm wondering, with the added thickness of metal and spacers, and without putting the bend in there, is there enough thread left?
My mistake, I thought they were talking about spacers to get the mount to sit level, not washers to hold the bushings in place.
Looking at the pictures of the darkstar mount installed there is plenty of thread on that bolt to account for those spacers...
 Old 01-09-2009, 12:57 AM   #74
Activity Longevity
0/20 15/20
Today Posts
0/7 ssssss631
Here you guys go.....
bioevolve (01-09-2009)
 Old 01-09-2009, 02:29 PM   #75
Alittle Faster
bioevolve's Avatar
Activity Longevity
2/20 18/20
Today Posts
0/7 sssss3249
Hey John (PTP), I got another tranny mount from you, what you want me to do with it?
This one has better welds than the first one! HAHAHA, LMK.
 Old 01-10-2009, 02:23 PM   #76
mouse0330's Avatar
Posts: 1,025   (View Stats)
mouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the world
Activity Longevity
2/20 16/20
Today Posts
0/7 sssss1025
Hey Rich, what's up with these guys sending you extra mount. By the way which one you like better now. I might send PTP the money for that extra tranny mount they send you and go to your place to pick it up instead of having you sending it back to PTP, thats if they agree to do that...will pay via Paypal.
mouse0330 is offline
 Old 01-10-2009, 05:59 PM   #77
Alittle Faster
bioevolve's Avatar
Activity Longevity
2/20 18/20
Today Posts
0/7 sssss3249
I'm using the PTP one now, I sent back the Medieval one.
I don't know why I keep getting extra parts lol, I'm not complaining hahaha.
It all depends on what PTP says I guess, John chime in please.
 Old 01-12-2009, 11:08 PM   #78
Munnugles's Avatar
Posts: 75   (View Stats)
Munnugles will become famous soon enough
Activity Longevity
3/20 20/20
Today Posts
0/7 sssssss75
hmm... im debating which mount to get. does anyone have any instructions on how to install this (with pics or somewhat detailed instructions). and i am extremely confused on where and why the spacers are needed. this may (hopefully) fix the shifting problem i have if due to that mount (dunno if its busted or not).
Munnugles is offline
 Old 01-14-2009, 07:24 PM   #79
medieval's Avatar
Activity Longevity
0/20 14/20
Today Posts
0/7 ssssss151
Dark Star is one of our dealers and stocks most of our product line. As for instructions, we are working on those for every motor mount we have and the Speed 3 ones will be done in 1-2 weeks. Pictured are much better shoots of our passenger side and transmission mount and the required hardware for each.
http://www.mazdaspeedforums.org/foru...tml#post140847
The transmission mount hardware went out to everyone and you will see 2 different packages (washers and then bolt).
If you do not see these for some reason, please send me an email at sales@medievalllc.com
If you can not wait you will need the following:
2x 2" washers with 1/2 holes
1x 12mm x 1.25 x 25mm bolt.
If you choose to buy your own hardware( less than $3) before ours shows up, please let me know. I will credit you $10 towards your next order of Medieval parts with Dark Star or with us directly.
medieval is offline
The Following 2 Users Say Thank You to medieval For This Useful Post:
bioevolve (01-15-2009), darkstarmotorsports (01-14-2009)
 Old 01-16-2009, 08:37 PM   #80
Betelgeuse's Avatar
Activity Longevity
1/20 20/20
Today Posts
0/7 ssssss343
Bioevolve, did you loosen the rear mount like stated in the instruction sheet? If you did, which bolt(s) did you loosen. Thanks!! PTP chime in if you read this. I'm doing my install tomorrow so I'll post my impressions. Hopefully everything will go smoothly.
Thread Tools
Speed6 AWR engine and tranny mounts jmhinkle MazdaSpeed 3/6 - For Sale / Trade 18 11-24-2009 05:00 PM
DarkStar Passenger Mount bioevolve MazdaSpeed 3 - Engine, Transmission & Driveline 53 01-01-2009 07:26 PM
Tranny pix franciscoescn MSP - Engine, Transmission & Driveline 6 08-09-2008 12:27 PM
Has anyone seen or tried these yet? - SU tranny and passenger side mounts. Betelgeuse MazdaSpeed 3 - Engine, Transmission & Driveline 7 07-24-2008 10:17 AM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.1
Advertisement System V2.6 By   Branden
©Copyright 2008 ; 2010 Cymru Internet Services LLC
Page generated in 1.38168 seconds with 129 queries
