![]() | | #41 | ![]() |
![]() Join Date: Apr 2008 Location: San Diego, CA
Rep Power: 493 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 666
| Not Ranked : 0 score
First of all, are you talking about me? I'm in San Diego.
![]() | | #42 | ![]() |
| Alittle Faster ![]() ![]() Join Date: May 2008 Location: Cape Coral, FL
Rep Power: 6078 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,006
(Thread Starter) | Not Ranked : 0 score I think DS is talking about the top plate. Guessing spacers under the motor side and none on the fender side of the top plate. |
![]() | | #43 | ![]() |
| Banned ![]() Join Date: Oct 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 568
Groaned at 6 Times in 2 Posts
yes the top piece. This will help correct the angle. Also some people are having probelms with the bushing being squeeze out the top once the engine load is on it, becasue there is a little bit of a gap, where the bushing mets with the other mount. If you place 1 or 2 washers in there, this will sovle that issue too and take up the extra room. Try to use a large diameter washer. AGAIN, I'm sorry for this everyone. I'm a huge believer in customer serivce, and if I receive this mount and had these same problems I would want a fix ASAP. I hope this helps everyone out! I'll be near the computer for the rest of the evening, so if anyone else has any more questions or concerns, please PM or email me. | |
| The Following User Says Thank You to darkstarmotorsports For This Useful Post: | bioevolve (01-05-2009) |
![]() | | #44 | ![]() |
| Not Ranked : 0 score |
| The Following User Says Thank You to Ferdball For This Useful Post: | phillyb (01-06-2009) |
![]() | | #45 | ![]() |
(Thread Starter) | Not Ranked : 0 score PTP mount feels like it has alittle less vibration or I have gotten used to both of them lol. I still have my odd deceleration vibration, but it doesn't happen all the time. Several times I tried to make it virbrate upon deceleration and by pushing the clutch in it goes away. Possible bad clutch?!?!?! Might not be because I didn't feel this vibration until I installed these mounts. I think both mounts pull the tranny up alittle higher than the stock mount. I can't confirm that yet. |
![]() | | #46 | ![]() |
![]() Join Date: Mar 2008 Location: Jacksonville, NC
Rep Power: 2469 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 810
Groans: 60
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks | |
![]() | | #47 | ![]() |
Anyways here are some more pics of the PTP in the car, I didn't feel like taking it apart lol. Anyone know if the PTP is a 2-part bushing or a single one? Last edited by bioevolve; 01-07-2009 at 11:27 AM. | |
![]() | | #48 | ![]() |
Groans: 60
There is a normal vibration that you get at or near idle that gradually lessens as the rpms rise(there is also some significant gear whine).. There is also a different vibration that's much stronger than the other that will only happen under deceleration and under certain conditions. I could almost make it happen at will with the AWR mount. It seems to depend on the load that's on the motor when you get off the gas..
| The Following User Says Thank You to SSinstaller For This Useful Post: | bioevolve (01-06-2009) |
![]() | | #49 | ![]() |
(Thread Starter) | Not Ranked : 0 score So it's basically a load and harmonics vibs dependent on certain conditions? So we are feeling an unbalanced form of vibs from a supposingly balanced setup lol? Well it's not balanced anymore lol. But you are right on, I just couldn't explain it like you just did, Thanks! |
![]() | | #50 | ![]() |
| Banned ![]() Join Date: Jun 2008 Location: misery
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,510
Groans: 1,940
| Not Ranked : 0 score bio, did you need the washers for the ptp mount? |
![]() | | #51 | ![]() |
(Thread Starter) | Not Ranked : 0 score If you are refering to the 3 extra silver washers, I thought it needed. You can try it without the extra washers and see if it bottoms out, the bronze color one is supplied by PTP. Actually they supplied 3 of them, I used the other 2 on the ends of the main bushing bolt. |
| The Following User Says Thank You to bioevolve For This Useful Post: | phillyb (01-06-2009) |
![]() | | #52 | ![]() |
Groans: 1,940
| Not Ranked : 0 score is that the stock bolt you used? |
![]() | | #53 | ![]() |
(Thread Starter) | Not Ranked : 0 score Nope, it's the one PTP supplied alittle shorter than the stock bolt. Here is the PTP bolt supplied by PTP vs stock bolt, it is shorter to take up space. If I'm remembering correctly, stock is 17mm and PTP is 19mm head sizes. |
![]() | | #54 | ![]() |
![]() Join Date: Mar 2008 Location: Miami, FL
Groaned at 4 Times in 2 Posts
| Not Ranked : 0 score Bio, do you have upgraded passenger and rear mounts as well? Also, it takes some time for the vibes to settle according to ptp so you may need to drive it a while more (they said 1500 miles in the instructions).
__________________ Cobb SRI // Cobb Shifter Weight // TWM Bushings // TWM STS // TWM type R weighted shift knob // Medieval Rear Mount // Darkstar Passenger Mount |
![]() | | #55 | ![]() |
Top Speed Passenger SU Rear Lower Turbine Tech Front I now all about that lol, just giving intial review of the vibs. Last edited by bioevolve; 01-07-2009 at 11:13 AM. | |
![]() | | #56 | ![]() |
| Banned ![]() Join Date: Dec 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 131
| Not Ranked : 0 score ahh now i see it. your battery tray is not level anymore, and that is why you had to slot the battery box holes, because it was leaning towards your intake. |
![]() | | #57 | ![]() |
![]() | | #58 | ![]() |
http://www.mazdaspeedforums.org/foru...fmm-oc-sp.html Turbine Tech Front Engine Mount: MAZDASPEED 3 ___________________________ Come to think of it. I wanna correct something: Darkstar is a Vendor not the Manufacturer of this mount. This is not a negative shot at Darkstar. I should have titled this Medieval & PTP Tranny Mount. I guess I saw Darkstar as a Manufacturer, Sorry man. Corrected my wrong lol. | ||
![]() | | #59 | ![]() |
| Not Ranked : 0 score when you look at it, is it visible? can you tell the thing is angled towards the motor? that would piss me off. i hate when things do not line up and are not symmetrical... the TRZ has that jog bend in it, correct? |
![]() | | #60 | ![]() |
(Thread Starter) | Not Ranked : 0 score I didn't pay any attention to the way the battery stance looked, just looked at the ecu housing touching the inlet pipe and adjusted accordingly. |
![]() | | #61 | ![]() |
| Banned ![]() Join Date: Nov 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19
| Not Ranked : 0 score All Medieval motor mounts come with a life time warranty. As for these issues that are being shown here, this is due to the hardware kit not being installed. When we sent DS his shipment it was a mistake on our part. The tranny mount comes with 2 x 2" washers and a bolt. The 2" washers are meant to be placed on each side of the bushing. This will eliminate the issues you see in these pictures. We here are very sorry about this and have received all the address from DS and are sending off hardware kits. If anyone has any issues or concerns, please fell free to email us at sales@medievalllc.com |
| The Following 3 Users Say Thank You to medieval For This Useful Post: |
![]() | | #62 | ![]() |
Medieval has sent me a pic of all the hardware kits that were shipped out. So that you guys will have edvidence that you are getting you correct pieces. Last edited by darkstarmotorsports; 01-08-2009 at 12:44 AM. | |
| The Following 2 Users Say Thank You to darkstarmotorsports For This Useful Post: | bioevolve (01-07-2009), skeeter149 (01-07-2009) |
![]() | | #63 | ![]() |
(Thread Starter) | Not Ranked : 0 score I see mine there lol. |
| The Following User Says Thank You to bioevolve For This Useful Post: | darkstarmotorsports (01-07-2009) |
![]() | | #64 | ![]() |
Groans: 60
| Not Ranked : 0 score I hope your not one of the bottom two envelopes, because I'm about to steal both their identities....
![]() | | #65 | ![]() |
Groans: 1,940
word | |
| The Following User Says Thank You to phillyb For This Useful Post: | darkstarmotorsports (01-08-2009) |
![]() | | #66 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: On this planet (Washington)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
It bothered me as well. Problem being bending or form fitting a .250 thick piece of plate steel takes tooking that costs into the $100's of thousands of dollars. We could get them form fitted but it would have taken the mount up to $400 per unit. The offset is very minimal, if you have a case of OCD it might bother you a good amount. We are taking a look at putting one bend in it or adding some spacers to the corners to level the mount out a little better. There is just so much you can do until you start running into problems with cost. Keep us updated on the mount and we will be in here to answer any questions that we can. Thanks. | |
![]() | | #67 | ![]() |
t DSMS should blur them out. | |
![]() | | #68 | ![]() |
![]() Join Date: Mar 2008 Location: Chicago
Seriously? Hundreds of thousands of dollars? My dad does this shit all day that would take 10 seconds to do and maybe 50cents a piece over the initial costs. The trz doesn't cost $200-300 a unit. | |
![]() | | #69 | ![]() |
![]() Join Date: Jun 2008 Location: lancaster, ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,297
Groans: 91
i wouldnt know but if your right damn!
__________________ "Go find your own enterprise, and get the fuck off my bridge!" 2008 Speed 3 GT- Cobb SRI, Cobb TIP, AQ Motorsports DP (Turboxs Adapter Plate), TurboXS FMIC, GReddy CBE, GReddy BPV, 3P Flange, GReddy TT, GReddy Boost Gauge, Vent Pod, GReddy Shift Knob, SU Shifter Bushings, AWR RMM, Cobb RSB, Cobb AP, Cobb Shifter Weight, Autotech FP Internals, Corksport Exhaust Hangers. "parked hard" 1996 200sx SE-R- Injen CAI, GReddy SP CBE, Tein Basic Coilovers, Progress FSB, Clutch Masters Flywheel, Progress RSB, Cusco FSTB, Progress LCAB, Prothane MM, JWT POP Program, JWT S4 Cams, Mishimoto Radiator, GoodRidge SS Brake Lines, Powerslot Rotors, Nismo CF Shift Knob. "back in action" | |
![]() | | #70 | ![]() |
![]() | | #71 | ![]() |
Groans: 60
| Not Ranked : 0 score Even with the spacers it shouldn't be any thicker than the stock cast mount, so there shouldn't be any issue...
| The Following User Says Thank You to SSinstaller For This Useful Post: | darkstarmotorsports (01-09-2009) |
![]() | | #72 | ![]() |
![]() | | #73 | ![]() |
Groans: 60
Looking at the pictures of the darkstar mount installed there is plenty of thread on that bolt to account for those spacers...
![]() | | #74 | ![]() |
| Not Ranked : 0 score Here you guys go..... |
| The Following User Says Thank You to darkstarmotorsports For This Useful Post: | bioevolve (01-09-2009) |
![]() | | #75 | ![]() |
(Thread Starter) | Not Ranked : 0 score Hey John (PTP), I got another tranny mount from you, what you want me to do with it? This one has better welds than the first one! HAHAHA, LMK. ![]() |
![]() | | #76 | ![]() |
![]() Join Date: Sep 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 908
| Not Ranked : 0 score Hey Rich, what's up with these guys sending you extra mount. By the way which one you like better now. I might send PTP the money for that extra tranny mount they send you and go to your place to pick it up instead of having you sending it back to PTP, thats if they agree to do that...will pay via Paypal. |
![]() | | #77 | ![]() |
I don't know why I keep getting extra parts lol, I'm not complaining hahaha. It all depends on what PTP says I guess, John chime in please. | |
![]() | | #78 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score hmm... im debating which mount to get. does anyone have any instructions on how to install this (with pics or somewhat detailed instructions). and i am extremely confused on where and why the spacers are needed. this may (hopefully) fix the shifting problem i have if due to that mount (dunno if its busted or not). |
![]() | | #79 | ![]() |
| Not Ranked : 0 score Dark Star is one of our dealers and stocks most of our product line. As for instructions, we are working on those for every motor mount we have and the Speed 3 ones will be done in 1-2 weeks. Pictured are much better shoots of our passenger side and transmission mount and the required hardware for each. http://www.mazdaspeedforums.org/foru...tml#post140847 The transmission mount hardware went out to everyone and you will see 2 different packages (washers and then bolt). If you do not see these for some reason, please send me an email at sales@medievalllc.com If you can not wait you will need the following: 2x 2" washers with 1/2 holes 1x 12mm x 1.25 x 25mm bolt. If you choose to buy your own hardware( less than $3) before ours shows up, please let me know. I will credit you $10 towards your next order of Medieval parts with Dark Star or with us directly. |
| The Following 2 Users Say Thank You to medieval For This Useful Post: | bioevolve (01-15-2009), darkstarmotorsports (01-14-2009) |
![]() | | #80 | ![]() |
| Not Ranked : 0 score Bioevolve, did you loosen the rear mount like stated in the instruction sheet? If you did, which bolt(s) did you loosen. Thanks!! PTP chime in if you read this. I'm doing my install tomorrow so I'll post my impressions. Hopefully everything will go smoothly.
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/darkstar-ptp-tranny-mounts-18368/ | ||||
| Medieval Transmission & Passenger Mount Review - TorontoMazda3 | This thread | Refback | 03-08-2009 11:23 AM | |
| Tranny pix | franciscoescn | MSP - Engine, Transmission & Driveline | 12 | 09-26-2012 04:24 PM |
| DarkStar Passenger Mount | bioevolve | MazdaSpeed 3 - Engine, Transmission & Driveline | 53 | 01-01-2009 08:26 PM |
| TRZ side mounts? | kopf | Mazdaspeed3/6 General Discussion | 55 | 12-18-2008 04:45 PM |
| Has anyone seen or tried these yet? - SU tranny and passenger side mounts. | Betelgeuse | MazdaSpeed 3 - Engine, Transmission & Driveline | 7 | 07-24-2008 11:17 AM |
