![]() | | #161 | ![]() |
![]() Join Date: Jun 2008
| Not Ranked : 0 score |
![]() | | #162 | ![]() |
| Alittle Faster ![]() ![]() Join Date: May 2008 Location: Cape Coral, FL
Rep Power: 6078 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,006
HUH? | |
![]() | | #163 | ![]() |
Rep Power: 0 ![]() ![]() ![]() Thanks: 13
| Not Ranked : 0 score [QUOTE=bioevolve;159804] Nut access slot looks like done by hand and a demel? I can’t believe they would let a product get out looking like this. I know it may be functional but still that looks really bad. |
![]() | | #164 | ![]() |
| Banned ![]() Join Date: Jun 2008 Location: misery
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,510
Groans: 1,940
| Not Ranked : 0 score function > form it works well. that's all i care about |
![]() | | #165 | ![]() |
![]() Join Date: Aug 2008 Location: jersey
Rep Power: 609 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 388
| Not Ranked : 0 score do you guys who have a transmission mount have a weird sound at idle that you hear inside the car that goes away if you push in the clutch? |
![]() | | #166 | ![]() |
(Thread Starter) | Not Ranked : 0 score No, no unusual sound........unless something is hitting, touching, loose, or you have a bent rod? IDK, double check everything for tightness and clearance. |
![]() | | #167 | ![]() |
Groans: 1,940
there were more vibes, and just more noise in general. with the tranny mount, you're basically talking about the same thing. and yes, i experience the sound you're talking about. this is my understanding. it'd be nice if others chimed in as well | |
![]() | | #168 | ![]() |
![]() | | #169 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: On this planet (Washington)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
| Not Ranked : 0 score Sorry about the hand cut slot guys, we rushed these and the rest will be lazer cut after we burn through the last 5 or 6 units. Again sorry about the mix up on these but you should all feel better with the new mount in there. If you are upset with the looks that is understood, it will not effect the performance of the mount. |
![]() | | #170 | ![]() |
| Not Ranked : 0 score Common with dual mass flwwheels. Also you have the trans gears and what not spinning in neutral when you let the clutch out, when the clutch is in nothing is spining other then the clutch disc. |
![]() | | #171 | ![]() |
| Neutral : +1 score its clutch bearing nothing unusal.... |
![]() | | #172 | ![]() |
| Not Ranked : 0 score I have vibrations when letting off the gas above 3k RPM and 60 MPH or above. I'm guessing that's normal and thought it would go away after some time but its still there after a few months. Let me know if anyone else notices this. Other then that I love the mount. |
| The Following User Says Thank You to albone For This Useful Post: | darkstarmotorsports (03-20-2009) |
![]() | | #173 | ![]() |
![]() Join Date: Mar 2008 Location: Miami, FL
Groaned at 4 Times in 2 Posts
| Neutral : +1 score Everyone has them once the tranny mount is replaced. You'll get used them. The stock mount was designed so soft to absorb vibrations like these. IMO, it's a small price to pay.
__________________ Cobb SRI // Cobb Shifter Weight // TWM Bushings // TWM STS // TWM type R weighted shift knob // Medieval Rear Mount // Darkstar Passenger Mount |
![]() | | #174 | ![]() |
| Not Ranked : 0 score the darkstar tranny mount cocks my cpe rear mount to the side, i need cpe mounts for the front two asap, i think the engine being not in the exact spot is the casue of alot of the vibrations |
![]() | | #175 | ![]() |
| Banned ![]() Join Date: Oct 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 568
Groaned at 6 Times in 2 Posts
First of all, it's Medieval's tranny mount, not Darkstar's. Can could provide a pic of you CPE rear mount sitting cocked to one side? | |
![]() | | #176 | ![]() |
| The Following User Says Thank You to bf360 For This Useful Post: | darkstarmotorsports (03-20-2009) |
![]() | | #177 | ![]() |
| Not Ranked : 0 score ![]() ![]() ![]() those are the best pics i could get, dont have time to jack up the car right now |
![]() | | #178 | ![]() |
![]() Join Date: Aug 2008 Location: Cerritos, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 222
Groaned at 9 Times in 5 Posts
| Not Ranked : 0 score i should take a look at mine too...i have the cp-e mount...no vibrations at all though...very smooth...i did break it in properly |
![]() | | #179 | ![]() |
(Thread Starter) | Not Ranked : 0 score Took the Medieval Tranny Mount out, it was causing my engine to be cocked. You can see the bushing to the right (which is the rear toward the firewall) the tranny is pushing back to go back to it original location. Pulled it out and installed the stock one. Update: I got off the phone with Medieval and gonna try another way of installing it and see if it fixes it. Last edited by bioevolve; 03-20-2009 at 06:59 PM. |
![]() | | #180 | ![]() |
![]() | | #181 | ![]() |
(Thread Starter) | Not Ranked : 0 score I guess it's just me then or that drop with the V1 PMM caused the TMM to twist and it's staying that way. Grrrrrrrrrrr. |
![]() | | #182 | ![]() |
| Not Ranked : 0 score Bio, you can center the motor if you have the time to do this. You need to loosen both the pass and drivers side mounts, then loosen the middle mount (rear center mount). Move the motor left or right to get to the proper possition, and wallah your golden. Tighten down the fixed lower mount bolts (frame bolts) then tighten down the mount to braket bolts. We have had a few that had shifted pass side mounts due to the excessive movement from the stock mounts. This will get the center mount more straight on and seems to fix a little bit of the vibes from the motor. |
| The Following User Says Thank You to ptperformance For This Useful Post: | darkstarmotorsports (04-13-2009) |
![]() | | #183 | ![]() |
![]() Join Date: May 2008 Location: Stamford, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 243
Groaned at 27 Times in 15 Posts
| Not Ranked : 0 score So the cocked rear mount (being that it's aftermarket of course) can just be loosened and then retorqued?
__________________ ![]() |
![]() | | #184 | ![]() |
![]() | | #185 | ![]() |
Groans: 1,940
| Not Ranked : 0 score sticky thread bump i'm going to post this here as well - http://www.mazdaspeedforums.org/foru...questions.html - it's basically a comparison between trz tranny mount and ptp tranny mount |
![]() | | #186 | ![]() |
![]() Join Date: Apr 2009
| Not Ranked : 0 score Has anyone else had one hell of a time getting their replacement pmm from darkstar/medieval?? I have been told through numerous emails that my new mount is being shipped out this week(2 seperate emails, 2 seperate weeks) I've now been waiting 6 weeks since this recall and still no new mount shipped to me. It's frustrating because the email responses from darkstar are quick and professional, but they don't follow through. Also the new mount is being sold for $25 cheaper than the original. Are they refunding that difference when they ship out the new mount?? Any info would be greatly appreciated! |
![]() | | #187 | ![]() |
(Thread Starter) | Not Ranked : 0 score As far as I know they are/were going thru employee restructuring. |
![]() | | #188 | ![]() |
As for the price, we're actually losing money shipping out the new V2 versions to you. But profit, is not the main goal in this situation. it's making sure that you as the customer is satisfied and have a high quality product. There was no employee restructuring, it's a ONE man show. | |
| The Following User Says Thank You to darkstarmotorsports For This Useful Post: | bioevolve (04-26-2009) |
![]() | | #189 | ![]() |
![]() Join Date: Mar 2009 Location: Woodridge,IL
Rep Power: 0 ![]() Thanks: 2
| Not Ranked : 0 score My PTP mount just shipped today, I'm so excited for it since my car is now in the shop from my stock bolt snapping in half and also snapping a bearing out of my axle |
![]() | | #190 | ![]() |
![]() Join Date: May 2009
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score YES PLS KEEP US UP TO DATE.... |
![]() | | #191 | ![]() |
![]() Join Date: Dec 2009 Location: Middle Earth
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
| Not Ranked : 0 score Linky for the place to buy the PTP tranny mount? Sorry, still new here. Would like to get this asap though as I'm sure my stock one is toast. |
![]() | | #192 | ![]() |
![]() | | #193 | ![]() |
![]() Join Date: Oct 2008 Location: New Brunswick, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 37
| Not Ranked : 0 score Just an update from a PTP tranny mount user, when I had the motor out (due to the KaBoom syndrome) I had all kinds of time to look at stuff.... anyhow, my PTP tranny mount with appox 20K miles on it, is in excellent shape. Just like the day I put it in. |
| The Following User Says Thank You to Thestaplegunkid For This Useful Post: | bioevolve (12-31-2009) |
![]() | | #194 | ![]() |
![]() | | #195 | ![]() |
![]() Join Date: Apr 2010 Location: Des Plaines, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 234
Groaned at 53 Times in 17 Posts
| Not Ranked : 0 score Very nice write up!!! I had the Medieval motor mount.the performance is great. the car felt more powerful. Although I took the mount off right away on the next day. Lots of noise and vibrations.my dashboard sounded like is going to come off any second. And lots of noise from the clutch. I could not stand it even for a day. I would like to put after market one but just when I remember how my car was and I am back to the stock one |
![]() | | #196 | ![]() |
![]() Join Date: Mar 2009 Location: Queens, NYC
Rep Power: 201 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 71
| Not Ranked : 0 score Updates? |
![]() | | #197 | ![]() |
Groans: 1,940
| Not Ranked : 0 score about what |
![]() | | #198 | ![]() |
| Not Ranked : 0 score Sorry, please disregard. |
![]() | | #199 | ![]() |
| Banned ![]() | Not Ranked : 0 score just ordered a set of ptp mounts but they are on back order so idk when I will be getting them my car is on blocks until they arrive |
![]() | | #200 | ![]() |
| Not Ranked : 0 score Which ones? |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/darkstar-ptp-tranny-mounts-18368/ | ||||
| Medieval Transmission & Passenger Mount Review - TorontoMazda3 | This thread | Refback | 03-08-2009 11:23 AM | |
| Tranny pix | franciscoescn | MSP - Engine, Transmission & Driveline | 12 | 09-26-2012 04:24 PM |
| DarkStar Passenger Mount | bioevolve | MazdaSpeed 3 - Engine, Transmission & Driveline | 53 | 01-01-2009 08:26 PM |
| TRZ side mounts? | kopf | Mazdaspeed3/6 General Discussion | 55 | 12-18-2008 04:45 PM |
| Has anyone seen or tried these yet? - SU tranny and passenger side mounts. | Betelgeuse | MazdaSpeed 3 - Engine, Transmission & Driveline | 7 | 07-24-2008 11:17 AM |
