Notices
 Old 07-31-2009, 10:17 AM   #1
flyrevs2's Avatar
Posts: 1,218   (View Stats)
flyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the world
Default DCR Engine build FTW !!!!
OK y'all know my engine blew. (if not see this link) Darrell Cox Racing has my car now and they are going to re-build my motor and do some magic on it. This thread is to update the status of the build and also get advice from others who are more experienced in this area than myself. My goals are super reliable forged DD with 330WHP or so (more would be cool but I'm not sure if my budget will allow it). No autoexe, no drag racing, just a go fast DD.
New Parts:
Wiseco Pistons and Pauter Rods
DCR Exhaust manifold
Cobb Catted Down Pipe
Turbo:
GT2871 or Garrett t3/t4 or DCR re-worked - Looking for advise on this !
Clutch:
Spec Stage 3 plus -
Used Block (thanks Randy).
I hope you guys will give me some good advice on the clutch / turbo. Thanks!
Mazdaspeed3 {Blowed Up 7/17/09}
Mods: MS-CAI2, Tip, Turbosmart BPV, Cobb AP, Cobb DP, Cobb CBE, CPE HPFP, CPE RMM, PTP Kicker Mount, StealthBox w/ 8" JBL, Alpine 500W Amp, CurbAlert
flyrevs2 is offline   Reply With Quote
 Old 07-31-2009, 10:19 AM   #2
mazda.speed3's Avatar
Posts: 125   (View Stats)
mazda.speed3 has much to be proud ofmazda.speed3 has much to be proud ofmazda.speed3 has much to be proud ofmazda.speed3 has much to be proud ofmazda.speed3 has much to be proud ofmazda.speed3 has much to be proud ofmazda.speed3 has much to be proud ofmazda.speed3 has much to be proud ofmazda.speed3 has much to be proud ofmazda.speed3 has much to be proud of
Sorry to hear you blew. Looks like your going places now..
mazda.speed3 is offline   Reply With Quote
 Old 07-31-2009, 10:48 AM   #3
Target:STi's Avatar
Posts: 289   (View Stats)
Target:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the world
if youre building it, go with something bigger than a 2871
Formerly: TG 06 MS6- CAI, TMIC, TBE
Currently: RR 08 Evo X- SRI, UICP, TP, CBE, Tune
Target:STi is offline   Reply With Quote
The Following User Says Thank You to Target:STi For This Useful Post:
djuosnteisn (07-31-2009)
 Old 07-31-2009, 10:50 AM   #4
JumpingJackson's Avatar
Posts: 940   (View Stats)
JumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the world
I wouldnt use Arias pistons either.. Get Wiseco or CP pistons, and move to a T3 flanged turbo. (the Mazdaspeed flange really restrictive)
Id get like a T3/vband GT3076r or a Bullseye/Borg Warner .55 A/R S256
JumpingJackson is online now   Reply With Quote
 Old 07-31-2009, 11:10 AM   #5
NEC
subparpunk03's Avatar
Posts: 1,267   (View Stats)
subparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the worldsubparpunk03 is the leader of the world
Groaned at 6 Times in 6 Posts
I've heard nothing but good things about the ACT Organic clutch. Several people have the 6 puck sprung and say its not bad at all either.
Don't skimp on the turbo... if one of your goals is reliability, MAKE SURE it is water cooled.
2006 Lotus Elise: Toy car
1999 B4000: DD / Parts hauler / SC Project
2007 Mazdaspeed 3: *sold*
2005 Corolla XRS: *sold*
subparpunk03 is offline   Reply With Quote
 Old 07-31-2009, 11:19 AM   #6
flyrevs2's Avatar
well bigger is ok, but I really don't want a lot of turbo lag
Jackson - what's the issue with the Arias pistons ? On the Vband Garrett, how much lag? And is that an external wastegate ?
 Old 07-31-2009, 11:27 AM   #7
I dont think the lag would be too bad if you have a good T3 manifiold (see DCR's manifold , possibly Steedspeeds new revised design manifold) Go look at ATP's webside for different housing options. IF your worried about spool get a smaller AR:
http://www.atpturbo.com/Merchant2/me...egory_Code=GRT
Id get the .63 A/R Vband GT turbine housing
If im not mistaken the wiseco pistons have alot more features built into them off the shelf than arias. you really should speak to your engine builder about this.
(moly coated skirts, the best piston rings, lots of other stuff)
 Old 07-31-2009, 12:54 PM   #8
mazdaj's Avatar
Posts: 369   (View Stats)
mazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the world
just curious, what is your budget for this build? or rather, what will dcr charge you for their work?
mazdaj is offline   Reply With Quote
The Following User Says Thank You to mazdaj For This Useful Post:
taf0422 (07-31-2009)
 Old 07-31-2009, 01:10 PM   #9
flyrevs2's Avatar
Well it's premature to talk about what DCR will charge because all the details are not worked out yet. However I can say that his price to re-build the motor is very reasonable. Since all the options (head work, machining, manifold, etc. are not know yet the price is yet to be determined. THere are a lot of assumtions but until the motor comes out of the car and DCR has examined it it I won't know. Best bet at this point is to talk to Palerider as he is the liaison with DCR. My budget started at "think $3k to $4k" and now it's $6k to $7k. The number has increased as I have added performance parts (forged rods & pistons, exhaust manifold, clutch & pressure plate, downpipe, BT etc.) If it gets much over that my wife will be puttin a serious hurt on me.
The Following User Says Thank You to flyrevs2 For This Useful Post:
mazdaj (10-11-2009)
 Old 07-31-2009, 01:10 PM   #10
taf0422's Avatar
Posts: 2,849   (View Stats)
Groans: 153
I second that...
...and I got beat to the punch
07 MS3 GT..
Engine:Cobb AP,BNR S3,FREEKTUNED 25PSI,Wiseco Pistons/Manley Rods,NJSpeed Manifold, Bosch 3bar MAP,CS DP/RP&cat-back,DNP manifold,FP internals,JBR 3.5"WP,CP-E flange HKS,DO Stage II 75% meth,PG piping,TR8L FMIC,JBR Trans mount 70d&80d RMM,DH CP-E mount,Colder Plugs,SURE shifter bushings,JBR SSP,JBR knob,ACT 6puck,JBR EGR delete,CPE Seals,Grimmspeed EBC,windage tray,JBR BSD,JBR TIG,MD Catch Can.Looks:yellow lamin-x fogs,chrome turn signals,side moldings removed,20% tint.Suspension/Wheels:Enkei RPF1 17x9,extreme contact DW,Eibach 5mm spaces H&R springs,koni yellows.
BNR-S3 424/397 @GSD Dyno
414/390 at MNM
KILLAH BUILT/FREEK TUNED
taf0422 is online now   Reply With Quote
 Old 07-31-2009, 03:33 PM   #11
dcphantom's Avatar
Posts: 634   (View Stats)
dcphantom is the leader of the worlddcphantom is the leader of the worlddcphantom is the leader of the worlddcphantom is the leader of the worlddcphantom is the leader of the worlddcphantom is the leader of the worlddcphantom is the leader of the worlddcphantom is the leader of the worlddcphantom is the leader of the worlddcphantom is the leader of the worlddcphantom is the leader of the world
I'll bet it goes over that budget. Cars will do that to you
dcphantom is offline   Reply With Quote
 Old 07-31-2009, 03:50 PM   #12
Captain
djuosnteisn's Avatar
Posts: 11,192   (View Stats)
Groans: 79
...My budget started at "think $3k to $4k" and now it's $6k to $7k....If it gets much over that my wife will be puttin a serious hurt on me.
Is that your wifey in your avatar?
500awhp 440awtq uncorrected
BW8875 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning.
Mounts be popping, and trans be hurting
Check out the hair Salon:
www.permtuning.com
 Old 07-31-2009, 03:54 PM   #13
Laloosh's Avatar
Posts: 5,172   (View Stats)
Groans: 57
if your getting a manifold that accepts t3/t4 get a real turbo...get a garret turbo DIRECTLY from garret. 3076 would be my choice at your goal level.
 Old 07-31-2009, 07:23 PM   #14
aaronc7's Avatar
Posts: 7,054   (View Stats)
Groans: 357
Groaned at 151 Times in 125 Posts
50 trim ball bearing!
'99 Miata | engine delete mod | GTX2867R | ARTech exhaust | Tein Flex 9/6 kg | C3M 15x9 225/45 RS3 | DIYPNP
aaronc7 is online now   Reply With Quote
 Old 07-31-2009, 07:25 PM   #15
flyrevs2's Avatar
Why not the GT3071 ? (T3 flange and 2.75 inlet). The 3076 has a 4" inlet and that opens up a whole new can of worms for me. Remember I'm not building a drag machine so I think the 2.75 would work out for my application. Thoughts ?
 Old 07-31-2009, 07:43 PM   #16
SSinstaller's Avatar
Posts: 3,619   (View Stats)
Groans: 46
Groaned at 16 Times in 11 Posts
Stick with the larger compressor housing unless space is tight. The 4" inlet will flow better..
 Old 07-31-2009, 08:00 PM   #17
SneakyP86's Avatar
Posts: 1,105   (View Stats)
SneakyP86 is the leader of the worldSneakyP86 is the leader of the worldSneakyP86 is the leader of the worldSneakyP86 is the leader of the worldSneakyP86 is the leader of the worldSneakyP86 is the leader of the worldSneakyP86 is the leader of the worldSneakyP86 is the leader of the worldSneakyP86 is the leader of the worldSneakyP86 is the leader of the worldSneakyP86 is the leader of the world
Groaned at 19 Times in 13 Posts
I myself got a Turbonetics 50 trim T3/T4 hybrid,watercooled with the ceramic bearings 63 A/R and a 57# wheel. If you go with a different turbo dont half ass it make sure you go with the water cooling and ball bearings not journal. I would rather have a little lag in the lower RPM's and the boost hold longer in the higher RPMS myself. I mean if your going wot what good does it do you if the turbo kicks in say around 2K if your revs arent dropping down below 4k during your shifts which might be at the upper limits of a quicker spooling turbo......at least thats my thinking anyways........but I've been know to be wrong afterall I've been divorced twice.........LMAO
SneakyP86 is offline   Reply With Quote
 Old 07-31-2009, 08:26 PM   #18
Laloosh's Avatar
Groans: 57
why does a 4 inch inlet open up a whole can of worms. Just get a 4 inch inlet and run the stock sized intake. Thats about all it changes. The reason i suggest the 76 is cause it spools a lil later and will be able to carry out power up top, where it matters. Its your car, keep in mind though i had a gt35r on my ms3 and the spool up wasnt that bad, however it make its peak power till 6700 rpms. when your on it, racing around, tracking it here and there, no1 give a shit about downlow tq, its all about top end.
The Following User Says Thank You to Laloosh For This Useful Post:
ms3077 (08-02-2009)
 Old 07-31-2009, 10:26 PM   #19
martyxattack's Avatar
Posts: 923   (View Stats)
martyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the world
Groaned at 37 Times in 27 Posts
i agree with t3 flanges. or go all vband. that shit would be awesome. i hope to see this as the standard in the near future.
know your roll
martyxattack is offline   Reply With Quote
 Old 07-31-2009, 11:03 PM   #20
spiker98's Avatar
Posts: 427   (View Stats)
spiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the world
Good luck keeping it under 10K!
spiker98 is offline   Reply With Quote
 Old 08-01-2009, 11:38 AM   #21
flyrevs2's Avatar
No but it could be soon !
 Old 08-02-2009, 11:30 AM   #22
davesxx01's Avatar
Posts: 93   (View Stats)
davesxx01 is a name known to alldavesxx01 is a name known to alldavesxx01 is a name known to alldavesxx01 is a name known to alldavesxx01 is a name known to alldavesxx01 is a name known to all
Groaned at 27 Times in 4 Posts
Looks like you'll have a possible future wife to be proud of!
Keep us in the loop on your DCR build also!
Cars: 07 MS6, '10 3 GT, '05 G35 coupe.
davesxx01 is offline   Reply With Quote
 Old 08-02-2009, 07:07 PM   #23
NEC
While we're all offering up opinions... Why not a 3082
Garrett GT3082R GT3040R DBB Turbocharger Turbo .82 A/R T3 In 3" V-Band Exhaust Housing
Thats what I would have run if i didn't get a sick deal on a 3071. As it stands I'm planning to swap the garbage ATP hotside for something T3 and V-band.... with a 1.06 A/R. It'll flow and it'll spool... not like a 35r and not like a 3082, but it'll do enough for me.
 Old 08-02-2009, 07:21 PM   #24
Groans: 46
Everything I've read says that CHRA is poorly sized, and it's just as slow to spool as the gt35, but without the extra compressor flow...
 Old 08-02-2009, 08:33 PM   #25
NEC
Really? I haven't found much about it, except I know Blouch makes one too. I'd be curious to take a peek at any reviews you've found. Guess its a good thing I went ahead and grabbed a 3071?
 Old 10-11-2009, 12:30 AM   #26
samsel450r's Avatar
Posts: 350   (View Stats)
samsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the world
i vote for the gt3082R.
1999 Formula WS6 1 of 175 Made
Built 347 - Built 347, ARP everything, milled AFR 205's, PatG cam, ls6 Intake, MTI TB, Jethot LT's, True duals, 9inch rear 3.73's, built t56, NX kit W/NANO and more!
samsel450r is offline   Reply With Quote
The Following User Says Thank You to samsel450r For This Useful Post:
djuosnteisn (10-11-2009)
 Old 10-11-2009, 06:29 AM   #27
mz32quick's Avatar
Posts: 191   (View Stats)
mz32quick has a reputation beyond reputemz32quick has a reputation beyond reputemz32quick has a reputation beyond reputemz32quick has a reputation beyond reputemz32quick has a reputation beyond reputemz32quick has a reputation beyond reputemz32quick has a reputation beyond reputemz32quick has a reputation beyond reputemz32quick has a reputation beyond reputemz32quick has a reputation beyond reputemz32quick has a reputation beyond repute
Groaned at 9 Times in 6 Posts
Do they still have your car?
mz32quick is online now   Reply With Quote
 Old 10-11-2009, 06:52 AM   #28
RC08MS3's Avatar
Posts: 154   (View Stats)
RC08MS3 has much to be proud ofRC08MS3 has much to be proud ofRC08MS3 has much to be proud ofRC08MS3 has much to be proud ofRC08MS3 has much to be proud ofRC08MS3 has much to be proud ofRC08MS3 has much to be proud ofRC08MS3 has much to be proud ofRC08MS3 has much to be proud ofRC08MS3 has much to be proud of
everything iv'e read about the 3082 says if your gonna get it, just get the 35 because itl have the same spool time but the 35 will make more power
08' BM MS3: Corksport FMIC, CP-E Inlet, Cobb AP with ATR, Stainlessworks v2 Cat/catless DP combo, HKS SSQV, HKS CBE, CP-E HPFP,TWM STS, PTP Turbo fix(performance increase has yet TBD), SU rear mount, Medieval Tranny mount, Top speed passenger mount.
pshhhh... you wont!
RC08MS3 is offline   Reply With Quote
 Old 10-11-2009, 09:20 AM   #29
Always Blasted
DCLXVI's Avatar
Posts: 651   (View Stats)
DCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the world
Groans: 34
Groaned at 274 Times in 34 Posts
3071 will meet your DD needs, and wont put a 550hp claim over a 300hp car, like the 76 and 35r will. the 28 isnt meant for these cars built, it holds up fine with just bolt ons. built and with a 3071 you should have no problem staying safe at 325whp and with the ability for safe improvement. a 3076 would be my choice, because it spools only 500rpm later than the 71, which i consider that 500rpm is the big blow up range for these engines. boost and power later on, and less fear of popping driving around getting groceries. also, why dont you look into DCR building up your low end, so when you're driving with the regular old mzr out of boost, you're still making more power than before. all the mods for these cars so far seem to take away from the low end, and put all the power to the top end. which is good for FWD and its traction, but my 6 would appreciate the wheel spin down low
07 Speed 6 GT Cobb AP Stage 2+TIHSF+TMIC 93 Octane, ETS 3.5'' TMIC, Cobb Short Ram Intake, Cobb Turbo Inlet Pipe, Turbosmart Dual Port Blow Off Valve, SU Test Pipe, Custom CPE/Magnaflow Exhaust, Corksport Strut Brace, TWM Stage 2 Short Shifter, TWM Weighted Desert Eagle Shift Knob, AWR Transmission Mount, SU Base Bushings, SU Rear Motor Mount, Optima Yellowtop Battery, PIAA Plasma Ion Fogs, EBC Red Brakes, Denso ITV22s .28 Gap, Prosport Boost Gauge, Pirelli Sottozeros (WHAT SNOW??)
DCLXVI is offline   Reply With Quote
Engine/transmission build up stand? RocketScientist MazdaSpeed 3 - Engine, Transmission & Driveline 0 04-22-2009 09:15 PM
-+- Some accoutrements to an engine build -+- socks MazdaSpeed 3 - Engine, Transmission & Driveline 14 11-12-2008 06:18 PM
For the kids: Help Mr. Stephens build a ZR1 engine Haltech Automotive News 0 11-07-2008 03:50 PM
the proper way to build a ms3 engine? blackmsp3 487 MazdaSpeed 3 - Engine, Transmission & Driveline 11 10-19-2008 09:56 AM
Page generated in 0.48931 seconds with 39 queries
