![]() | | #121 | ![]() |
| Not Ranked : 0 score
__________________ | |
| The Following User Says Thank You to silvapain For This Useful Post: | jmhinkle (06-28-2012) |
![]() | | #122 | ![]() |
Groans: 793
__________________ ![]() ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals | |
![]() | | #123 | ![]() |
Rep Power: 7491 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,190
| Not Ranked : 0 score I agree that horsepowet doesnt break VVTs, its valve springs.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG |
| The Following 2 Users Say Thank You to 06Speed6 For This Useful Post: | djuosnteisn (06-28-2012), jmhinkle (06-28-2012) |
![]() | | #124 | ![]() |
Groans: 79
I don't think finding the rev limit will be the biggest issue for you, it'll be fueling the motor at such high rpms, and hoping the stiffer springs don't cause your keyless crank to slip timing.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com | |
| The Following 5 Users Say Thank You to djuosnteisn For This Useful Post: | Erich (06-28-2012), jmhinkle (06-28-2012), RaisedOnPunk (06-28-2012), silvapain (06-28-2012), Tokay444 (06-28-2012) |
![]() | | #125 | ![]() |
| 708 ![]() Join Date: May 2008 Location: Maple Valley, WA
Rep Power: 45886 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21,982
This. I have been running for close to a year with a 7500 (and at times 7700) RPM redline with stock springs and zero issues.
__________________ 2 years after hitting 700hp and still running strong. Happy to see others joining the club. ![]() | |
| The Following 2 Users Say Thank You to Erich For This Useful Post: | RaisedOnPunk (06-28-2012), silvapain (06-28-2012) |
![]() | | #126 | ![]() |
Groans: 79
| Not Ranked : 0 score Didn't you go to track on much lower power tune erich? I thought you were dailying at like 450 or something, didn't know it was 640 this whole time.
![]() | | #127 | ![]() |
| Not Ranked : 0 score My daily tune is 460hp (which is what I went to the track at) but after I let John take my car out (the night he ran the Camero) I left the 640hp tune on for a while. Not that it was really useful, but I wanted to see how things would hold up.
| The Following User Says Thank You to Erich For This Useful Post: | djuosnteisn (06-28-2012) |
![]() | | #128 | ![]() |
Groans: 79
| Not Ranked : 0 score Hahahaha, it would take a lot of work to make 640 useful. All i want on my 3 is 500 and call it a day.
![]() | | #129 | ![]() |
| Not Ranked : 0 score 4 lane freeway? Check No cars with in 100+ yards of me? Check Okay, I get to step on it. The 460hp tune is a great daily driver tune.
![]() | | #130 | ![]() |
![]() Join Date: Jun 2012 Location: Savannah, GA.
Rep Power: 0 ![]() Thanks: 3
![]() | | #131 | ![]() |
| Not Ranked : 0 score Waste of money in my opinion.
| The Following User Says Thank You to Erich For This Useful Post: | silvapain (06-28-2012) |
![]() | | #132 | ![]() |
| Not Ranked : 0 score Without cams its a waste.
![]() | | #133 | ![]() |
![]() Join Date: Jun 2009 Location: Old Bridge, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,044
Groans: 125
| Not Ranked : 0 score Although with cams it's gonna be fantastic |
| The Following User Says Thank You to TWOptSL0W For This Useful Post: | 06Speed6 (06-30-2012) |
![]() | | #134 | ![]() |
| Axle Breaker ![]() Join Date: Mar 2008 Location: Rio Rancho, NM
Rep Power: 4000 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,595
Groans: 162
| Not Ranked : 0 score just got my tracking number from Cox. I had been so busy ordering shit for the Tundra I forgot I ordered this. I couldn't figure out who Cox performance was for the life of me. Built motor should be come along nicely when all these parts start rolling in.
| The Following User Says Thank You to jmhinkle For This Useful Post: | djuosnteisn (07-12-2012) |
![]() | | #135 | ![]() |
| Not Ranked : 0 score Same here. They called me yesterday to say my VVT actuator was done, get my CC number, and I received a shipping notice later in the afternoon. Tapadatass
| The Following User Says Thank You to silvapain For This Useful Post: | jmhinkle (07-12-2012) |
![]() | | #136 | ![]() |
| Not Ranked : 0 score They just shipped it today, took about a month
![]() | | #137 | ![]() |
Groans: 125
| Not Ranked : 0 score i got mine a week ago |
![]() | | #138 | ![]() |
| Not Ranked : 0 score Damnit, they charge you $150?
| The Following User Says Thank You to 06Speed6 For This Useful Post: | jmhinkle (08-08-2012) |
![]() | | #139 | ![]() |
Groans: 125
| Not Ranked : 0 score yup and they also broke my first vvt core and then denied it so i had to send another one |
| The Following User Says Thank You to TWOptSL0W For This Useful Post: | 06Speed6 (08-09-2012) |
![]() | | #140 | ![]() |
Groans: 162
| Not Ranked : 0 score I had no problems. I think it was 3 weeks total for mine. I paid online and didn't pay the core charge. Shipped them my VVT with the order number or whatever. Got it back a few weeks later ready to go. They even shipped back the old cam washers in a ziplock that were still in it.
![]() | | #141 | ![]() |
| Bob Ross Fanclub ![]() Join Date: Jan 2009 Location: SEFL
Rep Power: 4333 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,534
__________________ ![]() | |
![]() | | #142 | ![]() |
Groans: 162
| Not Ranked : 0 score Everyone get their VVT? Just curious if anyone was still waiting.
![]() | | #143 | ![]() |
| Not Ranked : 0 score Mine is in the mail supposidly, it was probably shipped thursday or friday.
![]() | | #144 | ![]() |
![]() Join Date: Jun 2011 Location: Okinawa, Japan
Rep Power: 161 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8
(Thread Starter) | Not Ranked : 0 score Update.... I've had my DCR VVT on the car for over 2k miles now with no issues. Amazing how much more smooth the engine sounds under the hood, didn't know how bad the old VVT had went i guess. Took less than 3 weeks to get my VVT back when I made this thread. Glad mostly everyone is getting theirs back in a timely manner.
__________________ [FONT="Franklin Gothic Medium"]2007 MS3 // Cobb AP // Cobb SRI // SURE TIP // Forge BPV // ATP 3" Catless Downpipe // Custom Midpipe // Autotech Internals // JBR 88 RMM/TMM 80 PMM // Denso ITV22 // DCR VVT // Custom Head P & P // Wiseco 9:5 CR on Eagle Rods // Prosport Boost & Wideband Gauges // Rebuilt K04 // 20% Tint // H&R Sports // HID 9K Low / 6K Fogs // Engine built at IAG Performance, Westminster, MD // Stratified Tuned (partial due to engine noise = knock)[COLOR="Red"] |
![]() | | #145 | ![]() |
![]() Join Date: Jun 2011 Location: Conroe, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,698
Groaned at 42 Times in 15 Posts
| Not Ranked : 0 score .
__________________ GTX3071R EWG, DNP Tubular Manifold, SSP Ported/VTCS deleted intake manifold, DCR VVT Actuator, CP-E FMIC, Cobb AP, JBR 3.5" WP Intake ||| JBR 80 Duro RMM, JBR 80 Duro PSMM ||| CNT Racing Catless full 3" DP/TP, Speed Daddy 3" CBE ||| AEM Water/Methanol Kit, Autotech FP Internals, PTP Inj Seals, Synapse Engineering Bypass Valve, Matt Jackson map sensor harness, 3 Bar map sensor, Grimmspeed 3-port EBCS, NGK 1 Step Colder Plugs ||| Sure AGS 621G, Sure Shortcut, JBR Solid Base Bushings and Weight ||| AMR Engineering Coilovers, JBR Rear Sway, JBR Rear Camber Arms, XXR 527 18x8.75 +35 Chromium Black ||| CP-E Tow Plate, Rotella T6, FoMoCo XT-M5-QS, JBR OCC, JBR EGR Delete, JBR TB Gasket, JBR TIG and Coolant Bypass, EBC Redstuff. Build Complete!!!! |
![]() | | #146 | ![]() |
| Not Ranked : 0 score Mines been on order since the 10th Sent from my Galaxy Nexus using Tapatalk 2
![]() | | #147 | ![]() |
Groans: 79
I think easiest way to do it with motor in the car would be: - set motor to TDC using the SST on the crank weight. - lock timing chain guides in place through blind plugs on the front cover. - remove old VVT actuator. - Using the cam SST to hold cams in proper position, install new VVT actuator, and dress chain. Replace cam friction washer while you're at it. - remove bolts from blind plugs on front cover, and crank blind plug, etc... Theoretically, that should keep the motor in time, and avoid having to touch the crank bolt. It would be a much nicer alternative to having to pull the whole front cover in order to replace the crank friction washers, etc.
![]() | | #148 | ![]() |
| Not Ranked : 0 score Just FYI, the friction washer behind the VVT Actuator is supposed to be replaced when replacing the actuator itself. It's a one-time-use item like the crank washers. Tapadatass
| The Following 2 Users Say Thank You to silvapain For This Useful Post: | djuosnteisn (08-20-2012), jmhinkle (08-20-2012) |
![]() | | #149 | ![]() |
(Thread Starter) | Not Ranked : 0 score The current VVT was put on during the engine build, but I have done this all before with the engine in the car. If you follow the manual directions, using the crank lock and cam alignment tool, you can do it pretty easily. It describes the steps very well just as your steps. Good luck and double check everything as you are doing it. The last thing you want is for the timing to be messed up.
__________________ [FONT="Franklin Gothic Medium"]2007 MS3 // Cobb AP // Cobb SRI // SURE TIP // Forge BPV // ATP 3" Catless Downpipe // Custom Midpipe // Autotech Internals // JBR 88 RMM/TMM 80 PMM // Denso ITV22 // DCR VVT // Custom Head P & P // Wiseco 9:5 CR on Eagle Rods // Prosport Boost & Wideband Gauges // Rebuilt K04 // 20% Tint // H&R Sports // HID 9K Low / 6K Fogs // Engine built at IAG Performance, Westminster, MD // Stratified Tuned (partial due to engine noise = knock)[COLOR="Red"] | |
| The Following User Says Thank You to speed31982 For This Useful Post: | djuosnteisn (08-23-2012) |
![]() | | #150 | ![]() |
![]() Join Date: Mar 2012 Location: Middletown, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 84
Groaned at 7 Times in 5 Posts
| Not Ranked : 0 score You mention holding the guides in place through the blind plugs, can anyone give more information on how to do this exactly. I plan to replace my VVT tomorrow without pulling the cover so I need to know how to release teh tension on the chain then put the tension back on after. The manual says to "ratchet" the tensioner but it doesn't say how to "un" ratchet again. |
![]() | | #151 | ![]() |
| Not Ranked : 0 score I think its obvious once you see it, there is a little triangle piece at the top of the tensioner that is spring loaded, you turn it clockwise to unlock the tensioner then you take another screwdriver and move the arm to the left and while holding the arm with the screwdriver you tighten the bottom bolt to hold the arm in place. It can be done with one person but it would probably be easier with two.
![]() | | #152 | ![]() |
| Not Ranked : 0 score Well, I gave up after a lot of trying, I couldn't get to the arm to hold it back as I only took the top cover off, not teh timing cover. Anyway, I put it all back together and when I turn it over by hand the chain goes slack then when it a piston gets past TDC the chain tightens back up and theres a knock. Sounds like it comes from #1 intake cams everytime but it could be the chain tightening up suddenly. Any ideas ? I hope you're still online, I need the car tomorrow ! Could it be that the tensioner is locked in the unratcheted position, you said it was spring loaded so I would have thought not. The noise only happens on #1 intake and on EVERY piston going past TDC. I don't get it. Will the tensioner automatically retension the chain if I start the car ? Is this actually the VVT actuator rattle I hear ? Last edited by Mandinca; 08-26-2012 at 11:25 AM. Reason: MSF Database - Automerged Doublepost |
![]() | | #153 | ![]() |
| Not Ranked : 0 score When I watch carefully, right as the chain goes tight again and theres a knock the intake cams suddenly jerk round a bit faster than before then they go back to normal speed until theres another knock and they do it again. I'm really thinking this is the faulty actuator and that when I get oil pressure it will stop, I'm just reluctant to try to start it until I get a second opinion. Besides, if it was interference would I be able to get past TDC so easily ? Last edited by Mandinca; 08-26-2012 at 11:42 AM. Reason: MSF Database - Automerged Doublepost |
![]() | | #154 | ![]() |
| Banned ![]() ![]() Join Date: May 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groaned at 75 Times in 8 Posts
| Not Ranked : 0 score So how much hp do the OEM VVT Actuators start going out? Or what's causing them to fail when you have stock head? |
![]() | | #155 | ![]() |
(Thread Starter) | Not Ranked : 0 score Ok have you taken the vvt off yet? What the blind top blind plug is doing is not letting the chain guide move, because the tensioner is pushing on the guide. Are you at page 01-10b-6 of the manual? If the crank sst and the cam alignment sst are in place you can get the exhaust sprocket off, replace the vvt, then put the chain on the exhaust sprocket last as you tighten it down keeping all the timing right.
| The Following 2 Users Say Thank You to speed31982 For This Useful Post: | djuosnteisn (08-27-2012), Tokay444 (08-27-2012) |
![]() | | #156 | ![]() |
| Not Ranked : 0 score Speed, thanks but I had to get it all back together as I needed the car this morning. The knocking noise I heard when manually turning the engine over must have been the faulty VVT as I thought because the engine started as normal. One thing that is unusual is that at idle the engine is revving around 650 rpm and is almost stalling. Is there a manual idle that I may have disturbed that caused this, or maybe a hose not connected properly ? Back to the timing, I could only get about a half inch of slack in the chain with the ratchet off. I was looking at 01-10B-6 and using the wrench on the cast hex on the exhaust camshaft as described. I figured there wasn't enough slack and was worried that if I took the sprocket off the chain tensioner would go to full extension and I wouldn't be able to get the sprocket back on again without removing the timing cover. My concern was that I hadn't been able to lock the guide in place with the bolt in the upper plug. I assumed that if I had done it correctly there would be a lot more slack so I called Streetunit on Saturday morning and talked to one of their support guys. They confirmed that there should be more slack and it wasn't a good idea to remove the sprocket. So, the motor is back together and going to Mazda. I can't dedicate the time to trying again right now. Plus I have a pretty massive oil leak from somewhere around where the transmission bolts onto the motor. Dropped a dinner plate sized pool of oil on my garage floor while I was working on it on Saturday. I thought it was burning off through the turbo, maybe not.... I'll be sending your tools out sometime this week. Thanks for all your help though. I appreciate you trying to talk me through all of this. |
![]() | | #157 | ![]() |
| Not Ranked : 0 score About 1/2" is all the slack that there should be, you shouldnt be able to pick the chain up and move it off of the cam/sprocket. Iirc you shouldnt need to mess with removing the exhaust sprocket at all. Maybe I need to read through that section of the manual again.
![]() | | #158 | ![]() |
| Not Ranked : 0 score Maybe I had it right after all, I just didn't have the confidence to unbolt the intake camshaft in case the chain suddenly tightened leaving me with having to take all the pulleys off and the cover etc. I htink you have to remove the exhaust sprocket so you can get the chain off the top two sprockets completely. I could be wrong and I don't have the manual here. Anyway, it's all back together and I called Mazda to have them take care of it....pains me to do so. I do have another issue that came up when I put it back together. In my last message I said it was idling around 650 rpm. Well, driving home from work last night I noticed that it is getting through a lot of gas. I've done 60 miles since my last fill and the guage already reads 3/4. This morning I am up to about 110 miles and I'm alsmost showing 1/2 on the gauge. Before I pulled it apart 1/2 would be at around 180. That's a huge increase in fuel consumption. All I did was to remove the IC, the plugs, the cam cover and the CDFP along with all the hoses that are in the way. What could have happened to cause my idling/economy issues or is it just a side effect of the VVT getting worse ? |
![]() | | #159 | ![]() |
| Not Ranked : 0 score Well DCR just called a few minutes ago and left a voicemail saying that my DCR actuator was ready and shipped out and should be here in 4 days.
![]() | | #160 | ![]() |
![]() Join Date: Dec 2008 Location: Tempe, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
| Not Ranked : 0 score I'm sporting the DCR VVT as well and i've had it installed for over a year and have about 15-17,000 miles on it and no issues. I just bought a gtx3071r so hopefully with my newish timing chain and dcr vvt i'll be good to go!
__________________ Eric Schlaht - Arizona Phoenix Photographer http://www.esimaging.net - http://www.facebook.com/esimaging [SIGPIC][/SIGPIC] 2007 MS3 Sport, gtx3071r, Full-Race Exhaust Manifold, SP PNP Intake Manifold, SP 88mm Pistons 9:5:1, Manley H Beam Rods, 10mm H11 Head Studs, ARP Main Studs, 4" HTP TIP + Small Battery Tray, 3 Bar MAP, Grimmspeed ECBS, CP-E FMIC, CP-E DP, CP-E Nexus CBE, Tokay Injector Seals, CP-E RMM, SU PMM, TRZ TMM, PTP FP Internals, DCR VVT, JBrone Shift Plate, SU Shifter Bushings, HKS SSQV, ITV22, DIY Perm Plate with dual OCC, Corksport Radiator Shroud, Southbend Stage 3 Clutch, DO Stage 2 Meth D10, Evo X Wheels, 245/40-18 Nitto NT05, Koni Sports + H&R Springs **463whp/409lb-ft via Mustang Dyno as of 3/28/14** **9/19/13** Zoom Zoom Boom ** Currently Rebuilding with goal of 475whp **11/19/13** Forged engine built and started up the car for the first time, success! **3/28/14** Dyno results from build 463whp / 409lb-ft Mustang Dyno **6/24/15** Sold the Mazdaspeed 3 **7/4/15** Purchased 2015 F150 Ecoboost Lariat FX4 with Sport Package |
| The Following User Says Thank You to Matrix311 For This Useful Post: | edowney4711 (07-17-2013) |
| How-To: VVT Actuator Swap | Chimmike | MazdaSpeed 3 - How-To's | 13 | 02-11-2016 10:34 PM |
| VVT Actuator | xhymer | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 36 | 06-25-2014 11:17 PM |
| VVT Actuator Help | nkornfender | MazdaSpeed 6 - Engine, Transmission & Driveline | 8 | 10-26-2011 06:48 PM |
| vvt actuator replacement | seanmiller09 | MazdaSpeed 3 - Engine, Transmission & Driveline | 3 | 07-12-2010 03:10 AM |
| Forge actuator | bbogue4 | Mazdaspeed3/6 General Discussion | 9 | 03-25-2009 03:22 PM |
