Like Tree15Likes
 Old 11-18-2011, 07:00 AM   #1
Atomic41's Avatar
Posts: 1,174   (View Stats)
Atomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond repute
Groaned at 38 Times in 26 Posts
Default Difference between JBR and SURE TIG
Do you really know difference between this two ?
Why SURE is a little bit higher in price ?
Both are great quality ?
Thanks
2008 MAZDASPEED3 Black
Stratified Tuned / Stage 2
Atomic41 is offline
 Old 11-18-2011, 07:25 AM   #2
Ckmazdaspeed3's Avatar
Posts: 2,077   (View Stats)
Groans: 134
Nothing except price and I'm sure the sure comes in a big stupid box or something.
Let me make this easy for you: JBR>sure UNLESS u like pretty boxes and clever names
Ckmazdaspeed3 is offline
The Following User Says Thank You to Ckmazdaspeed3 For This Useful Post:
m249saw (11-20-2011)
 Old 11-18-2011, 07:46 AM   #3
Atomic41's Avatar
It's the same spec for both ?
same material and same thickness ?
Atomic41 is offline
 Old 11-18-2011, 09:12 AM   #4
JohnMS3's Avatar
Posts: 754   (View Stats)
JohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the world
same material but you have the option of getting a thicker gasket at sure which would be twice the thickness.
i got the jbr tb tig w/ collant bypass. that combo dropped bats by 10* and i should have done it a long time ago.
-John
| Cobb AP | Cobb SRI/TIP | CXRacing/Godspeed FMIC | AQ Motorsports downpipe | Mazdaspeed CBE | Autotech HPFP internals | Koni Yellows | Eibach Prokit | Progress RSB | Mazdaspeed camber arms | CPE RMM | TWM shortshifter/bushings | Redlinegoods shifter/e-brake boots | Defi Red Racer boost gauge | RPM ventpod | OEM RX8 wheels | Yokohama S-drive 245/40/18 | Volt 4300K HID | Ho-en yellow fogs | Mazda5 rear rotors | Dual Fiamm horns |
JohnMS3 is offline
The Following 2 Users Say Thank You to JohnMS3 For This Useful Post:
Ckmazdaspeed3 (11-18-2011), JBR (11-18-2011)
 Old 11-18-2011, 09:24 AM   #5
Atomic41's Avatar
Thanks a lot for your answer !
Atomic41 is offline
 Old 11-18-2011, 09:26 AM   #6
Pendarus's Avatar
Posts: 165   (View Stats)
Pendarus is the leader of the worldPendarus is the leader of the worldPendarus is the leader of the worldPendarus is the leader of the worldPendarus is the leader of the worldPendarus is the leader of the worldPendarus is the leader of the worldPendarus is the leader of the worldPendarus is the leader of the worldPendarus is the leader of the worldPendarus is the leader of the world
Groans: 52
It is the same material, but different thickness. SURE is thicker, but you have to be careful when installing it because there have been some cases of cracked manifolds because of the larger offset. Some bolt holes get misaligned and when you torque the shit down it can cause too much stress on some very weak points in the manifold and you end up with a very expensive mistake.
As far as I know people using the thinner JBR gasket have not had this problem, but search just to be safe. You can also order multiples of the JBR gasket and stack them if you want a larger thickness, but again you get into the bolt misalignment problem.
Pendarus is offline
 Old 11-18-2011, 09:31 AM   #7
Travis's Avatar
Posts: 2,296   (View Stats)
Travis is the leader of the worldTravis is the leader of the worldTravis is the leader of the worldTravis is the leader of the worldTravis is the leader of the worldTravis is the leader of the worldTravis is the leader of the worldTravis is the leader of the worldTravis is the leader of the worldTravis is the leader of the worldTravis is the leader of the world
Groaned at 29 Times in 12 Posts
Sure is for people who are attracted to street unit parts in an over priced faggot box.
1993 Mazda RX7 RHD Time Attack Build 2012 - On-going
2005 Mazdaspeed Miata - #1,116 - 15x8 949 racing 6UL, Bridgestone RE-11, Flyin Miata Intake kit, Ebay FMIC, Ebay DP, Flyin miata cat-back, flyin miata 02 modifier - 2014 - On-going
2011 Mazdaspeed 3 Feb 2011 - June 2014
Travis is offline
The Following 3 Users Say Thank You to Travis For This Useful Post:
InFeXIoN (11-18-2011), JBR (11-18-2011), KevMS6 (01-19-2013)
 Old 11-18-2011, 09:32 AM   #8
Atomic41's Avatar
SO JBR FTW ?
Atomic41 is offline
The Following 3 Users Say Thank You to Atomic41 For This Useful Post:
JBR (11-18-2011), m249saw (11-20-2011), Travis (11-18-2011)
 Old 11-18-2011, 11:38 AM   #9
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
Correction..... JBR FTMFW!!!!
TEAM LUXURY
Sid3wayS is offline
The Following User Says Thank You to Sid3wayS For This Useful Post:
JBR (11-18-2011)
 Old 11-18-2011, 11:52 AM   #10
MarkyMark's Avatar
Posts: 1,624   (View Stats)
MarkyMark has disabled reputation
Groans: 62
Groaned at 156 Times in 148 Posts
LOL, travis. Problem?
Correction, thin black envelope.
Despite what everyone thinks, our "fancy" packaging is not very expensive at all. Plus we don't "upcharge" because we treat you to a nice visual experience when you open the box.
Do we think our product is worth more because of the packaging? C'mon dudes, we aren't idiots.
Ck, let me put it to you like this.
You spend $400 for a phone, it comes nicely and neatly packaged from Apple. Feels good right? What should be different about your $135 engine mount or your $200 intake? Would you be mad if your new iPhone came in a box wrapped in brown paper with the instructions and accessories in a ziplock bag? Maybe, maybe not.
It doesn't feel very good for us when we put a lot of effort into our products AND the way they are displayed to you only to have you pull down your pants and take a shit on it every chance you guys get.
Bucker and J-Liss like this.
MarkyMark is offline
The Following 17 Users Say Thank You to MarkyMark For This Useful Post:
06Speed6 (11-19-2011), ak_spray (11-18-2011), bayarea_pat (11-18-2011), breakfstincluded (11-18-2011), Bucker (11-20-2011), DONOTBUGME (11-18-2011), Geo13 (11-18-2011), Grab21 (12-03-2011), i8urgti (11-20-2011), J-Liss (11-20-2011), JohnMS3 (11-18-2011), nycMS3 (04-30-2012), Poohster (11-20-2011), Rich-PMS (11-19-2011), Shin Gouki (11-20-2011), SLOWHATCH (11-20-2011), socks (11-20-2011)
 Old 11-18-2011, 12:02 PM   #11
Stealth01's Avatar
Posts: 6,910   (View Stats)
Stealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the world
Groans: 201
Groaned at 164 Times in 103 Posts
The SURE TIG comes in two thicknesses, I believe, while the JBR one comes in one thickness, but is stackable to an extent.
Both come with excellent customer service, lifetime guarantees, etc. ANd yes, SURE's comes in a nice black sleeve/envelope.
Can't speak to quality of the JBR part, but generally his stuff is very good. I have the SURE TIG, but lack the balls to install it, so it sits.
Stealth01
2006 Mazdaspeed6 GT
Black Cherry Mica, Two-tone Leather interior, Sunroof, Bose
SURE Full3 Aeros ID300 | SURE Shortcut | SURE Countershift | SURE Anchors | SURE AGS Atom Shift Knob | SURE Torque R6 RMM | SURE Ventus in Hybrid Mode | SURE Dreadnaught | SURE Juggernaught | SURE Flow M6 TP | SURE Charge Tubes | SURE Return | SURE S6 Side Motor Mounts | SURE Breather Line | Hawk HPS F/R Brake Pads | StopTech F/R Rotors | Technafit SS BL | Technafit SS Clutch Line | Primewell PZ900 Tires (blech) | Red LED Dome & Door Lights | O-series Stubby Antenna | Cobb AP | ACT 6 Puck Clutch w/Prolite FW | Autolite XP Plugs (One Step Colder) | Whistler Pro-78SE Hard-wired | STRATIFIED Tuned by Lex | COMING SOON: Autotechs | SURE TIG
Read my stories: https://www.smashwords.com/books/view/55318
Stealth01 is offline
The Following 2 Users Say Thank You to Stealth01 For This Useful Post:
breakfstincluded (11-18-2011), Geo13 (11-18-2011)
 Old 11-18-2011, 12:04 PM   #12
speeed's Avatar
Posts: 2,999   (View Stats)
speeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the world
Groaned at 50 Times in 17 Posts
JBR better...
2012 LSM MS3
Some mods, No list, too much "zapos".
speeed is offline
The Following User Says Thank You to speeed For This Useful Post:
JBR (11-18-2011)
 Old 11-18-2011, 12:05 PM   #13
f-castrillo's Avatar
Posts: 1,342   (View Stats)
Don't hate on the SURE packaging, I actually like it lol
f-castrillo is offline
The Following 2 Users Say Thank You to f-castrillo For This Useful Post:
NinjaT1985 (11-28-2011), socks (11-20-2011)
 Old 11-18-2011, 12:06 PM   #14
Stealth01's Avatar
Groans: 201
Originally Posted by speeed View Post
JBR better...
I think this is hard to say and probably completely objective unless a person has both and has used both.
And I doubt anyone's done that.
You can't go wrong with either, IMHO...and please install mine for me.
Oh, and one more thing: THe JBARONE is $5 cheaper, but it says you only get one gasket...it doesn't say how thick that gasket is. SO there may be a need to buy two to reach the same thickness as a SURE TIG, especially if you want the full thickness possible.
However...Jamie offers free shipping. SURE does not. However, StreetUnit.com does!
Bottom line: see what thickness you want and determine which one is a better deal based on the final cost. QUality's probably about the same.
Stealth01
2006 Mazdaspeed6 GT
The Following 3 Users Say Thank You to Stealth01 For This Useful Post:
chuckms6 (11-20-2011), Geo13 (11-18-2011), Poohster (11-20-2011)
 Old 11-18-2011, 12:21 PM   #15
Stealth01's Avatar
Groans: 201
Originally Posted by jbarone View Post
The JBR gaskets haven't cracked any intake manifolds.
Neither have the SURE ones. Over-tightening the bolts HAS, however.
And the SURE guys won't call you a "gaping vagina" for criticizing their products. Why? They're professionals.
Stealth01
2006 Mazdaspeed6 GT
The Following 5 Users Say Thank You to Stealth01 For This Useful Post:
Geo13 (11-18-2011), laxplayermjd (11-18-2011), manelscout4life (11-20-2011), rfinkle2 (11-18-2011), SLOWHATCH (01-28-2012)
 Old 11-18-2011, 12:29 PM   #16
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
I have nice parts that I ordered from both companies.
I like Sure's packaging especially if it does not increase cost.
That being said, as long as the product performs, I would buy it if it was shipped wrapped in newspaper.
rfinkle2 is offline
The Following 10 Users Say Thank You to rfinkle2 For This Useful Post:
Don06speed6 (11-18-2011), Geo13 (11-18-2011), greenespeed (11-18-2011), m249saw (11-20-2011), Poohster (11-20-2011), Sid3wayS (11-18-2011), skeurton (11-18-2011), skiptowncat (11-18-2011), SLOWHATCH (11-20-2011), Stealth01 (11-18-2011)
 Old 11-18-2011, 12:34 PM   #17
Stealth01's Avatar
Groans: 201
In that case, I have this newspaper I want to sell you....it'll come wrapped....
Stealth01
2006 Mazdaspeed6 GT
The Following 4 Users Say Thank You to Stealth01 For This Useful Post:
Abu Zib (11-18-2011), myt_tuf1 (11-21-2011), rfinkle2 (11-18-2011), Travis (11-18-2011)
 Old 11-18-2011, 01:25 PM   #18
Travis's Avatar
No problem, simply encouraging you to provide Said gas monies for cool meet and part testing.
To be very honest I know nobody that has used any gaskets from either company. Just figured you'd find your way here. I have read about multiple cracks though with the sure TIG.
Travis is offline
 Old 11-18-2011, 01:37 PM   #19
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
yea, i support your efforts to use nice packaging. i also think it's fun to mock it time to time because it is over the top. of course, some people have to be the biggest and loudest at it.
that said, i would not buy any of your products because i do not see the value at your prices.
that said, that said, i don't really buy any parts b/c i'm poor. and i also buy used when possible, thusly negating some of the initial cost.
it's fun to do bad things
jack_hammer is offline
The Following 2 Users Say Thank You to jack_hammer For This Useful Post:
Abu Zib (11-18-2011), Travis (11-18-2011)
 Old 11-18-2011, 01:52 PM   #20
rfinkle2's Avatar
Groans: 298
Where you happy with the packaging your hypertech came in?
rfinkle2 is offline
DONOTBUGME (11-18-2011), jack_hammer (11-18-2011)
 Old 11-18-2011, 05:06 PM   #21
Groans: 549
where i happy? are you trying to say "were you happy"? maybe everyone hates you because you don't speak english properly and it's all just a simple misunderstanding?
anyway, i'm touched that you've decided to troll me.
The Following User Says Thank You to jack_hammer For This Useful Post:
 Old 11-18-2011, 05:33 PM   #22
Geo13's Avatar
Posts: 856   (View Stats)
Geo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the world
Groans: 107
Groaned at 8 Times in 7 Posts
Real difference is INSTALL INTRUCTIONS!!!
I got a GREAT deal on my SURE (IM) TIG (thanks @rfinkle2) the only reason I didn't crack anything is I used JBR Instructions from the JBR TIG (IM & TB) that I helped @skeurton install.
If Jamie hadn't provided those with his product I'm 'SURE' some people would have been pissing in his soup also.....remember TIG's don't crack manifolds people do!
rfinkle2 and skeurton like this.
SPONSORED BY MY WIFE- 2010 Mazdaspeed3 Black Mica (DeadPool): COBB AP Stage 2+(Custom skeurHYPNOTICton Tune), JBR TRILOGY 88D DogBone, 70D TMM & PMM, RSB, OCC, EGR Block Off, Mudflaps, TURBOSMART 50/50 BOV, Tanabe Strut Tower Bar, Moddiction Anvil, TWM Full Replacement Shifter, Fortune Auto 500 Coilovers, SPC Adjustable Camber Arms, Autotech Internals, Denso ITV24, ETS TMIC, UR Catted Down Pipe & Resonated Test Pipe, Corksport 3" Power Series Intake, CBE, GrimmSpeed 3 Port EBCS, Proto Tuning AP Holder, ProSport EVO Boost & AFR Gauge, Ultragauge Classic, Block8Head Dual Vent Pod, DDM Lows: 35w/6K & Fogs: 35w/3k HIDs, Headlight Armor Yellow Fog Overlays, some SURE stuff...still iNATORva
2 Reckless By Speed + 3 Speeding = Mazdaspeed3 (no more parts and a pissed off wife)
Geo13 is offline
The Following 3 Users Say Thank You to Geo13 For This Useful Post:
JBR (11-19-2011), rfinkle2 (11-18-2011), skeurton (11-18-2011)
 Old 11-18-2011, 05:38 PM   #23
rfinkle2's Avatar
Groans: 298
Originally Posted by broncojd78 View Post
yea i support your efforts to use nice packaging. i also think it's fun to mock it time to time because it is over the top. of course, some people have to be the biggest and loudest at it.
The grammar police need policing.
Maybe.
Everyone hates me?
m249saw likes this.
rfinkle2 is offline
 Old 11-18-2011, 05:48 PM   #24
Geo13's Avatar
Groans: 107
^^^ Maybe everyone hates you cause your so fucking helpful??
Geo13 is offline
The Following User Says Thank You to Geo13 For This Useful Post:
rfinkle2 (11-19-2011)
 Old 11-18-2011, 05:50 PM   #25
rfinkle2's Avatar
Groans: 298
Bronco insists on telling me I'm hated.
LOL!
rfinkle2 is offline
 Old 11-18-2011, 05:56 PM   #26
Nataphen's Avatar
Posts: 2,704   (View Stats)
Groans: 31
You are only supposed to tighten IM bolts to 19-25ish ft-lbs IIRC, or anything going into aluminum. I doubt that you'd crack anything as long as you threaded the bolts in lightly for a few turns, then used a tq wrench for final tightening in the correct cross pattern. I helped @JacksonMS30 intall one of, if not, THE first customer Sure TIG. We knew nothing of IM issues at that point, but we retightened the IM bolts CORRECTLY. That's the main problem with most issues, I'm sure.
I love you too, Jamie, just trying to diffuse misinformation. JBR and Sure make good products.
Stealth01, rfinkle2 and Geo13 like this.
06 BM MS6=stock (totaled)
13 5.0
Wife's 13 Focus ST
Nataphen is offline
The Following 4 Users Say Thank You to Nataphen For This Useful Post:
Geo13 (11-18-2011), JacksonMS30 (11-20-2011), rfinkle2 (11-18-2011), Stealth01 (11-18-2011)
 Old 11-18-2011, 05:58 PM   #27
radbrad's Avatar
Posts: 538   (View Stats)
radbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the world
From my experiences, I like both companies. JBR is my go to 1st guy. Top quality at a great price. But for things jbr does not have, sure makes awesome stuff too. Sure is a little more expensive and that is exactly why I went with the jbr shift weight, jbr tig, and the jbr egr block off last night. Its the same stuff, just better priced + ordered at 10pm, and had tracking# by 8am. I bet my stuff will be at my door in 2 more days. That my .02 cents
07Speed3
TWM STS || Forge BPVv1 || Sure RMM || Cobb SRI || CNT DP || AP || Autotech || ITV22 || COBB/TR8L FMIC || JBR TB&IM TIG || HTP TIP || JBR PMM&TMM || JBR EGR DELETE || Cobb CBE || SONIC COs || Perm Plate & OCC || JBR OCC || PnP IM || DO Meth Inj. ||
radbrad is offline
The Following 6 Users Say Thank You to radbrad For This Useful Post:
breakfstincluded (11-18-2011), Geo13 (11-18-2011), JBR (11-19-2011), Mizzle (11-20-2011), rfinkle2 (11-18-2011), Stealth01 (11-18-2011)
 Old 11-18-2011, 06:36 PM   #28
Travis's Avatar
@rfinkle2 I love you.
Travis is offline
 Old 11-18-2011, 06:51 PM   #29
Groans: 549
LOL!
no one says you're hated more than you.
Sent from my LG-MS690 using Tapatalk
 Old 11-18-2011, 06:56 PM   #30
Geo13's Avatar
Groans: 107
LOL!
@rfinkle2......I'd like you more if you sent out the TB TIG LoL.
Geo13 is offline
 Old 11-18-2011, 07:03 PM   #31
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
Groans: 52
Sure ftmtw ...
mark and su have always hooked me up and i have the sure tig on my car now.
and anyone can crack the IM when they are fucking tards and over torque it.
Nitr0EngiE is offline
The Following 4 Users Say Thank You to Nitr0EngiE For This Useful Post:
f-castrillo (11-18-2011), Geo13 (11-18-2011), MattJackson86 (11-20-2011), SLOWHATCH (01-28-2012)
 Old 11-18-2011, 07:04 PM   #32
Stealth01's Avatar
Groans: 201
Yes, Jamie's instructions are very, very good.
Stealth01
2006 Mazdaspeed6 GT
Geo13 (11-18-2011), rfinkle2 (11-19-2011)
 Old 11-18-2011, 07:08 PM   #33
Groans: 134
A phone and a car part are totally different. Yes, you are right, I do want my phone to come in a pretty box. But a car part? Fuck no. I want a brown box that looks industrial... I guess that JBRs usps boxes work too.
As gay as it sounds, a pretty box brings a feminine approach to a masculine hobby... that is my opinion and I'm going to share it every chance I get because I think nice boxes for car parts is just stupid. You don't and I'm sure that I am not going to change your opinion.
Other than the names, boxes and price points, I don't think I said anything bad. In fact, I don't think (I could be wrong) that I have ever commented on the quality of your products one way or the other... oh, I made fun of the worm clamps once.
 Old 11-18-2011, 07:12 PM   #34
Stealth01's Avatar
Groans: 201
Wow, really? You think a black box with foam inserts laser-cut to fit the part and protect it during shipping is feminine? I mean, certainly if my Dreadnaught came in a pretty pink box with flowers, rainbows, and unicorns, with pretty pastel tissue for packing, I'd find it feminine, but SURE's packing is top notch. Everything arrives undamaged and easy to find. No parts rolling around, no scratches...
I think you're just looking for SOMETHING to ding them on.
Stealth01
2006 Mazdaspeed6 GT
Geo13 (11-18-2011), i8urgti (11-20-2011), kngeducate (11-18-2011)
 Old 11-18-2011, 07:17 PM   #35
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
Groans: 261
I'll buy anything JBR makes. And so should you lol.
But Sure isn't bad at all.
I love white silicone. I also love the ones for my car.
breakfstincluded is offline
The Following User Says Thank You to breakfstincluded For This Useful Post:
Geo13 (11-18-2011)
 Old 11-18-2011, 07:19 PM   #36
Groans: 134
EDIT: I was too slow, this first response is to SURE fanboy stealth.
This coming from a SURE fanboy. LOL. Yes, I think so. Shit, the packaging is nicer than my $400 phone. And my car parts don't roll around. They come in bubble wrap, peanuts and newspaper.
The color and pattern are not what makes it feminine; it is the whole concept... Ok, not feminine, metro sexual. Whatever.
I'm sure that their parts perform fine I just don't like their marketing approach. If they make something that I need, I will rock it.
Last edited by Ckmazdaspeed3; 11-18-2011 at 07:20 PM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to Ckmazdaspeed3 For This Useful Post:
breakfstincluded (11-18-2011), Travis (11-18-2011)
 Old 11-18-2011, 07:29 PM   #37
Groans: 549
I don't think anyone says anything bad about the parts quality, except for the debacle when the aeros was first released.
I am surprised at how strong a response sure generates from using excessively elaborate packaging.
whatever.
Geo13 (11-18-2011)
 Old 11-18-2011, 07:31 PM   #38
Stealth01's Avatar
Groans: 201
LOL all right man, whatever floats your boat. I think you're putting way too much thought into the masculinity of car parts. Compensating?
Stealth01
2006 Mazdaspeed6 GT
The Following User Says Thank You to Stealth01 For This Useful Post:
 Old 11-18-2011, 07:41 PM   #39
Groans: 134
I drive a grocery getter, there is a lot to compensate for.
The Following 4 Users Say Thank You to Ckmazdaspeed3 For This Useful Post:
ASHMS3 (11-19-2011), Geo13 (11-18-2011), Stealth01 (11-18-2011), Travis (11-18-2011)
 Old 11-18-2011, 07:47 PM   #40
SleeperHatch's Avatar
Posts: 3,138   (View Stats)
SleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the world
Groans: 52
Groaned at 54 Times in 39 Posts
Stupid JBR Bandwagoners....SURE > JBR
Sent from my Epic Win Avatar
2009 CWP Speed3
SleeperHatch is offline
How Much Difference irishking03 MazdaSpeed 3/6 - ECU Computer Tuning 6 09-15-2011 09:05 AM
What a difference. Tokay444 MazdaSpeed 3/6 - Suspension & Brakes 47 07-02-2011 08:30 PM
DSC difference on vs off! Speedee3 MazdaSpeed 3 - Engine, Transmission & Driveline 7 12-09-2009 02:59 PM
Page generated in 0.59107 seconds with 37 queries
