 Old 04-09-2009, 10:07 AM   #1
Scottybones's Avatar
Posts: 10   (View Stats)
Scottybones will become famous soon enough
Default Different test pipes
Over at streetunit, the guys are complaining that the streetunit test pipe isn't lining up properly and it's making the install take that much longer. Is the TurboXS pipe doing the same thing? I noticed that the TurboXS is slanted and it looks like it has a flex pipe on it, so I would assume that fitment wouldn't be a problem.
Scottybones is offline   Reply With Quote
 Old 04-09-2009, 12:09 PM   #2
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
stock downpipe? stock CBE?
ive heard the SU one is best for an otherwise stock exhaust setup
 Old 04-09-2009, 01:04 PM   #3
C Notes
Cornerfreak's Avatar
Posts: 502   (View Stats)
Cornerfreak is the leader of the worldCornerfreak is the leader of the worldCornerfreak is the leader of the worldCornerfreak is the leader of the worldCornerfreak is the leader of the worldCornerfreak is the leader of the worldCornerfreak is the leader of the worldCornerfreak is the leader of the worldCornerfreak is the leader of the worldCornerfreak is the leader of the worldCornerfreak is the leader of the world
What he ^ said. I have the corksport and alignment was an issue at first but I fixed it now. If I had to do it again I would probably go SU for a stock setup.
You want Nator?
Cornerfreak is offline   Reply With Quote
 Old 04-09-2009, 01:19 PM   #4
aspiring turbo guru
08_ms3_gt's Avatar
Posts: 1,040   (View Stats)
SU test pipe seems to be well-received.
i don't have a TP but i've been considering it periodically. the SU is prolly the one i'd go for. i haven't pulled the trigger b/c of smoking turbo concerns as well as there's no concrete verdict as to whether the noise/power improvements are worthwhile.
 Old 04-09-2009, 02:16 PM   #5
martyxattack's Avatar
Posts: 924   (View Stats)
martyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the world
Groaned at 37 Times in 27 Posts
yea i havent really heard any complaints at all about the SU test pipe. its what i have.
know your roll
martyxattack is offline   Reply With Quote
The Following User Says Thank You to martyxattack For This Useful Post:
phillyb (04-10-2009)
 Old 04-09-2009, 02:33 PM   #6
motocrosser614's Avatar
Posts: 687   (View Stats)
motocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the world
Groaned at 15 Times in 14 Posts
SU testpipe is worth every penny period. Alingnment is perfect as well as quality and finish of the welds. I dont have a jack or jack stands so i paid 10 bucks to have a local shop throw it up there and in under 2 minutes i was off the lift. Total i spent was worth it and the power i now have after 3k, noise is noticed sometime on decel and upon startup but buy a catback if you want noise. Turbos dont smoke with testpipes only downpipes i thought?
If it smokes take it off and to the dealer for a turbo swap
motocrosser614 is offline   Reply With Quote
 Old 04-09-2009, 05:05 PM   #7
Speed3FTW's Avatar
Posts: 161   (View Stats)
Speed3FTW is a splendid one to beholdSpeed3FTW is a splendid one to beholdSpeed3FTW is a splendid one to beholdSpeed3FTW is a splendid one to beholdSpeed3FTW is a splendid one to beholdSpeed3FTW is a splendid one to beholdSpeed3FTW is a splendid one to behold
I've had my SU test pipe on for some time now.
The install was a breeze, fitment was spot on. The hp/tq gains and extra volume were there, but don't expect a night and day difference. It definitely is a mod you should consider if you aren't planning on doing a full DP. The cost/hp ratio is damned good with a test pipe.
True Red 2008 MS3 GT, CPE Xcel CAI, SU Test Pipe/2nd cat delete, SU 62A Rear Motor Mount, SU Shifter Bushings, Cobb Shifter Counter-weight, Dashhawk on CPE mount
Speed3FTW is offline   Reply With Quote
 Old 04-09-2009, 05:17 PM   #8
SharkDiver's Avatar
Posts: 969   (View Stats)
SharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the world
Groaned at 7 Times in 6 Posts
I think a test pipe and intake are 2 of the easiest and greatest mods for the money on this car. I have a TXS TP with a TXS Dp so I dont have a issue but some have had problems with the txs test pipe leaking with the stock Dp. The SU TP seems like a great product and worth the money. Some must have mods for this car are a Testpipe,Intake,rear motor mount and solid shifter bushings and maybe a new bpv but thats just a maybe. All of those are easy to remove for dealer visits and will give you some nice power gains..
enjoy
Pauter rods,Cp pistons 9.5:1 @ .020 over,ARP head & main studs,DNP ceramic coated exhaust mani.,TXS Dp,TXS Tp with high flow cat,PG reworked turbo,Cobb sri,Cobb fmic,Cobb Ap,Cobb inlet,HPFP,BSD,ACT street disk with light flywheel,TWM shifter bushing,rear MM,Oil CC and 1 step colder plugs and more
http://videos.streetfire.net/profile/SharkDiver.htm
http://www.youtube.com/user/sharkdiverjohn
SharkDiver is offline   Reply With Quote
 Old 04-09-2009, 05:31 PM   #9
AmillieMS6's Avatar
Posts: 1,700   (View Stats)
AmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the world
Groans: 365
Groaned at 594 Times in 575 Posts
tsx?
tp FTMFW
AmillieMS6 is offline   Reply With Quote
 Old 04-09-2009, 05:32 PM   #10
2008speed3's Avatar
Posts: 421   (View Stats)
2008speed3 is the leader of the world2008speed3 is the leader of the world2008speed3 is the leader of the world2008speed3 is the leader of the world2008speed3 is the leader of the world2008speed3 is the leader of the world2008speed3 is the leader of the world2008speed3 is the leader of the world2008speed3 is the leader of the world2008speed3 is the leader of the world2008speed3 is the leader of the world
Groans: 707
Groaned at 127 Times in 108 Posts
what type of alignment issues did you have with the corksport tp???
2008speed3 is offline   Reply With Quote
The Following User Says NO Thank You to 2008speed3 For This Un-useful Post:
 Old 04-09-2009, 05:34 PM   #11
SharkDiver's Avatar
Originally Posted by AmillieMS6 View Post
tsx?
tp FTMFW
TXS = Turbo XS
 Old 04-09-2009, 06:02 PM   #12
ozzmannt's Avatar
Posts: 167   (View Stats)
ozzmannt has much to be proud ofozzmannt has much to be proud ofozzmannt has much to be proud ofozzmannt has much to be proud ofozzmannt has much to be proud ofozzmannt has much to be proud ofozzmannt has much to be proud ofozzmannt has much to be proud ofozzmannt has much to be proud of
Bah just buy it. It really isn't a HUGE diff in power, but the sound and smoothness of HP is nice.
Also don't believe the b.s. of "exhaust upgrades make your turbo smoke" that's a bunch of bullshit. If you upgrade your exhaust and it smokes then u'r turbo was smoking before. The cat will do a good job of hiding the smoke.
07 Speed6 GT (Liquid Platinum Metallic) - 35/20% Tint
ozzmannt is offline   Reply With Quote
 Old 04-09-2009, 06:55 PM   #13
SharkDiver's Avatar
Im not so sure about that...Lots of people think these turbos need some back pressure and if you have no cats you have no back pressure or not enough.I dont think anyone has any hard core evidence on what is making the turbos smoke tho.
The Following User Says Thank You to SharkDiver For This Useful Post:
martyxattack (04-13-2009)
 Old 04-09-2009, 07:03 PM   #14
MarkyMark's Avatar
Posts: 1,624   (View Stats)
MarkyMark has disabled reputation
Groans: 62
Groaned at 156 Times in 148 Posts
I've had a couple people not follow the directions and call us up pissed off that the pipe doesn't fit, when I've had a 100% success rate. Turns out they put it on backwards.
MarkyMark is offline   Reply With Quote
The Following User Says Thank You to MarkyMark For This Useful Post:
 Old 04-09-2009, 07:34 PM   #15
94jedi's Avatar
Posts: 2,200   (View Stats)
94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world
Groaned at 7 Times in 5 Posts
holy crap LMAO!!
BONE STOCK.
94jedi is offline   Reply With Quote
 Old 04-09-2009, 07:47 PM   #16
AmillieMS6's Avatar
Groans: 365
hilarious hahahah
btw i might order one from you pretty soon mark
be ready
 Old 04-09-2009, 07:55 PM   #17
MarkyMark's Avatar
Groans: 62
hilarious hahahah
be ready
you got my number dawg.
 Old 04-09-2009, 07:56 PM   #18
AmillieMS6's Avatar
Groans: 365
fshoooo what am i looking at shipment?
 Old 04-10-2009, 12:07 PM   #19
TongMan's Avatar
Posts: 444   (View Stats)
TongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond repute
why is the streetunit test pipe more expensive than the corksport by $50?
2009 Crystal White Pearl Mazdaspeed3 Sport **SOLD**
2010 Monterey Blue Nissan 370z Base w/ Sport Package 6MT
TongMan is offline   Reply With Quote
 Old 04-10-2009, 12:42 PM   #20
MarkyMark's Avatar
Groans: 62
cuz ours kicks ass.
 Old 04-10-2009, 12:53 PM   #21
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
su race pipe is the best!
 Old 04-10-2009, 01:00 PM   #22
TongMan's Avatar
i'm sure it is, but something more specific? I'm looking into a test pipe and narrowing down my options trying to figure if it is worth paying $50 more for the same pipe.
 Old 04-10-2009, 01:02 PM   #23
phillyb's Avatar
Groans: 1,940
wut?
it fits. you won't be able to find a txs pipe easily. i don't know anything about the sls and the corksport leaks.
 Old 04-10-2009, 01:43 PM   #24
ozzmannt's Avatar
There is no proof. I still call bullshit on that, no turbo needs back pressure that I've seen. Who started saying the exhaust upgrades cause smoke anyways? If the turbo is going to smoke, it's going to smoke. Only thing you are doing is hiding it with a restrictive exhaust system. I also say the turbos are shitty anyways if that helps.
LOL that's great, those weren't just packing materials? Opps
BTW for anyone ordering the test pipe make you get it from StreetUnit, mine fit great and was at my door in no time flat. Thanks Mark and/or whoever did my order! Also free plug for streetunit.
 Old 04-10-2009, 03:54 PM   #25
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
I just purchased a Turbo XS test pipe...Purchased the last one the company had. Hopefully it all works out
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 04-12-2009, 10:55 AM   #26
Frequentflyer's Avatar
Posts: 1,959   (View Stats)
So does the CS pipe really have fitment issues? Do they know about it/done anything about it?
 Old 04-12-2009, 03:56 PM   #27
94jedi's Avatar
After I sell my CS DP/RP combo, I might come back for an SU test pipe...The CS stuff fits/works great, I just need to free up some money quick.
BONE STOCK.
 Old 04-13-2009, 07:53 AM   #28
TongMan's Avatar
^^^ Why are you getting rid of your downpipe/racepipe combo?
 Old 04-13-2009, 08:39 AM   #29
94jedi's Avatar
to be totally honest? I need money for rings/bumper plates/kettle bells. I'm building a home gym and I need to liquidate and get some cash. don't get me wrong, the CS DP combo is awesome. Alot of people agree that it makes the most power out of all the setups- of course, we're only talking a 5 +/- HP variance. Ask palerider. He'll tell you. It's a great setup...I just need money and I have too many hobbies lol.
BONE STOCK.
 Old 04-13-2009, 02:05 PM   #30
C Notes
CS pipe just needs some masaging to seal right. Sometimes the flange between the RP/CBE dont align properly. Make sure you use the right hardware and assemble loose first. Tighten the cbe end first and the dp side. After that mine has been flawless. Initial install had a small minor leak but still anoying.
You want Nator?
 Old 04-13-2009, 04:26 PM   #31
TongMan's Avatar
ok, so I'm not looking to upgrade the downpipe, just the testpipe, so my best bet would be for the Corksport or the Streetunit?
Downpipe install takes too long and is difficult to remove and replace when dealership visits occur.
 Old 04-13-2009, 05:45 PM   #32
AmillieMS6's Avatar
Groans: 365
yup just get tp.. i would prefer su i havent heard any bad feedback about their product
 Old 04-13-2009, 06:00 PM   #33
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
has anyone seen the speedaction tp? it looks identical to street unit's but sells for $170... http://www.speedaction.net/tema3tu.html
 Old 04-13-2009, 06:50 PM   #34
AmillieMS6's Avatar
Groans: 365
yea i wanna know.. ive never heard of this site before and wanna know if anyone has ever used this TP
Testpipe Mazdaspeed 6 Turbo
 Old 04-13-2009, 11:07 PM   #35
taf0422's Avatar
Groans: 192
hmm I'd be interested in that too
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 04-13-2009, 11:20 PM   #36
C Notes
If had to do it over I'd probably go with SU. Mark get's his parts done right first time around. His prices are usually free shipping too so take that in account.
You want Nator?
 Old 04-14-2009, 05:03 PM   #37
AmillieMS6's Avatar
Groans: 365
so anyone?
 Old 04-14-2009, 05:10 PM   #38
wassup61's Avatar
Posts: 1,232   (View Stats)
Groans: 29
About 2 inches to short and not worth it. You should drop by PG sometime and we can nail down a mod plan.
Jeff at PG
All wagon, No traction
 Old 04-14-2009, 05:12 PM   #39
AmillieMS6's Avatar
Groans: 365
Jeff at PG
i should :phillyb:
 Old 04-14-2009, 06:07 PM   #40
patrick failman
Groans: 74
Jeff at PG
was actually hoping for su mark to confirm whether speedaction has copied his test pipe since his fits the best based on forum feedback.
jeff, let me know when pg's corksport and sls test pipes fit as well as su's (i.e. no leak videos).
i have had wonderful buying experiences from both you guys (su & pg), but (a) i'm not going to overpay and (2) i'm not buying something that doesn't fit.
Any pictures of powder coated intercooler pipes? Anklh MazdaSpeed 3/6 - Appearance 3 08-09-2008 05:13 PM
race pipes coming in? ms3jake Mazdaspeed3/6 General Discussion 43 06-24-2008 05:48 PM
First Test: 2009 Nissan GT-R Track Test Video Haltech Automotive News 0 04-02-2008 05:50 PM
Page generated in 0.53755 seconds with 39 queries
