![]() | | #41 | ![]() |
| Nishan ![]() Join Date: Apr 2012
Rep Power: 9816 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,290
(Thread Starter) | Not Ranked : 0 score thats genious! be back later !
__________________ www.tunedbynishan.com |
| The Following User Says Thank You to ms3blackmica For This Useful Post: | mr.speedy3 (09-28-2013) |
![]() | | #42 | ![]() |
| Not Ranked : 0 score Diesels also always have pretty high velocity over the intake valves because they don't have throttles so it's tougher for gunk to settle. I don't think increasing head temperature will clean them without warping the head but it would probably help keep them clean in the first place. You might be able to make a map that would clean them but it needs to get up to ~900*F to do it. Would need to idle at 3000 to get oil pressure up, run maximum VVT and as retarded timing as you can and keep it running. Zigatapatalka
| The Following 2 Users Say Thank You to Ziggo For This Useful Post: | Easter Bunny (12-19-2012), Lex (11-06-2012) |
![]() | | #43 | ![]() |
![]() Join Date: Oct 2009 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,684
| Not Ranked : 0 score Did you do the DIY method (HOW TO: Clean your valves - easy & cheap) or some other method?
__________________ ● 2011 Jaguar XFR ● Full Resonator Delete ● Mina Cat-Back Exhaust ● Staggered Giovanna Portofinos ● ● 2010 Mazdaspeed 3 - GONE ● |
![]() | | #44 | ![]() |
Although i plan to invest in one for next time i clean. I just used B12 chemtool with my own little process, I mentioned it a few posts back
i'd much rather close the valve mechanically, clean & remove the gunk
__________________ www.tunedbynishan.com | ||
![]() | | #45 | ![]() |
And partially plug the exhaust and watch the exh manifold get cherry ![]() Once you burn the stuff to a crisp it can safely be ingested in the combustion chamber. When it's unburned and hard is when it causes damage.
| The Following 3 Users Say Thank You to Lex For This Useful Post: |
![]() | | #46 | ![]() |
![]() Join Date: Jul 2011 Location: Miami Beach, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,829
Groans: 55
@tddvrrn; I was reading in another thread that the metal hairs from the brush can fall while cleaning the valves. Did you encounter this problem??
__________________ 08 Black Mica Ms3~full bolt ons/Nishan Tuned-Sold NATOR FL | |
![]() | | #47 | ![]() |
In regards to the brushes, yes the thin wires of metal will come off of the brush when you start scrubbing hard. I tried it on one valve and many wires were falling off. I shop vac'd it up and blasted with compressed air. I really did not like seeing that, so i did away with the brushes. Plus they really did not do much...This gunk gets hard and needs to be scraped/picked off.
| The Following User Says Thank You to ms3blackmica For This Useful Post: | Ms3_Miami (11-06-2012) |
![]() | | #48 | ![]() |
Groans: 55
![]() | | #49 | ![]() |
![]() Join Date: Nov 2010 Location: northwest arkansas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,067
Groans: 103
| Not Ranked : 0 score @Ms3_Miami; i did not have any problems with wires coming off. i used a gun cleaning kit and those brushes were burly as fuck. plus, i vacuumed the shit out of the runners 5,000 times, so i wasn't too worried.
__________________ 2008 ms3 mit: hypertech tune, pg sri, corksport tip, jbr(80 tmm, 88 rmm, 80 pmm), jbarone bushings + heavy shift knob, diy sts, sure ssp, sensen shocks, jbr rsb, ford transfluid, aura 5 channel amp, jbl gt speakers, 6" bazooka sub, diy mudflaps, DDM 3000k HID fog kit, 6000k lows [SIGPIC][/SIGPIC] ![]() |
| The Following User Says Thank You to tddvrrn For This Useful Post: | Ms3_Miami (11-06-2012) |
![]() | | #50 | ![]() |
![]() Join Date: Jul 2008 Location: Ottawa, ON Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,005
| Not Ranked : 0 score Yeah I had an engine cleaning kit instead of a gun cleaning kit and it worked great. In fact I bought this kit: 20 PC Engine Block Cleaning Brush Kit Brass Steel Nylon | eBay That said, what ms3blackmica says is true.. the brushes only do so much and I had more success using picks and lightly scraping them. That would break away the larger pieces and I would spray and vacuum them up.. finally once the runner was dry spray some compressed air. As for cranking the engine to TDC... I just took all the coils and spark plugs out and cranked the crank bolt until it the valves were visibly seated. Then I poured a bit of gasoline in the runner and waited to see if anything leaked through. If it didn't then I knew it was fully seated.. if it did I would crank just a little more. Once fully seated I would tape up the open valve runners with masking tape and start spraying the Zoom cleaner and let it soak.
__________________ 2008 Cosmic Blue Mica Mazdaspeed 3. BNR s3, CoolingMist CMGS Meth, Damond TB Plate, JBR FMIC Undermount w/ TR8, JBR 3" Fullpath, Steedspeed EM, Cobb AP v3, Stratified Tuned, Autotech HPFP Internals, CP-e Catted Downpipe, Port and Polished IM with VTCS & Full EGR Delete, Grimmspeed EBCS, 3 BAR MAP Sensor, Turbosmart Dual-port BPV, Koni Sport Yellows, Eibach Prokits, SPC Camber Arms, Cobb FSB and RSB, AWR Front Endlinks, JBR Trilogy Mounts 70a Duro, KX-F3 Full Chassis Braces, Denso Iridium ITV-22, CP-e Safe Seals, SURE TIG IM and TB, Cobb Shift Weight, TWM SS w/Bushings and Specter Hybrid knob. To be installed: SS Brake Lines. |
| The Following User Says Thank You to theurgy For This Useful Post: | Ms3_Miami (11-07-2012) |
![]() | | #51 | ![]() |
Groans: 103
| Not Ranked : 0 score yeah, the brushes i used had burly wire shafts, so the were almost like picks as well. plus, i used some coat hanger and various screwdrivers. those valves were so fucking burly. at first i was worried i might break them. after 10 mins i was like, 'where's the drill?'.
| The Following 2 Users Say Thank You to tddvrrn For This Useful Post: | mr.speedy3 (09-28-2013), Ms3_Miami (11-07-2012) |
![]() | | #52 | ![]() |
(Thread Starter) | Not Ranked : 0 score It would be pretty hard to break the valves just scraping/picking them. The brushes really did nothing for me...Honestly the best thing they did was help to clean behind the valve stem as i could wrap it around the stem. Other than that, it did pretty much nothing for the caked on gunk. I just pulled my valve cover off since it only takes 2 minutes and i could see when the valves were closed by position of the cam lobe
| The Following User Says Thank You to ms3blackmica For This Useful Post: | Ms3_Miami (11-07-2012) |
![]() | | #53 | ![]() |
![]() Join Date: Mar 2011 Location: Bethlehem, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,167
| Not Ranked : 0 score Ugh, I really need to do this...
__________________ 07' Speed6 Velocity Red Mica Go Faster: CorkSport SRI/TIP, SU Test Pipe, SU TMIC, Autotech Internals, ITV22's, Cobb AP Anti break stuff: Upper Rear Diff Brace, RMM Appearence: STRI DSD Boost Guage/Blockhead 60mm Guage Pod |
![]() | | #54 | ![]() |
![]() Join Date: Mar 2011 Location: Greenwood, SC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 207
| Not Ranked : 0 score I have definitely got to MAKE time to do this..I got my car with 55K on it and know have around 83K...I bet mine look horrible!!lol
__________________ 08 MGM Speed 3=SURE Rmm/ShortCut/Anchors/Return,COBB AP/SF/TIP,TurboSmart B.O.V,BC Coilovers/SWIFT Springs,SPC R.C.A, M2 DP, CNT CBE, Autotech Internals, SSP EGR Delete, DDM 6K |
![]() | | #55 | ![]() |
(Thread Starter) | Not Ranked : 0 score do it i could not imagine
![]() | | #56 | ![]() |
![]() Join Date: Aug 2012 Location: Toronto
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 43
I'm piecing together the compressor/media blaster to make it happen that's for damn sure! eric | |
![]() | | #57 | ![]() |
I am planning on doing a lot of "preventative" maintenance all at once! This is definitely at the top of the list..I'm also considering doing the EGR delete/OCC at the same time..I'm just undecided on which one i want to go with!
__________________ 08 MGM Speed 3=SURE Rmm/ShortCut/Anchors/Return,COBB AP/SF/TIP,TurboSmart B.O.V,BC Coilovers/SWIFT Springs,SPC R.C.A, M2 DP, CNT CBE, Autotech Internals, SSP EGR Delete, DDM 6K | |
![]() | | #58 | ![]() |
| Not Ranked : 0 score It makes sense to install an occ and egr delete if you don't have one already. Why help those valves get dirty right after cleaning them! I'm in a local group-buy for jbr parts where I am ordering the egr delete kit, throttle body/intake manifold thermal insulating gaskets to all do at the same time. A local guy is also pioneering a double occ which I am hoping to jump on ![]() eric |
![]() | | #59 | ![]() |
(Thread Starter) | Not Ranked : 0 score OCC and EGR delete will help them stay clean for far far longer
| The Following User Says Thank You to ms3blackmica For This Useful Post: | Ms3_Miami (11-12-2012) |
![]() | | #60 | ![]() |
| Not Ranked : 0 score You might as well do some injector seals at the same time.
| The Following 2 Users Say Thank You to theurgy For This Useful Post: | ms3blackmica (11-12-2012), Ms3_Miami (11-12-2012) |
![]() | | #61 | ![]() |
![]() Join Date: Nov 2010 Location: Lido Beach,NY
Rep Power: 8624 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,845
| Not Ranked : 0 score Need to do on the new Pu!
__________________ Nator is what it does. |
| The Following 4 Users Say Thank You to kritz For This Useful Post: |
![]() | | #62 | ![]() |
| Not Ranked : 0 score Yea, I'm definitely sold on the fact that i need an OCC/EGR delete! From what I've read on here, it would be wise for me to do the injector seals while i have the IM off..?? I am planning on going big turbo at some point..
![]() | | #63 | ![]() |
| Not Ranked : 0 score If you're all going through all that trouble, do an injector seal replacement as well as a PCV Valve Replacement.
![]() | | #64 | ![]() |
| Not Ranked : 0 score I wouldn't personally consider the injector seals a preventative maintenance item.
![]() | | #65 | ![]() |
| Not Ranked : 0 score What would you consider it Lex? I'm just curious as to your opinion in this.
![]() | | #66 | ![]() |
![]() Join Date: Apr 2012 Location: Tacoma, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 104
| Not Ranked : 0 score ImageUploadedByTapatalk1355967238.340317.jpgImageUploadedByTapatalk1355967254.856942.jpgImageUploadedByTapatalk1355967271.922509.jpgImageUploadedByTapatalk1355967288.705867.jpg So I finally have the time to clean them and here they are at 90k |
| The Following 3 Users Say Thank You to tinboi479 For This Useful Post: |
![]() | | #67 | ![]() |
![]() Join Date: Jun 2012 Location: San Jose, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,963
Groans: 47
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() | |
![]() | | #68 | ![]() |
![]() Join Date: Jun 2010 Location: San Antonio, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,633
Groans: 79
Groaned at 34 Times in 31 Posts
| Not Ranked : 0 score I would have expected worse as well. Mods? OCC or EGR delete?
__________________ ![]() |
![]() | | #69 | ![]() |
| Not Ranked : 0 score Sorry no after pictures. It was my first time doing it and it was not a smooth process. It took me the whole day to do it I was irritated so I just cleaned it and put everything back on and I forgot to put a sensor back on the manifold which took me forever to figure out why my car wouldn't start. I don't have an OCC or EGR delete but I'm planning on doing it soon. My current mods are SRI, TIH, FMIC, COBB EBC, and upgraded mounts. That's pretty much it for motor mods. |
![]() | | #70 | ![]() |
![]() Join Date: Nov 2012 Location: North East
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 261
Groaned at 29 Times in 14 Posts
| Not Ranked : 0 score Do you guys finish cleaning the valves by having them slightly open so that you can really clean the ridge/edge of the valve that seats against the head? I feel like t would be important to brush the valve rim so that no gunk gets between then valve and the head, to avoid compression loss issues...
__________________ I drive fast, I turn fast, I do everything fast. I even breakfast. I tend to confuse people with my sudden changes of heart. Sometimes I even confuse myself, which tends to cause problems. "... if u can't find' em - grind 'em" - old Chinese proverb ![]() ![]() http://www.mazdamotorsports.com/ |
![]() | | #71 | ![]() |
![]() Join Date: Jun 2012 Location: Mesa, Arizona
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,244
__________________ Fastest GTX3076r, T3 twinscroll, built block, D14 meth spraying gen1 on the internet! | |
![]() | | #72 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,797
| Not Ranked : 0 score Meth is not spraying all the time. And most of the crud is made during cruise. Once it's baked into the valves, meth won't clean them. It does help, but actually getting in there and cleaning them is the only way to make them clean.
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 |
| The Following 3 Users Say Thank You to atvfreek For This Useful Post: |
![]() | | #73 | ![]() |
![]() Join Date: Feb 2012 Location: San Bernardino, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12,954
Solution, boost all the time! Haha I have often said this as well, while meth may clean/help it is only while the meth is present which honestly is not long at all. @Joe Isuzu; still needed to get in there and clean them the ol fashion way. tapafuck
__________________ 2010 velocity red mica ms3 AP/AT internals JBR 3.5" whale peen (non rubber for more feeling) JBR SSP/bushings JBR RMM JBR tigs/ egr delete/ coolant bypass JBR stage 2 OCC CS test pipe Turbosmart BPV (stocker currently on) SS lines/super blue/stoptech pads | |
| The Following 2 Users Say Thank You to lilred For This Useful Post: | atvfreek (09-28-2013), mr.speedy3 (09-28-2013) |
![]() | | #74 | ![]() |
![]() Join Date: May 2010 Location: Benton, AR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,028
__________________ 2010 Mazdaspeed 3 Liquid Silver Metallic HTA 3076 | HTP 4" Intake, battery tray, under mount piping | CPE Exhaust Manifold, downpipe, FMIC & Stage 2 RMM | MD TMM and PMM | Tial MV-R ewg w/ Kozmic dump tube | VCTS delete/Ported IM | JBR OCC, EGR delete, BSD w/ oil pan baffle & RSB | SP63 Oil Cap Breather | Synapse SB BPV | UR CBE | Autotech HPFP | H & R Coilovers | Whiteline Endlinks | Manley Pistons & Rods | L19 Head Studs | Kozmic 6th Port w/ DW65c ITFP | Snow Performance Stg 2 Meth | JMF Manifold | SouthBend Stg 3 Endurance Clutch | Tuned with | |
| The Following User Says NO Thank You to jdmage_mx5 For This Un-useful Post: | bwspeed (10-17-2013) |
![]() | | #75 | ![]() |
![]() Join Date: Feb 2013 Location: Moore, OK
Groaned at 8 Times in 5 Posts
| Not Ranked : 0 score What about pouring sea foam on the valve and letting sit for a bit? Anyone try that ? If any leaks down into the cc then into oil pan just do a full oil change after it's said and done? |
![]() | | #76 | ![]() |
![]() Join Date: Dec 2009 Location: San Antonio, TX
Rep Power: 5051 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28,143
Groans: 146
| Not Ranked : 0 score |
![]() | | #77 | ![]() |
Neither seemed to work any better than the other.
![]() | | #78 | ![]() |
| Not Ranked : 0 score Mazda Zoom Cleaner worked well for me.
![]() | | #79 | ![]() |
![]() Join Date: Mar 2012 Location: Long Beach, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
| Not Ranked : 0 score thinking about cleaning my valves this Saturday, but i don't have a shop vac or air compressor. i heard you can remove the liquid with a fluid transfer pump from harbor freight, can anyone confirm this?
__________________ 2009 CWP MS3: CP-E FMIC / CP-E RMM / Cobb SRI / Cobb TIP / Cobb AP V3/ HKS BOV / PTP HPFP Internals / UR V1 Catted DP / UR Racepipe / Cobb SS Catback Exhaust / Swift Spec-R Lowering Springs w/Koni Yellow |
![]() | | #80 | ![]() |
![]() Join Date: Apr 2013 Location: Providence, Rhode Island
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28
| Not Ranked : 0 score I Really need to do this, 75k never been done. Can i get everything i need to do it from harbor freight?
__________________ 2008 Mazdaspeed3 Sport | Cobb AP | JBR Dogbone RMM | Corksport Stage 2 SRI+TIP | JBR Shortshift plate | Corksport Shifter Bushings | Mazdaspeed cat-back exhaust | Cobb Access Port stage1+SF+TIH 93 v231 map | H&R Coilovers /w Whiteline endlinks/RSB | SOLD |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/dirty-valves-were-dirty-129339/ | ||||
| Tache dans l'intake - Mazda 3 Quebec | This thread | Refback | 09-09-2014 08:11 PM | |
| Sea Foam Spray vs. Catch Can - Page 4 | This thread | Pingback | 11-06-2012 09:26 AM | |
| dirty car with FDs | romeox929 | MazdaSpeed 3/6 - Appearance | 35 | 05-21-2010 11:32 AM |
