![]() | | #41 | ![]() |
![]() Join Date: Jan 2009 Location: Cleveland, OH
Rep Power: 3292 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,280
Groans: 52
| Not Ranked : 0 score
Ok so for arguments sake, lets say timing is the issue... and for arguments sake...lets say CP-e has NOT unlocked injector timing... So what can be changed...right now??? Just a thought, but if we now have more fuel(yay!), and the timing of the injection process is a constant...but we need to get fuel in earlier in the ignition process... Can't we change the timing of said ignition??? Everyone has been trying to up the timing up top to combat the loss of power...but isn't that just making it HARDER to get more fuel in before ignition??? So if we RETARD the timing up top shouldn't that give us MORE time to inject fuel prior to ignition???????? | |
| The Following User Says Thank You to Realgib3 For This Useful Post: | SpeedSixxx (01-02-2010) |
![]() | | #42 | ![]() |
![]() Join Date: Jan 2009 Location: San Antonio, TX.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 212
Groans: 90
Groaned at 69 Times in 21 Posts
| Not Ranked : 0 score You just have to think systematically and if you break everything down in sections. You remove the blocks one by one until there isn't any blocks left. The community and vendors have been doing this one by one for the last 3 years. Remember when we were all complaining about the damn throttle plate..lol We have to be systematic. EDIT: Well, in Jan. I get my fuel pump, and I'll have my GT35. If we don't figure it out by then, I'll get some logs at redline for you guys. I don't have an AP, and will either have CPE's flashs or Versa tune, but I'm down to help if I can. Last edited by kore2000; 12-31-2009 at 03:56 PM. |
| The Following 2 Users Say Thank You to kore2000 For This Useful Post: | Lex (12-31-2009), SpeedSixxx (01-02-2010) |
![]() | | #43 | ![]() |
| Eth/Meth Junkie ![]() Join Date: Mar 2008 Location: Columbus, OH
Rep Power: 2957 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,846
| Not Ranked : 0 score FYI, I do not believe that we have any airflow limitations due to the ECU. If we did, we would see the MAF g/s fall off. This obviously doesn't happen now that the throttle blade is held open. Obviously, spark isn't the issue either. So it is quite simply a fuel related phenomenon. Based upon the Cobalt's recent break through, our path forward is quite apparent. There might be a few new twists involved in rectifying our situation due to specifics in our ECU and fuel rail hardware, but it will be resolved in the near future.
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) |
| The Following 2 Users Say Thank You to cld12pk2go For This Useful Post: | djuosnteisn (12-31-2009), SpeedSixxx (01-02-2010) |
![]() | | #44 | ![]() |
Groans: 79
| Not Ranked : 0 score Here's to 2010!
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
| The Following 3 Users Say Thank You to djuosnteisn For This Useful Post: |
![]() | | #45 | ![]() |
Rep Power: 414 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 105
| Not Ranked : 0 score Just babbling some generalities, and yeah, I know you can't compare dyno numbers, but I'm going to anyway. Like I said, general observations ... 12pk and RR make the same peak tq. 12pk and RR hold peak tq for the same time (~1000 rpm) 12pk and RR are above 300 tq for the same time (~2000 rpm although if you squint, maybe 12pk holds a little longer) 12pk holds above 250 tq for significantly longer than RR - about 750 rpm longer. 12pk and me log the same loads but he makes way more tq presumably. I understand that the RR solution to turning the speed into a drag car is a good one and I'm not criticizing them, I just think the comparison (similarities) to a stock turbo screaming for mercy is interesting.
__________________ ![]() |
![]() | | #46 | ![]() |
I don't think the calculated loads are very accurate. I make over 2.0 loads when temps are below 30F, with lower MAF g/s than when I am at ~1.8 load when it is around 60F. IIRC my recent logs showed about 4.5v on MAF compared to 4.6v ish when warmer and my WGDC was going to 0%.
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) Last edited by cld12pk2go; 01-03-2010 at 07:00 AM. | |
![]() | | #47 | ![]() |
(Thread Starter) | Not Ranked : 0 score Temperatures have an effect on calculated load as it should but there's more to it than just oxygen mass. I would like to know what formula is used to derive the load parameter. |
![]() | | #48 | ![]() |
| Not Ranked : 0 score My highly inaccurate butt-o-meter indicates that the higher load does not equate to faster go in the above two situations. I would also like to know how it is calculated...
![]() | | #49 | ![]() |
Groans: 79
| Not Ranked : 0 score I read on a post on a bmw forum by a bosch guy. He stated that load is not just air, but rather the amount of fueling needed for the air that entered. So it may shed a lil light on your observations 12pk. Here's the quote:
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com | |
| The Following 5 Users Say Thank You to djuosnteisn For This Useful Post: | Fobio (01-01-2010), FreeFlyFreak (01-01-2010), MarkyMark (01-01-2010), SpeedSixxx (01-02-2010), superskaterxes (01-02-2010) |
![]() | | #50 | ![]() |
| Not Ranked : 0 score I have been thinking of the load as Tl = Q/n Which should pretty much represent torque production. I am not sure I understand why an injector constant would need to be added...
![]() | | #51 | ![]() |
Groans: 79
| Not Ranked : 0 score I'm pretty sure the constant is just used to "scale" the equation. Basically adjust the slope of the line for a given injector characteristic.
| The Following 2 Users Say Thank You to djuosnteisn For This Useful Post: | MarkyMark (01-01-2010), SpeedSixxx (01-02-2010) |
![]() | | #52 | ![]() |
![]() Join Date: Sep 2008 Location: California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 92
| Not Ranked : 0 score im really interested in this too, pre maf cal, i was hitting loads around 180 at 3k (21psi) tappering to 155 at 6k (17.x psi) now post maf cal, im hitting 20X at 3k (18.X psi) tappering to 16X at 6k (14-16psi) its really a huge difference and I feel its really high load for a stg1 mscai 105 (i also have tmic, bpv,aem) Well hopefully there will be some enlightenment in the near future
__________________ 08.5 MS3 ![]() Cobb AP-ATR tune; AEM CAI; COBB TIP; Test Pipe; PG piping/GS FMIC; AT Internals; HKS SSQV; Denso ITV22s; SURE counter weight; Cobb RSB; Swift spec R springs; Koni Sports; SU RMM, shifter bushings; Hankook Ventus V12 EVO 2 Team Beachbody Coach, Contact me to get started GF2revolution.com |
![]() | | #53 | ![]() |
Groans: 79
| Not Ranked : 0 score How much did your afr's & LTFT's change from pre to post maf cal? Would be best if you could give numbers like LTFT went from +12 to -1 or something like that.
![]() | | #54 | ![]() |
| Not Ranked : 0 score That sounds like cold weather. I gain about .12 in the cold here (20-30F vs. 75 when calibrated.) I target 1.84 and hit about 1.96, and that carries through most of the range. In normal weather I'm spot on.
![]() | | #55 | ![]() |
![]() Join Date: Sep 2008 Location: Soledad, CA
Rep Power: 446 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 393
Groaned at 5 Times in 2 Posts
| Not Ranked : 0 score where in the PID datalogging in the AP do you find Timing? I am interested in knowing how much timing my car is running at WOT. |
![]() | | #56 | ![]() |
![]() Join Date: Mar 2008 Location: State College, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,091
Groaned at 9 Times in 7 Posts
| Not Ranked : 0 score I think they call it spark advance
__________________ ![]() 07 Mazdaspeed3 |
![]() | | #57 | ![]() |
![]() Join Date: Apr 2009 Location: Cincinnati
Rep Power: 2046 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,096
Groans: 32
Groaned at 19 Times in 15 Posts
If the system can handle significantly increased pressure, we should be able to get a lot more fuel before ignition without changing the injection start time.
__________________ 2006 MS6 GT - Built engine, twin scroll GT3076R, dual MV-S wastegates dumped to atmosphere, TR1035 FMIC, too many parts to list... ![]() 2009 MS3 GT - Built engine, JBR intake/TIP and short shifter, all engine mounts, Autotech HPFP internals, ETS TMIC, Custom AP tune, Pauter rods, CP pistons, and 6-puck ACT clutch -GTX2867R Coming Soon | |
![]() | | #58 | ![]() |
![]() Join Date: Dec 2009 Location: camas valley
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,720
Groans: 40
| Not Ranked : 0 score ON OTHER DISI MTRS WHAT PSI ARE THEY RUNNING TO GET THE LETS SAY 500 HP. AND IS IT GOING TO BE REASONABLE TO GET OUR DI FUEL SYSTEM UP TO THIS PRESSURE AND FLOW RATE, OR BE CHEAPER TO AD THE AUXILIARY FUEL SYSTEM. BECAUSE IN MY SIMPLE MIND WE NEED THE FUEL SHOT IN BEFORE THE SQUEEZE ON THE FUEL. AND WHAT KIND OF INJECTOR IS THAT GOING TO TAKE IF THEY EVEN MAKE THEM JUST MY .02 I HOPE ITS PROGRAMING BUT I DOUBT IT
__________________ BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw 472 hp 461tq virtual dyno and ran out of fuel! nishan said theirs a easy 550 in the setup if i had the fuel but meh... 54,000 miles big turbo! stock block at 104000 2 bent rods current miles 113000 and runs perfect! no hiccups! tuned by nishan |
| The Following User Says Thank You to rigor For This Useful Post: | aaronc7 (01-02-2010) |
![]() | | #59 | ![]() |
Groans: 32
| Not Ranked : 0 score Our stock injectors should be able to inject a lot more fuel if we increase the pressure and stay with DI. If we add port injection we should be able to use just about any injectors we want since it will have to be a custom setup anyway - it shouldn't take very big injectors since we'll still have the stock ones too.
| The Following User Says Thank You to JMEngineer For This Useful Post: | SpeedSixxx (01-02-2010) |
![]() | | #60 | ![]() |
| Not Ranked : 0 score |
![]() | | #61 | ![]() |
| Not Ranked : 0 score A good question, which I haven't found much info on. I can vouch that my timing curve is safe for my mod combination. It is actually in all likelihood conservative. I am not looking to trailblaze; however, and would like to know what others have done successfully prior to tweaking.
![]() | | #62 | ![]() |
Groans: 79
| Not Ranked : 0 score IMO it's best to tune spark advance on a dyno, where you can get immediate feed back on each incremental change, not just butt dyno. Safe range is determined by detonation and EGT's. Typically you want to shoot for minimum advance for maximum torque. I'm all talk though, cause i've yet to actually tune my timing on a dyno, still waiting for my hardware to be finalized. Also, on a dyno, as you advance the timing, you'll eventually see a point where torque starts to fall off with increased timing, and egt's will go up quite a bit. This means you've gone too far.
| The Following User Says Thank You to djuosnteisn For This Useful Post: | SpeedSixxx (01-02-2010) |
![]() | | #63 | ![]() |
![]() Join Date: Jan 2009 Location: ME, Kittery
Rep Power: 1818 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,848
Groans: 105
| Not Ranked : 0 score well, so far, I believe people have tried to advance timing but didn't really see any results. Of course things are changing around here pretty quickly so we will see. |
| The Following User Says Thank You to spnkr21 For This Useful Post: | SpeedSixxx (01-02-2010) |
![]() | | #64 | ![]() |
![]() Join Date: Jul 2009 Location: Sardinia, Ohio
Rep Power: 4726 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,721
| Not Ranked : 0 score I picked up 10 HP per degree in timing advance. With no detonation and EGT's were still well within check. The problem I ran into, was once we tried to go past 3 degrees, the car threw a multiple misfire code.
__________________ I am my own After Market Company. A common mistake that people make when trying to design something completely idiot proof is to underestimate the ingenuity of a complete idiot. - Douglas Adams Better to remain silent and be thought a fool than to speak out and remove all doubt. - Mark Twain Cops carry guns to protect themselves, not to protect you. READ THIS---- 2nd Amendment A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. I've learned that pleasing everyone is impossible, but pissing everyone off is a piece of cake. |
![]() | | #65 | ![]() |
Tks
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) | |
![]() | | #66 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 952
| Not Ranked : 0 score Please post it up, i would like to see where you uped it. Now i know the ATR that we use is somewhat limited in how we can adjust timing. what timing changes does the professional ATR allow that we cannot? |
![]() | | #67 | ![]() |
| Driver ![]() Join Date: May 2008 Location: Toronto
Rep Power: 1986 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,158
Groans: 44
| Not Ranked : 0 score the new 500hp 911 Turbo's with DI uses 2000PSI fuel pumps...
__________________ ![]() DONE . Cobb AP 22-psi Self-Tuned . ATP GT3071 . CP-e 3.25" MAF+4" inlet . Denso ITV-24 . CP-e HPFP . CP-e FMIC . Turbosmart Ultimate BPV . 50/50 Meth w/ M5 nozzle . PTP IM Spacer+EGR delete . GrimmSpeed EBCS 3-port . SteedSpeed Mani . CP-e TBE . Greddy OCC w/ 2nd PCV valve . F2 BSD + oil-pan baffle . Hawk HP+ pads . Goodridge SS brake lines w/ Ford Super Dot 4 . Cobb Springs+FSB . Tri-Point RSB+Endlinks . Koni Yellows . KMAC Camber Plates . 60mm Boost Gauge . TWM Complete Shifter w/ JBR SSP+weight . CP-e RMM+PTP trans+kicker mount . Sparco Harness Bar w/ MOMO 4-pt harness . Rays/Volks 57F 18x8.5" +45mm 235/40/18 Hankook V12 . BBS RK 17x8" +45mm 235/45/17 RA1/R6 . OEM Snowflakes w/ 215/50/17 Nitto NT-SN1 . 3rd in CSCS 2009 Time Attack Championship - Super Street FWD . 360whp/390wtrq . SOON . 3-bar MAP sensor . MSpeed Tuning & Diagnostics - The Street Lab is ALWAYS OPEN FOR BUSINESS "It is amazing how many drivers, even at the Formula One Level, think that the brakes are for slowing the car down." -- Mario Andretti -- |
| The Following User Says Thank You to Fobio For This Useful Post: | SpeedSixxx (01-02-2010) |
![]() | | #68 | ![]() |
Groans: 40
| Not Ranked : 0 score so do they have better flowing injectors cause you would think if the Cly is in the intake stroke i shouldn't take a lot of pressure to over come Cly pressure if the injector open's up to let it flow. but on DJ,s post on injector pulse with i just looked to me it would just stay open longer the higher the revs? i assume the pressure was still good so that would tell me the injector is not able to flow the fuel in the short amount of time just my .02 btw you guys kick ass
![]() | | #69 | ![]() |
| Not Ranked : 0 score I use the SB, so this will not help you guys that run the AP very much. The day of this tuning session the ECU was running around 10* advanced at WOT. This same tune is also running a solid 11.8 AFR and about 1300* on the EGT (probe is in the DP) I looked through the Dash hawk logs I did a few days after this tune, and the highest recorded knock at WOT was .7 for less than a few tenths of a second.
| The Following User Says Thank You to SilverDemon For This Useful Post: | SpeedSixxx (01-02-2010) |
![]() | | #70 | ![]() |
Groans: 105
| Not Ranked : 0 score that's crazy. I was pulling so much timing before my build to get rid of knock |
![]() | | #71 | ![]() |
That would mean that you were running ~4-7° more than me in the 4500-5500 RPM range and about the same from 6000-7000 RPM. Very interesting. So you are saying you picked up ~30hp with the 3° increase? Got any dyno plots?
![]() | | #72 | ![]() |
(Thread Starter) | Not Ranked : 0 score I believe that in order to avoid codes with the SB, you have to incrementally advance timing such that the ECU does not see a sudden jump in crank speed. In other words you have to ramp up the timing, only 3 deg difference from cell to cell or less. |
| The Following 2 Users Say Thank You to Lex For This Useful Post: | SpeedSixxx (01-02-2010), superskaterxes (01-02-2010) |
![]() | | #73 | ![]() |
| Not Ranked : 0 score I just have the final dyno, I am sorry I completely forgot to ask for the baseline graph, but the car pulled 290hp and 285lbft on the first pull of the day, all the charts at zero. EDIT: I have already posted the dyno chart in another thread.......let me dig up the other thread and I will post a link LINK: http://www.mazdaspeedforums.org/foru...eed-3-a-34435/ POST 16 Double merge post FTL!! As you can see from the chart, we took the timing up incrementally, moving one degree of timing per cell. Once we got to 3* is when the car thew the code.
__________________ I am my own After Market Company. A common mistake that people make when trying to design something completely idiot proof is to underestimate the ingenuity of a complete idiot. - Douglas Adams Better to remain silent and be thought a fool than to speak out and remove all doubt. - Mark Twain Cops carry guns to protect themselves, not to protect you. READ THIS---- 2nd Amendment A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. I've learned that pleasing everyone is impossible, but pissing everyone off is a piece of cake. Last edited by SilverDemon; 01-02-2010 at 11:56 AM. Reason: MSF Database - Automerged Doublepost |
![]() | | #74 | ![]() |
Groans: 79
| Not Ranked : 0 score Wonder if you were pushing the spark advance into the fueling event, and that caused the misfires.
![]() | | #75 | ![]() |
| Not Ranked : 0 score No audible misfire, the car did not stumble or nothing funny happened, it just threw the CEL.
![]() | | #76 | ![]() |
Groans: 79
| Not Ranked : 0 score Wonder if the ecu would interpret a spark during fueling as a misfire, even if ignition was still successful. I mean even with a piggy back the ecu would still know if it were spraying during a spark event. Just an idea.
![]() | | #77 | ![]() |
![]() Join Date: Apr 2009 Location: Bethpage, New York
Rep Power: 4481 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,850
Groans: 778
| Not Ranked : 0 score HKS twin spark...
__________________ 2003 SilverStone Grey Honduh S2000 ![]() ![]() |
![]() | | #78 | ![]() |
| Not Ranked : 0 score The HKS will not, at this point, cure the random misfire code, since it really is not a misfire. I think (and correct me if I am wrong) the ECU interprets how many spark events happen in a cam rotation, and advancing the timing to a point where the spark event happens outside of that window throws the CEL.
| The Following User Says Thank You to SilverDemon For This Useful Post: | SpeedSixxx (01-04-2010) |
![]() | | #79 | ![]() |
(Thread Starter) | Not Ranked : 0 score Misfires are determined by examining the rate at which each tooth of the crank sensor is accelerated during the power stroke. The SB retards timing by delaying the crank pulse. The ECU senses this discrepancy and throws a misfire code. The SB might also be doing this a little crudely - not sure how fast their processor is. |
| The Following User Says Thank You to Lex For This Useful Post: | SpeedSixxx (01-04-2010) |
![]() | | #80 | ![]() |
| Not Ranked : 0 score Ahhh, it is the crank position, not the cam position that makes the determination. Thanks for clearing that up for me.
| Stock ECU bolt-on limitations | Speed3FTW | MazdaSpeed 3 - Engine, Transmission & Driveline | 35 | 04-30-2009 02:16 PM |
| Haven't found this CBE discussion yet so here goes... | jbarbaresi | MazdaSpeed 3 - Engine, Transmission & Driveline | 23 | 03-16-2009 04:45 PM |
| MS3 Fueling Discussion | Haltech | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 39 | 02-23-2009 12:09 PM |
| Fueling/AFR Discussion | dadasracecar | Mazdaspeed3/6 General Discussion | 13 | 12-24-2008 09:56 AM |
