 Old 01-05-2010, 08:40 PM   #121
cpolly69's Avatar
Posts: 2,116   (View Stats)
Groans: 27
abs works great when you do the "trick" - i smashed the brakes just last week in the snow with the "trick" on and abs went nuts
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
The Following User Says Thank You to cpolly69 For This Useful Post:
reddeerspeed3 (01-05-2010)
 Old 01-05-2010, 08:41 PM   #122
bf360's Avatar
Posts: 2,069   (View Stats)
lol and dont add 5 deg at a time!!!
in the words of a famous tuner,
"baby steps, baby steps"
lol missed that 5 degrees part, holy shit, 1-2 at most and make small changes and see where it goes
Originally Posted by DCLXVI View Post
your car is possessed by satan, so i dunno whats goin on with that LOL vta's shootin fire some crazy ass extra fluid lines. secret boost control settings haha ninja, or your demon spawn gas pedal not taking no for an answer lololol but your shit rips it.
 Old 01-05-2010, 11:08 PM   #123
kgb
kgb's Avatar
Posts: 808   (View Stats)
kgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the world
Groans: 88
Originally Posted by kgb View Post
I decided to up my timing 5* with 20 psi boost and broke loose my tires for the first time in 3rd gear evah...easily...
I should specify I meant it total over a couple of maps...so 2.5* each map...the second 2.5 * incriment was when my wheels lost traction in 3rd. My car runs smoother than ever compared to the thread I made about it running roughly about a month half ago. Knock is just as good as with stock timing. Now I will say that my gas mileage is shit 24 - 25...not driver mod....is this because extra fuel is being thrown in due to the tune? Hwy mileage at 60 goes between 29.50 - 33 mpg in 6th gear.
I use to get 30+ mpg in the summer!
I am going to up my timing to 10* at 1.00 load and higher, 3000 rpms - 6500 rpms , lower to 19 psi of boost and test it tommorrow.....it is very cold in Tampa so the 42* weather could be contributing to the tires breaking loose but damn it scared me not expecting tire spin in 3rd gear.
Ya, you guys are probably right, 5* is alot even if I lower boost. I will keep a eye on my parameters and report back in a couple of days with my logs...I am using cld12pk2go fuel tables and and my individual TRL tables are all lower than stock up til 3500 rpms. This is my 85th map and I data log every time I drive the car. I hope this can help us out at least.
Balls to the walls baby!!!
FAST & FURIOUS... MazdaSpeed CBE - CNT Downpipe (diode trick) - Cp-e Nano - Autotech Internals - AMSOIL Signature Series 5W-30 Motor Oil - NGK 1-Step Colder Plugs
WHEEL HOP...........Cp-e RMM (75) - Cobb SS - TMW Shifter Brushings - Cobb Shifter Weight - H&R Springs - Hawk HPS Pads (Front) - CS Pads (Rear) - JBR Rear Cambers - JBR 5mm Wheel Spacers - JBR Rear Sway Bar - NATOR Clutch By-Pass - Nitto NT05s
AL GORE...............EGR Block, Valve Delete - JBR TB Coolant Bypass - NATOR Air Reroute to SRI
MMMM BRAINS.....Dashhawk (Mounted) - Hypertech Tune - SWAStika Oppression Defeated[SIGPIC][/SIGPIC] - DSC LED Reroute
JAM SESSION........US Amps (in Series w/ Stock Amp) using
OEM Speakers for Mids & Highs Only - Bazooka 8" Amplified (Got my trunk back)
RICE.................. NATOR Interior Red LEDs - NATOR Engine Blue LEDs - Advanced Film Solutions Tint - NATOR Gun Metal Stock Wheels - Ventshade Deflectors
- Acne Rear Bumper LED Reflectors
kgb is offline   Reply With Quote
 Old 01-05-2010, 11:17 PM   #124
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
ha yeah the tires definitely spin easy in anything below 50 degrees. believe me, I ran them for a while around the temps youre having down there now.
'08 CWP MS3 w/ T3 3071r
 Old 01-06-2010, 05:27 AM   #125
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
YouTube - I have come here to chew bubble gum and kick ass and I'm all out of bubble gum.
Please post some data logs with the increased timing and your Ign maps.
tks,
 Old 01-06-2010, 09:00 AM   #126
Remember that the knock sensor goes deaf above 5700RPM so be careful with timing up top.
kgb (01-06-2010)
 Old 01-06-2010, 09:13 AM   #127
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Groans: 67
Pressing the button during startup does something, the car feels different pulling out of corners and my lap times are lower with both off. It could just be a placebo effect, but I doubt it.
Bingo.
Like I said, it may do "something," but it doesn't turn your DSC or TSC systems any more "off" than by just pushing the button with the car running...
 Old 01-06-2010, 09:33 AM   #128
Ziggo's Avatar
Posts: 3,843   (View Stats)
I hate to derail this thread, but I can run pretty consistent lap times, and on corners where I can put the power down the car pulls harder out of the turns and the lap times are lower. I think it may remove or alter the steering angle boost limitation, I will be sure to record a data log of it the next time I run at streets of willow CW. The back bowl has 20º of camber in it so you are full throttle and steering at the exit.
 Old 01-06-2010, 11:50 AM   #129
Nliiitend1's Avatar
Groans: 67
Well while I've never logged things, I have never been able to perceive a discernable difference in "powering out of turns" (this car has more than enough torque to spin the tires coming out of most turns on-track in my experience).
I believe the "steering angle boost limitation changing with the 'hold and start' method" theory has been disproven as well, but I don't recall if it was on this forum or a different one...
 Old 01-06-2010, 12:22 PM   #130
cpolly69's Avatar
Groans: 27
there's a thread out there somewhere where someone claims to have data logged the difference in throttle plate position - with it opening more with the "trick" engaged - i remember reading it a long time ago.....i got really interested in this back when i first got my dh, but i don't think i ever logged it...
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
 Old 01-08-2010, 09:50 AM   #131
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
HHHHMMMMMMMMMmmmmmmmmm......mmm..m.....m......mmm.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
JMEngineer (01-08-2010)
 Old 01-08-2010, 10:51 AM   #132
JMEngineer's Avatar
Posts: 2,122   (View Stats)
JMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the world
Groans: 32
Groaned at 19 Times in 15 Posts
^^ Not a very useful post, but it made me laugh.
I have someone looking at my ecu this weekend. He probably won't have enough time to find anything useful since I need my ecu back for my car to run but he used to be an ECU programmer for Nissan so he knows a few tricks they use to limit stuff.
2006 MS6 GT - Built engine, twin scroll GT3076R, dual MV-S wastegates dumped to atmosphere, TR1035 FMIC, too many parts to list...
2009 MS3 GT - Built engine, JBR intake/TIP and short shifter, all engine mounts, Autotech HPFP internals, ETS TMIC, Custom AP tune, Pauter rods, CP pistons, and 6-puck ACT clutch
-GTX2867R Coming Soon
JMEngineer is offline   Reply With Quote
The Following 6 Users Say Thank You to JMEngineer For This Useful Post:
06Speed6 (01-10-2010), cld12pk2go (01-09-2010), djuosnteisn (01-08-2010), FreeFlyFreak (01-08-2010), kgb (01-09-2010), superskaterxes (01-08-2010)
 Old 01-08-2010, 11:05 AM   #133
Captain
Groans: 79
Sweet!
www.permtuning.com
 Old 01-09-2010, 06:39 AM   #134
Eth/Meth Junkie
cld12pk2go's Avatar
KGB
Still would like to see some data logs of your increased timing runs...
Tks
 Old 01-09-2010, 09:37 AM   #135
kgb
kgb's Avatar
Groans: 88
lol...I'm getting them but wanted to wait and do it in more realistic, moderate weather that I will normally be in. Here in Tampa it's getting into the mid 20's and I want to wait until 60 or higher before I make any runs or determinations....this weather is odd but I will post ASAP...one thing I have noticed is that at idle my AFR never goes above 14.3 and my gas mileage is WAY down but for the couple of pulls I have done my fuel pressure is higher then ever
If you want I will post my map and then post my datalogs later.
*Edit*
Wanted to also mention that while cruising, my AFRs jump from 14 - 15. They were at 14.6 -14.8 before....ok....hope to get some pulls in soon.
The Following User Says Thank You to kgb For This Useful Post:
djuosnteisn (01-09-2010)
 Old 01-09-2010, 09:57 AM   #136
Eth/Meth Junkie
cld12pk2go's Avatar
I would have interest in both the 20°F and 60°F logs. It is 22°F here at the moment...
 Old 01-09-2010, 10:11 AM   #137
cpolly69's Avatar
Groans: 27
kgb, from what i've seen, the idle afr you described is unusual, but the cruising sounds pretty normal - i've noticed my car tried to achieve about 14.69 exactly at idle
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
 Old 01-10-2010, 04:46 PM   #138
rigor's Avatar
Posts: 2,399   (View Stats)
rigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the world
Groans: 40
Smile
so socks went down to cp-e and made a lair out of me .......... it is tuning frigin sweet their is hope !!
now i need to find out if their is a cp-e tuner around here in Oregon
BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw
472 hp 461tq virtual dyno and ran out of fuel!
nishan said theirs a easy 550 in the setup if i had the fuel but meh...
54,000 miles big turbo! stock block
at 104000 2 bent rods
current miles 113000 and runs perfect! no hiccups!
tuned by nishan
Last edited by rigor; 01-10-2010 at 04:48 PM. Reason: MSF Database - Automerged Doublepost
rigor is offline   Reply With Quote
 Old 01-10-2010, 05:10 PM   #139
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
www.cp-e.com is the leader of the worldwww.cp-e.com is the leader of the worldwww.cp-e.com is the leader of the worldwww.cp-e.com is the leader of the worldwww.cp-e.com is the leader of the worldwww.cp-e.com is the leader of the worldwww.cp-e.com is the leader of the worldwww.cp-e.com is the leader of the worldwww.cp-e.com is the leader of the worldwww.cp-e.com is the leader of the worldwww.cp-e.com is the leader of the world
Groaned at 115 Times in 51 Posts
Results were beyond what we even expected. We ran the car to 24psi on pump with no meth and made over 100whp and 100wtq more than his car dyno'd when he arrived. We were only able to go to 19psi on the dynojet run because an injector seal popped. 428whp at 19psi was fun to see. Too bad we didnt get to try the 24psi on that run.
www.cp-e.com is offline   Reply With Quote
 Old 01-10-2010, 06:25 PM   #140
Congrats CPE, I look forward to seeing the dynos.
www.cp-e.com (01-10-2010)
 Old 01-11-2010, 06:21 AM   #141
shpankey's Avatar
Posts: 496   (View Stats)
wow, impressive! looking forward to seeing the dyno's. nice job!
09 Speed 3 GT
 Old 01-11-2010, 06:29 AM   #142
dyon's have been posted on our blog
cp-e News & Events
 Old 01-13-2010, 11:00 AM   #143
We're seeing some strange behavior on Dustin's car that may lead us down the right path. Past a certain point, MAF corrections no longer seem to have an effect on AFR. It appears as though the car is reaching some sort of ECU limited fueling cap.
More to come as we learn more.
cld12pk2go (01-13-2010), djuosnteisn (01-13-2010), Fobio (01-13-2010), MPSdriver (01-14-2010), SpeedSixxx (01-13-2010)
 Old 01-13-2010, 11:09 AM   #144
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
dude...this is what I've been trying to say, but not in so many words!...I'm glad we're where we are now. =)
-- Mario Andretti --
 Old 01-13-2010, 01:38 PM   #145
shpankey's Avatar
Didn't the Race Roots guys say something like after you reach a certain point you had to upgrade the fuel pump in the tank? Maybe that's it?
09 Speed 3 GT
 Old 01-13-2010, 01:42 PM   #146
Captain
Groans: 79
They are not using the conventional setup like stock. Their intank pump is supplying more than the HPFP IMO.
On a stock setup, or stock with upgraded HPFP, a failing intank pump should be evidenced by a drop in fuel pressure.
At least that's what logic would lead me to believe.
www.permtuning.com
 Old 01-13-2010, 03:12 PM   #147
Cataphract_40's Avatar
Posts: 1,730   (View Stats)
Groans: 30
glad to see the community making progress.
subbing, very excited to see what happens over the next few weeks
2008 GT MS3 - 307 WHP/338 WTQ
1995 Miata
 Old 01-13-2010, 03:18 PM   #148
Eth/Meth Junkie
cld12pk2go's Avatar
I have absolutely seen this behavior recently. Added 3% in the 4-4.5v range and nothing changed. Added another 3% and still nothing...
The Following 2 Users Say Thank You to cld12pk2go For This Useful Post:
djuosnteisn (01-13-2010), SpeedSixxx (01-13-2010)
 Old 01-13-2010, 03:26 PM   #149
Realgib3's Avatar
Posts: 2,443   (View Stats)
Groans: 52
I know this doesnt have anything to do with the wall or the limitations cp-e broke through but... Anyone else see the RMR Soltice drift car? they upped the compression to almost 14.5:1 compression and are making over 500whp... and we thought we ran high compression for a boosted car lol.
 Old 01-13-2010, 05:10 PM   #150
Deadman's Avatar
Posts: 868   (View Stats)
Deadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the world
don't know if the solstice drift car has the same motor in it as the normal... but thats the LNF i do believe... DI
Deadman is offline   Reply With Quote
 Old 01-13-2010, 06:27 PM   #151
Eth/Meth Junkie
cld12pk2go's Avatar
Anyone running over 2.0 load? I logged up to 2.1 today...
Looks like it is just using the timing from the 2.0 load...
 Old 01-13-2010, 06:34 PM   #152
stealthspeed6's Avatar
Posts: 136   (View Stats)
stealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant future
for load do you divide the calculated load by 10 or is there another load value to log? because a log i did today had load of 232 or 2.32 if you divide by 10 but i don't think thats right.
stealthspeed6 is offline   Reply With Quote
 Old 01-13-2010, 07:25 PM   #153
Eth/Meth Junkie
cld12pk2go's Avatar
Divide the logged "Calculated Load (%)" by 100 to make it match the load tables in ATR (example: 180 = 1.80 load).
kgb (01-13-2010)
 Old 01-13-2010, 08:07 PM   #154
Captain
Groans: 79
Like i've said, i've never seen above 2.0 load, even fully bolted running a 3071 @ 24psi.
www.permtuning.com
 Old 01-13-2010, 08:15 PM   #155
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
i had seen that with the ap before.
if i would go too far with the maf scaling, the car would end up stupid lean.
The Following User Says Thank You to socks For This Useful Post:
 Old 01-13-2010, 08:19 PM   #156
Captain
Groans: 79
All this is starting to make me feel less stupid.
I swear, at times out there i felt like a fucking cave man with a computer. Figured i was better off with a horse.
Personally, everything worked fine with moderate power levels, but only became problematic as i upped the power.
www.permtuning.com
 Old 01-13-2010, 08:24 PM   #157
socks's Avatar
Groans: 125
i would go too far trying to richen the car up, and i'd have to start all over.
kurt (subparpunk) had it dialed in in 2 tries. Get a second set of eyes. what size maf do you have?
with my stock maf housing, i ended up around 390 at 5v.
dustin, gmail. i needz ur stock terbow
Last edited by socks; 01-13-2010 at 08:28 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-13-2010, 08:36 PM   #158
kgb
kgb's Avatar
Groans: 88
I have seen 2.0 - 2.01 a couple times when temps were/are under 60 here in Tampa....
 Old 01-13-2010, 08:57 PM   #159
Alright, let's see if there's truth to this.
The people hitting the MAF issues (at or above 2.0 load) please log using the DH:
Fuel injection amount
commanded AFR
actual AFR
mass airflow sensor
RPM
Log this in a 4th or 5th gear pull to redline. If it's cold outside it certainly helps.
 Old 01-14-2010, 12:47 AM   #160
SpeedSixxx's Avatar
Posts: 4,184   (View Stats)
Groans: 778
ok im off but i'd like to test me car for u..i don't think I have any issues but if you need I can log those in 4th and 5th to redline.
Stock ECU bolt-on limitations Speed3FTW MazdaSpeed 3 - Engine, Transmission & Driveline 35 04-30-2009 02:16 PM
Haven't found this CBE discussion yet so here goes... jbarbaresi MazdaSpeed 3 - Engine, Transmission & Driveline 23 03-16-2009 04:45 PM
MS3 Fueling Discussion Haltech MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 39 02-23-2009 12:09 PM
Fueling/AFR Discussion dadasracecar Mazdaspeed3/6 General Discussion 13 12-24-2008 09:56 AM
Page generated in 0.59103 seconds with 40 queries
