-   -   DISI Compression Results (http://www.mazdaspeedforums.org/forum/f10/disi-compression-results-43395/)
mituc 11-17-2014 07:03 AM
too much boost and too low timing.
meicalnissyen 12-07-2014 08:54 AM
back in may, after I hydrolocked, I got these numbers with HF gauge
160/165/140/160 dry
175/170/150/165 wet
wood dowel and sharp pencil showed no badly bent rod
no vibes in clutch
been driven relatively easy for 3K since then
I have some fresh plugs on the way, I plan to use my caliper to get more exact with the rod check, and redo comp test and do the leakdown thing.
might be I popped ringlands?
Tokay444 12-07-2014 09:39 AM
Do a leak down.
meicalnissyen 12-07-2014 10:32 AM
Originally Posted by Tokay444 (Post 2768012)
Do a leak down.
buying the HF tester today
dry, and warm for the test?
Tokay444 12-07-2014 11:46 AM
Dry for sure.
I would give it about 20 minutes after shut down.
I usually let it sit for ten, and then start tearing it down.
meicalnissyen 12-07-2014 01:08 PM
done,
well done friday, after the plugs show up
[R]usty 04-27-2015 11:21 AM
Had a bit of time this weekend so I did some boost leak testing and a compression test. Car has 57300 and was completely cold.
1-180
2-180
3-179
4-179
snailD 04-30-2015 03:10 PM
i did a comp test in utah (roughly 4500ft asl) at 90,000 miles
every cylinder was 162. ill take it
Cevaes_64 05-08-2015 08:24 PM
4 Attachment(s)
Two months ago I did a compression test with a autozone gauge... I got 165 in all 4 Cylinders, 14K on a new engine, Needless to say I was dissapointed, but hey at least numbers were consistent, so finally today i got a brand new gauge and decided to try this again... really happy with the new results, Numbers are DRY on a somewhat warm engine, didn't do a wet test
myspeed90 05-16-2015 08:41 PM
So I did mine after I experience a cylinder 2 misfire. Did compression test and it said fuck off. 150,30,150,150 tested warm .
FreshAsWoodie 06-09-2015 05:30 AM
5 Attachment(s)
Did the test on Sunday. Been wanting to do it for future references. Have almost 90k miles on the slow thing. Did the test about 10 minutes after I parked, drove around for about 20 minutes before. I want to believe the numbers but not sure, I might get another tester and see what it reads. Should I maybe consider a cold test? Only got to page 13, going to read rest later.
Top left: passenger
Top right: passenger middle
Bottom left: driver middle
Bottom right: driver
BackRoads 06-09-2015 06:10 AM
Top left: passenger
You're golden.
FreshAsWoodie 06-09-2015 06:41 AM
Yeah I hope so haha. Kind of a dead thread too. But I still wanted to post my info.
snailD 06-09-2015 08:44 AM
this thread is never dead. it just slowly accumulates info
myspeed90 06-09-2015 12:58 PM
MY 30PSI CYLINDER 2
Well I've gotten the block and head back from the machine shop now I'm just waiting on my bearings to come in the mail then i'll begin the assembly process. I never got around to showing the problem with cylinder 2 but the picture below will explain all. :madfawk:
mituc 06-10-2015 11:59 PM
Yeah... same cylinders (2, 3 or both), same spot (the end towards the exhaust valves).
GregScuba 06-11-2015 03:14 AM
cyl one 195
cyl two 198
cyl three 195
cyl four 200
Test was last month at 96,000 mi. Used Craftsman tester. This was prior to installing FMIC and going from stage 2 to stage 3 cobb OTS map. See sig for other mods. Live in Florida. Drive it like I stole it almost every day, but always take it easy on warm up and cool down. Change oil every 5K mi, always synthetic, 5w-40 Rotella T as of late.
I was absolutely thrilled! Especially since I'd like to get at least another 100K mi and/or five more glorious years out of this wonderful car.
Hammology 06-11-2015 03:17 AM
If you wanna keep that compression the way it is, I suggest you get a real tune.
GregScuba 06-11-2015 04:26 AM
That is the next thing I plan on doing. Don't want to take any chances. Plan on going with Stratified @Lex;. Def won't do any track days or anything too crazy until then. Been trying to keep the revs below ~5K in the mean time.
Edit: Just wonder if I should clean the intake valves before getting a tune? Perhaps @Lex; can chime in? 100K miles, and never cleaned the valves. Already have an air compressor, just would need the walnut media and the blaster tool.
snailD 06-11-2015 07:54 AM
if you are able to do it then you should. mine at 50k were pretty horrible
Dano 06-11-2015 09:33 AM
your intake valves will be HORRIBLE, just a common issue with any DISI, Mazda, BMW, Audi, VW, etc.
Yes clean them before investing in a tune if feasible. It will run like a new car.
I personally bought Walnut media and a blaster on Amazon, made a plate out of 1x4 MDF using the IM gasket as a template, put two holes in each runner location (one for the blaster another for vacuum) and went to work with each cylinder at TDC. Just like the dealerships clean them.
BackRoads 06-11-2015 09:36 AM
Interested - about how much did the parts/media cost you, and how much time to do it?
I had this done at 100k miles, with great results. Been thinking of it again as I am at 206k.
Dano 06-11-2015 09:47 AM
let me amazon that for you
media..I got a larger bag but this lil guy would be plenty for a number of valve cleaning jobs.
blaster
intake removal/install is the most time consuming part maybe 2 hours total. blasting only took about 30 minutes. So +- 2.5 hours.
BackRoads 06-11-2015 09:55 AM
Thanks - not bad. If A person was pulling the IM anyway, seems smart.
jpopcorn 06-21-2015 08:40 PM
Well this wasn't exactly how I was hoping my first post would play out but here we are. I've been navigating around the forums just taking all the info in since buying the car last Novemberish, investing in an ap shortly after. Six months later I'm here with compression and leak down numbers..
Cyl 1: 175, 11% leakage
Cyl 2: 176, 6% leakage
Cyl 3: 155, 27% leakage past the rings
Cyl 4: 175, 7% leakage
Dont worry, I'll see myself over to the build diaries..
JgamB 06-21-2015 11:01 PM
At least you're paying attention. Odds are good you can recoup with minimal expense since you've caught it early, just plan for .020 over with the parts and research reputable machine shops near you.
jpopcorn 06-22-2015 09:53 AM
Do most end up needing to bore? I've been hoping to get away with just honing as I'm looking to stay away from forged pistons with what I'm looking to get out of the car reliability and power wise.
From what I've read it seems sticking with the stock rods is a bad idea though.
mituc 06-22-2015 11:56 AM
At these compression values I'm 100% sure you will not have to bore. However, expect to have cracked ring lands so do not buy just rings, get pistons and eventually (why not?!) rods as well.
JgamB 06-22-2015 09:54 PM
Your rods aren't what got you into this situation - it's your ring lands (most likely, possibly a filthy valve not fully closing, didn't read the rest of this thread), and if you want more substantial ring lands, you will want forged pistons as well.
Your best bet if you want to get by on the cheap is a buy a reman from Edge and sell your long block. It's worth (a lot) more to the used market than it would be for the $450 core refund. They have a $50 option for a 3 year unlimited warranty, a no brainer if you go that route.
InkedInspector 07-05-2015 05:15 PM
2013-56k miles
SRI (Stock size), Catless DP, CPe Triton CBE, Autotechs, Freek OTS+, Original Spark Plugs, Roughly 90% of miles highway. T6 for it's lifetime.
Cylinder 1- 180
Cylinder 2- 175
Cylinder 3- 180
Cylinder 4- 175
I started losing oil a few weeks back, seems the K04 is not liking the catless DP. CPe TMIC, JBR 3" Intake, BNR S3, and CPe Manifold are on the way. Gonna let Mr. Hypnotic do a full tune on it.
GregScuba 07-17-2015 07:21 AM
Cleaned the intake valves since my last compression test, and boy what a difference it made in performance and drivability!
I am currently on the first version of my pro tune with Stratified Automotive Controls, so decided to do another compression test today:
195
198
198
196
Once again, I'm thrilled with the results. All the while I was running the Cobb OTS map I never really saw any KR over 2, and trust me, I watched that shit like a hawk. There was only one exception when I got a bad tank of gas from a mom and pop station while traveling in the mountains, and my KR went up to 5.3, so I just took it easy until the next fill up, and sure enough, it went right back down.
Now that I'm running the first iteration of my stratified map, my KR has been below 0.8 so far. I know the tunes start out fairly conservative initially, but that is still pretty impressive, none the less. Kudos to Stan, @Lex; and everyone else at Stratified!
HaXiR 07-18-2015 04:07 AM
Within the past month or so I finally got around to upgrading my smoking K04 to a BNR s3. Prior to install we cleaned the intake valves and they were dirty as hell. Did the injector seals and all that jazz. Got it all back together and before I really started tuning I wanted to get a comp test since I have 87k miles on the car. Did the test and my numbers were pretty shit. 170,150,150,170. So I took it in for a Leakdown yesterday. His numbers were 160,150,135,160 with leaks coming from the intake valves. Said I need to have my head machines and reseat the valves. But after talking with some people here it's possible my valves are still dirty where they actually seat since you can only really clean when the valves are down. I'm just trying to figure out what to do exactly... On one hand is to start saving for rods and pistons and machine work. I have people here that will help me build, but the machine process and parts is $ I just don't have at the moment. That damn cylinder 3 is such a pain. Looking into what I can find about porting/machining the stock mani to try to avoid this issue in the future as well as meth. But that aquamist kit is looking pretty infeasible at the moment if I have to sell my first born to build this motor. But I guess the good news was it wasn't showing leak at the ringlands?
Edit: How can one safely clean intake valves while open to clean where they actually seat and from a seal?
mituc 07-19-2015 10:37 AM
Cylinder #3 being lower is quite consistent with what we've seen so far in these engines. The heat either indicates more wear in the rings on #2 and #3 or even leads to ring lands cracking for those two (usually starting with #3 ).
So I'd say, if the car runs good currently leave it as is and don't do any more work to it as you can invite more problems in the game. Save for pistons and rods and have the head cleaned up when you pull the engine for the rebuild.
csmaan12 07-19-2015 11:12 AM
70k on the clock mine tested out to be 180, 180, 178, 180. Funny enough it's #3 that's misfiring as well. Only problem is I can't remember if the 178 was on 2 or 3. Numbers are dry, didn't test wet.
Might have the valves cleaned at the dealer once I salve up some cash, no time to do it myself.
jpopcorn 07-20-2015 06:09 AM
Now that I've finally got around to tearing the motor down after seeing 27% leakage past cylinder 3, I don't notice anything too dramatic. I was expecting a cracked ringland but it doesn't look to be the case (at least without a closer look).
Is that kind of leakage possible with just bad rings? Being my first go at a rebuild I'm not sure if there's anything I'd be able to see that would be a telltale sign for the bad compression.
phate 07-20-2015 07:18 AM
Was the car running funny at all? It could just be a worn engine if you don't find anything suspect. Maybe check ring end gap if you feel like it, check if the cylinder is out of round.
jpopcorn 07-20-2015 07:42 AM
Everything was running fine, I wouldn't have even known there was a problem if I didn't do a compression and leakdown test. I did start getting some knock at higher rpms shortly after, though it could be unrelated as I didn't see any knock prior to running the tests. I guess I just figured with the usual cylinder 3 issues I'd see something obvious.
phate 07-20-2015 07:51 AM
Was it all leaking down through the crank case? Could injector seals have been a cause? Even at 30%, I probably wouldn't rebuild unless there were other problems. Did it burn oil?
jpopcorn 07-20-2015 09:03 AM
Yeah there was a swift breeze coming from the oil cap haha. Injector seals looked fine but I'm replacing them regardless so we shall see. It didn't really burn oil, just needed topped off once between changes. As far as it really needing to be rebuilt I'm not sure, but it needed the timing components, valve cleaning, and downpipe so pulling the head was convenient enough with the extra pistons and rods I have.
HawkeyeGeoff 08-31-2015 06:52 PM
Addin' to the madness finally.
Mods are in Sig.
Cyl 1: 180
Cyl 2: 170
Cyl 3: 180
Cyl 4: 185
Ran immediately after getting the vehicle up to temperature. I'm thinking about doing a leakdown.
HawkeyeGeoff 09-01-2015 08:15 PM
Did another tonight after an oil change (and another warm up)
Got:
Cyl 1: 182
Cyl 2: 175/178 (2 tries)
Cyl 3: 182
Cyl 4: 185
I did a couple extra cranks on all of these this time. Interesting.
BackRoads 09-01-2015 09:20 PM
You are golden. How many miles on your engine?
HawkeyeGeoff 09-02-2015 06:31 AM
There's about 40-45k on the engine build. 60k on the whole car.
Edit; I want your bumper, in and around my mouth. lol done jacked mine up on the track.
AND Also going to do a leakdown once I get it from @maisonvi; I'll report back.
BackRoads 09-02-2015 06:37 AM
Whaaaa??
HawkeyeGeoff 09-02-2015 06:39 AM
Originally Posted by BackRoads (Post 2944804)
Whaaaa??
You saying WHAAA to the length of the build or that I want to lick your non-jacked up bumper?
Design 09-16-2015 03:11 PM
1 month ago:
1: 155 / 10%
2: 155 / 10%
3: 150 / 10%
4: 155 / 10%
Compression numbers are obviously low due to not engaging the gas pedal during startup. :facepalm:
[R]usty 09-23-2015 05:41 PM
Tested this morning. 60500 miles. Engine was completely cold.
1 - 181
2 - 180
3 - 180
4 - 180
Crazy, I've only driven 3000 miles in the last 5 months.
Design 09-23-2015 05:43 PM
One update on mine - still getting oil consumption despite strong numbers. We're pretty sure it's worn oil control rings.
sho 09-23-2015 06:35 PM
Stock motor at 145k miles. I retired it at 161.5k and it had seen 22psi from a 5858 from 124k to the day it was pulled out. (still ran great)http://i1298.photobucket.com/albums/...psdbnybyp4.jpg
Built motor at 3k miles
http://i1298.photobucket.com/albums/...psjpwzrnhv.jpg
riflex 10-06-2015 08:57 AM
Stock motor, simple bolt ons with hpfp internals and Catless dp. 75k currently on motor. Had dp and internals on car for about 5k miles. Did my compression test yesterday while car was still warm. Pulled necessary fuses and all Spark plugs. Held down Clutch and gas while cranking.
1 - 188
2 - 190
3 - 189
4 - 188
Sent from my SAMSUNG-SM-G900A using Tapatalk
SNOW_QN 10-06-2015 12:10 PM
Stock motor and turbo @ 95k. Hpfp internals, gutted cats, Cai and tip,
Dry: (130) (120) (110) (130)
Wet: (150) (150) (140) (140)
Leak down results
Cylinder 1 = 28%
Cylinder 2 = 33%
Cylinder 3 = 36%
Cylinder 4 = 32%
Sent from my SCH-I545 using Tapatalk
blackms3_71 10-06-2015 12:35 PM
Leak down results
Cylinder 1 = 28%
Cylinder 2 = 33%
Cylinder 3 = 36%
Cylinder 4 = 32%
Damn
Just did mine it april and had
1-180
2-180
3-180
4-180
Car has 77k with all bolt ons and meth
SNOW_QN 10-07-2015 10:32 AM
I'm sure the last guy that owned this car raped the shit out of it. It's all good though.... "We will rebuild".
HaXiR 10-09-2015 03:20 AM
Leak down results
Cylinder 1 = 28%
Cylinder 2 = 33%
Cylinder 3 = 36%
Cylinder 4 = 32%
Is that motor leak or valve leak?
SNOW_QN 10-09-2015 04:21 AM
It was leaking into the crank case.
lolwrx 10-25-2015 03:48 PM
2010 with 81k mods in sig. Stage 2 since 65k and bnr since 75k. First time testing.
Looks pretty consistent around 190 in every cylinder. Performed the test at operating temp.
5doorsoffury 12-02-2015 06:28 AM
Sitting at 46 k drivin hard highway miles. Tuned at 9k on e85.
196,197,200,200
everton99 01-03-2016 04:48 PM
http://images.tapatalk-cdn.com/16/01...e7097d6a8e.jpg
Did this today.
GTX2871, CPE TMIC, 3.5 intake, UR catless TBE, and EGR Delete. I'm switching to an S4 within the next month.
Rcimp 01-08-2016 09:29 AM
With 157K miles
#1 = 180
#2 = 150
#3 = 125
#4 = 180
brandon96 01-15-2016 03:57 PM
2010 speed3 stock at 85k km..
Dry
cyl 1 - 170
cyl 2 - 150
cyl 3 - 160
cy 4 - 190
wet
cyl 1 - 185
cyl 2 - 180
cyl 3 - 190
cy 4 - 190
NRBt 01-21-2016 11:37 PM
2008 Mazda 3 MPS
The only power mod: Cobb SF + Cobb TIH + AP selftuned
134000km
~180 all across
195600km
PCV valve replaced, EGR cleaned. Manual intake valves cleaning with Wynn's stuff and cylinders/pistons/rings de-coking procedures for 6 hours. Different compression tester.
Compression before/after:
1 - 145 / 188
2 - 159 / 145
3 - 188 / 188
4 - 188 / 188
Leakdown test before/after:
1 - 75% / 7%(!)
2 - 65% / 70%
3 - 15% / 15%
4 - 17% / 14%
RoadTripSaloonGT 09-16-2016 12:19 PM
2008.5 MS3 GT
102,XXXmiles
No bolt ons (only mods; suspension, rmm.)
Dry: 175/174/174/170
Wet: 179/181/179/180
I was a happy, happy man today. Having the VVT and timing chain serviced, then tuning to head for 200K. Would love to keep this car for the long-haul. Always regretted selling my '03 SVT Focus, and I won't be making that same mistake again particularly since my motor seems solid.
Also, hello. I think this might be my first post.
BackRoads 09-16-2016 12:21 PM
Welcome - and congrats on having such a happy car!
[R]usty 03-02-2017 11:45 AM
Just hit 72,000 miles
1 - 180
2 - 180
3 - 180
4 - 180
She just won't quit.
mituc 03-02-2017 10:10 PM
Good! What oil are you using and how often the changes?
[R]usty 03-03-2017 12:37 AM
Since day one Mobil 1 10w30 with OEM Filters (sometimes Napa Gold). I change every 3,000 miles.
Thor Hammer 03-20-2017 10:30 AM
2007 MS6 with 111K miles. Engine up to temp/ dry test.
My fairly new compression tester read:
Cyl 1: 180
Cyl 2: 180
Cyl 3: 180
Cyl 4: 180
Autozone rented shoddy compression tester read:
Cyl 1: 165
Cyl 2: 165
Cyl 3: 165
Cyl 4: 165
What would you believe? The autozone comp gauge or mine? Either way, I'm stoked.
everton99 03-20-2017 10:40 AM
Yours.
mituc 03-20-2017 11:41 AM
Even if you believe both and compute an average, 172PSI across the board is an awesome number for this mileage.
So the usual question: what oil, how often?
Thor Hammer 03-20-2017 12:51 PM
Got the car July 2015 at 80K miles from original owner. Older family man that drove it for work and took great care of it. Clearly. I've never launched, drag raced (ok once against a cobra mustang F body and won) or beat on it.
I took it home and put in Rotella T6 5W-30. Changed with same every 3K-4K miles.
Saturday when I did the test I put in Penzoil Platinum Euro 5W-40.
My turbo seals are leaking into the intake and exhaust at the moment. Just bought a 70K mile K04 to replace it with. Can't afford the BNR S4/V2 with supporting mods right now.
ddt23 08-01-2017 07:49 AM
2006 MS6 with 96k, 27k fully bolted with an S3. Engine wasn't quite to temp and did a dry test.
Cyl 1: 148
Cyl 2: 148
Cyl 3: 148
Cyl 4: 148
Rotareez 10-15-2017 07:14 PM
06 MS6 62K on motor. Stock, besides TurboSmart BOV.
170 - 0 -175 - 185
Currently troubleshooting and praying for a burnt valve :censored:
Djohns 10-15-2017 07:56 PM
2010, 60k miles, full bolt ones, big turbo and meth. 195-195-195-195
CWP_MS3 10-16-2017 08:12 AM
190 across all 4 with all of the mods in my signature. E85 50/50 tuned by RichTune since 7k miles and E85 all I have ever run.
Shadley 11-25-2017 03:38 PM
155 for all four, warm + dry. No mods.
138k miles gen1 MS3. Autozone compression tester. Seems a bit low, but I'm wondering if that could be the gauge???
mituc 11-26-2017 02:34 AM
Could be the gauge, altitude (what altitude are you at?) or the compression itself. The consistency is what matters in this case.
cld12pk2go 07-15-2018 07:44 PM
182-185-185-182 today.
BuddySpeed3 07-15-2018 08:46 PM
Oh nice! How many miles on the clock at 26 psi, and is it a stock block?
cld12pk2go 07-16-2018 05:38 AM
~50-60k and yes stock block.
BuddySpeed3 07-17-2018 07:31 PM
That's inspiring :D
cld12pk2go 07-18-2018 12:00 PM
Originally Posted by BuddySpeed3 (Post 3147632)
That's inspiring :D
Irony time...
It appears that my #3 rod finally decided it had had enough. It appears to have bent on me...
Oh well, I still had thousands of pulls with the stock engine at those power levels...
Bingo 07-19-2018 07:48 AM
I've been rocking 1-4: 140-150-110-160 for about 10k miles of moderate-hard use including multiple auto crosses and what can be considered one track day. Car drives fine and doesn't burn a significant amount of oil. I'm just gonna keep going as I have been, if it makes it to another summer I'll rebuild it, if it blows up earlier I'll buy a block.
BuddySpeed3 07-19-2018 06:31 PM
Originally Posted by cld12pk2go (Post 3147653)
Irony time...
Wow that is ironic! Thank you for being on the front lines and pushing the limits of the stock block:) Going to build now?
cld12pk2go 07-19-2018 07:51 PM
No. Car is for sale (cheap).
http://www.mazdaspeedforums.org/foru...ml#post3146399
mituc 07-23-2018 02:04 PM
It served you very well though.
mgeoffriau 07-28-2018 01:39 PM
Got some interesting results on the used 2009 MS3 I just bought. A little backstory first.
So, I have an old compression tester. Probably 15-20 years old, typical gauge plus a flex line with a couple adapters. I've had a misfire on cyl 3 (P0303) the last few days, so I warmed up the car for 10 minutes, then pulled the TMIC, pulled the spark plugs (see photo), and hooked up the battery charger. Started with cylinder #1 , and got 185 PSI. Was pretty happy with that result.
https://i.imgur.com/Mihx5OEl.jpg
I go to remove the tester from cyl #1 , and the hose just spins -- the crimp fitting down near the threaded end is just spinning around. I futz around with it for 30 minutes before cutting the hose, jamming a long screwdriver down it, and getting the threaded fitting loose.
https://i.imgur.com/aqZFb9Hl.jpg
After hitting 3 separate parts stores, I finally find the kit I want, that has a 14mm fixed extension (Bosch FIX 7828). I get back home, still want to finish the compression test, but I'm not really looking forward to reinstalling the TMIC, warming up the car again, and then removing the TMIC for another test. I figure, it's 90+ degrees out, and I have access right now, I might as well try a cold test and see what I get. This is what I got on a somewhat cold engine, using the new Bosch gauge.
Cyl #1 - 200 PSI
Cyl #2 - 200 PSI
Cyl #3 - 195 PSI
Cyl #4 - 195 PSI
Did I mention this car has 173,000 miles? Is this result believable at all? I thought cold results would typically be lower than warm results, no? Or was the fact that the car sat for a couple hours in 90+ degree heat not really enough for it to cool off, and thus it was still a warm test?
mituc 07-29-2018 08:56 AM
How many miles on the spark plugs? Also 173k? :)
mgeoffriau 07-29-2018 01:03 PM
Noticed that, did you? :)
Got a new set of NGK Laser Iridium (95369) going in today, hoping that clears up the intermittent miss in cylinder 3.
Thor Hammer 07-30-2018 10:33 AM
Incredible comp test result. Those spark plugs! Damn.
mgeoffriau 07-30-2018 10:35 AM
New NGK plugs are in, so far no misfires, no codes. Going to take it in for the VVT actuator job tomorrow as the dealer quoted me $900. Feel a bit silly for having put Rotella T6 in it a week ago, but oh well.
Edietrich721 09-12-2019 05:46 PM
2008 ms3 90k no mods (Resonator delete) just bought less than 2 months ago compression results cyl1-114 cyl2-121. cyl3-100 /120 wet cyl4-120 have been starting to smoke at idle after 10 min but no oil consumption that worries 10fl oz each oil change cheap Pittsburgh compression tester was used so maybe it’s off? Any comments to these results? (other than poor maintenance and non productive comments)
MSMS3 09-13-2019 06:44 AM
Smoke at idle is probably turbo bearing seals - a well-known problem with the stock K04 turbo on our engines. At 90k that turbo, if OEM is probably due for this.
While compression seems a bit low, this may partly be a low reading gauge. Cylinder 3 is usually the lowest, and yours is. If you are not going to mod the engine this may be fine for awhile. It is worrisome. Can you rent/borrow another gauge? Did you get wet numbers on all four? Did cylinder 1 come up?
You might want to have a cylinder compression leak down test done.
MSMS3 12-21-2019 03:21 PM
Originally Posted by Jonkabir (Post 3173272)
Which is the best camera for photography?:bukkake:
You, sir are a slime ball. The quote from ten years ago said “cam cover”, not camera cover. Camshaft. WTF did you alter it?
Darth has no been here in years.
Mods, check this guy’s other posts. All misdirection spam.
Page generated in 0.33128 seconds with 11 queries
