Does Mazda actually allow engines to be rebuilt? AFAIK, they will replace the engine, but not allow a rebuild. Ford is the same way, and it is due to the "new age" machining required. If his head or block were milled, it probably wasn't through Mazda :) |
Why I have such high compr. #'s I am not sure. Tight engine is tight? I don't really know. I checked compr. again 2 nights ago and it was still 200~205 in all 4. On a warm day I'll see up to 210. TBH, I don't even care that they are strong #'s, I am just glad they are all the same @ 63,000 miles ! |
The Skyactiv motors are not rebuildable period. |
Sent from my PC36100 using Tapatalk 2 |
Sprayed on steel cylinder walls IIRC Tappin |
disposable blocks. but then again Mazda will not rebuild a motor, ever. they put new ones in so to them there is no reason to build a block that can be resurfaced. I suspect that saves them money and with uber thin cylinder walls, heat transfer to the coolant has got to be much improved. |
It is part of evolution. The processes employed by the factories have such tight tolerances and are increasingly less expensive that it is very difficult to achieve the same for a small shop/business. The shops that remain in business will only be dealing with older engines and cars ... but the good thing for us, the consumer, is that new factory engines are better and better off the shelf. |
so making monster power on future cars is gonna be insanely expensive because you would need to start with a new block? sigh... or drop in a different engine completely |
Mazda does rebuild the rotaries, but as far as I know the piston engines are all new. |
Figured I would post my results here as well; 182, 180, 120, 195. After pouring a little oil in the results were 185, 182, 121, 200. This is a built motor with about 1500 miles at the time of the test. I'll be doing a leakdown test as soon as possible. |
I'm thinking it is. Unfortunately that would mean tearing into the engine again possibly. I kinda hope he just didn't quite get the measurements right when he checked the clearances; I think that would be an easier fix. I don't think it's the injector seals; for one thing, we were very careful about putting the injectors back in. Also I'm not seeing much KR at all on any of my logs. |
I had a completely leaking toyota seal once on cyl #2 and my compression was no where near that low. It never hurts to check these things, however. |
I thought the funniest part of the conversation was when he suggested that the rings were still seating, that the motor isn't fully broken in. Probably not, but damn, why would 1 cylinder be that much lower? I hated to hear that, because I liked this guy. He seemed like someone I could trust. |
Good luck. :happysad: |
A leakdown test will show you where the leak is coming from with such a large compression difference. |
Did a compression test today. Rented the gauge from a newly opened Autozone. From left to right: 190/165/190/195. Wet test of the low one brought compression up to 190. Main reason I tested the compression is because I'm getting some oil out of my valve cover vent. |
have you been watching your oil temps at the track? what oil have you been using? |
I have not been watching my oil temps at the track as I have no way of doing so yet. I've been running Rotella since about 40k. |
I'll make note of my idle vacuum when I leave work and when I get home. |
Exactly the symptoms I went through when I broke my ringland in #3 . First started to "oil" my maf and intake so I put an OCC vta on the VC vent. Fast forward a few months and the failure was confirmed Seems this has now become a mainstream failure mode. The uber tight OEM ring gaps coupled with high oil/coolant and cylinder temps overall is taking its toll and the rings butt. Sorry to hear it. Tappin |
I thought I noted my mileage but apparently I didn't. Engine has 117k on it. |
is it time to go to cooler thermostats or get better fan control, oil coolers? What would be the least troublesome approach that would yield the best results? I personally don't like seeing my car run at 217-220ish all summer long. The fan will not even come on until it is 217 or the motor is shut off which ever comes first. I have no idea what the thermostats are rated at and if cooler models are available, and if that would make a difference in a DD situation. on an open course with a ton of airflow maybe that is all that is needed but in city traffic it may make little difference. @Ziggo; has replaced his I think and wonder what it is rated at and if he knows of the availability of others and what difference it made in his ECT...is does live in Texas for god sake. this may not be necessary for a forged motor, yet, but better heat management for the OEM ring gaps is def necessary. |
I only did one trackday last year (on one of the hottest days of the year in the Midwest) after you tuned my car, and had to end my day early (before the end of the 5th of 6 sessions) due to heat-related issues (slipping clutch primarily). I'm not a "high-horsepower guy" by any means, but I do tend to drive the proverbial piss out of my car and am still at the very least going to be running one of the map iterations you sent me that has less timing advance in it the next time I go to the track because of this (at least until I get a "fresh" clutch and perhaps upgrade to a Koyo radiator). I'd also like to get an oil temp gauge (and maybe even transmission fluid temp guage, a la @Tomas;'s setup) as well... |
The car was designed to reject 270hp worth of heat and 400whp cars are at 450+crank. That's 50% more heat the must be rejected. Perhaps starting another thread about this is best. |
Agreed, a dedicated thread to get some ideas out there would be good. |
2 Attachment(s) Quote:
Vacuum at idle was 21.56 and when I got home it was the same. The pic with the red screen is the hot idle. Both were with ac off. Sent from my EVO using Tapatalk 2 |
So @Lex; what would it mean if I'm not getting any lower vacuum at idle? |
Sent from your couch |
Does your vacuum fluctuate at all while the car is running, or does it stay pretty steady (at idle or under steady load)? |
| All times are GMT -7. The time now is 06:29 AM. |
