-   -   DISI Compression Results (http://www.mazdaspeedforums.org/forum/f10/disi-compression-results-43395/)
Ziggo 03-11-2013 08:07 PM
The vacuum test is just a roundabout way of checking compression. If you are directly measuring compression then I don't really see its usefulness.
Nliiitend1 03-11-2013 08:25 PM
Indeed. Best not to "get lost in the weeds" talking about vacuum...
I'd say a leakdown test is in order. ;)
daafisch 03-11-2013 08:36 PM
I was just curious how it was related. As for your previous question, no it doesn't fluctuate. seems to stay pretty steady. I know while engine braking it pulls about 23-24"
Now to find time to do a leak down test...
Lex 03-14-2013 01:21 PM
Vacuum readings are a "constant" gauge on compression and that's why I like them. You can keep an eye on it without breaking out the tester but be careful as engine temperature and ambient conditions (temperature, pressure, altitude) all affect the vacuum reading.
If you have a good gauge (or monitor the MAP sensor) you can see a change in your average vacuum if compression drops and this is something you keep an eye on.
phate 03-14-2013 01:34 PM
It was really interesting to be able to literally watch the compression come up in my new engine. When it was brand spanking new, it would only pull ~18inHg when fully warmed at idle. Over the first 400 miles, it slowly crept up to holding ~22inHg, and it has been steady for the past 1500 miles. Definitely a good indicator for if/when things start to go south.
My compression tested at 228/228/230/232 once it leveled out.
qtrmile beast 03-25-2013 10:54 AM
So i just broke 50,000 on my built motor and i did a compression test last night here are the results..
180
http://i206.photobucket.com/albums/b...ps2c7f3081.jpg
170
http://i206.photobucket.com/albums/b...psd33491fd.jpg
180
http://i206.photobucket.com/albums/b...ps06dd390b.jpg
180
http://i206.photobucket.com/albums/b...psa4254edc.jpg
p057 03-26-2013 06:39 AM
did mine last night. sobering results
160
155
155
170
MS6
72k miles
1 full year BT
spraying meth for the past... 3-4 months?
Originally Posted by Lex (Post 1941322)
Did this start happening after a track event? It may be the ringlands. If you watch the hot idle vacuum readings you should be getting less vacuum at idle with lower compression. Any other drive ability issues aside from the oil in the intake?
I get ~21-22 in/mg
i've had "coolant issues" in the past where tube falls off, gets disconnected, shop that did clutch forgot to put coolant back in....
so my car has "overheated" about 3 times. I usually catch it way before the needle goes up to the top, thank god to Dashhawk and alarm set to 230*. But overheating is still no bueno. I'll attribute my shitty numbers to those instances.
Yeah leakdown test is coming up next.
Kyle Undefined 03-26-2013 08:04 AM
MS3 - 68k miles. I'm pretty happy with my results, was fearing the worst.
170 - 170 - 160 - 160
Lex 03-26-2013 09:45 AM
160
155
155
170
MS6
72k miles
1 full year BT
I get ~21-22 in/mg
It's unlikely you lost compression from hitting 230F coolant temps. If anything you might have a leaking head gasket from this but not compression problems.
I don't even think you have compression problems. Do you have excessive blowby? Consume oil? Did you crank until the needle stopped rising in all cylinders?
As these motors wear compression will fall off a bit but I think some of these lower numbers can also be attributed to the testing procedure and tester itself.
silvapain 03-26-2013 10:19 AM
Originally Posted by Lex (Post 1968610)
It's unlikely you lost compression from hitting 230C coolant temps. If anything you might have a leaking head gasket from this but not compression problems.
230F, not C. Silly Canadian.
sidekick 03-26-2013 10:55 AM
My compression test numbers before buying the car:
190 - 165 - 150 - 175
I have noticed that since I started running 18PSI, it seems like I've been losing/burning more oil. Every fill up (about 1 week/200-250 miles), I lose about 1/4 of a quart of oil. I assume that is PCV related, since it only started happening after turning up the boost, but an OCC should put an end to that, if that's the case.
Clearly there is something up with cylinder #3 , but I have not done a leak down test. The car seems to run fine overall, maybe a slightly rough idle, but it also has not had the valves cleaned yet and needs a new VVT actuator/timing chain. It makes pretty good power, but @cld12pk2go; pointed out that I seem to be making lower numbers than he would expect. However, I'm also right on par with my old speed3 with the same mods in terms of crank horsepower, so I'm not too sure what to think.
Honestly, if anything, I expect it to be a cracked ringland. The oil loss and low compression point right at that. I will do a leakdown test sometime soon and try to figure it out. The best part? The dealership tech who did the test stated "the engine is in very good health" on the work order. It's pretty much outside of Mazda's specs even if you don't count the highest cylinder. It has received a healthy amount of beating over the last 3 months, so I may do a compression test next time I pull the TMIC, just to see if it has changed.
p057 03-26-2013 11:00 AM
I figured as much about the headgasket, no sign of poopoo coolant in my oil.
I can't tell if i have excessive blowby because i only drive .8miles to work, I get a TON of water in my OCC so I have to drain it nearly weekly in the "winter" due to the milkshake machine I have going on in there.
The intake tract was never connected until I installed the Cobb prototype inlet hose, but I did have a crankcase filter, never absorbed any oil on it though. Doesn't look like the hose has anything in it really either, just a very thin film (light vapors?) inside.
After reading through the entire thread, i saw that some of you guys cranked up to 20 times... i think I only did 3 to 6 at the most. Even though it was levelling off pretty decently. Maybe I'll get a second tester to try this out again.
thanks for the input.
qtrmile beast 03-26-2013 11:42 AM
160
155
155
170
MS6
72k miles
1 full year BT
I get ~21-22 in/mg
Check for head lifting.... does coolant come out of the over flow or past the cap after hard driving? when the car is cold start it up and see if the water shoots out of over flows really fast.....
p057 03-26-2013 12:05 PM
Nope, none of that. I think something may have been a little off during the test. car is probably fine.
thanks though.
Lex 03-26-2013 12:49 PM
Guys and gals, cylinder 3 takes more cranking than the other ones to bring up the compression on the gauge. Don't just crank 3 times. Crank until the needle stops rising with foot to the floor (14-18 cranks) and all spark plugs out.
If you want to do a more thorough test do a leakdown.
p057 03-26-2013 01:36 PM
the "gals" part was for me huh?
I stopped because friend said the needle stopped after about 6 cranks.
like i said, i'll try it out again and i'll be a little more thorough. we did this when going out to eat and decided to do it on a whim since he had the tester in his car. We were pretty hungry so maybe we were rushing a bit.
Still, they're within tolerance spec and arent horrible numbers, so i feel somewhat OK about that :)
alphasaur 03-26-2013 03:55 PM
180 180 150 180
cranked 3rd alot with hopes and dreams.
Lex 03-26-2013 03:59 PM
Originally Posted by alphasaur (Post 1969383)
180 180 150 180
Oil in the intake?
alphasaur 03-26-2013 04:13 PM
Originally Posted by Lex (Post 1969391)
Oil in the intake?
Yessir.
Nliiitend1 03-26-2013 04:43 PM
:frown:
Dano 03-26-2013 05:05 PM
180 180 150 180
sorry to hear man..although not definitely a ringland at this point. I would check piston height next.
himurax13 03-26-2013 05:08 PM
Originally Posted by alphasaur (Post 1969430)
Yessir.
What is your oil consumption?
alphasaur 03-26-2013 05:12 PM
I don't really go through much, MAYBE half a quart every oil change (I do 3-4k miles rotella t6)
Queen - Another One Bites The Dust - YouTube
Don't have any clutch pedal vibes if you're alluding to a bent rod. Will do a height check though.
Dano 03-26-2013 05:15 PM
yeah it looks eerily like my compression results and mine ended up being a ringland. No idea what a slightly bent rod would look like as far as compression results go nor if it would cause vibes.
But you can drive indefinitely on a cracked ringland but NOT with a bent rod...IMO at least, so it's good to rule the rod out.
cld12pk2go 03-26-2013 05:16 PM
I cranked over the engine about 10-11 revolutions...
Compression check results:
Driver side to Passenger side (I forget the numerical order)
182-176-174-177
4.5% delta between max/min. I can live with that at ~500whp.
http://i77.photobucket.com/albums/j6...psde7696a8.jpg
I love these motors...
alphasaur 03-26-2013 05:19 PM
to measure for a bent rod could I just insert a metal rod into each cylinder and mark off where it exits the valve cover? Then see if the corresponding cylinders match? Or is this not accurate enough to diagnose a bent rod? Makes sense in my head but I don't have experience working on cars other than the speed :dunce:
Dano 03-26-2013 05:23 PM
That will do the trick if its bent enough...I went overboard and used a dial gauge b/c I could find no appreciable difference using a screwdriver, which just confirmed I didn't have a bent rod...lol
my anal retentive results can be found here.
http://www.mazdaspeedforums.org/foru...ml#post1662597
himurax13 03-26-2013 07:24 PM
Well if the bent rod is ruled out, what does one do? My leakdown test was inconclusive and my compression test was 160 accross the board. I ruled out a bent rod by neasuring with a long piece of paintball macroline.
I figure might as well start VTA the crankcase and start prepping for rebuild or stocking out and trading in. :rolleyes:
Sent via smokey turbo.
alphasaur 03-26-2013 07:27 PM
afaik, you're looking for differences. I'd be happy with 160 across the board.
Dano 03-26-2013 07:30 PM
truth...having equal numbers is more important than what the actual number is.
160 might just be the tester used.
himurax13 03-26-2013 08:12 PM
VTA the crancase still allowed me to make decent power and mileage but I could fill up my SSP can in a few minutes.
After I stocked out, the excessive blowby caused a misfire in cylinder #4 (from bent, burned valve) and the engine went to shit in a few weeks.
sidekick 03-26-2013 08:51 PM
A bent or burned valve isn't going it cause blow by. What did the bent valve have to do with anything? You would just lose most of the compression in that cylinder.
himurax13 03-26-2013 10:02 PM
The burnt valves just caused lots of smoking and oil consumption (45 psi). I suspect multiple broken ringlands causes the blowby, haha.
sidekick 03-27-2013 01:01 AM
Ahh, I see. I didn't realize you had a bent valve and cracked ringlands. Sorry.
Anyways, I tried to do a compression test today, but the HF tester I bought was apparently DOA... Too bad I ordered it 5 months ago. The gauge just sat at zero while cranking. FUCK. So while I had the plugs out, I took some pictures and checked them out. Clearly something is going on in cylinder 3. The old plugs didn't look like this when they came out and I've only recently started losing oil, so I assume it has something to do with modifications and higher boost. Maybe a bad PCV valve? Anyways, here are the plugs:
http://farm9.staticflickr.com/8097/8...39de0885_b.jpg
http://farm9.staticflickr.com/8514/8...edab213b_b.jpg
http://farm9.staticflickr.com/8097/8...b001a546_b.jpg
http://farm9.staticflickr.com/8245/8...eabc4588_z.jpg
Tokay444 03-27-2013 04:27 AM
Did you put any anti seize on those plugs prior to instal?
mrQQ 03-27-2013 09:34 AM
why does #3 require more cranking?
sidekick 03-27-2013 11:54 AM
Yes, on all of them. Why? There is a little antiseize on them in the pictures, but most of that is definitely oil.
himurax13 03-27-2013 12:08 PM
Yeah, that is definately not a good sign ...
sidekick 03-27-2013 12:15 PM
Yeah, it seems that whatever is happening was probably caused by me as the old plugs I pulled had little to no signs of oil contamination. I'm wondering if the PO(s) ran low octane gas most of its life and ended up damaging a ringland. Then I came along and cranked up the boost and timing and it finally gave. Not really sure at this point though. I guess I should start selling the aftermarkets parts I have accumulated to fund a rebuild. :ugh:
himurax13 03-27-2013 12:17 PM
Personally I would run a vented OCC and then start saving up for the rebuild. I was able to run for almost 6 months like that and I had ridiculous amounts of oil going into the catch can. I would avoid selling all of your aftermarket parts since it is a pain to collect in the first place.
Page generated in 0.24058 seconds with 11 queries
