-   -   DISI Compression Results (http://www.mazdaspeedforums.org/forum/f10/disi-compression-results-43395/)
sidekick 03-27-2013 12:20 PM
Originally Posted by himurax13 (Post 1971060)
Personally I would run a vented OCC and then start saving up for the rebuild. I was able to run for almost 6 months like that and I had ridiculous amounts of oil going into the catch can. I would avoid selling all of your aftermarket parts since it is a pain to collect in the first place.
I already have a JBR OCC sitting in my room, so maybe I'll install that sooner rather than later. I can probably go for quite a while on a cracked ringland, but I'd rather build before it blows up.
Tokay444 03-27-2013 01:10 PM
I would just sell it and get a brz. They're at 640whp already.
Stock block.
himurax13 03-27-2013 01:40 PM
Just buy this little upgrade before you install it. It will keep oil out of the intake.
New Products : James Barone Racing, Custom Fabrication
sidekick 03-27-2013 02:47 PM
Stock block.
Lol on my way to the dealership now.
But seriously did visconti tuning actually make it up that high on stock internals?
Tokay444 03-27-2013 02:53 PM
Yup
sidekick 03-27-2013 03:18 PM
Originally Posted by Tokay444 (Post 1971351)
Yup
I find that hilarious that the car that comes stock with about 200HP has stronger internals than their bread and butter WRX/STI that come factory boosted with quite a bit more power... SubaruLOL.
Tokay444 03-27-2013 03:19 PM
That's Toyota's influence.
They've been putting 1000hp cranks in 140hp cars for decades.
himurax13 03-28-2013 03:07 AM
Originally Posted by sidekick (Post 1970278)
Ahh, I see. I didn't realize you had a bent valve and cracked ringlands. Sorry.
Actually I am just speculating cause Mazda recalled my motor but I haven't heard if anyone blowing through as much oil as I did. I wouldn't be surprised if my #4 had a hole in it.
I ditched my HF tester cause the guage stopped at 75. I bought a nice craftsman setup that had a customer review rating of 5 stars.
Anywhoo I tested a 08 with 110k+ miles running 21 lbs boost on a stage 1 map with K04 and 91 octane from passenger to driver side:
170, 170, 160, 170.
Installed a beaner last weekend.
Tested a 12 with less than 10k miles running a slightly modified Stage map on a K04 at around 17 lbs if boost from passenger to driver side:
168, 168, 164, 80 (87 Wet)
I told him to stock out. I am not sure how he should document this to get warranty coverage.
Sent via smokey turbo.
sidekick 03-28-2013 11:26 AM
170, 170, 160, 170.
Well was the compression test on his car just to check over-all health of the engine or did you suspect there was a problem? Just have him tell them it feels like it is down on power and request a compression test. Lol.
himurax13 03-28-2013 11:39 AM
Well with all of the fail I have noticed lately, I find any excuse to whip out the compression tester. ;)
http://www.sears.com/craftsman-compr...p-00947089000P
sidekick 03-28-2013 11:53 AM
That's probably for the better. Lol. But, oil consumption and loss of power are probably the main things someone would notice due to low compression in one cylinder.
sundowned 03-30-2013 03:19 PM
if anyone still looking for results
pass to driver 170,165-170,175,170
mods corksport intake and tip, hks ssq, and an ap stge 1 93 tune
kimura 04-16-2013 08:41 AM
just hit 80K miles so I thought I'd do a comp test.
results were ~178 ~177 ~178 ~179
this is exactly 7 cranks for each cylinder, with all the plugs out, foot on the gas pedal. I've put about 11K miles on the 3071 over the course of a year.
himurax13 04-16-2013 09:46 AM
After 1500 miles on the replacement engine and stock everything, 185, 180, 180, 180.
Sent via stocked out for a while ...
BigBoostMS3 04-17-2013 08:44 AM
I did mine last week. ~85k on it. ~15k of that has been modded.
180-182-178-180
breakfasteatre 04-17-2013 04:21 PM
last night, 42k kms on my poo
175-175-170-150
a build is already in the works, alot of racing on the weekend..
mrQQ 04-22-2013 11:41 AM
you guys make me jealous
soul.survivor 04-25-2013 07:34 AM
Last weekend, 89k.
190-190-190-185
Carbon buildup on tops of pistons??
himurax13 04-25-2013 01:29 PM
For @SoCal MS3; at approximately 63K on a bone stock 2008 Speed:
185, 180, 185, 185
I think she is ready for Big Turbo. ;)
Tyhackman15 04-25-2013 01:36 PM
2008 53k tuned for ~2k miles
180-185 across the board
SLOWHATCH 04-25-2013 02:26 PM
I'll be trying mine again soon. Anyone have any tricks to keep that damn adapter piece on the tester and not get it stuck every time in every cylinder? I spent hours doing my test due to this and that shit had me ready to burn my car to the ground. :feedback:
himurax13 04-25-2013 02:31 PM
Are you talking about the part that threads onto the sparkplug hole? The threads on the adapter might be shot. You could try a little oil or some anti-seize if you are frisky. It should spin out easily.
Tyhackman15 04-25-2013 02:32 PM
Tape it on after threading it fully (electrical works), thankfully I thought of that right before testing the 1st cylinder
Tokay444 04-25-2013 02:36 PM
Just crank it tighter onto the the tester, tighter than into the plug well.
himurax13 04-25-2013 02:54 PM
OK, I must have read that post wrong. Is the adapter coming off the tester itself or is the part that screws into the sparkplug hole getting stuck?
The Craftsman Tester I posted earlier is the tits because the adapter simply screws into the sparkplug holes and then attached to the guage with a quick disconnect. The test itself takes less than the time it takes to smoke one cigarrette.
Now if you have POS Harbor feight one, I used teflon tape and 2 crescent wrenches to make sure the quick disconnect piece is attached properly to the adapter piece that goes into the sparkplug hole.
fredricktsang 04-25-2013 04:22 PM
anyone know where to get just the hose/adapter/fitting to the gauge?
Tokay444 04-25-2013 04:25 PM
Try emailing the manufacturer.
skiptowncat 04-26-2013 10:49 AM
Done on a cold engine
110-100-75-100
What the fuck!!!
btstarcher 04-26-2013 10:56 AM
Needs to be done at close to operating temp.
Lex 04-26-2013 11:14 AM
110-100-75-100
What the fuck!!!
Did you push the throttle to the floor, how many times did you crank, was the tester good?
skiptowncat 04-26-2013 12:00 PM
I don't know wether the throttle was pressed. I'm going bnr soon so ill get the valves cleaned at the same time. I just hope it lasts till then.
himurax13 04-26-2013 12:23 PM
Performing a proper compression test(and leakdown if the test results are bad) is far more important than getting a Beaner or cleaning your valves. If your engine needs a rebuild, then there is no point in doing those things.
The Beaner will put more stress a dying motor and will force a rebuild much sooner.
Tokay444 04-26-2013 12:33 PM
Replace lost compression with more boost.
himurax13 04-26-2013 12:38 PM
Tried that, didn't last too long, lol.;)
Sent via stockish Black Mica Pu
skiptowncat 04-26-2013 01:42 PM
Going forged as well this year.
timjs 04-26-2013 03:34 PM
110-100-75-100
What the fuck!!!
Try a different gauge, I doubt that's anywhere close to actual.
edit:If the engine runs!
skiptowncat 04-27-2013 12:12 AM
I will certainly be getting it retested ASAP.
mps6dave 04-27-2013 02:32 AM
Throttle was to the floor. Engine did 10 compression strokes .compression tester was brand new as well and i later did mine and got 170psi right across bar cylinder 3 which was 155psi.also done on a mildly warm engine.
skips car on roadtest actually feels to have uneven power across the cylinders ,having solid mounts help you feel it more.told him to try a seafoam through it along with a fuel treatment ,then after 1k get it retested.this should tell us if its a carbon build it sticking the rings or the valves being poorly seated due to the usual disi intake
skiptowncat 04-27-2013 04:30 AM
I'll get a leakdown test as well
Metal409 05-01-2013 01:29 PM
Originally Posted by Metal409 (Post 887325)
Went ahead and tested my car again today. 2009 Speed3, 42,600miles, more than half of that was stage 1, car is stage 2 now. Was roughly 80degrees out when I tested, 570~ ASL.
1: 185
2: 185
3: 185
4: 185
Only did 6 cranks to get these readings, 7 on cylinder 1.
Did another test today, same location about 78deg outside and while the car was still hot. Just over 65k miles on the car now and back to stock.. for now. Cranked for about 5 seconds on each:
1: 190
2: 190
3: 188
4: 190
Page generated in 0.21708 seconds with 11 queries
