-   -   DISI Compression Results (http://www.mazdaspeedforums.org/forum/f10/disi-compression-results-43395/)
Tokay444 06-12-2013 09:40 AM
What percentage leak did you measure?
DTKII 06-12-2013 09:50 AM
About 30% 75psi down to 55psi. I'm getting ready to email SPEEDPERF6RMANC3 for a quote on a short block.
Nliiitend1 06-12-2013 09:58 AM
Originally Posted by Nliiitend1 (Post 1321511)
I checked my compression tonight. '08 MS3 with ~49K miles.
From left to right, it was:
128
126
127
129
I need to check it again with a different gauge/tester, as I'm not too confident in the accuracy of the one I used.
Related thread here:
http://www.mazdaspeedforums.org/foru...-issues-92171/
Finally got around to doing this again with my shiny new compression tester and here are the results (car now has 61,819 miles):
Again, from left to right (with the engine warm):
186
182
189
186
I feel a bit better about those numbers. :)
Dano 06-12-2013 10:16 AM
shitty tester was shitty
What you can take away from any test is consistency. even low numbers, if they are all in the same ballpark is a good indication the motor is healthy and the gauge is the problem.
fivefingerdeathpunch 07-22-2013 10:27 PM
bumpity bump
did a compression test today. did it how a friend said to do it. dont think the engine was warm by the time i did the test
anyway got from left to right.. 170, 157, 170, 157
one person said thats fine... do you guys agree? i liked the consistency but obviously two are lower than the other two. should i redo with the proper method from the first page?
himurax13 07-22-2013 11:05 PM
Originally Posted by fivefingerdeathpunch (Post 2172388)
bumpity bump
It isn't terrible but you should have done a wet test.
Sent via blown passenger side speakers.
fivefingerdeathpunch 07-22-2013 11:15 PM
yeah i shouldve done it exactly as mentioned on the first page but my friend said he knew how to do it so i did what he said haha. i may redo it and do a wet test too if its the same results
Tokay444 07-23-2013 06:01 AM
A compression test doesn't really paint a full picture.
For example, my compression has always been in spec (when I do it by the MSF disi standard testing procedure), but my leakdown shows 31% leak in cyl 3.
If you go to the trouble to do a comp test, do a proper leak test at the same time.
sidekick 07-23-2013 01:16 PM
What is your compression number on that cylinder? It must be lower. That's a ton of leakage. How high does the gauge read on the first compression stroke when testing that cylinder? A low reading on the first stroke can also indicate issues, even if overall compression numbers are in spec.
scubasteve711 07-23-2013 01:26 PM
Agreed that a comp. test doesn't tell the whole story, but a cylinder that leaks down at 31% is going to have a variance in the comp test....
Tokay444 07-23-2013 01:53 PM
Compression at time of leak down was 182-176-178-180.
First pump is 90. Same as the rest.
sidekick 07-23-2013 02:04 PM
Something isn't adding up. 30% leakage is significant. Did you find the source of the leakage? Rings, valves?
EDIT: Don't you have an issue with oil in your intact tract? Those compression numbers could be similar to "wet test" numbers if a significant amount of oil is entering your combustion chamber.
Tokay444 07-23-2013 02:34 PM
It's rings. Most likely a broken land. I burn a litre of oil/1000kms.
sidekick 07-23-2013 02:36 PM
Very interesting findings. Maybe your rings still seal well, but the cracked ringland is the source of the leakage? Any plans for a teardown?
Tokay444 07-23-2013 02:42 PM
Not until after my wedding.
btstarcher 07-23-2013 03:22 PM
Fucking liters....WTF Canada. :unitedstates:
Tokay444 07-23-2013 05:29 PM
Litres*
silvapain 07-23-2013 07:31 PM
Originally Posted by Tokay444 (Post 2173965)
Litres*
Quarts*
Sent from my iPhone using Tapatalk 2
BigRedSpecial 07-23-2013 07:43 PM
*Furlongs
Micha 07-23-2013 07:47 PM
Fathoms*
BigRedSpecial 07-23-2013 07:51 PM
My car gets 16 rods to the hogs head, and that's the way I likes it
Dano 07-23-2013 11:14 PM
^^^^ fagots*
theurgy 07-23-2013 11:23 PM
You realize the rest of the world uses the metric system now right?
btstarcher 07-24-2013 12:28 AM
'Merica. Fuck you.
:usa:
:fuckyou:
Tokay444 07-24-2013 03:52 AM
Originally Posted by Dano (Post 2174475)
^^^^ fagots*
faggots*
Originally Posted by silvapain (Post 2174156)
Quarts*
almost.
Dano 07-24-2013 09:54 AM
Originally Posted by Tokay444 (Post 2174576)
faggots*
Thanks for the spelling correction...I knew a faggot would know how to spell it...you fell right into the trap :)
now rebuild your POS motor already.
Tokay444 07-24-2013 10:02 AM
tarp*
Dano 07-24-2013 10:04 AM
negative...you did in deed fall into my T R A P !
Tokay444 07-24-2013 10:21 AM
i really just want you to wrap me up in your tarp.
baby oil?
Dano 07-24-2013 10:27 AM
hahaha
not right now...maybe later?
azazelthegreat 07-28-2013 02:33 PM
Cylinders 1 3 and 4 were around 180
Cylinder 2 was at 60
Looked for leaks
Hooked my compressor to c2
No air from anywhere
himurax13 07-28-2013 02:37 PM
Looked for leaks
How did you look for leaks?
azazelthegreat 07-28-2013 02:48 PM
w
Air compressor hose where the cylinder 2 plug goes
Listened for air from intake oil cap area abx exaust
Came from intake at first but my friend told me to crank the motor once and it went away.
Going to his house in a few days to redo it just in case
btstarcher 07-28-2013 03:06 PM
I thought that leakdown test required you to be at TDC? Anyway also check around injector seals and dipstick. If it's coming from intake, is that intake valves?
Dano 07-28-2013 03:51 PM
Yes TDC compression stoke otherwise air just goes out the valves.
Tappin
ms3blackmica 08-05-2013 09:43 AM
Checked Compression again @ 73,000 miles yesterday. Motor was warm but not hot.
Still looking good.
203 202 202 205
https://www.youtube.com/watch?featur...&v=h_c66_ZHe4E
btstarcher 08-05-2013 09:50 AM
Still looking good.
203 202 202 205
I want to borrow your tester.
ms3blackmica 08-05-2013 09:51 AM
I would gladly send it over to you Ben but it isn't mine!
ArmanRus 08-05-2013 10:16 AM
I need to do this. I'm at 102k miles and although she's pulling strong and not burning any oil, I want to for the peace of mind.
LatinKraze 08-05-2013 09:48 PM
2007 106,000 miles
Fully Bolted +BNRs3
119-121-120-121
On two different gauges (HF and O'Rileys). Wet test gave me an extra 2-3 psi. My buddy is letting me borrow a tester where he hits 180 psi. We'll see what his gauge yields and we'll also be doing a leak down
Page generated in 0.21530 seconds with 11 queries
