Threw P0302 CEL which is cylinder 2 misfire. Pulled and replaced plugs, swapped coil packs and did a compression test. Got the following 125 80 155 155 I'm looking for a used block to build :boggled: I knew it was coming just thought it would take a little longer. |
Just doesn't seem right to hit the "like" or "thank" button. Kinda that awkward situation. We feels for ya, butt, ya gotta pay when you wanna play. :knockedout: |
I would say its better to have low compression than a hole in the block and messed up head :) much less $$$ needed for rebuild |
take it from me guys. ALWAYS pair a leak down test withy our compression tests. that way you know you're seeing the big picture. |
"We don't pull no stinking relays." Just hold the go pedal all the way down to the floor and it cuts off fuel flow to the cylinders. |
Edit: blazing saddles haha love it |
just got mine back from the shop with these results... 170 165 150 177 opinions? im looking to tune the car asap but want things running as well as i can get it before. |
fuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu |
Sent via blown passenger side speakers. |
Compression test last year was 180 on all 4 cylinders. Did anyone 2 days ago and got 180,180,150,180. Add a teaspoon of oil in cylinder 3 and it popped back up to 180. That's pretty much a sign of cylinder ring right? I'm guessing theres no way it's the injector seal =\ |
Stop doing comp tests without leak downs! |
Since we did one on my PU this weekend as it has burned a qt of 5w 30 in 2500 miles I figured I throw up our findings. Compression test was done with two different testers for accuracy and right after driving 100+ miles to @silvapain;s house so plenty warm. First test: Cyl 1= 192 Cyl 2= 192 Cyl 3= 195 Cyl 4= 195 Second test: (within 5 mins of first test) Cyl 1= 190 Cyl 2= 186 Cyl 3= 190 Cyl 4= 190 So my concerns went down somewhat but when i went to put the hotpipe (fmic) back oil residue was present with the finger test but not visible at first glance. Poor ko4.... Also after spending some time yesterday looking at shit underneath I found a small amount of buildup at the crankcase but nothing on the undertray. RMS leaking was the diagnoses from my fellow Nator IL gearheads. Figured data is data, whether good or bad but internals seem healthy with just under 47K of miles put on them. Sent using stupid fucking Swype! |
id originally took the car in to get a leak down test but they didnt do it saying it was pointless since i had a compression test done. fuuuuuuuuuu also, the car was running very lean according to the mechanic after inspecting the spark plug. they found that the gasket around the bpv was fucked and replaced it. could any of this help in me getting that 150 in cyl 3? |
So in others words they've never done a compression test before, since those subby guys never take their plugs out. |
Did my first compression test with a brand new craftsman compression tester (old one doesn't seal). I beat the shit out of this car and I currently have 42000 hard earned miles. I've been wanting to do one for a while now but I've been busy. Car was not 100% warm so I'm expecting slightly higher numbers on a warmer car. Dry only 1 - 175 2 - 174 3 - 175 4 - 172 Very happy with the results. Car runs perfect so I expected no less. Also checked the plugs (they have 10K on them) and they're very clean and gap is spot on. I gotta say this MZR engine is holding up damn well. |
Got out of class and did a compression test after going to get gas and back to my dorm. Pretty satisfied with my numbers at 15k running Pennzoil Ultra 5w-30. 1= 180 2= 175 3= 179 4= 180 |
Just did a test on my motor after finishing my break in.(1000) miles! It wasnt very warm. 1=180 2=180 3=180 4=180 Will do another test when i have the motor warm |
knowing what i know now, with my motor, i honestly would only do a compression test SECONDARY to a leak down from now on. So much more vital information to be had from a leak test. |
Figure i'd throw in my numbers. Did a test yesterday just to see how healthy the car is. Car is a 2008 with 60200 miles and fully bolted with e85 and meth. Car has been raced a bunch of times and driven aggressively sometimes but i baby it plenty and maintain it well. Numbers were 188-183-183-190. |
09 MS3 with 50k miles 195 - 192 - 190 - 190 Mods: SRI, OCC, EGR Delete, Injector Seals, AP + Nishan tune ;) |
Swapped plugs this morning so I decided to do a compression test while I'm at it. Car was at operating temperature. 1 - 182 2 - 180 3 - 181 4 - 180 :fest30: |
Nice numbers! |
08.5 MS3 with 84K on the clock. 135 137 135 135 Thinking the gauge was off. (cheap one I borrowed) Car runs like a champ, so I figure its ok. I would like to do a leak down at some point. |
| All times are GMT -7. The time now is 06:29 AM. |
