177/125/109/155. Tested today. No leak down. There's still absolutely no trace of smoke when accelerating hard and the car still pulls pretty good. When the oil consumption started suddenly in May/June I said that if I have to open up the engine even only for replacing some valve seals, I will rebuild it completely. This is going to be a costly word keeping. |
I posted a while back. Two of my cylinders were around 180. 3 was at 155 and 4 was slightly higher. Additionally, 3 leaked over 30% on leakdown. Engine ran ok but smoked real bad. It appears that the smoke was caused by the cylinder and the turbo. I've built the motor and get very little smoke, however, the turbo smokes here and there just not as bad as before. Also, I can smell burning oil out of the exhaust. I've pulled the turbo yesterday and it did in fact leak. I am replacing the CHRA with a rotomaster part and will report results. I haven't seen anyone use that CHRA yet. However, when I've pulled the old motor apart the rings looked fine. I think I could have probably gotten a little more out of it. |
2008.5 with 72K miles I think the only mod is an ebay test pipe from the previous owner 150 155 152 148 |
2010 MS3 54k miles Running beaner for about 4k miles, always @rfinkle2; tuned. 190 across the board. Dry. Sent while granny shiftin' and not double clutching like I should |
What kind of power are you making these days? Any E85 or meth? |
1 Attachment(s) tried to do a comp test, tester from vatozone was shit and broken. regardless pulled the plugs and they look healthy at least. 81k miles, gtx2867r went in at 50k. |
http://s28.postimg.org/qer20camx/IMAG1916.jpghttp://s28.postimg.org/vtzs1b26x/IMAG1917.jpghttp://s28.postimg.org/6f5uiadi1/IMAG1920.jpg |
I am still planning on doing meth once the spring comes! Sent while granny shiftin' and not double clutching like I should |
Sweet! You're about 10whp ahead of me on both counts. Interested to hear how your meth project turns out. |
And I will for sure. @maisonvi; and myself are going to try a meth throttle body spacer and see how it turns out...it's just such an easy option. |
My next mod is my clutch. I guess 154,000 miles was all the abuse she could take. Still trying to finalize my tune with Lex, but the clutch can't handle WOT in 4th anymore. |
GL man, make sure to post up how it all goes! |
Fer sher!! |
I did a compression test at the dealership yesterday as I had other things to do, results all accross the board was 205. He suspects the engine needs a good cleaning but it's in good shape. 2010 with 74 000 miles |
That's way too high. You need to take that car out and drive it hard RIGHT NOW! It's like blood pressure - your car needs more exertion! |
Just tested 180's across the board. 100k on the clock. Self tuned since about 50k. 3071 has only been on for about 2k. |
Did a quick compression test last night after I noticed the clamp on my turbo inlet had lost the tightening nut. The turbo had some dirt on one of the corners from a big air leak :(. Luckily no damage done to the turbo or the motor, compression still sitting at a perfect 180 across the board @53600 miles. |
1 Attachment(s) My compression was 180-180-180-zero. 138,XXX on motor. stage 1 93 ots for 20K. Burnt valve. |
That's a good one. |
what caused it? |
too much boost and too low timing. |
back in may, after I hydrolocked, I got these numbers with HF gauge 160/165/140/160 dry 175/170/150/165 wet wood dowel and sharp pencil showed no badly bent rod no vibes in clutch been driven relatively easy for 3K since then I have some fresh plugs on the way, I plan to use my caliper to get more exact with the rod check, and redo comp test and do the leakdown thing. might be I popped ringlands? |
Do a leak down. |
dry, and warm for the test? |
Dry for sure. I would give it about 20 minutes after shut down. I usually let it sit for ten, and then start tearing it down. |
done, well done friday, after the plugs show up |
Had a bit of time this weekend so I did some boost leak testing and a compression test. Car has 57300 and was completely cold. 1-180 2-180 3-179 4-179 |
i did a comp test in utah (roughly 4500ft asl) at 90,000 miles every cylinder was 162. ill take it |
4 Attachment(s) Two months ago I did a compression test with a autozone gauge... I got 165 in all 4 Cylinders, 14K on a new engine, Needless to say I was dissapointed, but hey at least numbers were consistent, so finally today i got a brand new gauge and decided to try this again... really happy with the new results, Numbers are DRY on a somewhat warm engine, didn't do a wet test |
So I did mine after I experience a cylinder 2 misfire. Did compression test and it said fuck off. 150,30,150,150 tested warm . |
5 Attachment(s) Did the test on Sunday. Been wanting to do it for future references. Have almost 90k miles on the slow thing. Did the test about 10 minutes after I parked, drove around for about 20 minutes before. I want to believe the numbers but not sure, I might get another tester and see what it reads. Should I maybe consider a cold test? Only got to page 13, going to read rest later. Top left: passenger Top right: passenger middle Bottom left: driver middle Bottom right: driver |
You're golden. |
Yeah I hope so haha. Kind of a dead thread too. But I still wanted to post my info. Sent from my iPhone using Tapatalk |
MY 30PSI CYLINDER 2 1 Attachment(s) Well I've gotten the block and head back from the machine shop now I'm just waiting on my bearings to come in the mail then i'll begin the assembly process. I never got around to showing the problem with cylinder 2 but the picture below will explain all. :madfawk: |
Yeah... same cylinders (2, 3 or both), same spot (the end towards the exhaust valves). |
cyl one 195 cyl two 198 cyl three 195 cyl four 200 Test was last month at 96,000 mi. Used Craftsman tester. This was prior to installing FMIC and going from stage 2 to stage 3 cobb OTS map. See sig for other mods. Live in Florida. Drive it like I stole it almost every day, but always take it easy on warm up and cool down. Change oil every 5K mi, always synthetic, 5w-40 Rotella T as of late. I was absolutely thrilled! Especially since I'd like to get at least another 100K mi and/or five more glorious years out of this wonderful car. |
If you wanna keep that compression the way it is, I suggest you get a real tune. |
Edit: Just wonder if I should clean the intake valves before getting a tune? Perhaps @Lex; can chime in? 100K miles, and never cleaned the valves. Already have an air compressor, just would need the walnut media and the blaster tool. |
| All times are GMT -7. The time now is 06:29 AM. |
