-   -   DISI Compression Results (http://www.mazdaspeedforums.org/forum/f10/disi-compression-results-43395/)
Dano 03-26-2013 05:05 PM
Originally Posted by alphasaur (Post 1969383)
180 180 150 180
cranked 3rd alot with hopes and dreams.
sorry to hear man..although not definitely a ringland at this point. I would check piston height next.
himurax13 03-26-2013 05:08 PM
Originally Posted by alphasaur (Post 1969430)
Yessir.
What is your oil consumption?
alphasaur 03-26-2013 05:12 PM
I don't really go through much, MAYBE half a quart every oil change (I do 3-4k miles rotella t6)
Queen - Another One Bites The Dust - YouTube
Don't have any clutch pedal vibes if you're alluding to a bent rod. Will do a height check though.
Dano 03-26-2013 05:15 PM
yeah it looks eerily like my compression results and mine ended up being a ringland. No idea what a slightly bent rod would look like as far as compression results go nor if it would cause vibes.
But you can drive indefinitely on a cracked ringland but NOT with a bent rod...IMO at least, so it's good to rule the rod out.
cld12pk2go 03-26-2013 05:16 PM
I cranked over the engine about 10-11 revolutions...
Compression check results:
Driver side to Passenger side (I forget the numerical order)
182-176-174-177
4.5% delta between max/min. I can live with that at ~500whp.
http://i77.photobucket.com/albums/j6...psde7696a8.jpg
I love these motors...
alphasaur 03-26-2013 05:19 PM
to measure for a bent rod could I just insert a metal rod into each cylinder and mark off where it exits the valve cover? Then see if the corresponding cylinders match? Or is this not accurate enough to diagnose a bent rod? Makes sense in my head but I don't have experience working on cars other than the speed :dunce:
Dano 03-26-2013 05:23 PM
That will do the trick if its bent enough...I went overboard and used a dial gauge b/c I could find no appreciable difference using a screwdriver, which just confirmed I didn't have a bent rod...lol
my anal retentive results can be found here.
http://www.mazdaspeedforums.org/foru...ml#post1662597
himurax13 03-26-2013 07:24 PM
Well if the bent rod is ruled out, what does one do? My leakdown test was inconclusive and my compression test was 160 accross the board. I ruled out a bent rod by neasuring with a long piece of paintball macroline.
I figure might as well start VTA the crankcase and start prepping for rebuild or stocking out and trading in. :rolleyes:
Sent via smokey turbo.
alphasaur 03-26-2013 07:27 PM
afaik, you're looking for differences. I'd be happy with 160 across the board.
Dano 03-26-2013 07:30 PM
truth...having equal numbers is more important than what the actual number is.
160 might just be the tester used.
himurax13 03-26-2013 08:12 PM
VTA the crancase still allowed me to make decent power and mileage but I could fill up my SSP can in a few minutes.
After I stocked out, the excessive blowby caused a misfire in cylinder #4 (from bent, burned valve) and the engine went to shit in a few weeks.
sidekick 03-26-2013 08:51 PM
A bent or burned valve isn't going it cause blow by. What did the bent valve have to do with anything? You would just lose most of the compression in that cylinder.
himurax13 03-26-2013 10:02 PM
The burnt valves just caused lots of smoking and oil consumption (45 psi). I suspect multiple broken ringlands causes the blowby, haha.
sidekick 03-27-2013 01:01 AM
Ahh, I see. I didn't realize you had a bent valve and cracked ringlands. Sorry.
Anyways, I tried to do a compression test today, but the HF tester I bought was apparently DOA... Too bad I ordered it 5 months ago. The gauge just sat at zero while cranking. FUCK. So while I had the plugs out, I took some pictures and checked them out. Clearly something is going on in cylinder 3. The old plugs didn't look like this when they came out and I've only recently started losing oil, so I assume it has something to do with modifications and higher boost. Maybe a bad PCV valve? Anyways, here are the plugs:
http://farm9.staticflickr.com/8097/8...39de0885_b.jpg
http://farm9.staticflickr.com/8514/8...edab213b_b.jpg
http://farm9.staticflickr.com/8097/8...b001a546_b.jpg
http://farm9.staticflickr.com/8245/8...eabc4588_z.jpg
Tokay444 03-27-2013 04:27 AM
Did you put any anti seize on those plugs prior to instal?
mrQQ 03-27-2013 09:34 AM
why does #3 require more cranking?
sidekick 03-27-2013 11:54 AM
Yes, on all of them. Why? There is a little antiseize on them in the pictures, but most of that is definitely oil.
himurax13 03-27-2013 12:08 PM
Yeah, that is definately not a good sign ...
sidekick 03-27-2013 12:15 PM
Yeah, it seems that whatever is happening was probably caused by me as the old plugs I pulled had little to no signs of oil contamination. I'm wondering if the PO(s) ran low octane gas most of its life and ended up damaging a ringland. Then I came along and cranked up the boost and timing and it finally gave. Not really sure at this point though. I guess I should start selling the aftermarkets parts I have accumulated to fund a rebuild. :ugh:
himurax13 03-27-2013 12:17 PM
Personally I would run a vented OCC and then start saving up for the rebuild. I was able to run for almost 6 months like that and I had ridiculous amounts of oil going into the catch can. I would avoid selling all of your aftermarket parts since it is a pain to collect in the first place.
sidekick 03-27-2013 12:20 PM
I already have a JBR OCC sitting in my room, so maybe I'll install that sooner rather than later. I can probably go for quite a while on a cracked ringland, but I'd rather build before it blows up.
Tokay444 03-27-2013 01:10 PM
I would just sell it and get a brz. They're at 640whp already.
Stock block.
himurax13 03-27-2013 01:40 PM
Just buy this little upgrade before you install it. It will keep oil out of the intake.
New Products : James Barone Racing, Custom Fabrication
sidekick 03-27-2013 02:47 PM
Stock block.
Lol on my way to the dealership now.
But seriously did visconti tuning actually make it up that high on stock internals?
Tokay444 03-27-2013 02:53 PM
Yup
sidekick 03-27-2013 03:18 PM
Originally Posted by Tokay444 (Post 1971351)
Yup
I find that hilarious that the car that comes stock with about 200HP has stronger internals than their bread and butter WRX/STI that come factory boosted with quite a bit more power... SubaruLOL.
Tokay444 03-27-2013 03:19 PM
That's Toyota's influence.
They've been putting 1000hp cranks in 140hp cars for decades.
himurax13 03-28-2013 03:07 AM
Actually I am just speculating cause Mazda recalled my motor but I haven't heard if anyone blowing through as much oil as I did. I wouldn't be surprised if my #4 had a hole in it.
I ditched my HF tester cause the guage stopped at 75. I bought a nice craftsman setup that had a customer review rating of 5 stars.
Anywhoo I tested a 08 with 110k+ miles running 21 lbs boost on a stage 1 map with K04 and 91 octane from passenger to driver side:
170, 170, 160, 170.
Installed a beaner last weekend.
Tested a 12 with less than 10k miles running a slightly modified Stage map on a K04 at around 17 lbs if boost from passenger to driver side:
168, 168, 164, 80 (87 Wet)
I told him to stock out. I am not sure how he should document this to get warranty coverage.
sidekick 03-28-2013 11:26 AM
170, 170, 160, 170.
Well was the compression test on his car just to check over-all health of the engine or did you suspect there was a problem? Just have him tell them it feels like it is down on power and request a compression test. Lol.
himurax13 03-28-2013 11:39 AM
Well with all of the fail I have noticed lately, I find any excuse to whip out the compression tester. ;)
http://www.sears.com/craftsman-compr...p-00947089000P
sidekick 03-28-2013 11:53 AM
That's probably for the better. Lol. But, oil consumption and loss of power are probably the main things someone would notice due to low compression in one cylinder.
sundowned 03-30-2013 03:19 PM
if anyone still looking for results
pass to driver 170,165-170,175,170
mods corksport intake and tip, hks ssq, and an ap stge 1 93 tune
kimura 04-16-2013 08:41 AM
just hit 80K miles so I thought I'd do a comp test.
results were ~178 ~177 ~178 ~179
this is exactly 7 cranks for each cylinder, with all the plugs out, foot on the gas pedal. I've put about 11K miles on the 3071 over the course of a year.
himurax13 04-16-2013 09:46 AM
After 1500 miles on the replacement engine and stock everything, 185, 180, 180, 180.
Sent via stocked out for a while ...
BigBoostMS3 04-17-2013 08:44 AM
I did mine last week. ~85k on it. ~15k of that has been modded.
180-182-178-180
breakfasteatre 04-17-2013 04:21 PM
last night, 42k kms on my poo
175-175-170-150
a build is already in the works, alot of racing on the weekend..
mrQQ 04-22-2013 11:41 AM
you guys make me jealous
soul.survivor 04-25-2013 07:34 AM
Last weekend, 89k.
190-190-190-185
Carbon buildup on tops of pistons??
himurax13 04-25-2013 01:29 PM
For @SoCal MS3; at approximately 63K on a bone stock 2008 Speed:
185, 180, 185, 185
I think she is ready for Big Turbo. ;)
Tyhackman15 04-25-2013 01:36 PM
2008 53k tuned for ~2k miles
180-185 across the board
SLOWHATCH 04-25-2013 02:26 PM
I'll be trying mine again soon. Anyone have any tricks to keep that damn adapter piece on the tester and not get it stuck every time in every cylinder? I spent hours doing my test due to this and that shit had me ready to burn my car to the ground. :feedback:
himurax13 04-25-2013 02:31 PM
Are you talking about the part that threads onto the sparkplug hole? The threads on the adapter might be shot. You could try a little oil or some anti-seize if you are frisky. It should spin out easily.
Tyhackman15 04-25-2013 02:32 PM
Tape it on after threading it fully (electrical works), thankfully I thought of that right before testing the 1st cylinder
Tokay444 04-25-2013 02:36 PM
Just crank it tighter onto the the tester, tighter than into the plug well.
himurax13 04-25-2013 02:54 PM
OK, I must have read that post wrong. Is the adapter coming off the tester itself or is the part that screws into the sparkplug hole getting stuck?
The Craftsman Tester I posted earlier is the tits because the adapter simply screws into the sparkplug holes and then attached to the guage with a quick disconnect. The test itself takes less than the time it takes to smoke one cigarrette.
Now if you have POS Harbor feight one, I used teflon tape and 2 crescent wrenches to make sure the quick disconnect piece is attached properly to the adapter piece that goes into the sparkplug hole.
fredricktsang 04-25-2013 04:22 PM
anyone know where to get just the hose/adapter/fitting to the gauge?
Tokay444 04-25-2013 04:25 PM
Try emailing the manufacturer.
skiptowncat 04-26-2013 10:49 AM
Done on a cold engine
110-100-75-100
What the fuck!!!
btstarcher 04-26-2013 10:56 AM
Needs to be done at close to operating temp.
Lex 04-26-2013 11:14 AM
110-100-75-100
What the fuck!!!
Did you push the throttle to the floor, how many times did you crank, was the tester good?
skiptowncat 04-26-2013 12:00 PM
I don't know wether the throttle was pressed. I'm going bnr soon so ill get the valves cleaned at the same time. I just hope it lasts till then.
himurax13 04-26-2013 12:23 PM
Performing a proper compression test(and leakdown if the test results are bad) is far more important than getting a Beaner or cleaning your valves. If your engine needs a rebuild, then there is no point in doing those things.
The Beaner will put more stress a dying motor and will force a rebuild much sooner.
Tokay444 04-26-2013 12:33 PM
Replace lost compression with more boost.
himurax13 04-26-2013 12:38 PM
Tried that, didn't last too long, lol.;)
Sent via stockish Black Mica Pu
skiptowncat 04-26-2013 01:42 PM
Going forged as well this year.
timjs 04-26-2013 03:34 PM
110-100-75-100
What the fuck!!!
Try a different gauge, I doubt that's anywhere close to actual.
edit:If the engine runs!
skiptowncat 04-27-2013 12:12 AM
I will certainly be getting it retested ASAP.
mps6dave 04-27-2013 02:32 AM
Throttle was to the floor. Engine did 10 compression strokes .compression tester was brand new as well and i later did mine and got 170psi right across bar cylinder 3 which was 155psi.also done on a mildly warm engine.
skips car on roadtest actually feels to have uneven power across the cylinders ,having solid mounts help you feel it more.told him to try a seafoam through it along with a fuel treatment ,then after 1k get it retested.this should tell us if its a carbon build it sticking the rings or the valves being poorly seated due to the usual disi intake
skiptowncat 04-27-2013 04:30 AM
I'll get a leakdown test as well
Metal409 05-01-2013 01:29 PM
Originally Posted by Metal409 (Post 887325)
Went ahead and tested my car again today. 2009 Speed3, 42,600miles, more than half of that was stage 1, car is stage 2 now. Was roughly 80degrees out when I tested, 570~ ASL.
1: 185
2: 185
3: 185
4: 185
Only did 6 cranks to get these readings, 7 on cylinder 1.
Did another test today, same location about 78deg outside and while the car was still hot. Just over 65k miles on the car now and back to stock.. for now. Cranked for about 5 seconds on each:
1: 190
2: 190
3: 188
4: 190
SLOWHATCH 05-01-2013 07:44 PM
Finally did another test. Car has 40,500 miles. Bought used with 16,800 with dp, tp, sri, tih and no fp internals or tune. :smashfreakB:
Dry test:
Cyl 1- 180
Cyl 2- 180
Cyl 3- 165
Cyl 4- 172
Wet test:
185
185
175
175
No oil in intake etc. In process of finding someone who can do a leak down test. Still on stock injector seals. Contemplating on replacing them.
Is piston design on gen 2 the reason for what appears to be lower #'s. I see lots of gen 1's hitting 190's more often than gen2.
scubasteve711 05-15-2013 10:56 AM
7 Attachment(s)
Here's my results!
Car has 79K on it, Coolant temp was 111* during testing according to the AP. The motor was pretty warm but I could keep my hand on the valve cover with out it being too hot. Car had been run for no more than a minute to pull it into the garage bay about 30 min prior to the tests, and was driven home from work about 2.5 hours prior to test. Warmed engine, recently run engine, and possible gauge differences may be to blame for the seemingly elevated numbers... I'll try and use this gauge/tester on another DISI at some point to verify... All I know is I am extremely happy with the results being nice and even across. Engine was cranked until the gauge very little more, probably 7-9 turn overs of the engine.
Results - 1/2/3/4 as one would look at the engine from the front of the car:
(197/203/200/196)
Pictures are all below and labeled. I replaced the old plugs while in there (ITV22) they had about 40k on them. Definitely worn.
theurgy 05-15-2013 01:52 PM
Those are very good results.
scubasteve711 05-15-2013 01:54 PM
Well, fighting a pretty irritating KR issue at the moment which is why this was done... At this point, I've pulled a ton of timing and it has brought KR down, but not totally eliminated it... Next step I think is going to be to determine if this is real KR or not... Car has run more timing in the past without any issue at all.
Lex 05-15-2013 01:56 PM
Put some E85 in the tank or methyl hydrate to see if it is fuel related.
theurgy 05-15-2013 01:57 PM
Hate to say it, but have you checked your intake valves?
I trust that you're datalogging these knock events.
scubasteve711 05-15-2013 02:00 PM
No E85 around - "methyl hydrate" any good place to get this? or a more common name for it? (besides meth :p) I've heard of denatured alcohol being used in place of E85...
Yes - It is all WOT KR, and I've pulled a ton of timing out of the tune to reduce it. I'm basically not going WOT without the AP hooked up and displaying KR though at this point to avoid any issues.
No Valves never been done - this is VERY much on the to do list however. The VVT / Timing chain has never been done either - Anything that could be see in the logs regarding the VVT? The engine is a little noisy on startup, but it last for only a couple seconds and is absolutely nothing like any of the youtube vids I've seen.
theurgy 05-15-2013 02:07 PM
I know you can get some at Home Depot:
Recochem | Methyl Hydrate - 3.78 L | Home Depot Canada
Oh yeah and Valves and VVT stat... the youtube videos are pretty extreme, mine didn't make as much noise as what I heard online, however, I did notice the noise and brought it into my dealership and they confirmed and swapped it under warranty.
scubasteve711 05-15-2013 02:10 PM
As far as the warranty goes, I have an extended for exactly 600 more miles... As I am at 79k and change,,, :( This will probably be something I will be doing on my own unfortunately. I'd have to front the 200 for them to pull the valve cover and confirm, and then hope the extended covers it, by the time I spend 200 bucks, I might as well have put that towards the parts.
Starting point on how much for a tank?
theurgy 05-15-2013 02:11 PM
I would ask @Lex; on that one.. he's the expert.
scubasteve711 05-15-2013 02:17 PM
ahhh f*ck a duck... Us US peoples can't get that stuff... Brings me back to denatured alcohol lol...
Tokay444 05-15-2013 02:40 PM
A gallon of meth in tank will tell you if it's fuel related real knock b
Dano 05-15-2013 03:06 PM
Results on my new motor with 350 miles
185 across the board on a very warm motor. PU pistons.
Lex 05-15-2013 03:30 PM
methanol, I would put in 1 gallon per tank for testing, e85 2 gallons.
sidekick 05-15-2013 06:23 PM
Originally Posted by sidekick (Post 1968752)
My compression test numbers before buying the car:
190 - 165 - 150 - 175
I have noticed that since I started running 18PSI, it seems like I've been losing/burning more oil. Every fill up (about 1 week/200-250 miles), I lose about 1/4 of a quart of oil. I assume that is PCV related, since it only started happening after turning up the boost, but an OCC should put an end to that, if that's the case.
Clearly there is something up with cylinder #3 , but I have not done a leak down test. The car seems to run fine overall, maybe a slightly rough idle, but it also has not had the valves cleaned yet and needs a new VVT actuator/timing chain. It makes pretty good power, but @cld12pk2go; pointed out that I seem to be making lower numbers than he would expect. However, I'm also right on par with my old speed3 with the same mods in terms of crank horsepower, so I'm not too sure what to think.
Honestly, if anything, I expect it to be a cracked ringland. The oil loss and low compression point right at that. I will do a leakdown test sometime soon and try to figure it out. The best part? The dealership tech who did the test stated "the engine is in very good health" on the work order. It's pretty much outside of Mazda's specs even if you don't count the highest cylinder. It has received a healthy amount of beating over the last 3 months, so I may do a compression test next time I pull the TMIC, just to see if it has changed.
I made this post about a page back, but it turns out the techs that did the compression test did something wrong. Either they didn't crank until the number finished going up or they let the car cool down too much before doing the test. I finally got a compression tester kit that actually worked, so I did a compression test while I was tearing it down to do VVT/timing chain. I had the plugs out within 20 minutes of turning the car off and started doing the compression test right away. Here are my results from today:
http://farm8.staticflickr.com/7287/8...e4fcfdac_c.jpg
I did the test twice just to make sure and I got pretty much exactly the same numbers. I'm thinking my oil consumption may be either PCV related or turbocharger seal related. I will look further into the oil consumption issue after I finish the VVT/timing chain swap.
@Dano; @Lex;
Edit: This is with close to 87K miles too, even though the numbers themselves may be slightly off, I'm amazed that they are all within 10PSI(about 5-6% variance) of each other.
Lex 05-15-2013 10:03 PM
Those numbers look strong to me. A good indicator for blowby is oil in your intake tract via the valve cover vent.
Dano 05-15-2013 11:27 PM
+1 on the oil in the TIP. if you go the extra mile and pull it you may see oil pooling in the compressor inlet like I did but that was with a busted ringland and your numbers don't seem to point to something that severe.
BackRoads 05-16-2013 11:51 AM
Ok, had the techs do a comp test this morning - I am now at 165k.
155
150
155
145
I plan to put in the step-colder plugs soon, and will probably see if I can get a gauge and do my own leak-down test as well. The gauge is not very expensive, is it?
theurgy 05-16-2013 01:13 PM
Depends on the ones you get. The ones on ebay or Harbor Freight are pretty cheap.. but you get what you pay for on those.
Have you considered renting one?
I know there are some places that loan them (with a deposit) or rent them.
himurax13 05-16-2013 02:36 PM
155
150
155
145
I posted the link for the Craftsman one I purchased for $55 earlier. Its a nice set.
Sent via rental car
sidekick 05-16-2013 03:05 PM
Last time I pulled the TIP there was some oil entering it via the valve cover vent, but not much and it didn't seem to be pooled up in there. There is a pool of oil in the TB coupler though and my turbo inlet does not have wet oil on it, but the compressor blades are black, which I'm assuming is from oil.
Is it possible I could be consuming this much oil via the turbocharger seals and my stock cats are not allowing me to see the smoke? I suppose it even could smoke, but I've never seen it. I suppose it could also be related in some way to the PCV valve itself. I'm just not sure how I can pin point the source of the oil consumption.
I spoke to a mechanic I know and he said he had a very similar issue with an N/A 2.3, but everything was in good mechanical condition and even replacing the PCV didn't help, but Mazda didn't offer any guidance because it fell within the "acceptable" range of 1 QT per 1K miles.
@Lex;
Lex 05-16-2013 03:24 PM
@Lex;
Have someone tail you in another car and see if you get blue smoke under vacuum (coasting) or under acceleration. If it's not leaking that much oil will make some smoke (and smell).
Tokay444 05-16-2013 07:40 PM
I'm pretty convinced my oil consumption issue is turbo related. Under boost only.
Small pool at the throttle body. And my valve cover is vta'd. No where else for it to come from.
Try that. Clean the throttle body and coupler. Clean the intercooler, and cap the tip and vta the valve cover. Then see if you still get oil at the throttle body.
Dahouse702 05-18-2013 02:45 PM
2007 MS3 85k miles
motor was hot relay removed and clutch/gas floored. :(
DRY
1-182
2-152
3-156
4-182
btstarcher 05-18-2013 02:59 PM
Isn't it usually the head gasket if the middle two cylinders are both low?
atvfreek 05-18-2013 06:28 PM
Checked mine today. 170-170-165-170
timjs 05-18-2013 08:41 PM
Yes. Low compression in adjacent cylinders can indicate leakage between cylinders, especially if they are similarly low.
cld12pk2go 06-02-2013 11:42 AM
182-176-174-177
Measured again today.
Cranked ~12 revolutions on each:
1 - 186
2 - 183
3 - 181
4 - 180
~3% spread. I still seem to have a happy engine. :-)
ABolewski 06-02-2013 12:24 PM
I'm at 107/115/120/110.
Trying to get another gauge on there but the gallon of oil in my intercooler suggests that those reading are correct.
How awesome is that?
But I deploy in two months so I'm DD'ing on the economy map until I can store it.
Dat Kaboom tune lyfe yo
btstarcher 06-02-2013 12:40 PM
Was that with the engine at operating temperature?
ABolewski 06-02-2013 01:21 PM
Yes after a good long drive (100+ miles) pulled into the drive way and went to work.
I'll post up some pictures later. I have no idea how my engine still runs. So much fucking oil it's insane. I'm going to try to get another tester on it, but the one I bought was a $50 one that was supposed to be decent. Not a cheap autozone one.
Lex 06-02-2013 01:38 PM
Make sure you crank it until the needled stops rising.
himurax13 06-02-2013 02:15 PM
Is there oil in the intake as well?
This is a decent and affordable tester.
Sent via blown passenger side speakers.
ABolewski 06-02-2013 03:45 PM
I did, both using the starter and then cranking it manually.
And there is oil in the intake too. My engine is toast. I just can't believe it's that low and not zzb'd, I'm just staying entirely out of boost until I can store it.
himurax13 06-02-2013 04:05 PM
Can you stock it out?
sidekick 06-02-2013 05:23 PM
So you had no issues until dantes tuned you @ABolewski;
ABolewski 06-02-2013 05:57 PM
I guess it's possible to stock out, but I'd need a stock intake manifold and gasket, a cbe, and I think a EGR tube (not sure where it is).
The problem is I do not have the time to do that before I deploy.
Maybe I'll put a little more thought into it and see if stocking out is a possibility.
First, is it even possible givin I've done all of my own oil changes, and it'll still be an obviously highly modded car?
And yes, my engine was perfectly gone until Dantes tuned me.
himurax13 06-02-2013 07:24 PM
As long as you have the receipts for the oil and filters you will be fine. How long will you be deployed for?
@lilred; still has his oem Catback.
I decided to do a compression test with 3300 miles on the new engine.
190
188
190
186
ABolewski 06-02-2013 10:30 PM
190
188
190
186
Definitely don't have any of that shit. Hahah
And I deploy from August '13 to March '14.
The thing is I literally have no time for that at all. I have like 6 days off for the next two months before I deploy. I don't want to even think how it would be possible for me to do that.
Thanks for your help though man.
himurax13 06-03-2013 12:01 AM
12 hours if you have no suspension to remove and if lots of fail is involved, haha. Just have someone buy oil filters and oil while you are gone every few months. Its doable but arrangements need to be made before bringing it in.;-)
Page generated in 0.30335 seconds with 11 queries
