The mounts have to be swapped. The only thing that can stay is the fuel pump internals. Sent via blown passenger side speakers. |
I'd pull the internals anyways. They may replace the pump for some unknown reason, and then you're out $300+. It only takes 15 minutes to swap internals. |
I have a stock fuel pump you can use and I know someone that might buy your intake mani from you and give you his stock one. @Spoc; |
I'd definitely throw stock internals in there, exactly why silvapain said. Also, this isn't the thread for this, I'll PM you @himurax13; This might work out better then I thought. EDIT: @Micha; I'll sext you. Swapping mani's would work perfect, I'd give him my JBR gasket too and use his stock one. I have my on internals still. |
Let me know what you guys think please. I started to smoke about 2 weeks ago since then I've added a JBR OCC with VTA kit (still waiting on Check Valve), a BNOON Bolt, and Rotella 5w-40. The other mods are in my Sig. So after these modifications I'm still smoking so i decided to do a compression test. 08 MS3 60,500 miles 862ft ASL #1 191 #2 172 #3 171 #4 171 I think if it was 170's across the board I would be ok with these results but with cylinder 1 being so much higher I don't know what to think? I'm hoping the check valve will help maybe my PCV valve is junk which is causing me to smoke. If not then I hope its just the turbo. Do you guys think it might be something else with the compression results above? Thanks for any advice! |
How warm was your engine when you did the test and did you crank until the needle stopped? |
That's your problem. Crank till gauge doesn't move. |
The prognosis is not good. It is a 10% difference. A little more and I would be getting ready to take some action. |
You're technically still in specs. I wouldn't worry too much if the engine is running fine. Sorry if I missed some information somewhere. |
Leak down test should be your next step. |
Well i just did my first compression test. Car is a 2011 genpu with 57,000 miles. Basically fully bolted around 20,000 and BT at ~52,000. Results are as follows. (Passenger Side) Cylinder 1: 174 Cylinder 2: 183 Cylinder 3: 184 Cylinder 4: 184 (Driver Side) I was going to test cylinder one again to confirm the slightly lower reading but after the engine cranked a few times I blew the hose on the tester kit apart. It was a rented autozone kit though so w/e. Do you guys think I have anything to worry about at the moment? |
Nonetheless, I am pretty excited that cylinder 3 isn't being a little bitch. |
did my MS6 and CX7 last night while changing oil in both. My car has 40k and got 190s on all cylinders CX-7 has 70k and got 1:180psi 2:180psi 3:150psi 4:180psi Weird that oil level was perfect in CX-7 but I was down a couple of quarts in mine a week or so ago. I started a job that is a 100mi/day commute so I figured it would be a good time to make sure my car was up to the job. GUess I need to sell the cx7 |
TL: DR Which relay do I pull to do the compression test? Injector or Fuel Pump? |
^that |
Sounds good, I jest remember the last time I did a compression test I had pulled a relay of sorts. Isn't this similar to the procedure to pressurize the fuel rail? |
Well my results should be posted later today. |
Results: 1-4 (left to right) 1: 165 2: 170 3: 160 4: 165 |
Engine was warm, but it is clear cyl 3 is fucked. Wet test as in with fuel on? no pulled INJ relay. Or wet as in spray oil in and see if numbers go up to determine if rings bad? I guess I can do that. I just cleaned intake valves at 60k so I doubt there is a problem with them sealing but who know. Could do a leakdown test but not sure what this will tell me also. Car gets 14mpgs so have been wanting to get something new but owe 11k so its not like I could sell it and buy a new car with the profits. Wife wants a minivan but they dont get great mileage either. But either way I think we should get rid of the CX7 soon... |
When I cleaned my intake valves on another engine I could not get one of the valves to seal as the B12 would always drain out overnight. However it obviously did get clean after I ran it as it now has 180psi... so it is def possible that its just gunk. |
Alright I did a leak down test and pushed oil out of the dipstick while testing cylinder 2 so it looks like I'm gonna have to build the motor? |
Here is my post from a couple of days ago..... Okay, after re testing the compression it is higher but there is still a 20psi difference in cylinder1 and the rest of them. Other info a couple posts above. Thanks. #1 192 #2 172 #3 171 #4 171 Thanks for the tip, now what are your thoughts? |
Soooooooo dipstick was removed from tube? |
What percentage leak did you measure? |
Again, from left to right (with the engine warm): 186 182 189 186 I feel a bit better about those numbers. :) |
shitty tester was shitty What you can take away from any test is consistency. even low numbers, if they are all in the same ballpark is a good indication the motor is healthy and the gauge is the problem. |
bumpity bump did a compression test today. did it how a friend said to do it. dont think the engine was warm by the time i did the test anyway got from left to right.. 170, 157, 170, 157 one person said thats fine... do you guys agree? i liked the consistency but obviously two are lower than the other two. should i redo with the proper method from the first page? |
A compression test doesn't really paint a full picture. For example, my compression has always been in spec (when I do it by the MSF disi standard testing procedure), but my leakdown shows 31% leak in cyl 3. If you go to the trouble to do a comp test, do a proper leak test at the same time. |
Agreed that a comp. test doesn't tell the whole story, but a cylinder that leaks down at 31% is going to have a variance in the comp test.... |
First pump is 90. Same as the rest. |
EDIT: Don't you have an issue with oil in your intact tract? Those compression numbers could be similar to "wet test" numbers if a significant amount of oil is entering your combustion chamber. |
It's rings. Most likely a broken land. I burn a litre of oil/1000kms. |
Not until after my wedding. |
Fucking liters....WTF Canada. :unitedstates: |
Litres* |
Sent from my iPhone using Tapatalk 2 |
*Furlongs |
Fathoms* |
My car gets 16 rods to the hogs head, and that's the way I likes it |
^^^^ fagots* |
'Merica. Fuck you. :usa: :fuckyou: |
now rebuild your POS motor already. |
tarp* |
negative...you did in deed fall into my T R A P ! |
i really just want you to wrap me up in your tarp. baby oil? |
hahaha not right now...maybe later? |
Cylinders 1 3 and 4 were around 180 Cylinder 2 was at 60 Looked for leaks Hooked my compressor to c2 No air from anywhere |
Air compressor hose where the cylinder 2 plug goes Listened for air from intake oil cap area abx exaust Came from intake at first but my friend told me to crank the motor once and it went away. Going to his house in a few days to redo it just in case |
I thought that leakdown test required you to be at TDC? Anyway also check around injector seals and dipstick. If it's coming from intake, is that intake valves? |
Yes TDC compression stoke otherwise air just goes out the valves. Tappin |
Checked Compression again @ 73,000 miles yesterday. Motor was warm but not hot. Still looking good. 203 202 202 205 https://www.youtube.com/watch?featur...&v=h_c66_ZHe4E |
I need to do this. I'm at 102k miles and although she's pulling strong and not burning any oil, I want to for the peace of mind. |
2007 106,000 miles Fully Bolted +BNRs3 119-121-120-121 On two different gauges (HF and O'Rileys). Wet test gave me an extra 2-3 psi. My buddy is letting me borrow a tester where he hits 180 psi. We'll see what his gauge yields and we'll also be doing a leak down |
Was the engine at operating temperature? Those numbers look fine; only 2psi difference. |
Yeah I'm thinking your engine wasn't warm enough. |
140000km. car felt slow so i tested it 160,170,160,170. i dont think i let it turn ove r enough on the 160 cylinders. Guess car is just slow...but at least no issues. |
150 across the board! Car was tested cold and warm, and tested on another car which tested 180 in all four! |
Got any datalogs? |
I run meth but probably need a valve cleaning (although before and after dynos dont really show that much of an improvement...). I ve got lots of logs and all is well in those. I went from a speed3 to a speed6 and the 6 is just heaver wwith more drivetrain loss so is slower than iam used to. |
:twak: |
Oh I do. But this guy has crazy high numbers, so I wanted to be blessed by his tester. |
this guy also has crazy flow/power on his k04. borrow his car not the tester ;) |
I make 230 PSi on 3 out of 4 cylinders. Am I cool? |
You're very cool @Micha;! Any ideas what happened with the other one? |
First compression check ever, 83.xxx miles BT 3071, 415whp 12.0 quarter mile. 165 167 165 167 The car has been running flawless until the last week when there is oil coming out of the valve cover breather. I have a little filter on it that came with my cp-e kit. Saikou catch can hooked up the old school way with two check valves. I know a leak down test is the next step but in the mean time I am going to go over the catch can and pcv system. |
@Snyeed; was telling me altitude will mess with compression numbers. I looked it up briefly and people seemed to concur. If usual is 180, and we are at 4500ft would that be accurate for a healthy motor? He runs 25ish, but is on 18psi for the winter months. bt has been in for 2 years? |
The compressions look reasonable....and more importantly, even. |
| All times are GMT -7. The time now is 06:29 AM. |
