I had the 3rd cylinder at 125, rest around 155-160 with very loud grinding VVT, (the second VVT to be replaced) yet the chain wasn't ticking at all. 169000mi, mostly all highway miles. Other than that nothing ever went wrong with the car since I bought it in 07. Turbo is still good. Did timing chain, VVT and rings. |
Finally got my MS6 put back together. Used mostly factory new parts. Cold compression on the refreshed motor was 150 across the board prior to the first start. After 700 miles it is now 170 across the board at operating temp. |
what did you do? |
Hm, how much miles did you have? Did you do any honing at all? Did the ringlands scratch the walls at all? |
Have 85k, about 17k on the 3071. Did a hone with fine stones only. There was a very light visual scratch on one of the cylinder walls but I couldn't feel it. After the hone it was gone. |
Well did mine today... 110,000 MS6 From driver side to passenger. 172 159 163 170 :disappointed: |
it's not even that bad :) |
Yeah you're golden. I'm at 184000 with pressures around 150. Still life left in it. Going through a quart about every 4000 miles , but she runs smooth. |
Thanks for the confidence guys. I know the numbers are ok, it's just getting over the fact that she is getting old and stuff needs to be fixed. I'm noticing that the car Is louder when idling. Had the vvt timing chain replace 10k Ago Sent from my HTC6525LVW using Tapatalk |
6 Attachment(s) Photos For Grins. |
There are some brand new killah builds with less compression than that. |
Update for my car. Last results were on September 27th, 2013 @56,000 miles. Fully bolted, e85, and meth...188, 183, 183, 190. Test done today with the addition of a gtx3076 and cpe manifold tuned to 416whp @ 22psi and 71,600 miles...205, 205, 195, 205. Needless to say, even if the gauge reads a bit high my compression is absolutely on point because of my tuner @ms3blackmica; |
78K Compression Check Finally did a compression test on my 09 Speed3. It had 45K when I bought it, 78K now. 190 187 190 190 Also the Autolite XP plugs looked GREAT after 28K! So good, I put die electric grease on boots, and re-installed them. No oil in intercooler. I have been worried after all the stories here, but decided I needed to know! Happy I checked! Runs solid, and uses zero oil in-between changes. |
sent while granny shifting and not double clutching like I should. |
Had time to test this morning after changing my motor mount. Car was only driven for 5 minutes before the test so it wasn't completely warm. I'm about to roll past 50,000 miles. This is also my first compression test after my etune with @Lex; that was about 2000-3000 miles ago. Since then I've been enjoying the WOT life. 1 - 175 2 - 175 3 - 175 4 - 173 Good stuff. |
Just did mine last Friday. 2011 Pu with 90k kms (~56k miles). Mods: fully bolted k04 (minus DP). Stratified tune by @Lex; - 91 octane (no E85 in my part of Canuckstan). Dry: cyl 1 @ 180 cyl 2 @ 185 cyl 3 @ 187 cyl 4 @ 190 Wet: cyl 1 @ 195 cyl 2 @ 195 cyl 3 @ 192 cyl 4 @ 200 I've been getting some clutch vibes for the past few months. It happens as all other threads about this subject already explained (only whenever you press the clutch about an inch down). I only get the "vibes" while on throttle.. As soon as I release the throttle, vibes cease immediately. I therefore decided to also to a piston height test using a depth gauge. Cyl 1 @ 45.43mm and Cyl 4 @ 45.55mm (TDC) Cyl 2 @ 45.59mm and Cyl 3 @ 45.49mm (TDC) Now, I had measured with a steel rod first and all rods measured equally (1-4 and 2-3). When I measured with the depth gauge, as you can see, some little difference. But, I did notice that the .xxmm tenth of mm would not seem to ever stay the same as the gauge is very very sensitive. Would you think my vibrating clutch on throttle be rod related with these numbers??? |
1:190 2: 190 3: 168 4: 186 - sigh Sent from my SAMSUNG-SGH-I777 using Tapatalk |
passenger cyl 1 is closest to the crank pulley |
sent while Netflixing... |
Finally did a compression test on my car. 115,400 miles, tested it while warm. 1- 180 2- 180 3- 185 4- 185 Rechecked a second time just to be sure. Only difference was 1 came up with 175. Pretty stoked right now. |
You are golden! Happy trails! |
57k miles, no additional track time. 190-188-185-168 ................. |
Youd need rings. On 2nd thought, for the heat of track use id go forged. I still believe the PU pistons would have been just fine in my motor for DD usage. |
@Dano; those PU pistons are just as fragile as the gen1 pistons. They do not like heat and power. Every summer we see more and more ring land failures. And they far trump the amount of rod failures we used to see |
Any other symptoms? Leak down next? It does look like ring lands but would be good to confirm. |
no other symptoms, though it might have just occurred. The car leaned out after I fixed that exhaust leak, I stopped the first pull at 4.5k but I was at 23psi and 13afr. I don't have a leak down tester, maybe I will pick one up soon. |
Roger that. I was just thinking with aftermarket heat management like a fan controller, you might be able to stretch the useful HP range they can survive. Its a crap shoot for sure and not worth the gamble when rebuilding. |
I'm really not sure if one pull could do that. |
I've forgot to warm up the engine and it was too late because I had everything out so I ended up testing on cold engine. 80k/stock k04 some smoke after long idle. 1. 180 2. 180 3. 156 4. 165 Retested 3 & 4 wet and both were right on 180....FML:disappointed: I will redo again tomorrow on warm engine. |
180 on a cold engine seems high. |
Up your idle to 900 and say goodbye to that smoke |
Did compression today again on a warm engine....numbers were exactly the same as cold. 1. 180 2. 180 3. 156 4. 165 Wet test brought the lower numbers to 180, however, I've discovered low coolant and a little milk on my oil cap. Last summer I had water pump and coolant replaced. I don't think it could be a headgasket since oil dramatically improved those bad cylinders. Thoughts? |
I posted this in local section and just figured I would share in case anyone is wondering. Performed a leak down test today. Cylinder/gauge1/gauge2/%between gauges 1. 90psi/88psi/2% leaking 2. 90psi/86psi/4% leaking 3. 90psi/46psi/ SHIT LOAD(abt 46%) LEAKING coming out of the PCV/Oil fill hole 4. 90psi/79psi/12% leaking My cylinder 3 is fucked. Most likely going forged. |
900 miles after rebuild with SP63 10.5:1 pistons the compression is 195 in all 4 cylinders. |
Did a compression test today just to make sure everything is gonna be fine when I install my BNR S3. 84k kms on the motor. 1. 180 2. 180 3. 180 4. 180 Looks like I'm good to go. |
Just tested today again with a working gauge (previous HF gauges all read 120 across the board) Fully bolted (minus Ex/Int Mani) on BNRs3v1 for the last 20k miles...going forged next year Left to right 168, 165, 170, 173 with 118k Miles. |
Looking at everybody's number, I don't feel so bad now. At 120k I got: 1-170 2-181 3-175 4-170 |
@35700 1k on BT 1- 189 2- 185 3- 180 4- 186 |
100K miles, cold wet test 210 200 195 205 I'm thinking compression gauge is a piece of shit (vatozone) but the consistency is what matters anyway. |
1: 150 2: 150 3: 145 4: 145 Yay. |
Just got my otc comp tester in the mail. 32k tuned since 9k 201 199 199 197 |
175 70 175 175... 24800 Miles in FL Car has been at he dealership for 2 weeks with a blown Cylinder #2 trying to get a replacement engine under warranty =( |
I will redo the test next time I'm working on the car. |
I do comp tests every few months. |
You did it cold and wet. Big difference. |
Tested this morning to check if everything was okay after cleaning my intake valves 2 weeks ago. Car was completely warm. Each cylinder was cranked 7 times. 1 - 180 2 - 180 3 - 180 4 - 180 Most consistent numbers I've ever had. :cheers: |
Bump'd I started getting some nasty KR (over 5) on my tune which I have been running for about a year now. 3" intake, catted dp, cbe, fuel pump, forge v1, occ, had autolite step colder, switched to itv22, problem started, switched back to autolite, still persists. The car is a 2012, had about 25k when the issue arose. I threw my maf cal onto stage 2 ots and no more knock at wot (which I'm doing significantly less of since this all started), but when I tested comp, this is what I got... 195 170 (wet was 175) 195 190 What is interesting to me is that the plug on cylinder 2 was MUCH lighter than the other 3. So for some reason that cylinder is running low comp but also much hotter than the rest. Fwiw the engine, pedals, steering wheel all vibrate somewhat harshly at any given rpm/load/speed. I checked piston height with a 3/8" extension, and cylinders 2 and 3 are identical. So at this point I'm speculating that it could be a valve issue, or injector seals, possibly both. But I'm still trying to wrap my mind around what could be causing a lean condition in #2 (no CEL however) All were gapped at .026, and rechecked when I tested, still .026 |
I don't think that difference could cause knock. |
Maybe an injector issue? causing too lean conditon and knock in cylinder. |
I threw a half pint of seafoam in a 3/4 full tank this morning, it seems to be running a bit smoother but I'll see how it goes as I burn through this tank. Seems that the low comp could be a symptom of the knock, which itself is caused by a fuel issue |
Doing my first test, 130 dry test on the nose across the board, tested at a temp of 165. 2008.5 45k miles, no CEL's, no smoke, not eating oil /and runs smooth. Bad gauge? |
Did you do a wet test? If there all exactly 130, I would bet the gauge is toast. |
Now that I think about it, the packaging of the tester was kind of sliced up near the extension and gauge, I'm going to go borrow one from Autozone tomorrow. |
Did mine again today - dry test at 192,500 original miles on the engine: 155-150-150-160. There's life in her yet! Did a leak down test on 4, and got just a little coming through exhaust, nothing past the rings. Overall, pretty happy about it, as we are about to add E85 to my tune on the BNRS3. |
New OEM motor, 900 miles, warm (sat for ~30 mins after turned off). 176 - 176 -176 -176 This pleases me. |
Tested mine a few weeks ago 180 150 180 180 Rebuild in progress, cracked ringland on cyl 2. |
Scoped the cylinder in question, this is what it looked like. http://tapatalk.imageshack.com/v2/14...ecdb575a9b.jpg It looks like a hot spot on the piston? Or maybe some anti seize got in there from when I did the comp test, hard to tell and being the first time I've looked inside a motor I don't have much of a baseline |
So I posted a while back that the brand new Innova (3614) gauge I used gave me a reading of 130psi across all cylinders. Ordered the Innova gauge with the solid rubber hose (3612) and just got 185 190 190 190. Beware if you buy that gauge. |
177/125/109/155. Tested today. No leak down. There's still absolutely no trace of smoke when accelerating hard and the car still pulls pretty good. When the oil consumption started suddenly in May/June I said that if I have to open up the engine even only for replacing some valve seals, I will rebuild it completely. This is going to be a costly word keeping. |
I posted a while back. Two of my cylinders were around 180. 3 was at 155 and 4 was slightly higher. Additionally, 3 leaked over 30% on leakdown. Engine ran ok but smoked real bad. It appears that the smoke was caused by the cylinder and the turbo. I've built the motor and get very little smoke, however, the turbo smokes here and there just not as bad as before. Also, I can smell burning oil out of the exhaust. I've pulled the turbo yesterday and it did in fact leak. I am replacing the CHRA with a rotomaster part and will report results. I haven't seen anyone use that CHRA yet. However, when I've pulled the old motor apart the rings looked fine. I think I could have probably gotten a little more out of it. |
2008.5 with 72K miles I think the only mod is an ebay test pipe from the previous owner 150 155 152 148 |
2010 MS3 54k miles Running beaner for about 4k miles, always @rfinkle2; tuned. 190 across the board. Dry. Sent while granny shiftin' and not double clutching like I should |
What kind of power are you making these days? Any E85 or meth? |
1 Attachment(s) tried to do a comp test, tester from vatozone was shit and broken. regardless pulled the plugs and they look healthy at least. 81k miles, gtx2867r went in at 50k. |
http://s28.postimg.org/qer20camx/IMAG1916.jpghttp://s28.postimg.org/vtzs1b26x/IMAG1917.jpghttp://s28.postimg.org/6f5uiadi1/IMAG1920.jpg |
I am still planning on doing meth once the spring comes! Sent while granny shiftin' and not double clutching like I should |
Sweet! You're about 10whp ahead of me on both counts. Interested to hear how your meth project turns out. |
And I will for sure. @maisonvi; and myself are going to try a meth throttle body spacer and see how it turns out...it's just such an easy option. |
My next mod is my clutch. I guess 154,000 miles was all the abuse she could take. Still trying to finalize my tune with Lex, but the clutch can't handle WOT in 4th anymore. |
GL man, make sure to post up how it all goes! |
Fer sher!! |
I did a compression test at the dealership yesterday as I had other things to do, results all accross the board was 205. He suspects the engine needs a good cleaning but it's in good shape. 2010 with 74 000 miles |
That's way too high. You need to take that car out and drive it hard RIGHT NOW! It's like blood pressure - your car needs more exertion! |
Just tested 180's across the board. 100k on the clock. Self tuned since about 50k. 3071 has only been on for about 2k. |
Did a quick compression test last night after I noticed the clamp on my turbo inlet had lost the tightening nut. The turbo had some dirt on one of the corners from a big air leak :(. Luckily no damage done to the turbo or the motor, compression still sitting at a perfect 180 across the board @53600 miles. |
1 Attachment(s) My compression was 180-180-180-zero. 138,XXX on motor. stage 1 93 ots for 20K. Burnt valve. |
That's a good one. |
what caused it? |
| All times are GMT -7. The time now is 06:29 AM. |
