MazdaSpeed 3 - Engine, Transmission & Driveline Discussion of engine, tranny and drivelines. |
![]() | ![]() | #361 | ![]() |
![]() Join Date: Jul 2012 Location: Raleigh,NC
Rep Power: 0 ![]() Thanks: 0
![]() | ![]() | #362 | ![]() |
Trail of Fail ![]() Join Date: Jan 2010 Location: rock city AR
Rep Power: 9882 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,493
| ![]() ![]() ![]() There is def something wrong in that 3rd cylinder. I would get a leakdown test to confirm but some possibilities, non of which are good are: bent rod broken piston ringland do you get any vibrations when you press the clutch in?
![]() | ![]() | #363 | ![]() |
| ![]() ![]() ![]() No there is no clutch pedal vibrations, the car runs great, no burning oil, still very strong pulls, i also am still getting great gas mileage as well... i have read in this thread the oil in plug hole test which i plan on doing tuesday... im hoping its a valve problem more than anything else |
![]() | ![]() | #364 | ![]() |
![]() Join Date: Jul 2008 Location: Ottawa, ON Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,005
| ![]() ![]() ![]() Get a leakdown test done.
__________________ 2008 Cosmic Blue Mica Mazdaspeed 3. BNR s3, CoolingMist CMGS Meth, Damond TB Plate, JBR FMIC Undermount w/ TR8, JBR 3" Fullpath, Steedspeed EM, Cobb AP v3, Stratified Tuned, Autotech HPFP Internals, CP-e Catted Downpipe, Port and Polished IM with VTCS & Full EGR Delete, Grimmspeed EBCS, 3 BAR MAP Sensor, Turbosmart Dual-port BPV, Koni Sport Yellows, Eibach Prokits, SPC Camber Arms, Cobb FSB and RSB, AWR Front Endlinks, JBR Trilogy Mounts 70a Duro, KX-F3 Full Chassis Braces, Denso Iridium ITV-22, CP-e Safe Seals, SURE TIG IM and TB, Cobb Shift Weight, TWM SS w/Bushings and Specter Hybrid knob. To be installed: SS Brake Lines. |
![]() | ![]() | #365 | ![]() |
Tripple OG ![]() Join Date: Dec 2008 Location: North Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,643
Groans: 113
The Following 5 Users Say Thank You to NJSPEED3 For This Useful Post: | atvfreek (08-06-2012), Dano (08-06-2012), EdgeAutosport.com (08-06-2012), SLOWHATCH (05-01-2013), Tokay444 (08-06-2012) |
![]() | ![]() | #366 | ![]() |
![]() | ![]() | #367 | ![]() |
| ![]() ![]() ![]() Injector seals are my next install.
![]() | ![]() | #368 | ![]() |
![]() Join Date: Jun 2009
Rep Power: 991 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,126
Groans: 108
| ![]() ![]() ![]() Late to the compression posting party, but here it is. 70,000 miles on '08 MS3, purchased new in May, 2008. Mods below. Drive it hard. Recently did the intake manifold valve cleaning (about two months ago). Full synthetic 5w-30 since first oil change. Altitude is 200 feet. Ambient temp was 92 degrees. Did warm engine compression test last night out of curiosity. Forgot to pull the fuse on the injectors, so this is with some fuel being shot into the cylinders. Facing engine left to right (passenger side to driver side) #1 - 180 #2 - 180 #3 - 172 #4 - 180 I repeated #3 and got the same number. Have not done a leak down test, but I don't see 8 psi as a reason to be worried. It is something to watch and recheck. Original turbo. Never smoked. Did just have VVT and timing chain service done at dealer right before hitting 70,000. They did it free under warranty, even with my mods and no oil change records! I only flashed ECU back to stock for dealer service. Thought I'd get hit for $1200. I guess there may be some benefit from being 62 years old and not looking like the racer that i really am. lol.
__________________ Sunlight Silver '08 MS3 GT Mods: BNR Stage 1 (to fix smoking K04 turbo), TurboXS 3" Catless DP/RP "Stealthback" into stock CBE, Vibrant 3 inch Ultra Quiet Resonator in RP section, Magnaflow 3 1/2" exhaust tip, Mazdaspeed CAI w/air straightener and K&N conical filter, NGK 6510 Iridium IX one step colder plugs, Hypertech tune, Autotech HPFP internals, Stock BPV (works perfectly), Yokohama Advan Neova AD08R's (stock size on stock rims); Hawk HPS pads; SURE RMM; Grimmspeed EBCS (2 port mode), Bilstein B6's, SPC rear camber arms. |
![]() | ![]() | #369 | ![]() |
![]() Join Date: Jun 2009 Location: Old Bridge, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,044
Groans: 125
![]() | ![]() | #370 | ![]() |
| ![]() ![]() ![]() lol @ zero compression in all cylinders.
![]() | ![]() | #371 | ![]() |
Two nuns and a pack mule ![]() Join Date: Jan 2010 Location: Virginia Beach, VA
Rep Power: 573 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 459
| ![]() ![]() ![]() ~180 across. 81K.
__________________ ![]() |
![]() | ![]() | #372 | ![]() |
jbr makes fall-a-parts. ![]() Join Date: Jan 2011 Location: Cambridge Ontario Canada
Rep Power: 13509 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,742
Groans: 792
| ![]() ![]() ![]() @MSMS3 if you hold the gas to the floor while cranking, the injectors shut off. Try it on your next startup.
The Following User Says Thank You to Tokay444 For This Useful Post: | MSMS3 (08-09-2012) |
![]() | ![]() | #373 | ![]() |
Groans: 108
| ![]() ![]() ![]() ^ Thanks! That is useful info. I intended to pull the fuse and just forgot. Will certainly follow your advice when I check compression again. I want to keep an eye on #3 and make sure it does not drop further in relation to the others.
![]() | ![]() | #374 | ![]() |
![]() Join Date: Aug 2011 Location: woodbury,NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 168
Groaned at 27 Times in 13 Posts
| ![]() ![]() ![]() just picked up my 06 ms6, did a compression check b4 i purchased it, 175 down the board! @phate
__________________ 06 Mazdaspeed 6 Precision 5858cea, PG turbo mani, 3" catless vband DP, 3" JBR intake, Cobb AP, Cobb EBCS 3 bar, TR8 intercooler, CPE 3" single exhaust/magnaflow muffler, NJSPEED P&P intake mani KMD internals, CPE safe seals, GFB turbo fuse, Turbosmart 50/50 JBR tranny mount, AWR dogbone, Turbine Tech front/rear diff mount, Whiteline Rsb, AWR rear adjustable endlinks, BC coils (suckie), OZ Ultraleggeras, waiting to install Devils own meth kit, ATVFREEK tuned! PS: Forever BT slow |
![]() | ![]() | #375 | ![]() |
Engineered Tuning ![]() ![]() Join Date: Jun 2008 Location: Vancouver, Canada
Rep Power: 12001 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,485
(Thread Starter) | ![]() ![]() ![]()
![]() | ![]() | #376 | ![]() |
![]() Join Date: Sep 2011 Location: Rockville, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,554
Groans: 130
Groaned at 8 Times in 7 Posts
| ![]() ![]() ![]() Did mine last night. Uh oh (passenger) 175 150 125 175 (driver) Looks like time to source a new motor!
__________________ ![]() 06 Black Cherry Mica MS6 GT: Speed Perf6rmanc3 built motor, GT3076r EWG, ACT 6 puck Clutch kit, HTP 3.5" full intake, M2 downpipe, XS Power Exhaust Manifold, CP-E austenite 3" exhaust, Whiteline 24mm rear sway bar, Injector RX Cleaned injectors, JBR trilogy motor mounts, JBR EGR Block off plate, Ported and ceramic coated intake manifold, 3 bar MAP, 3 port EBCS, Cobb AP, CX racing piping with Treadstone TR8, CP-E SAFEseals, MD OCC, Step Colder spark plugs, Turbo XS RFL BOV, AT fp internals, CP-E rear diff mount, Turbine Tech Front rear diff mount, DSS 500hp rear drivers side axle, Wilwood 4 Pot Calipers, Team Dynamics 18"x8" Pro Race 1.2s +38, SPC front ball joints, H&R springs, Morimoto clear projector retrofits. |
![]() | ![]() | #377 | ![]() |
(Thread Starter) | ![]() ![]() ![]() Did you crank it until the needle stopped rising?
![]() | ![]() | #378 | ![]() |
Groans: 130
| ![]() ![]() ![]() Yep, even checked cylinder #3 twice. Consistent 125
![]() | ![]() | #379 | ![]() |
![]() Join Date: Feb 2011 Location: Waterford,CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,169
Groans: 423
| ![]() ![]() ![]() Do a leak down test to find the source of the loss in compression. Its possible you might not need a whole new engine.
__________________ -Pat 2008 True Red MS3 GT3071R 'n Stuff SOLD 1999 Jeep XJ 6.5" Lift | Armor | 33" Tires | Bumpers 1996 Jeep XJ 3.5" Lift | 31" GY Duratracs | Bumpers 1994 Miata 15x8's w/NT05's | KYB AGX | Hardog Roll Bar | 70D Engine Mounts |
![]() | ![]() | #380 | ![]() |
![]() Join Date: Jun 2011 Location: Cumberland, Rhode Island
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,309
| ![]() ![]() ![]() I just did mine today. 83k on the motor. 170 160 165 165 I am pretty happy with the results.
__________________ 2007 MS3 Black Mica. ![]() FREEKtuned 277/316 Dynojet Corksport SRI/TIP/FMIC/GFB BPV/AT Internals/EBCS/Gutted 2nd Cat Bilstein B8/Swift Spec-R/ST120s/Nitto 555 JBR 70dur. RMM-TMM-PMM/SSP+Bushings/TIGs/OCC |
![]() | ![]() | #381 | ![]() |
![]() Join Date: Feb 2012 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,815
Groans: 255
| ![]() ![]() ![]() Any update on this?
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress ![]() |
![]() | ![]() | #382 | ![]() |
Groans: 130
![]() | ![]() | #383 | ![]() |
Eth Fiend ![]() Join Date: May 2010 Location: Auburn Hills, MI
Rep Power: 11120 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,790
| ![]() ![]() ![]() [QUOTE=Jh8909;1698256]Yep. Brand spankin new from Mazda? I recognize that box lol.
The Following User Says Thank You to phate For This Useful Post: | Jh8909 (10-19-2012) |
![]() | ![]() | #384 | ![]() |
Groans: 130
| ![]() ![]() ![]() [quote=phate;1698287]Yep. Just tested to see if it works. Its got 3 miles on it. Got it for a steal. You don't wanna know how much lol
The Following User Says Thank You to Jh8909 For This Useful Post: | phate (10-19-2012) |
![]() | ![]() | #385 | ![]() |
| ![]() ![]() ![]() [quote=Jh8909;1698334]
![]() New shit runs SOOO well, lol. Have fun with it!
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. | |
![]() | ![]() | #386 | ![]() |
Groans: 130
| ![]() ![]() ![]() [quote=phate;1698385]
__________________ ![]() 06 Black Cherry Mica MS6 GT: Speed Perf6rmanc3 built motor, GT3076r EWG, ACT 6 puck Clutch kit, HTP 3.5" full intake, M2 downpipe, XS Power Exhaust Manifold, CP-E austenite 3" exhaust, Whiteline 24mm rear sway bar, Injector RX Cleaned injectors, JBR trilogy motor mounts, JBR EGR Block off plate, Ported and ceramic coated intake manifold, 3 bar MAP, 3 port EBCS, Cobb AP, CX racing piping with Treadstone TR8, CP-E SAFEseals, MD OCC, Step Colder spark plugs, Turbo XS RFL BOV, AT fp internals, CP-E rear diff mount, Turbine Tech Front rear diff mount, DSS 500hp rear drivers side axle, Wilwood 4 Pot Calipers, Team Dynamics 18"x8" Pro Race 1.2s +38, SPC front ball joints, H&R springs, Morimoto clear projector retrofits. | |
![]() | ![]() | #387 | ![]() |
| ![]() ![]() ![]() LOL, AWESOME!
![]() | ![]() | #388 | ![]() |
Groans: 255
| ![]() ![]() ![]() [quote=Jh8909;1698399]
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress ![]() | |
![]() | ![]() | #389 | ![]() |
| ![]() ![]() ![]() Seriously jealous.
![]() | ![]() | #390 | ![]() |
good for ya
The Following User Says Thank You to Dano For This Useful Post: | Jh8909 (10-20-2012) |
![]() | ![]() | #391 | ![]() |
Groans: 130
| ![]() ![]() ![]() Yeah there is no rush to put it in now. I picked up a beater so I'm just gonna try to save up for now and then take it to pablo eventually and let him do his magic.
![]() | ![]() | #392 | ![]() |
![]() Join Date: Jun 2010 Location: Ellicott City, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 57
| ![]() ![]() ![]() tested again after about 6k miles on the gt30 got the best results I've ever seen on any car I've owned lol 1 - 184 2 - 182 3 - 183 4 - 184
__________________ 09 CWP MS3 Sport - ATP GT3071r on ~E30, ACT 6-puck, TR8 FMIC, Bilsteins, etc... sold ![]() |
![]() | ![]() | #393 | ![]() |
![]() Join Date: Mar 2008 Location: W. Suffield, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 665
Groans: 67
| ![]() ![]() ![]() That is what I am getting on two motors. Yet to test the one in my car. Looks like both motors the intake valves dont close until TDC. Could both be perfectly off 90* of time or whatever it is? First motor is a built engine and should be perfect. 2nd has 60k on it and should be good also. Seems like user error but I didn't think I was that stupid. Tested comp tester with compressor and can get it to go up to 60 or so. Did someone else have the same problem? I assume that is what you were quoting. Didn't have time to read all 10 pages yet. |
![]() | ![]() | #394 | ![]() |
Groans: 423
Edit; re read post. The part about the compressor is what confused me. In that case, have you done a leak down? Tapa
__________________ -Pat 2008 True Red MS3 GT3071R 'n Stuff SOLD 1999 Jeep XJ 6.5" Lift | Armor | 33" Tires | Bumpers 1996 Jeep XJ 3.5" Lift | 31" GY Duratracs | Bumpers 1994 Miata 15x8's w/NT05's | KYB AGX | Hardog Roll Bar | 70D Engine Mounts | |
![]() | ![]() | #395 | ![]() |
Groans: 67
One tried with starter attached using a battery and got nothing for compression. I can look down spark plug hole on both and see that the valves stay open as cylinder comes up. This confuses me. | |
The Following User Says Thank You to aviator79 For This Useful Post: | smoogs12 (11-12-2012) |
![]() | ![]() | #396 | ![]() |
![]() | ![]() | #397 | ![]() |
Groans: 67
I just got 30psi on cylinder 1. ![]() | |
![]() | ![]() | #398 | ![]() |
Groans: 423
Tapa
![]() | ![]() | #399 | ![]() |
| ![]() ![]() ![]() never have...and to get an accurate compression or leakdown test the motor needs to be at operating temp which you cant duplicate with it out of the car. I wouldn't think it would be that low even stone cold. maybe 150 where warmed up it would be 180.
![]() | ![]() | #400 | ![]() |
Nishan ![]() Join Date: Apr 2012
Rep Power: 9791 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,290
| ![]() ![]() ![]() Very cool thread! Here are my results. I did not pull all the spark plugs (did one at a time). I'll do it again with all plugs removed. Gotta nag my friend to let me get that snap on tester back ! 205 200 200 200
__________________ www.tunedbynishan.com Last edited by ms3blackmica; 11-20-2012 at 02:29 AM. |
The Following 4 Users Say Thank You to ms3blackmica For This Useful Post: |
![]() LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/disi-compression-results-43395/ | ||||
Posted By | For | Type | Date | |
Random MS3 Chat Thread - Page 171 | This thread | Refback | 04-20-2013 04:45 PM | |
Anyone measure compression on stock motor? - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum | Post #12 | Pingback | 03-12-2010 08:06 AM |
Display Modes | |
Compression test on built motor | SharkDiver | MazdaSpeed 3 - Engine, Transmission & Driveline | 5 | 10-22-2009 02:48 PM |
Compression check on Laloosh's motor | gsrtype1 | MazdaSpeed 3 - Engine, Transmission & Driveline | 27 | 09-06-2009 06:25 PM |
engine build with stock compression | Jessed87 | MazdaSpeed 3 - Engine, Transmission & Driveline | 8 | 06-12-2009 10:55 PM |
Compression test done.. | SharkDiver | MazdaSpeed 3 - Engine, Transmission & Driveline | 3 | 03-25-2009 03:28 PM |
engine compression? | bombdotcom | Mazdaspeed3/6 General Discussion | 12 | 09-23-2008 03:06 AM |
