Like Tree41Likes
 Old 08-03-2012, 04:06 PM   #361
'MERICA's Avatar
Posts: 10   (View Stats)
'MERICA will become famous soon enough
190, 185, 155, 190....... how bad is this? I tried reading the whole thread and im losing my train of thought...... ugh im nervous about this... any suggestions?
'MERICA is offline   Reply With Quote
 Old 08-03-2012, 04:41 PM   #362
Posts: 9,484   (View Stats)
There is def something wrong in that 3rd cylinder. I would get a leakdown test to confirm but some possibilities, non of which are good are:
bent rod
broken piston ringland
do you get any vibrations when you press the clutch in?
phate (08-03-2012), Tokay444 (08-03-2012)
 Old 08-06-2012, 06:34 AM   #363
'MERICA's Avatar
bent rod
No there is no clutch pedal vibrations, the car runs great, no burning oil, still very strong pulls, i also am still getting great gas mileage as well... i have read in this thread the oil in plug hole test which i plan on doing tuesday... im hoping its a valve problem more than anything else
 Old 08-06-2012, 12:39 PM   #364
theurgy's Avatar
Posts: 2,580   (View Stats)
Get a leakdown test done.
BNR s3, CoolingMist CMGS Meth, Damond TB Plate, JBR FMIC Undermount w/ TR8, JBR 3" Fullpath, Steedspeed EM, Cobb AP v3, Stratified Tuned, Autotech HPFP Internals, CP-e Catted Downpipe, Port and Polished IM with VTCS & Full EGR Delete, Grimmspeed EBCS, 3 BAR MAP Sensor, Turbosmart Dual-port BPV, Koni Sport Yellows, Eibach Prokits, SPC Camber Arms, Cobb FSB and RSB, AWR Front Endlinks, JBR Trilogy Mounts 70a Duro, KX-F3 Full Chassis Braces, Denso Iridium ITV-22, CP-e Safe Seals, SURE TIG IM and TB, Cobb Shift Weight, TWM SS w/Bushings and Specter Hybrid knob.
To be installed: SS Brake Lines.
theurgy is offline   Reply With Quote
 Old 08-06-2012, 12:41 PM   #365
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
bent rod
blown injector seal
The Following 5 Users Say Thank You to NJSPEED3 For This Useful Post:
atvfreek (08-06-2012), Dano (08-06-2012), EdgeAutosport.com (08-06-2012), SLOWHATCH (05-01-2013), Tokay444 (08-06-2012)
 Old 08-06-2012, 01:22 PM   #366
'MERICA's Avatar
That was also on the checklist.. im feeling more confident its not a bent rod.. however if its the piston rings its still going to cost me :/... injector seal would be optimal problem lol
 Old 08-06-2012, 01:39 PM   #367
theurgy's Avatar
Injector seals are my next install.
 Old 08-08-2012, 10:41 AM   #368
MSMS3's Avatar
Posts: 2,834   (View Stats)
Groans: 157
Late to the compression posting party, but here it is. 70,000 miles on '08 MS3, purchased new in May, 2008. Mods below. Drive it hard. Recently did the intake manifold valve cleaning (about two months ago). Full synthetic 5w-30 since first oil change. Altitude is 200 feet. Ambient temp was 92 degrees.
Did warm engine compression test last night out of curiosity. Forgot to pull the fuse on the injectors, so this is with some fuel being shot into the cylinders.
Facing engine left to right (passenger side to driver side)
#1 - 180
#2 - 180
#3 - 172
#4 - 180
I repeated #3 and got the same number. Have not done a leak down test, but I don't see 8 psi as a reason to be worried. It is something to watch and recheck. Original turbo. Never smoked. Did just have VVT and timing chain service done at dealer right before hitting 70,000. They did it free under warranty, even with my mods and no oil change records! I only flashed ECU back to stock for dealer service. Thought I'd get hit for $1200. I guess there may be some benefit from being 62 years old and not looking like the racer that i really am. lol.
 Old 08-08-2012, 11:36 AM   #369
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
Originally Posted by TWOptSL0W View Post
just hit 50k and i have 180 in all cylinders i guess im good for another few miles until my shit explodes
70k...my shit exploded
The Following 3 Users Say Thank You to TWOptSL0W For This Useful Post:
802MS3 (08-12-2012), Dano (08-08-2012), trf5000 (08-08-2012)
 Old 08-08-2012, 11:38 AM   #370
lol @ zero compression in all cylinders.
 Old 08-08-2012, 01:07 PM   #371
Two nuns and a pack mule
AtTheDriveIn's Avatar
Posts: 1,527   (View Stats)
AtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the world
~180 across. 81K.
AtTheDriveIn is offline   Reply With Quote
 Old 08-08-2012, 05:52 PM   #372
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
@MSMS3 if you hold the gas to the floor while cranking, the injectors shut off.
Try it on your next startup.
"Exclusivity" - CP-enis
Demodded.
The Seals
MSMS3 (08-09-2012)
 Old 08-09-2012, 09:48 AM   #373
MSMS3's Avatar
Groans: 157
^ Thanks! That is useful info. I intended to pull the fuse and just forgot. Will certainly follow your advice when I check compression again. I want to keep an eye on #3 and make sure it does not drop further in relation to the others.
 Old 08-11-2012, 09:03 PM   #374
nextgenerationx1's Avatar
Posts: 536   (View Stats)
nextgenerationx1 is the leader of the worldnextgenerationx1 is the leader of the worldnextgenerationx1 is the leader of the worldnextgenerationx1 is the leader of the worldnextgenerationx1 is the leader of the worldnextgenerationx1 is the leader of the worldnextgenerationx1 is the leader of the worldnextgenerationx1 is the leader of the worldnextgenerationx1 is the leader of the worldnextgenerationx1 is the leader of the worldnextgenerationx1 is the leader of the world
Groaned at 27 Times in 13 Posts
just picked up my 06 ms6, did a compression check b4 i purchased it, 175 down the board! @phate
06 Mazdaspeed 6
Precision 5858cea, PG turbo mani, 3" catless vband DP, 3" JBR intake, Cobb AP, Cobb EBCS
3 bar, TR8 intercooler, CPE 3" single exhaust/magnaflow muffler, NJSPEED P&P intake mani
KMD internals, CPE safe seals, GFB turbo fuse, Turbosmart 50/50
JBR tranny mount, AWR dogbone, Turbine Tech front/rear diff mount, Whiteline Rsb,
AWR rear adjustable endlinks, BC coils (suckie), OZ Ultraleggeras,
waiting to install Devils own meth kit,
ATVFREEK tuned!
PS: Forever BT slow
nextgenerationx1 is offline   Reply With Quote
The Following 2 Users Say Thank You to nextgenerationx1 For This Useful Post:
phate (08-11-2012), Tokay444 (08-11-2012)
 Old 08-11-2012, 09:14 PM   #375
Sounds like you got one in good shape!
 Old 08-30-2012, 09:36 AM   #376
Jh8909's Avatar
Posts: 1,457   (View Stats)
Jh8909 is the leader of the worldJh8909 is the leader of the worldJh8909 is the leader of the worldJh8909 is the leader of the worldJh8909 is the leader of the worldJh8909 is the leader of the worldJh8909 is the leader of the worldJh8909 is the leader of the worldJh8909 is the leader of the worldJh8909 is the leader of the worldJh8909 is the leader of the world
Groans: 130
Groaned at 8 Times in 7 Posts
Did mine last night. Uh oh
(passenger)
175
150
125
175
(driver)
Looks like time to source a new motor!
06 Black Cherry Mica MS6 GT: Speed Perf6rmanc3 built motor, GT3076r EWG, ACT 6 puck Clutch kit, HTP 3.5" full intake, M2 downpipe, XS Power Exhaust Manifold, CP-E austenite 3" exhaust, Whiteline 24mm rear sway bar, Injector RX Cleaned injectors, JBR trilogy motor mounts, JBR EGR Block off plate, Ported and ceramic coated intake manifold, 3 bar MAP, 3 port EBCS, Cobb AP, CX racing piping with Treadstone TR8, CP-E SAFEseals, MD OCC, Step Colder spark plugs, Turbo XS RFL BOV, AT fp internals, CP-E rear diff mount, Turbine Tech Front rear diff mount, DSS 500hp rear drivers side axle, Wilwood 4 Pot Calipers, Team Dynamics 18"x8" Pro Race 1.2s +38, SPC front ball joints, H&R springs, Morimoto clear projector retrofits.
Jh8909 is offline   Reply With Quote
 Old 08-30-2012, 09:48 AM   #377
(passenger)
175
150
125
175
(driver)
Did you crank it until the needle stopped rising?
 Old 08-30-2012, 09:51 AM   #378
Jh8909's Avatar
Groans: 130
Yep, even checked cylinder #3 twice. Consistent 125
 Old 08-30-2012, 10:09 AM   #379
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
(passenger)
175
150
125
175
(driver)
Do a leak down test to find the source of the loss in compression. Its possible you might not need a whole new engine.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 09-01-2012, 05:40 PM   #380
franz's Avatar
Posts: 1,258   (View Stats)
franz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the world
I just did mine today. 83k on the motor.
170
160
165
165
I am pretty happy with the results.
2007 MS3 Black Mica. Stock. 235whp/244wtq Dynojet
FREEKtuned 277/316 Dynojet
Corksport SRI/TIP/FMIC/GFB BPV/AT Internals/EBCS/Gutted 2nd Cat
Bilstein B8/Swift Spec-R/ST120s/Nitto 555
JBR 70dur. RMM-TMM-PMM/SSP+Bushings/TIGs/OCC
franz is offline   Reply With Quote
 Old 10-19-2012, 02:05 PM   #381
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
(passenger)
175
150
125
175
(driver)
Any update on this?
Pickles Tune in progress
 Old 10-19-2012, 02:30 PM   #382
Jh8909's Avatar
Groans: 130
Originally Posted by himurax13 View Post
Any update on this?
Yep.
 Old 10-19-2012, 02:46 PM   #383
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
[QUOTE=Jh8909;1698256]Yep.
Brand spankin new from Mazda? I recognize that box lol.
-06 MS6
-Corn fed 07 MS3 - Sold
Jh8909 (10-19-2012)
 Old 10-19-2012, 03:19 PM   #384
Jh8909's Avatar
Groans: 130
[quote=phate;1698287]
Yep.
Yep. Just tested to see if it works. Its got 3 miles on it. Got it for a steal. You don't wanna know how much lol
The Following User Says Thank You to Jh8909 For This Useful Post:
phate (10-19-2012)
 Old 10-19-2012, 03:44 PM   #385
Eth Fiend
phate's Avatar
[quote=Jh8909;1698334]
You're doing well if it was under $3500 or so
New shit runs SOOO well, lol. Have fun with it!
-06 MS6
Jh8909 (10-19-2012)
 Old 10-19-2012, 03:50 PM   #386
Jh8909's Avatar
Groans: 130
[quote=phate;1698385]
Well i got it from a guy that works at mazda down in maryland, traded him an AP and Autotechs for it. So $763 lol
The Following 5 Users Say Thank You to Jh8909 For This Useful Post:
802MS3 (10-21-2012), Dano (10-20-2012), phate (10-19-2012), silvapain (10-19-2012), smoogs12 (10-20-2012)
 Old 10-19-2012, 03:53 PM   #387
Eth Fiend
phate's Avatar
LOL, AWESOME!
-06 MS6
 Old 10-19-2012, 03:56 PM   #388
himurax13's Avatar
Groans: 255
[quote=Jh8909;1698399]
Jealous.
 Old 10-19-2012, 05:08 PM   #389
theurgy's Avatar
Seriously jealous.
 Old 10-20-2012, 09:51 AM   #390
that is redic....seriously!
good for ya
Jh8909 (10-20-2012)
 Old 10-20-2012, 09:58 AM   #391
Jh8909's Avatar
Groans: 130
Yeah there is no rush to put it in now. I picked up a beater so I'm just gonna try to save up for now and then take it to pablo eventually and let him do his magic.
 Old 10-21-2012, 10:12 PM   #392
kimura's Avatar
Posts: 170   (View Stats)
kimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the world
tested again after about 6k miles on the gt30
got the best results I've ever seen on any car I've owned lol
1 - 184
2 - 182
3 - 183
4 - 184
09 CWP MS3 Sport - ATP GT3071r on ~E30, ACT 6-puck, TR8 FMIC, Bilsteins, etc... sold
kimura is offline   Reply With Quote
 Old 11-12-2012, 01:26 PM   #393
aviator79's Avatar
Posts: 3,934   (View Stats)
Groans: 67
That is what I am getting on two motors. Yet to test the one in my car. Looks like both motors the intake valves dont close until TDC. Could both be perfectly off 90* of time or whatever it is? First motor is a built engine and should be perfect. 2nd has 60k on it and should be good also. Seems like user error but I didn't think I was that stupid. Tested comp tester with compressor and can get it to go up to 60 or so.
Did someone else have the same problem? I assume that is what you were quoting. Didn't have time to read all 10 pages yet.
 Old 11-12-2012, 03:45 PM   #394
smoogs12's Avatar
Groans: 423
Hold on are you doing a compression test or a leakdwn test?
Edit; re read post. The part about the compressor is what confused me.
In that case, have you done a leak down?
Tapa
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 11-12-2012, 04:04 PM   #395
aviator79's Avatar
Groans: 67
Tapa
Nowhere had a leakdown tester so have no way to do one yet. Both engines are on stands, not in car.
One tried with starter attached using a battery and got nothing for compression. I can look down spark plug hole on both and see that the valves stay open as cylinder comes up. This confuses me.
smoogs12 (11-12-2012)
 Old 11-12-2012, 04:11 PM   #396
pull the oil fill cap and see if the timing chain is moving when you turn the motor over...if not the crank bolt/washer combo is fubared...turn the motor by hand not with a starter.
 Old 11-12-2012, 09:37 PM   #397
aviator79's Avatar
Groans: 67
Timing chain is moving, valves are moving. Anyone ever check compression when engine is out of car?
I just got 30psi on cylinder 1.
 Old 11-12-2012, 10:17 PM   #398
smoogs12's Avatar
Groans: 423
I feel like given your situation, a leak down test would really be better.
Tapa
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 11-12-2012, 10:21 PM   #399
never have...and to get an accurate compression or leakdown test the motor needs to be at operating temp which you cant duplicate with it out of the car. I wouldn't think it would be that low even stone cold. maybe 150 where warmed up it would be 180.
aviator79 (11-13-2012), phate (11-12-2012)
 Old 11-20-2012, 03:13 AM   #400
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
Very cool thread!
Here are my results. I did not pull all the spark plugs (did one at a time). I'll do it again with all plugs removed. Gotta nag my friend to let me get that snap on tester back !
205
200
200
200
www.tunedbynishan.com
The Following 4 Users Say Thank You to ms3blackmica For This Useful Post:
smoogs12 (11-20-2012), SPEED6 KILLAH (11-20-2012), Speed_j23 (11-21-2012), Tokay444 (11-20-2012)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/disi-compression-results-43395/
Random MS3 Chat Thread - Page 171 This thread Refback 04-20-2013 05:45 PM
Anyone measure compression on stock motor? - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum Post #12 Pingback 03-12-2010 09:06 AM
Compression test on built motor SharkDiver MazdaSpeed 3 - Engine, Transmission & Driveline 5 10-22-2009 03:48 PM
Compression check on Laloosh's motor gsrtype1 MazdaSpeed 3 - Engine, Transmission & Driveline 27 09-06-2009 07:25 PM
engine build with stock compression Jessed87 MazdaSpeed 3 - Engine, Transmission & Driveline 8 06-12-2009 11:55 PM
Compression test done.. SharkDiver MazdaSpeed 3 - Engine, Transmission & Driveline 3 03-25-2009 04:28 PM
engine compression? bombdotcom Mazdaspeed3/6 General Discussion 12 09-23-2008 04:06 AM
Page generated in 0.57339 seconds with 38 queries
