![]() | | #561 | ![]() |
![]() Join Date: Jan 2011 Location: Midlothian, Va
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12,042
Groans: 274
| Not Ranked : 0 score Dry test: Cyl 1- 180 Cyl 2- 180 Cyl 3- 165 Cyl 4- 172 Wet test: 185 185 175 175 No oil in intake etc. In process of finding someone who can do a leak down test. Still on stock injector seals. Contemplating on replacing them. Is piston design on gen 2 the reason for what appears to be lower #'s. I see lots of gen 1's hitting 190's more often than gen2. Last edited by SLOWHATCH; 05-02-2013 at 10:06 AM. |
![]() | | #562 | ![]() |
![]() Join Date: Mar 2011 Location: Bethlehem, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,167
| Not Ranked : 0 score Here's my results! Car has 79K on it, Coolant temp was 111* during testing according to the AP. The motor was pretty warm but I could keep my hand on the valve cover with out it being too hot. Car had been run for no more than a minute to pull it into the garage bay about 30 min prior to the tests, and was driven home from work about 2.5 hours prior to test. Warmed engine, recently run engine, and possible gauge differences may be to blame for the seemingly elevated numbers... I'll try and use this gauge/tester on another DISI at some point to verify... All I know is I am extremely happy with the results being nice and even across. Engine was cranked until the gauge very little more, probably 7-9 turn overs of the engine. Results - 1/2/3/4 as one would look at the engine from the front of the car: (197/203/200/196) Pictures are all below and labeled. I replaced the old plugs while in there (ITV22) they had about 40k on them. Definitely worn.
__________________ 07' Speed6 Velocity Red Mica Go Faster: CorkSport SRI/TIP, SU Test Pipe, SU TMIC, Autotech Internals, ITV22's, Cobb AP Anti break stuff: Upper Rear Diff Brace, RMM Appearence: STRI DSD Boost Guage/Blockhead 60mm Guage Pod |
| The Following 5 Users Say Thank You to scubasteve711 For This Useful Post: | atvfreek (05-15-2013), Lex (05-15-2013), ms3blackmica (05-15-2013), phate (05-15-2013), qtrmile beast (05-16-2013) |
![]() | | #563 | ![]() |
![]() Join Date: Jul 2008 Location: Ottawa, ON Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,005
| Not Ranked : 0 score Those are very good results.
__________________ 2008 Cosmic Blue Mica Mazdaspeed 3. BNR s3, CoolingMist CMGS Meth, Damond TB Plate, JBR FMIC Undermount w/ TR8, JBR 3" Fullpath, Steedspeed EM, Cobb AP v3, Stratified Tuned, Autotech HPFP Internals, CP-e Catted Downpipe, Port and Polished IM with VTCS & Full EGR Delete, Grimmspeed EBCS, 3 BAR MAP Sensor, Turbosmart Dual-port BPV, Koni Sport Yellows, Eibach Prokits, SPC Camber Arms, Cobb FSB and RSB, AWR Front Endlinks, JBR Trilogy Mounts 70a Duro, KX-F3 Full Chassis Braces, Denso Iridium ITV-22, CP-e Safe Seals, SURE TIG IM and TB, Cobb Shift Weight, TWM SS w/Bushings and Specter Hybrid knob. To be installed: SS Brake Lines. |
| The Following User Says Thank You to theurgy For This Useful Post: | scubasteve711 (05-15-2013) |
![]() | | #564 | ![]() |
| Not Ranked : 0 score Well, fighting a pretty irritating KR issue at the moment which is why this was done... At this point, I've pulled a ton of timing and it has brought KR down, but not totally eliminated it... Next step I think is going to be to determine if this is real KR or not... Car has run more timing in the past without any issue at all.
![]() | | #565 | ![]() |
| The Following 3 Users Say Thank You to Lex For This Useful Post: |
![]() | | #566 | ![]() |
| Not Ranked : 0 score Hate to say it, but have you checked your intake valves? I trust that you're datalogging these knock events.
![]() | | #567 | ![]() |
| Not Ranked : 0 score No E85 around - "methyl hydrate" any good place to get this? or a more common name for it? (besides meth :p) I've heard of denatured alcohol being used in place of E85...
No Valves never been done - this is VERY much on the to do list however. The VVT / Timing chain has never been done either - Anything that could be see in the logs regarding the VVT? The engine is a little noisy on startup, but it last for only a couple seconds and is absolutely nothing like any of the youtube vids I've seen.
__________________ 07' Speed6 Velocity Red Mica Go Faster: CorkSport SRI/TIP, SU Test Pipe, SU TMIC, Autotech Internals, ITV22's, Cobb AP Anti break stuff: Upper Rear Diff Brace, RMM Appearence: STRI DSD Boost Guage/Blockhead 60mm Guage Pod | |
![]() | | #568 | ![]() |
| Not Ranked : 0 score I know you can get some at Home Depot: Recochem | Methyl Hydrate - 3.78 L | Home Depot Canada Oh yeah and Valves and VVT stat... the youtube videos are pretty extreme, mine didn't make as much noise as what I heard online, however, I did notice the noise and brought it into my dealership and they confirmed and swapped it under warranty.
![]() | | #569 | ![]() |
| Not Ranked : 0 score As far as the warranty goes, I have an extended for exactly 600 more miles... As I am at 79k and change,,, This will probably be something I will be doing on my own unfortunately. I'd have to front the 200 for them to pull the valve cover and confirm, and then hope the extended covers it, by the time I spend 200 bucks, I might as well have put that towards the parts. Starting point on how much for a tank?
__________________ 07' Speed6 Velocity Red Mica Go Faster: CorkSport SRI/TIP, SU Test Pipe, SU TMIC, Autotech Internals, ITV22's, Cobb AP Anti break stuff: Upper Rear Diff Brace, RMM Appearence: STRI DSD Boost Guage/Blockhead 60mm Guage Pod Last edited by scubasteve711; 05-15-2013 at 02:41 PM. |
![]() | | #570 | ![]() |
| Not Ranked : 0 score I would ask @Lex; on that one.. he's the expert.
![]() | | #571 | ![]() |
| Not Ranked : 0 score ahhh f*ck a duck... Us US peoples can't get that stuff... Brings me back to denatured alcohol lol...
![]() | | #572 | ![]() |
Groans: 793
| Not Ranked : 0 score A gallon of meth in tank will tell you if it's fuel related real knock b
| The Following User Says Thank You to Tokay444 For This Useful Post: | SLOWHATCH (05-19-2013) |
![]() | | #573 | ![]() |
| Not Ranked : 0 score Results on my new motor with 350 miles 185 across the board on a very warm motor. PU pistons.
| The Following 9 Users Say Thank You to Dano For This Useful Post: | atvfreek (05-15-2013), btstarcher (05-15-2013), Easter Bunny (05-15-2013), Lex (05-15-2013), Nliiitend1 (05-15-2013), phate (05-15-2013), Realgib3 (05-16-2013), SLOWHATCH (05-19-2013), Ziggo (05-15-2013) |
![]() | | #574 | ![]() |
(Thread Starter) | Not Ranked : 0 score methanol, I would put in 1 gallon per tank for testing, e85 2 gallons.
![]() | | #575 | ![]() |
![]() Join Date: Jun 2012 Location: San Jose, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,963
Groans: 47
![]() I did the test twice just to make sure and I got pretty much exactly the same numbers. I'm thinking my oil consumption may be either PCV related or turbocharger seal related. I will look further into the oil consumption issue after I finish the VVT/timing chain swap. @Dano; @Lex; Edit: This is with close to 87K miles too, even though the numbers themselves may be slightly off, I'm amazed that they are all within 10PSI(about 5-6% variance) of each other.
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() Last edited by sidekick; 05-15-2013 at 06:57 PM. | |
| The Following 8 Users Say Thank You to sidekick For This Useful Post: | atvfreek (05-16-2013), btstarcher (05-15-2013), cld12pk2go (05-15-2013), Easter Bunny (05-17-2013), jseams (05-15-2013), Lex (05-15-2013), theurgy (05-15-2013), Tokay444 (05-16-2013) |
![]() | | #576 | ![]() |
(Thread Starter) | Not Ranked : 0 score Those numbers look strong to me. A good indicator for blowby is oil in your intake tract via the valve cover vent.
| The Following 2 Users Say Thank You to Lex For This Useful Post: | Dano (05-15-2013), Easter Bunny (05-17-2013) |
![]() | | #577 | ![]() |
| Not Ranked : 0 score +1 on the oil in the TIP. if you go the extra mile and pull it you may see oil pooling in the compressor inlet like I did but that was with a busted ringland and your numbers don't seem to point to something that severe.
![]() | | #578 | ![]() |
![]() Join Date: Jun 2008 Location: Midwest
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 477
| Not Ranked : 0 score Ok, had the techs do a comp test this morning - I am now at 165k. 155 150 155 145 I plan to put in the step-colder plugs soon, and will probably see if I can get a gauge and do my own leak-down test as well. The gauge is not very expensive, is it?
__________________ 2007 Sunlight Silver MazdaSpeed3 Sport | BNR S3v2 | Autotech Internals | Cobb TIH | 3BAR MAP Sensor | Denso itv-22's | MSCAI | ETS 3.5" TMIC | Synchronic DV | Stratified EBCS | Guardian Angel | UR Test Pipe | Cobb AP | Koni Yellows | JBR RMM | CORN YEAH! | 265,000m | Tuned by STRATIFIED!!! To install: CPE SafeSeals 2012 Velocity Red MazdaSpeed3 w/Tech | Autotech Internals | Sure Aeros V2 | 98,000m |
| The Following User Says Thank You to BackRoads For This Useful Post: | Tyhackman15 (05-16-2013) |
![]() | | #579 | ![]() |
| Not Ranked : 0 score Depends on the ones you get. The ones on ebay or Harbor Freight are pretty cheap.. but you get what you pay for on those. Have you considered renting one? I know there are some places that loan them (with a deposit) or rent them.
![]() | | #580 | ![]() |
![]() Join Date: Feb 2012 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,815
Groans: 255
Sent via rental car
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress | |
| The Following User Says Thank You to himurax13 For This Useful Post: | atvfreek (05-16-2013) |
![]() | | #581 | ![]() |
Groans: 47
Is it possible I could be consuming this much oil via the turbocharger seals and my stock cats are not allowing me to see the smoke? I suppose it even could smoke, but I've never seen it. I suppose it could also be related in some way to the PCV valve itself. I'm just not sure how I can pin point the source of the oil consumption. I spoke to a mechanic I know and he said he had a very similar issue with an N/A 2.3, but everything was in good mechanical condition and even replacing the PCV didn't help, but Mazda didn't offer any guidance because it fell within the "acceptable" range of 1 QT per 1K miles. @Lex;
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() | |
![]() | | #582 | ![]() |
![]() | | #583 | ![]() |
Groans: 793
| Not Ranked : 0 score I'm pretty convinced my oil consumption issue is turbo related. Under boost only. Small pool at the throttle body. And my valve cover is vta'd. No where else for it to come from. Try that. Clean the throttle body and coupler. Clean the intercooler, and cap the tip and vta the valve cover. Then see if you still get oil at the throttle body.
![]() | | #584 | ![]() |
![]() Join Date: May 2011 Location: Las Vegas NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 655
| Not Ranked : 0 score 2007 MS3 85k miles motor was hot relay removed and clutch/gas floored. ![]() DRY 1-182 2-152 3-156 4-182
__________________ 2007 MS3 Black Mica-Totaled @98500 on 09/2014 ![]() Current Car... 2009 MS3 Black Mica GT JBR TRU 3.0 Widepath full intake, BNR S3 v1, GS EBCS, 3 BAR , Forge BPV V2, Autotech internals , Denso Itv22, CNT Downpipe, CX-Racing piping with Cobb v2 core, Cobb AP v2, JBR RMM, JBR PMM, JBR TMM, JBR Oil Catch Can, EGR Delete, JBR TIG, Toyota Seals, HTP battery tray, DashHAWK Zoom Zoom |
![]() | | #585 | ![]() |
![]() Join Date: May 2009 Location: Russellville, AR
Rep Power: 1975 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,199
Groans: 112
| Not Ranked : 0 score Isn't it usually the head gasket if the middle two cylinders are both low?
__________________ JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, Forge V2 BPV, JBR TIG's, Kozmic EGR delete, Cobb AP, PTP HPFP internals, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Swift springs, Tri Point Engineering RSB, Whiteline Anti Lift Kit, PTP Injector Seals, GenPu transmission, Fidanza flywheel, 3 BAR MAP sensor, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, sleeved block, PTP BSD SnailTune in progress |
| The Following User Says Thank You to btstarcher For This Useful Post: | Tokay444 (05-19-2013) |
![]() | | #586 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,797
| Not Ranked : 0 score Checked mine today. 170-170-165-170
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 |
| The Following 3 Users Say Thank You to atvfreek For This Useful Post: |
![]() | | #587 | ![]() |
![]() Join Date: Sep 2011 Location: Jacksonville, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 360
| Not Ranked : 0 score Yes. Low compression in adjacent cylinders can indicate leakage between cylinders, especially if they are similarly low.
__________________ '06 Mazdaspeed 6 |
| The Following 2 Users Say Thank You to timjs For This Useful Post: | btstarcher (05-18-2013), Tokay444 (05-19-2013) |
![]() | | #588 | ![]() |
| Eth/Meth Junkie ![]() Join Date: Mar 2008 Location: Columbus, OH
Rep Power: 2957 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,846
Measured again today. Cranked ~12 revolutions on each: 1 - 186 2 - 183 3 - 181 4 - 180 ~3% spread. I still seem to have a happy engine. :-)
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) | |
| The Following 3 Users Say Thank You to cld12pk2go For This Useful Post: |
![]() | | #589 | ![]() |
![]() Join Date: Jul 2012 Location: Oceanside, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,654
Groans: 52
| Not Ranked : 0 score I'm at 107/115/120/110. Trying to get another gauge on there but the gallon of oil in my intercooler suggests that those reading are correct. How awesome is that? But I deploy in two months so I'm DD'ing on the economy map until I can store it. Dat Kaboom tune lyfe yo
__________________ 2010 Alternative Lifestyle Blue Mazdaspeed3 (sold)2008 Chevy Colorado. The only truck that comes with a lifetime guarantee... |
![]() | | #590 | ![]() |
Groans: 112
| Not Ranked : 0 score Was that with the engine at operating temperature?
![]() | | #591 | ![]() |
Groans: 52
| Not Ranked : 0 score Yes after a good long drive (100+ miles) pulled into the drive way and went to work. I'll post up some pictures later. I have no idea how my engine still runs. So much fucking oil it's insane. I'm going to try to get another tester on it, but the one I bought was a $50 one that was supposed to be decent. Not a cheap autozone one.
![]() | | #592 | ![]() |
(Thread Starter) | Not Ranked : 0 score Make sure you crank it until the needled stops rising.
![]() | | #593 | ![]() |
Groans: 255
This is a decent and affordable tester. http://www.sears.com/craftsman-compr...p-00947089000P Sent via blown passenger side speakers.
![]() | | #594 | ![]() |
Groans: 52
| Not Ranked : 0 score I did, both using the starter and then cranking it manually. And there is oil in the intake too. My engine is toast. I just can't believe it's that low and not zzb'd, I'm just staying entirely out of boost until I can store it.
![]() | | #595 | ![]() |
Groans: 255
| The Following User Says Thank You to himurax13 For This Useful Post: | ABolewski (06-02-2013) |
![]() | | #596 | ![]() |
Groans: 47
| Not Ranked : 0 score So you had no issues until dantes tuned you @ABolewski;
| The Following User Says Thank You to sidekick For This Useful Post: | ABolewski (06-02-2013) |
![]() | | #597 | ![]() |
Groans: 52
| Not Ranked : 0 score I guess it's possible to stock out, but I'd need a stock intake manifold and gasket, a cbe, and I think a EGR tube (not sure where it is). The problem is I do not have the time to do that before I deploy. Maybe I'll put a little more thought into it and see if stocking out is a possibility. First, is it even possible givin I've done all of my own oil changes, and it'll still be an obviously highly modded car? And yes, my engine was perfectly gone until Dantes tuned me.
| The Following User Says Thank You to ABolewski For This Useful Post: | Easter Bunny (06-03-2013) |
![]() | | #598 | ![]() |
Groans: 255
@lilred; still has his oem Catback. I decided to do a compression test with 3300 miles on the new engine. 190 188 190 186 Sent via blown passenger side speakers.
| The Following User Says Thank You to himurax13 For This Useful Post: | sidekick (06-02-2013) |
![]() | | #599 | ![]() |
Groans: 52
And I deploy from August '13 to March '14. The thing is I literally have no time for that at all. I have like 6 days off for the next two months before I deploy. I don't want to even think how it would be possible for me to do that. Thanks for your help though man.
__________________ 2010 Alternative Lifestyle Blue Mazdaspeed3 (sold)2008 Chevy Colorado. The only truck that comes with a lifetime guarantee... | |
![]() | | #600 | ![]() |
Groans: 255
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/disi-compression-results-43395/ | ||||
| Random MS3 Chat Thread - Page 171 | This thread | Refback | 04-20-2013 05:45 PM | |
| Anyone measure compression on stock motor? - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum | Post #12 | Pingback | 03-12-2010 09:06 AM | |
| Compression test on built motor | SharkDiver | MazdaSpeed 3 - Engine, Transmission & Driveline | 5 | 10-22-2009 03:48 PM |
| Compression check on Laloosh's motor | gsrtype1 | MazdaSpeed 3 - Engine, Transmission & Driveline | 27 | 09-06-2009 07:25 PM |
| engine build with stock compression | Jessed87 | MazdaSpeed 3 - Engine, Transmission & Driveline | 8 | 06-12-2009 11:55 PM |
| Compression test done.. | SharkDiver | MazdaSpeed 3 - Engine, Transmission & Driveline | 3 | 03-25-2009 04:28 PM |
| engine compression? | bombdotcom | Mazdaspeed3/6 General Discussion | 12 | 09-23-2008 04:06 AM |
