![]() | | #601 | ![]() |
![]() Join Date: Jul 2012 Location: Oceanside, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,654
Groans: 52
| Not Ranked : 0 score
__________________ 2010 Alternative Lifestyle Blue Mazdaspeed3 (sold)2008 Chevy Colorado. The only truck that comes with a lifetime guarantee... | |
![]() | | #602 | ![]() |
![]() Join Date: Feb 2012 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,815
Groans: 255
The mounts have to be swapped. The only thing that can stay is the fuel pump internals. Sent via blown passenger side speakers.
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress | |
| The Following User Says Thank You to himurax13 For This Useful Post: | ABolewski (06-03-2013) |
![]() | | #603 | ![]() |
| Not Ranked : 0 score I'd pull the internals anyways. They may replace the pump for some unknown reason, and then you're out $300+. It only takes 15 minutes to swap internals.
__________________ |
| The Following 4 Users Say Thank You to silvapain For This Useful Post: |
![]() | | #604 | ![]() |
![]() Join Date: Jun 2011 Location: Beach Park Illinois
Rep Power: 2610 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 46,278
Groans: 261
Groaned at 73 Times in 60 Posts
| Not Ranked : 0 score I have a stock fuel pump you can use and I know someone that might buy your intake mani from you and give you his stock one. @Spoc; |
| The Following 3 Users Say Thank You to Micha For This Useful Post: |
![]() | | #605 | ![]() |
Groans: 52
| Not Ranked : 0 score I'd definitely throw stock internals in there, exactly why silvapain said. Also, this isn't the thread for this, I'll PM you @himurax13; This might work out better then I thought. EDIT: @Micha; I'll sext you. Swapping mani's would work perfect, I'd give him my JBR gasket too and use his stock one. I have my on internals still.
![]() | | #606 | ![]() |
Groans: 255
![]() | | #607 | ![]() |
![]() Join Date: Aug 2012 Location: Versailles, KY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 162
| Not Ranked : 0 score Let me know what you guys think please. I started to smoke about 2 weeks ago since then I've added a JBR OCC with VTA kit (still waiting on Check Valve), a BNOON Bolt, and Rotella 5w-40. The other mods are in my Sig. So after these modifications I'm still smoking so i decided to do a compression test. 08 MS3 60,500 miles 862ft ASL #1 191 #2 172 #3 171 #4 171 I think if it was 170's across the board I would be ok with these results but with cylinder 1 being so much higher I don't know what to think? I'm hoping the check valve will help maybe my PCV valve is junk which is causing me to smoke. If not then I hope its just the turbo. Do you guys think it might be something else with the compression results above? Thanks for any advice!
__________________ Stay away from RD Motorsportz Last edited by DTKII; 06-03-2013 at 07:27 PM. Reason: Updated results after another test |
![]() | | #608 | ![]() |
![]() Join Date: Jul 2008 Location: Ottawa, ON Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,005
| Not Ranked : 0 score How warm was your engine when you did the test and did you crank until the needle stopped?
__________________ 2008 Cosmic Blue Mica Mazdaspeed 3. BNR s3, CoolingMist CMGS Meth, Damond TB Plate, JBR FMIC Undermount w/ TR8, JBR 3" Fullpath, Steedspeed EM, Cobb AP v3, Stratified Tuned, Autotech HPFP Internals, CP-e Catted Downpipe, Port and Polished IM with VTCS & Full EGR Delete, Grimmspeed EBCS, 3 BAR MAP Sensor, Turbosmart Dual-port BPV, Koni Sport Yellows, Eibach Prokits, SPC Camber Arms, Cobb FSB and RSB, AWR Front Endlinks, JBR Trilogy Mounts 70a Duro, KX-F3 Full Chassis Braces, Denso Iridium ITV-22, CP-e Safe Seals, SURE TIG IM and TB, Cobb Shift Weight, TWM SS w/Bushings and Specter Hybrid knob. To be installed: SS Brake Lines. |
![]() | | #609 | ![]() |
| Not Ranked : 0 score Engine was up to Temp, I cranked it until i heard about 4 pumps of air.
__________________ Stay away from RD Motorsportz |
![]() | | #610 | ![]() |
Groans: 793
| Not Ranked : 0 score That's your problem. Crank till gauge doesn't move.
| The Following 3 Users Say Thank You to Tokay444 For This Useful Post: |
![]() | | #611 | ![]() |
| Not Ranked : 0 score Shit just got it all back together Thank you i will update after i test it again.
![]() | | #612 | ![]() |
| Not Ranked : 0 score Okay, after re testing the compression it is higher but there is still a 20psi difference in cylinder1 and the rest of them. Other info a couple posts above. Thanks. #1 192 #2 172 #3 171 #4 171 Thanks for the tip, now what are your thoughts?
__________________ Stay away from RD Motorsportz Last edited by DTKII; 06-03-2013 at 07:24 PM. |
![]() | | #613 | ![]() |
Groans: 255
| Not Ranked : 0 score The prognosis is not good. It is a 10% difference. A little more and I would be getting ready to take some action.
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress Last edited by himurax13; 06-03-2013 at 11:13 PM. |
![]() | | #614 | ![]() |
![]() Join Date: Sep 2011 Location: Jacksonville, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 360
| Not Ranked : 0 score You're technically still in specs. I wouldn't worry too much if the engine is running fine. Sorry if I missed some information somewhere.
__________________ '06 Mazdaspeed 6 | |
![]() | | #615 | ![]() |
| Not Ranked : 0 score The car runs fine other than the smoking, I figured I would run a compression test to make sure the rings were ok. It seems to have good compression just a big variance from 1 and the rest of cylinders. I hope your right bc a turbo is much easier to replace than internals. Thanks
![]() | | #616 | ![]() |
| Not Ranked : 0 score Leak down test should be your next step.
![]() | | #617 | ![]() |
| Resident Baus ![]() Join Date: Mar 2011 Location: Cherry Hill, NJ
Rep Power: 356 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 261
Groans: 34
Groaned at 56 Times in 18 Posts
| Not Ranked : 0 score Well i just did my first compression test. Car is a 2011 genpu with 57,000 miles. Basically fully bolted around 20,000 and BT at ~52,000. Results are as follows. (Passenger Side) Cylinder 1: 174 Cylinder 2: 183 Cylinder 3: 184 Cylinder 4: 184 (Driver Side) I was going to test cylinder one again to confirm the slightly lower reading but after the engine cranked a few times I blew the hose on the tester kit apart. It was a rented autozone kit though so w/e. Do you guys think I have anything to worry about at the moment?
__________________ 2011 Black Mica MS3 FREEKTUNE (On hold 'til EWG) ATP GTX3071R IWG (soon to be EWG) Full Race exhaust manifold CP-e whale peen + 3.25 in. intake COBB EBCS + Downpipe + BPV + AP Stage 2 Corksport CBE + Brake Pads Ultimate FMIC NGK Iridium IX @ .28 DDM HID 6000k Autotech CDFP Internals JBarone EGR delete, TB + IM gaskets, SSP + Shift Anchors, 88D RMM, 70D passenger + tranny mount, RSB, and OCC HTP battery box TSW Nurburgrings 18x8.5 MBR w/ Michelin Pilot Super Sports 235x40x18 +45 Goodridge SS Brake Lines Installation TBD: H&R springs + Koni yellow shocks + struts |
![]() | | #618 | ![]() |
![]() Join Date: Sep 2012 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 644
__________________ SOLD 2008 MS3 17x8 Evo 9's, 235 v12 1995 Miata 1.8L w/ FMII GT2560R @11psi, FM stage 2 clutch/flywheel, FM Frame rail braces, FM high capacity radiator/fans, RB Sway bars, Racing beat exhaust, Fat cat Coilovers, Jongbloed 15x9, Wilwood 4 wheel BBK, Rollbar, Hardtop, TDR Racing seat 2001 Saab 9-3 Viggen 2.3T Stage 3+ bro, SRI, 3" DP, ETS FMIC, 17x8 BBS RK2's, Full chassis bracing / sway bars, Forge BPV, Winter/DD | |
| The Following User Says Thank You to Tyhackman15 For This Useful Post: | duappleganger (06-04-2013) |
![]() | | #619 | ![]() |
Groans: 34
| Not Ranked : 0 score Nonetheless, I am pretty excited that cylinder 3 isn't being a little bitch.
| The Following User Says Thank You to duappleganger For This Useful Post: | atvfreek (06-04-2013) |
![]() | | #620 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,797
| Not Ranked : 0 score Those results look great!
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 |
| The Following 2 Users Say Thank You to atvfreek For This Useful Post: | duappleganger (06-04-2013), himurax13 (06-04-2013) |
![]() | | #621 | ![]() |
![]() Join Date: Mar 2008 Location: W. Suffield, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 674
Groans: 67
| Not Ranked : 0 score did my MS6 and CX7 last night while changing oil in both. My car has 40k and got 190s on all cylinders CX-7 has 70k and got 1:180psi 2:180psi 3:150psi 4:180psi Weird that oil level was perfect in CX-7 but I was down a couple of quarts in mine a week or so ago. I started a job that is a 100mi/day commute so I figured it would be a good time to make sure my car was up to the job. GUess I need to sell the cx7 |
![]() | | #622 | ![]() |
Groans: 255
![]() | | #623 | ![]() |
| Not Ranked : 0 score TL: DR Which relay do I pull to do the compression test? Injector or Fuel Pump?
![]() | | #624 | ![]() |
Groans: 255
| The Following 2 Users Say Thank You to himurax13 For This Useful Post: | atvfreek (06-09-2013), btstarcher (06-09-2013) |
![]() | | #625 | ![]() |
Groans: 793
| Not Ranked : 0 score ^that
![]() | | #626 | ![]() |
| Not Ranked : 0 score As these guys just stated. I just mash my gas pedal to the floor. That shuts the injectors off, as its a factory "clear flood" mode
![]() | | #627 | ![]() |
| Not Ranked : 0 score Sounds good, I jest remember the last time I did a compression test I had pulled a relay of sorts. Isn't this similar to the procedure to pressurize the fuel rail?
![]() | | #628 | ![]() |
Groans: 255
| The Following User Says Thank You to himurax13 For This Useful Post: | theurgy (06-09-2013) |
![]() | | #629 | ![]() |
| Not Ranked : 0 score Well my results should be posted later today.
![]() | | #630 | ![]() |
| Not Ranked : 0 score Results: 1-4 (left to right) 1: 165 2: 170 3: 160 4: 165
| The Following User Says Thank You to theurgy For This Useful Post: | btstarcher (06-09-2013) |
![]() | | #631 | ![]() |
Groans: 67
Engine was warm, but it is clear cyl 3 is fucked. Wet test as in with fuel on? no pulled INJ relay. Or wet as in spray oil in and see if numbers go up to determine if rings bad? I guess I can do that. I just cleaned intake valves at 60k so I doubt there is a problem with them sealing but who know. Could do a leakdown test but not sure what this will tell me also. Car gets 14mpgs so have been wanting to get something new but owe 11k so its not like I could sell it and buy a new car with the profits. Wife wants a minivan but they dont get great mileage either. But either way I think we should get rid of the CX7 soon... | |
![]() | | #632 | ![]() |
Groans: 255
![]() | | #633 | ![]() |
Groans: 793
__________________ ![]() ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals | |
![]() | | #634 | ![]() |
Groans: 67
| Not Ranked : 0 score So your saying there could just be a piece of gunk on the seat causing it not to seal? I guess adding oil and retesting compression and doing a leakdown will tell me what it is better? When I cleaned my intake valves on another engine I could not get one of the valves to seal as the B12 would always drain out overnight. However it obviously did get clean after I ran it as it now has 180psi... so it is def possible that its just gunk. |
| The Following User Says Thank You to aviator79 For This Useful Post: | btstarcher (06-11-2013) |
![]() | | #635 | ![]() |
![]() Join Date: Jun 2012 Location: San Jose, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,963
Groans: 47
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() | |
![]() | | #636 | ![]() |
| Not Ranked : 0 score Alright I did a leak down test and pushed oil out of the dipstick while testing cylinder 2 so it looks like I'm gonna have to build the motor?
__________________ Stay away from RD Motorsportz Last edited by DTKII; 06-12-2013 at 09:29 AM. |
![]() | | #637 | ![]() |
Groans: 255
| The Following User Says Thank You to himurax13 For This Useful Post: | btstarcher (06-12-2013) |
![]() | | #638 | ![]() |
| Not Ranked : 0 score While performing a leak down test on cylinder 2 oil started coming out of the dip stick tube. I'm pretty sure it did that bc I put my finger over the valve cover vent so the air had no where else to go so it pushed oil out. Here is my post from a couple of days ago..... Okay, after re testing the compression it is higher but there is still a 20psi difference in cylinder1 and the rest of them. Other info a couple posts above. Thanks. #1 192 #2 172 #3 171 #4 171 Thanks for the tip, now what are your thoughts?
![]() | | #639 | ![]() |
![]() Join Date: May 2009 Location: Russellville, AR
Rep Power: 1975 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,199
Groans: 112
| Not Ranked : 0 score Soooooooo dipstick was removed from tube?
__________________ JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, Forge V2 BPV, JBR TIG's, Kozmic EGR delete, Cobb AP, PTP HPFP internals, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Swift springs, Tri Point Engineering RSB, Whiteline Anti Lift Kit, PTP Injector Seals, GenPu transmission, Fidanza flywheel, 3 BAR MAP sensor, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, sleeved block, PTP BSD SnailTune in progress |
![]() | | #640 | ![]() |
| Not Ranked : 0 score Yes to see if I could hear air coming out of it while doing a leak down test.
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/disi-compression-results-43395/ | ||||
| Random MS3 Chat Thread - Page 171 | This thread | Refback | 04-20-2013 05:45 PM | |
| Anyone measure compression on stock motor? - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum | Post #12 | Pingback | 03-12-2010 09:06 AM | |
| Compression test on built motor | SharkDiver | MazdaSpeed 3 - Engine, Transmission & Driveline | 5 | 10-22-2009 03:48 PM |
| Compression check on Laloosh's motor | gsrtype1 | MazdaSpeed 3 - Engine, Transmission & Driveline | 27 | 09-06-2009 07:25 PM |
| engine build with stock compression | Jessed87 | MazdaSpeed 3 - Engine, Transmission & Driveline | 8 | 06-12-2009 11:55 PM |
| Compression test done.. | SharkDiver | MazdaSpeed 3 - Engine, Transmission & Driveline | 3 | 03-25-2009 04:28 PM |
| engine compression? | bombdotcom | Mazdaspeed3/6 General Discussion | 12 | 09-23-2008 04:06 AM |
