Like Tree41Likes
 Old 06-12-2013, 09:40 AM   #641
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
What percentage leak did you measure?
"Exclusivity" - CP-enis
Demodded.
The Seals
DTKII (06-12-2013)
 Old 06-12-2013, 09:50 AM   #642
DTKII's Avatar
Posts: 247   (View Stats)
DTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the world
About 30% 75psi down to 55psi. I'm getting ready to email SPEEDPERF6RMANC3 for a quote on a short block.
Stay away from RD Motorsportz
DTKII is offline   Reply With Quote
 Old 06-12-2013, 09:58 AM   #643
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Groans: 67
I checked my compression tonight. '08 MS3 with ~49K miles.
From left to right, it was:
128
126
127
129
I need to check it again with a different gauge/tester, as I'm not too confident in the accuracy of the one I used.
Related thread here:
Oil Volume issues...
Finally got around to doing this again with my shiny new compression tester and here are the results (car now has 61,819 miles):
Again, from left to right (with the engine warm):
186
182
189
186
I feel a bit better about those numbers.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
The Following 6 Users Say Thank You to Nliiitend1 For This Useful Post:
Dano (06-12-2013), Downmented (07-24-2013), Micha (08-06-2013), ms3blackmica (06-13-2013), SLOWHATCH (07-23-2013), Tokay444 (06-12-2013)
 Old 06-12-2013, 10:16 AM   #644
Posts: 9,484   (View Stats)
shitty tester was shitty
What you can take away from any test is consistency. even low numbers, if they are all in the same ballpark is a good indication the motor is healthy and the gauge is the problem.
Nliiitend1 likes this.
himurax13 (06-13-2013), Micha (08-06-2013), Nliiitend1 (06-12-2013), Realgib3 (06-12-2013)
 Old 07-22-2013, 10:27 PM   #645
fivefingerdeathpunch's Avatar
Posts: 437   (View Stats)
fivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the world
bumpity bump
did a compression test today. did it how a friend said to do it. dont think the engine was warm by the time i did the test
anyway got from left to right.. 170, 157, 170, 157
one person said thats fine... do you guys agree? i liked the consistency but obviously two are lower than the other two. should i redo with the proper method from the first page?
2006 White Water Pearl Mazdaspeed6 Grand Touring #5430
HTA3076 Tial .82 Turbine Housing, CPE tial Mani, Tial MVR 44mm 20psi spring VTA
DO Stage 2 Meth w/ D07 & 100% - NJSPEED3 PnPed IM - HTP 3" TIP - SSP BigMAF SRI w/ AEM Dryflow and filter wrap - GS EBCS - Fabbed M2 Catless DP - Autotech HPFP Internals - Cobb AP - Custom 2.5" w/ TR8 FMIC - GHL Resonated Dual Catback Exhaust - TS/SU DP BOV - SP63 Aux Fan
Old: BNR S3 370/380 VD 91 + Meth
BNR S3 400/410 VD E21 + Meth - Dyno confirmed: http://www.mazdaspeedforums.org/forum/f338/mazdaspeed6-bnr-s3-dyno-400-410-a-180820/
fivefingerdeathpunch is offline   Reply With Quote
 Old 07-22-2013, 11:05 PM   #646
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Originally Posted by fivefingerdeathpunch View Post
bumpity bump
It isn't terrible but you should have done a wet test.
Sent via blown passenger side speakers.
Pickles Tune in progress
 Old 07-22-2013, 11:15 PM   #647
yeah i shouldve done it exactly as mentioned on the first page but my friend said he knew how to do it so i did what he said haha. i may redo it and do a wet test too if its the same results
 Old 07-23-2013, 06:01 AM   #648
Tokay444's Avatar
Groans: 793
A compression test doesn't really paint a full picture.
For example, my compression has always been in spec (when I do it by the MSF disi standard testing procedure), but my leakdown shows 31% leak in cyl 3.
If you go to the trouble to do a comp test, do a proper leak test at the same time.
Demodded.
The Seals
Easter Bunny (07-24-2013), Micha (08-06-2013), Realgib3 (07-23-2013)
 Old 07-23-2013, 01:16 PM   #649
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
What is your compression number on that cylinder? It must be lower. That's a ton of leakage. How high does the gauge read on the first compression stroke when testing that cylinder? A low reading on the first stroke can also indicate issues, even if overall compression numbers are in spec.
2006 Mazdaspeed6
 Old 07-23-2013, 01:26 PM   #650
scubasteve711's Avatar
Posts: 1,238   (View Stats)
scubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the world
Agreed that a comp. test doesn't tell the whole story, but a cylinder that leaks down at 31% is going to have a variance in the comp test....
07' Speed6 Velocity Red Mica
Go Faster: CorkSport SRI/TIP, SU Test Pipe, SU TMIC, Autotech Internals, ITV22's, Cobb AP
Anti break stuff: Upper Rear Diff Brace, RMM
Appearence: STRI DSD Boost Guage/Blockhead 60mm Guage Pod
scubasteve711 is offline   Reply With Quote
The Following 2 Users Say Thank You to scubasteve711 For This Useful Post:
sidekick (07-23-2013), SLOWHATCH (07-23-2013)
 Old 07-23-2013, 01:53 PM   #651
Tokay444's Avatar
Groans: 793
Compression at time of leak down was 182-176-178-180.
First pump is 90. Same as the rest.
Demodded.
The Seals
Last edited by Tokay444; 07-23-2013 at 01:53 PM. Reason: MSF Database - Automerged Doublepost
 Old 07-23-2013, 02:04 PM   #652
sidekick's Avatar
Groans: 47
Something isn't adding up. 30% leakage is significant. Did you find the source of the leakage? Rings, valves?
EDIT: Don't you have an issue with oil in your intact tract? Those compression numbers could be similar to "wet test" numbers if a significant amount of oil is entering your combustion chamber.
2006 Mazdaspeed6
 Old 07-23-2013, 02:34 PM   #653
Tokay444's Avatar
Groans: 793
It's rings. Most likely a broken land. I burn a litre of oil/1000kms.
Demodded.
The Seals
 Old 07-23-2013, 02:36 PM   #654
sidekick's Avatar
Groans: 47
Very interesting findings. Maybe your rings still seal well, but the cracked ringland is the source of the leakage? Any plans for a teardown?
2006 Mazdaspeed6
 Old 07-23-2013, 02:42 PM   #655
Tokay444's Avatar
Groans: 793
Not until after my wedding.
Demodded.
The Seals
Micha (07-23-2013), sidekick (07-23-2013)
 Old 07-23-2013, 03:22 PM   #656
btstarcher's Avatar
Posts: 4,852   (View Stats)
Groans: 112
Fucking liters....WTF Canada.
SnailTune in progress
 Old 07-23-2013, 05:29 PM   #657
Tokay444's Avatar
Groans: 793
Litres*
Demodded.
The Seals
Micha (07-23-2013), Nliiitend1 (07-23-2013)
 Old 07-23-2013, 07:31 PM   #658
Litres*
Quarts*
Sent from my iPhone using Tapatalk 2
The Following 6 Users Say Thank You to silvapain For This Useful Post:
atvfreek (07-23-2013), btstarcher (07-24-2013), Dano (07-23-2013), Easter Bunny (07-24-2013), Micha (07-23-2013), nojjy (07-23-2013)
 Old 07-23-2013, 07:43 PM   #659
BigRedSpecial's Avatar
Posts: 1,436   (View Stats)
BigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the world
Groans: 56
Groaned at 6 Times in 6 Posts
*Furlongs
2008.5 CWP: GTX 3071//Rapebuilt EM//Relentless pnp IM//JBR 3.5" WP//TurboXS DP/RP//TR8C/Cobb FMIC//GFS bpv//JBR 88/70/70a//Eibach Pro Kit//Koni Yellows//JBR RSB//RX8's
Awaiting Install: DO Stage 2//3 Bar MAP//CPe Safeseals
Winter Beater: 96 GMC K1500 5 speed 4x4
Needed: Driver mod
BigRedSpecial is offline   Reply With Quote
The Following 2 Users Say Thank You to BigRedSpecial For This Useful Post:
Easter Bunny (07-24-2013), silvapain (07-24-2013)
 Old 07-23-2013, 07:47 PM   #660
Micha's Avatar
Posts: 3,436   (View Stats)
Micha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the world
Groans: 261
Groaned at 73 Times in 60 Posts
Fathoms*
Micha is offline   Reply With Quote
The Following 2 Users Say Thank You to Micha For This Useful Post:
 Old 07-23-2013, 07:51 PM   #661
Groans: 56
My car gets 16 rods to the hogs head, and that's the way I likes it
Needed: Driver mod
The Following 4 Users Say Thank You to BigRedSpecial For This Useful Post:
Easter Bunny (07-24-2013), Micha (08-06-2013), silvapain (07-24-2013), Tokay444 (07-23-2013)
 Old 07-23-2013, 11:14 PM   #662
^^^^ fagots*
The Following 5 Users Say Thank You to Dano For This Useful Post:
BigRedSpecial (07-24-2013), Easter Bunny (07-24-2013), Micha (07-23-2013), Nliiitend1 (07-24-2013), silvapain (07-24-2013)
 Old 07-23-2013, 11:23 PM   #663
theurgy's Avatar
Posts: 2,580   (View Stats)
You realize the rest of the world uses the metric system now right?
BNR s3, CoolingMist CMGS Meth, Damond TB Plate, JBR FMIC Undermount w/ TR8, JBR 3" Fullpath, Steedspeed EM, Cobb AP v3, Stratified Tuned, Autotech HPFP Internals, CP-e Catted Downpipe, Port and Polished IM with VTCS & Full EGR Delete, Grimmspeed EBCS, 3 BAR MAP Sensor, Turbosmart Dual-port BPV, Koni Sport Yellows, Eibach Prokits, SPC Camber Arms, Cobb FSB and RSB, AWR Front Endlinks, JBR Trilogy Mounts 70a Duro, KX-F3 Full Chassis Braces, Denso Iridium ITV-22, CP-e Safe Seals, SURE TIG IM and TB, Cobb Shift Weight, TWM SS w/Bushings and Specter Hybrid knob.
To be installed: SS Brake Lines.
theurgy is offline   Reply With Quote
The Following User Says Thank You to theurgy For This Useful Post:
Tokay444 (07-24-2013)
 Old 07-24-2013, 12:28 AM   #664
btstarcher's Avatar
Groans: 112
'Merica. Fuck you.
The Following 3 Users Say Thank You to btstarcher For This Useful Post:
Easter Bunny (07-24-2013), Micha (08-06-2013), Tokay444 (07-24-2013)
 Old 07-24-2013, 03:52 AM   #665
Tokay444's Avatar
Groans: 793
^^^^ fagots*
faggots*
Quarts*
almost.
Demodded.
The Seals
Last edited by Tokay444; 07-24-2013 at 03:52 AM. Reason: MSF Database - Automerged Doublepost
The Following 4 Users Say Thank You to Tokay444 For This Useful Post:
Dano (07-24-2013), Micha (08-06-2013), Nliiitend1 (07-24-2013), silvapain (07-24-2013)
 Old 07-24-2013, 09:54 AM   #666
faggots*
Thanks for the spelling correction...I knew a faggot would know how to spell it...you fell right into the trap
now rebuild your POS motor already.
 Old 07-24-2013, 10:02 AM   #667
Tokay444's Avatar
Groans: 793
tarp*
Demodded.
The Seals
Micha (08-06-2013)
 Old 07-24-2013, 10:04 AM   #668
negative...you did in deed fall into my T R A P !
Micha (08-06-2013)
 Old 07-24-2013, 10:21 AM   #669
Tokay444's Avatar
Groans: 793
i really just want you to wrap me up in your tarp.
baby oil?
Demodded.
The Seals
Micha (08-06-2013)
 Old 07-24-2013, 10:27 AM   #670
hahaha
not right now...maybe later?
Micha (08-06-2013)
 Old 07-28-2013, 02:33 PM   #671
azazelthegreat's Avatar
Posts: 596   (View Stats)
azazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the world
Cylinders 1 3 and 4 were around 180
Cylinder 2 was at 60
Looked for leaks
Hooked my compressor to c2
No air from anywhere
azazelthegreat is offline   Reply With Quote
 Old 07-28-2013, 02:37 PM   #672
himurax13's Avatar
Groans: 255
Looked for leaks
How did you look for leaks?
 Old 07-28-2013, 02:48 PM   #673
w
Air compressor hose where the cylinder 2 plug goes
Listened for air from intake oil cap area abx exaust
Came from intake at first but my friend told me to crank the motor once and it went away.
Going to his house in a few days to redo it just in case
 Old 07-28-2013, 03:06 PM   #674
btstarcher's Avatar
Groans: 112
I thought that leakdown test required you to be at TDC? Anyway also check around injector seals and dipstick. If it's coming from intake, is that intake valves?
 Old 07-28-2013, 03:51 PM   #675
Yes TDC compression stoke otherwise air just goes out the valves.
Tappin
btstarcher (07-29-2013), Micha (08-06-2013), Realgib3 (07-28-2013), Tokay444 (07-28-2013)
 Old 08-05-2013, 09:43 AM   #676
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
Checked Compression again @ 73,000 miles yesterday. Motor was warm but not hot.
Still looking good.
203 202 202 205
https://www.youtube.com/watch?featur...&v=h_c66_ZHe4E
www.tunedbynishan.com
The Following 4 Users Say Thank You to ms3blackmica For This Useful Post:
btstarcher (08-05-2013), h0ckeyman (08-06-2013), Micha (08-05-2013), Roddiy (08-05-2013)
 Old 08-05-2013, 09:50 AM   #677
btstarcher's Avatar
Groans: 112
Still looking good.
203 202 202 205
I want to borrow your tester.
 Old 08-05-2013, 09:51 AM   #678
Nishan
I would gladly send it over to you Ben but it isn't mine!
The Following 2 Users Say Thank You to ms3blackmica For This Useful Post:
btstarcher (08-05-2013), Micha (08-06-2013)
 Old 08-05-2013, 10:16 AM   #679
ArmanRus's Avatar
Posts: 1,566   (View Stats)
ArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the world
Groans: 42
I need to do this. I'm at 102k miles and although she's pulling strong and not burning any oil, I want to for the peace of mind.
ArmanRus is offline   Reply With Quote
 Old 08-05-2013, 09:48 PM   #680
LatinKraze's Avatar
Posts: 804   (View Stats)
LatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the world
2007 106,000 miles
Fully Bolted +BNRs3
119-121-120-121
On two different gauges (HF and O'Rileys). Wet test gave me an extra 2-3 psi. My buddy is letting me borrow a tester where he hits 180 psi. We'll see what his gauge yields and we'll also be doing a leak down
2007 MS3: BNRs3 PPT Tuned 350hp/360tq Stocked out and SOLD
2016 CX-5 GT AWD
LatinKraze is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/disi-compression-results-43395/
Random MS3 Chat Thread - Page 171 This thread Refback 04-20-2013 05:45 PM
Anyone measure compression on stock motor? - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum Post #12 Pingback 03-12-2010 09:06 AM
Compression test on built motor SharkDiver MazdaSpeed 3 - Engine, Transmission & Driveline 5 10-22-2009 03:48 PM
Compression check on Laloosh's motor gsrtype1 MazdaSpeed 3 - Engine, Transmission & Driveline 27 09-06-2009 07:25 PM
engine build with stock compression Jessed87 MazdaSpeed 3 - Engine, Transmission & Driveline 8 06-12-2009 11:55 PM
Compression test done.. SharkDiver MazdaSpeed 3 - Engine, Transmission & Driveline 3 03-25-2009 04:28 PM
engine compression? bombdotcom Mazdaspeed3/6 General Discussion 12 09-23-2008 04:06 AM
Page generated in 0.59940 seconds with 37 queries
