Like Tree41Likes
 Old 08-06-2013, 06:59 AM   #681
btstarcher's Avatar
Posts: 4,852   (View Stats)
Groans: 112
Was the engine at operating temperature? Those numbers look fine; only 2psi difference.
SnailTune in progress
The Following 3 Users Say Thank You to btstarcher For This Useful Post:
atvfreek (08-06-2013), LatinKraze (08-06-2013), Tokay444 (08-06-2013)
 Old 08-06-2013, 11:31 AM   #682
theurgy's Avatar
Posts: 2,580   (View Stats)
Yeah I'm thinking your engine wasn't warm enough.
BNR s3, CoolingMist CMGS Meth, Damond TB Plate, JBR FMIC Undermount w/ TR8, JBR 3" Fullpath, Steedspeed EM, Cobb AP v3, Stratified Tuned, Autotech HPFP Internals, CP-e Catted Downpipe, Port and Polished IM with VTCS & Full EGR Delete, Grimmspeed EBCS, 3 BAR MAP Sensor, Turbosmart Dual-port BPV, Koni Sport Yellows, Eibach Prokits, SPC Camber Arms, Cobb FSB and RSB, AWR Front Endlinks, JBR Trilogy Mounts 70a Duro, KX-F3 Full Chassis Braces, Denso Iridium ITV-22, CP-e Safe Seals, SURE TIG IM and TB, Cobb Shift Weight, TWM SS w/Bushings and Specter Hybrid knob.
To be installed: SS Brake Lines.
theurgy is offline   Reply With Quote
 Old 08-06-2013, 11:50 AM   #683
speed23's Avatar
Posts: 1,480   (View Stats)
140000km. car felt slow so i tested it 160,170,160,170. i dont think i let it turn ove r enough on the 160 cylinders. Guess car is just slow...but at least no issues.
 Old 08-06-2013, 12:02 PM   #684
Little John's Avatar
Posts: 494   (View Stats)
Little John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the world
Groans: 55
150 across the board! Car was tested cold and warm, and tested on another car which tested 180 in all four!
Little John is offline   Reply With Quote
The Following User Says Thank You to Little John For This Useful Post:
Micha (08-06-2013)
 Old 08-06-2013, 12:26 PM   #685
theurgy's Avatar
Intake Valve Cleaning?
Got any datalogs?
The Following User Says Thank You to theurgy For This Useful Post:
speed23 (08-06-2013)
 Old 08-06-2013, 03:49 PM   #686
speed23's Avatar
I run meth but probably need a valve cleaning (although before and after dynos dont really show that much of an improvement...). I ve got lots of logs and all is well in those. I went from a speed3 to a speed6 and the 6 is just heaver wwith more drivetrain loss so is slower than iam used to.
 Old 08-06-2013, 04:44 PM   #687
CosmicArkie's Avatar
Posts: 1,332   (View Stats)
CosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the world
Originally Posted by btstarcher View Post
I want to borrow your tester.
Oh, ye of little faith. Don't believe my two (2) testers within 5lbs of each other, hummmmm?
"I only do what the voices in my wife’s head tell her to tell me to do"
CosmicArkie is offline   Reply With Quote
The Following 2 Users Say Thank You to CosmicArkie For This Useful Post:
btstarcher (08-06-2013), SLOWHATCH (08-19-2013)
 Old 08-06-2013, 04:45 PM   #688
btstarcher's Avatar
Groans: 112
Oh I do. But this guy has crazy high numbers, so I wanted to be blessed by his tester.
 Old 08-06-2013, 04:54 PM   #689
fivefingerdeathpunch's Avatar
Posts: 437   (View Stats)
fivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the world
this guy also has crazy flow/power on his k04. borrow his car not the tester
2006 White Water Pearl Mazdaspeed6 Grand Touring #5430
HTA3076 Tial .82 Turbine Housing, CPE tial Mani, Tial MVR 44mm 20psi spring VTA
DO Stage 2 Meth w/ D07 & 100% - NJSPEED3 PnPed IM - HTP 3" TIP - SSP BigMAF SRI w/ AEM Dryflow and filter wrap - GS EBCS - Fabbed M2 Catless DP - Autotech HPFP Internals - Cobb AP - Custom 2.5" w/ TR8 FMIC - GHL Resonated Dual Catback Exhaust - TS/SU DP BOV - SP63 Aux Fan
Old: BNR S3 370/380 VD 91 + Meth
BNR S3 400/410 VD E21 + Meth - Dyno confirmed: http://www.mazdaspeedforums.org/forum/f338/mazdaspeed6-bnr-s3-dyno-400-410-a-180820/
fivefingerdeathpunch is offline   Reply With Quote
 Old 08-06-2013, 05:17 PM   #690
Micha's Avatar
Posts: 3,436   (View Stats)
Micha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the world
Groans: 261
Groaned at 73 Times in 60 Posts
I make 230 PSi on 3 out of 4 cylinders. Am I cool?
Micha is offline   Reply With Quote
The Following 2 Users Say Thank You to Micha For This Useful Post:
btstarcher (08-06-2013), Little John (08-06-2013)
 Old 08-06-2013, 06:06 PM   #691
btstarcher's Avatar
Groans: 112
You're very cool @Micha;! Any ideas what happened with the other one?
Micha (08-06-2013)
 Old 08-06-2013, 06:35 PM   #692
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Well 75% is a passing grade in college.
Sent via blown passenger side speakers.
Pickles Tune in progress
Micha (08-06-2013)
 Old 08-06-2013, 06:39 PM   #693
LatinKraze's Avatar
Posts: 804   (View Stats)
LatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the world
Had 15-20 minutes on the highway right before the test. ECT was normal
2007 MS3: BNRs3 PPT Tuned 350hp/360tq Stocked out and SOLD
2016 CX-5 GT AWD
LatinKraze is offline   Reply With Quote
 Old 08-13-2013, 09:30 PM   #694
Snyeed's Avatar
Posts: 743   (View Stats)
Snyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the world
Groaned at 8 Times in 4 Posts
First compression check ever, 83.xxx miles BT 3071, 415whp 12.0 quarter mile.
165 167 165 167
The car has been running flawless until the last week when there is oil coming out of the valve cover breather. I have a little filter on it that came with my cp-e kit.
Saikou catch can hooked up the old school way with two check valves. I know a leak down test is the next step but in the mean time I am going to go over the catch can and pcv system.
417whp 428tq 12.037@117.2mph
Snyeed is offline   Reply With Quote
 Old 08-13-2013, 11:40 PM   #695
himurax13's Avatar
Groans: 255
165 167 165 167
Might as well start saving for a rebuild ...
Snyeed (08-16-2013)
 Old 08-13-2013, 11:47 PM   #696
MPS_Fan's Avatar
Posts: 436   (View Stats)
MPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the world
165 167 165 167
How many miles on BT and how much boost?
MPS_Fan is offline   Reply With Quote
The Following User Says Thank You to MPS_Fan For This Useful Post:
Snyeed (08-16-2013)
 Old 08-13-2013, 11:54 PM   #697
snailD's Avatar
Posts: 3,039   (View Stats)
@Snyeed; was telling me altitude will mess with compression numbers. I looked it up briefly and people seemed to concur. If usual is 180, and we are at 4500ft would that be accurate for a healthy motor?
He runs 25ish, but is on 18psi for the winter months. bt has been in for 2 years?
The Following User Says Thank You to snailD For This Useful Post:
Snyeed (08-16-2013)
 Old 08-15-2013, 05:50 PM   #698
Mandinca's Avatar
Posts: 1,700   (View Stats)
Mandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the world
Groaned at 7 Times in 5 Posts
Originally Posted by cpolly69 View Post
aaron - i kinda called this a while back if you remember when i sold you that used k04
btw guys something to keep in mind - if you are leaking compression out of your piston rings or out your valve guide seals - 2 things will be happening
1. your pcv will be even more messed up then normal - compression gases and pressures in places where they shouldn't be screws up the flow of lots of stuff -
a good indication of this (at least with the stock pcv setup) is seeing crud coming back out of the port on the valve cover that leads to your turbo intake -
when my motor was on it's way to death i had lots of crud in this area - at points so bad it was getting on my maf
2. you will be burning oil - i was up to about a quart every 200 miles when i started the battle for a new motor with my dealer - the amount that gets squeezed out via pcv imbalance should be minimal - if you notice more, you've got an issue
the day i actually took my car in i was bellowing smoke
if you have the other leak of compression (head gasket) you will most likely see increased ect - well above 220 - but hell the other things i'm saying here will cause that too
CPolly, had to bump this since I am getting through a qt every 200 miles as well. Are you suggesting that my rings are fucked and the blowby is forcing oil through the pcv into the IM ? Did a compression test and one cylinder was 30psi below the rest. Also, all four plugs were fouled like I've never seen and they were only 30K miles old. Covered in encrusted white deposits. Doing a leakdown test this weekend.
165 167 165 167
Wouldn't that suggest a blocked PCV system forcing the pressure out through the valve cover ?
The compressions look reasonable....and more importantly, even.
Last edited by Mandinca; 08-15-2013 at 05:50 PM. Reason: MSF Database - Automerged Doublepost
Mandinca is offline   Reply With Quote
The Following User Says Thank You to Mandinca For This Useful Post:
Snyeed (08-16-2013)
 Old 08-15-2013, 05:57 PM   #699
Mandinca's Avatar
Originally Posted by WaterlooDrew View Post
Thanks man, I didn't think it was that bad. The oil consumption did slow down dramatically after a little more driving with the new PCV....mechanic did say it could take time for the flush chemicals to do their job.
It starts, drives, sounds fine and has good power.
What did you mean by flush chemicals ?
 Old 08-15-2013, 06:01 PM   #700
himurax13's Avatar
Groans: 255
I had 160 PSI accross the board and I was filling my SSP Vented Catch can with 3 WOT Pulls. I had the TIP and the Mani blocked off. Your rings could be fucked or you could have multiple cracked ringlands even though you have good compression. You might as well save for a rebuild because once you have retarded amounts of blowby occurring, that is the only real fix for it.
Snyeed (08-16-2013)
 Old 08-15-2013, 06:08 PM   #701
Mandinca's Avatar
Yeah, that's kinda where I'm headed. I'm completely stock and always used whatever oil the dealer put in it as they did all changes up to 100K. OCI's were not always good so I think I may be paying the price for it now. There's an outfit on ebay that sells refurbished motors (all kinds) for $3K plus a core deposit. I don't have time to rebuild my motor since it's my DD.
I changed the pcv and the turbo and still get through the same amount of oil so it must be rings, ringlands or valves. Low compression in cylinder 4 will be checked with leak down this weekend.
 Old 08-15-2013, 07:40 PM   #702
BigRedSpecial's Avatar
Posts: 1,436   (View Stats)
BigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the world
Groans: 56
Groaned at 6 Times in 6 Posts
Barely over that will get you a built shortblock from @SPEEDPERF6RMANC3; just sayin'
2008.5 CWP: GTX 3071//Rapebuilt EM//Relentless pnp IM//JBR 3.5" WP//TurboXS DP/RP//TR8C/Cobb FMIC//GFS bpv//JBR 88/70/70a//Eibach Pro Kit//Koni Yellows//JBR RSB//RX8's
Awaiting Install: DO Stage 2//3 Bar MAP//CPe Safeseals
Winter Beater: 96 GMC K1500 5 speed 4x4
Needed: Driver mod
BigRedSpecial is offline   Reply With Quote
The Following 2 Users Say Thank You to BigRedSpecial For This Useful Post:
SLOWHATCH (08-16-2013), Tokay444 (08-16-2013)
 Old 08-15-2013, 07:48 PM   #703
Mandinca's Avatar
Thanks but I'm looking to keep it stock. My DD with a 70 mile daily commute so I need it to be very reliable......not that I am saying his built blocks are no good.....just figure that staying stock is the most reliable. Besides that, I can't afford to rebuild my head etc.
 Old 08-16-2013, 08:45 AM   #704
Groans: 56
Gotcha... Just putting it out there. IF your head were good you could get a block built with upgraded rods and OEM pistons; should be completely reliable and have good power potential for the future.
Of course if your head isn't good that doesn't matter.
Needed: Driver mod
 Old 08-16-2013, 08:48 AM   #705
Mandinca's Avatar
Thanks. I'll keep it in mind. Hopefully the leak down will reveal all this weekend. A qt of oil every 200 miles is getting to be a bit much, plus I have CEL P0401 now which will fail CT emissions when the time comes. Anyway, if I have a cracked piston, ringland etc I imagine it's only a matter of time before Zoom Zoom Boom. I've already done about 20,000 miles or more with it burning oil like this, I magine the cats are toast by now.
atvfreek (08-16-2013)
 Old 08-16-2013, 09:01 AM   #706
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
HawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the world
@maisonvi;
Silver 2007 Speed3 GT
Xona Rotor 6156, Port Injection w/ E85...Bunch of other stuff. I make some power.
Titanium Grey Mazdaspeed6 GTX3071, DD
HawkeyeGeoff is offline   Reply With Quote
 Old 08-16-2013, 04:08 PM   #707
himurax13's Avatar
Groans: 255
Are you staying out of boost? I noticed that blowby is reduced if you don't punch it all of the time. Do you still have both cats installed? My motor went like that for 7,000 miles and I was still able to save my cats.
 Old 08-19-2013, 07:39 AM   #708
Mandinca's Avatar
Yeah, I’m completely stock.
I boost here and there and usually when I do I get a cloud of black smoke and misfires.
I attended an install meet with the CT Nator guys a few weeks ago and we pulled the plugs, they were caked with white deposits. So, we put new plugs in and this weekend I pulled them to do compression tests and they were almost as bad again – maybe 4 thousand miles on them.
So, I’m totally stock, have a rebuilt KO4 in it as well as a new PCV valve. I burn a quart of oil every 200 miles. I did compression tests yesterday at a Nator BBQ and got the following results…..cylinder, dry test, wet test.
1 / 180 / 200
2 / 180 / 210
3 / 185 / 200
4 / 200 / 205
We tried to do leakdown tests but for some reason the tester wouldn’t work properly…..either that or it was operator fail ;-)
One thing we did notice was that the plug in cylinder 4 came out very easily…it was loose. Also, the end of the plug socket had about a 1/8” wide ring of oil on it. One of the guys also said he saw a lot of junk on top of the piston.
My guess looking at the numbers is that 4 is already seeing a lot of oil so the wet test made no difference.
One of the guys from the NY Nator who was at the BBQ suggested a catch can to see how quickly it filled up. I had another thought on this and wanted your opinion.
Rather than buying a catch can could I just disconnect the hose that connects the PCV to the IM, block the IM hole and see what pukes out of the PCV ?
With the oil consumption I’m seeing I doubt it would be long before it was obvious that I was pushing oil through the PCV (if that’s what my issue is).
If I didn’t see evidence of that then I could switch my attention to the valves.
Thoughts ?
 Old 08-19-2013, 10:37 AM   #709
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
I assume your valve cover gasket is ok.....I havent taken the valve cover off in a while but i think you have a gasket that goes around the spark plug holes in the valve cover.
track weight 3220
street weight 3370
 Old 08-19-2013, 10:56 AM   #710
MSMS3's Avatar
Posts: 2,834   (View Stats)
Groans: 157
New dry test yesterday on warmed up engine when replacing spark plugs.
#1 - 193
#2 - 192
#3 - 180
#4 - 195
If you look at my older post in this thread, these numbers are about 10 psi HIGHER than my last test.
In August of last year the numbers were:
#1 - 180
#2 - 180
#3 - 172
#4 - 180
No change in engine mods. Same compression gauge used. Same testing technique of testing with all four plugs removed and cranking engine until needle stopped rising, same differential on #3 cylinder.
The only explanations I can offer is that I am now running Rotella T6 5w-40 oil instead of Mobil 1 5w-30 and perhaps I had the engine warmer this time. Maybe someone else has an opinion. I know the car did not magically get better compression, ha ha.
 Old 08-19-2013, 11:16 AM   #711
Mandinca's Avatar
Valve cover gasket is ok, no leaks anywhere. I drop absolutely no oil on my garage floor.
#1 - 193
#2 - 192
#3 - 180
#4 - 195
#1 - 180
#2 - 180
#3 - 172
#4 - 180
Just a guess here but maybe the T6 makes the rings seal better.
Last edited by Mandinca; 08-19-2013 at 11:31 AM. Reason: MSF Database - Automerged Doublepost
 Old 08-19-2013, 12:09 PM   #712
btstarcher's Avatar
Groans: 112
How many of you guys actually pull the fuel pump relay and wait for the car to die before checking compression?
 Old 08-19-2013, 12:14 PM   #713
himurax13's Avatar
Groans: 255
Never did that once.
atvfreek (08-19-2013)
 Old 08-19-2013, 12:33 PM   #714
Mandinca's Avatar
Me neither. Just push and hold the gas pedal to the floor - that disables the injectors. Apparently it's a built in system to clear flooded engines but it works for compression tests as well.
The Following 2 Users Say Thank You to Mandinca For This Useful Post:
atvfreek (08-19-2013), theurgy (08-19-2013)
 Old 08-19-2013, 12:57 PM   #715
theurgy's Avatar
^^ Exactly.. I once did it by pulling the fuel pump relay, now I just slam the gas pedal.
 Old 08-19-2013, 01:07 PM   #716
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
#1 - 193
#2 - 192
#3 - 180
#4 - 195
#1 - 180
#2 - 180
#3 - 172
#4 - 180
ring gaps just lined up for the previous test, or were closer.
"Exclusivity" - CP-enis
Demodded.
The Seals
atvfreek (08-19-2013), MSMS3 (08-19-2013)
 Old 08-19-2013, 01:14 PM   #717
#1 - 193
#2 - 192
#3 - 180
#4 - 195
#1 - 180
#2 - 180
#3 - 172
#4 - 180
Carbon buildup = smaller combustion chamber = higher compression?
btstarcher (08-19-2013), MSMS3 (08-19-2013)
 Old 08-19-2013, 02:06 PM   #718
MSMS3's Avatar
Groans: 157
Maybe. Did not think of that and would have thought that any changes in carbon deposits in the combustion chamber or on top of the pistons would not be enough to account for that. Dunno.
I just think it may be the built in margin of error in the cheap Actron compression gauge I have. If I checked it again tomorrow, it might be somewhere between the two readings above. I guess the important thing is to compare cylinder-to-cylinder on the same day. Both sets of numbers are pretty good. I need to continue to watch cylinder #3 , which is a bit lower than the others, as so many other people are experiencing. Down maybe what 6-8% compared to the average of the others?
 Old 08-19-2013, 03:57 PM   #719
btstarcher's Avatar
Groans: 112
When Omar checked my compression right after it was built, he got around 180-190 across the board; when he referred to the manual it directed him to pull the relay, etc. When he did that he got 210 on all four.
 Old 08-19-2013, 04:54 PM   #720
I'd be interested in an explanation for that....
Unless ya'll cranked it longer/harder.
The Following User Says Thank You to CosmicArkie For This Useful Post:
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/disi-compression-results-43395/
Random MS3 Chat Thread - Page 171 This thread Refback 04-20-2013 05:45 PM
Anyone measure compression on stock motor? - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum Post #12 Pingback 03-12-2010 09:06 AM
Compression test on built motor SharkDiver MazdaSpeed 3 - Engine, Transmission & Driveline 5 10-22-2009 03:48 PM
Compression check on Laloosh's motor gsrtype1 MazdaSpeed 3 - Engine, Transmission & Driveline 27 09-06-2009 07:25 PM
engine build with stock compression Jessed87 MazdaSpeed 3 - Engine, Transmission & Driveline 8 06-12-2009 11:55 PM
Compression test done.. SharkDiver MazdaSpeed 3 - Engine, Transmission & Driveline 3 03-25-2009 04:28 PM
engine compression? bombdotcom Mazdaspeed3/6 General Discussion 12 09-23-2008 04:06 AM
Page generated in 0.64881 seconds with 38 queries
