![]() | | #681 | ![]() |
![]() Join Date: May 2009 Location: Russellville, AR
Rep Power: 1975 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,199
Groans: 112
| Not Ranked : 0 score
__________________ JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, Forge V2 BPV, JBR TIG's, Kozmic EGR delete, Cobb AP, PTP HPFP internals, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Swift springs, Tri Point Engineering RSB, Whiteline Anti Lift Kit, PTP Injector Seals, GenPu transmission, Fidanza flywheel, 3 BAR MAP sensor, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, sleeved block, PTP BSD SnailTune in progress |
| The Following 3 Users Say Thank You to btstarcher For This Useful Post: |
![]() | | #682 | ![]() |
![]() Join Date: Jul 2008 Location: Ottawa, ON Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,005
| Not Ranked : 0 score Yeah I'm thinking your engine wasn't warm enough.
__________________ 2008 Cosmic Blue Mica Mazdaspeed 3. BNR s3, CoolingMist CMGS Meth, Damond TB Plate, JBR FMIC Undermount w/ TR8, JBR 3" Fullpath, Steedspeed EM, Cobb AP v3, Stratified Tuned, Autotech HPFP Internals, CP-e Catted Downpipe, Port and Polished IM with VTCS & Full EGR Delete, Grimmspeed EBCS, 3 BAR MAP Sensor, Turbosmart Dual-port BPV, Koni Sport Yellows, Eibach Prokits, SPC Camber Arms, Cobb FSB and RSB, AWR Front Endlinks, JBR Trilogy Mounts 70a Duro, KX-F3 Full Chassis Braces, Denso Iridium ITV-22, CP-e Safe Seals, SURE TIG IM and TB, Cobb Shift Weight, TWM SS w/Bushings and Specter Hybrid knob. To be installed: SS Brake Lines. |
![]() | | #683 | ![]() |
![]() Join Date: Nov 2008 Location: Edmonton, Alberta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,648
| Not Ranked : 0 score 140000km. car felt slow so i tested it 160,170,160,170. i dont think i let it turn ove r enough on the 160 cylinders. Guess car is just slow...but at least no issues. |
![]() | | #684 | ![]() |
![]() Join Date: Jan 2013 Location: Lake Forest, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,942
Groans: 55
| Not Ranked : 0 score 150 across the board! Car was tested cold and warm, and tested on another car which tested 180 in all four! |
| The Following User Says Thank You to Little John For This Useful Post: | Micha (08-06-2013) |
![]() | | #685 | ![]() |
Got any datalogs?
__________________ 2008 Cosmic Blue Mica Mazdaspeed 3. BNR s3, CoolingMist CMGS Meth, Damond TB Plate, JBR FMIC Undermount w/ TR8, JBR 3" Fullpath, Steedspeed EM, Cobb AP v3, Stratified Tuned, Autotech HPFP Internals, CP-e Catted Downpipe, Port and Polished IM with VTCS & Full EGR Delete, Grimmspeed EBCS, 3 BAR MAP Sensor, Turbosmart Dual-port BPV, Koni Sport Yellows, Eibach Prokits, SPC Camber Arms, Cobb FSB and RSB, AWR Front Endlinks, JBR Trilogy Mounts 70a Duro, KX-F3 Full Chassis Braces, Denso Iridium ITV-22, CP-e Safe Seals, SURE TIG IM and TB, Cobb Shift Weight, TWM SS w/Bushings and Specter Hybrid knob. To be installed: SS Brake Lines. | |
| The Following User Says Thank You to theurgy For This Useful Post: | speed23 (08-06-2013) |
![]() | | #686 | ![]() |
| Not Ranked : 0 score I run meth but probably need a valve cleaning (although before and after dynos dont really show that much of an improvement...). I ve got lots of logs and all is well in those. I went from a speed3 to a speed6 and the 6 is just heaver wwith more drivetrain loss so is slower than iam used to. Last edited by speed23; 08-06-2013 at 04:28 PM. |
![]() | | #687 | ![]() |
![]() Join Date: Jun 2008 Location: Harrison, AR Heart of the Ozarks
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32,768
| Not Ranked : 0 score Oh, ye of little faith. Don't believe my two (2) testers within 5lbs of each other, hummmmm?
__________________ ![]() "I only do what the voices in my wife’s head tell her to tell me to do" |
| The Following 2 Users Say Thank You to CosmicArkie For This Useful Post: | btstarcher (08-06-2013), SLOWHATCH (08-19-2013) |
![]() | | #688 | ![]() |
Groans: 112
| Not Ranked : 0 score Oh I do. But this guy has crazy high numbers, so I wanted to be blessed by his tester.
![]() | | #689 | ![]() |
![]() Join Date: Mar 2010 Location: Philadelphia, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 413
| Not Ranked : 0 score this guy also has crazy flow/power on his k04. borrow his car not the tester
__________________ 2006 White Water Pearl Mazdaspeed6 Grand Touring #5430 HTA3076 Tial .82 Turbine Housing, CPE tial Mani, Tial MVR 44mm 20psi spring VTA DO Stage 2 Meth w/ D07 & 100% - NJSPEED3 PnPed IM - HTP 3" TIP - SSP BigMAF SRI w/ AEM Dryflow and filter wrap - GS EBCS - Fabbed M2 Catless DP - Autotech HPFP Internals - Cobb AP - Custom 2.5" w/ TR8 FMIC - GHL Resonated Dual Catback Exhaust - TS/SU DP BOV - SP63 Aux Fan Old: BNR S3 370/380 VD 91 + Meth BNR S3 400/410 VD E21 + Meth - Dyno confirmed: http://www.mazdaspeedforums.org/forum/f338/mazdaspeed6-bnr-s3-dyno-400-410-a-180820/ |
![]() | | #690 | ![]() |
![]() Join Date: Jun 2011 Location: Beach Park Illinois
Rep Power: 2610 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 46,278
Groans: 261
Groaned at 73 Times in 60 Posts
| Not Ranked : 0 score I make 230 PSi on 3 out of 4 cylinders. Am I cool? |
| The Following 2 Users Say Thank You to Micha For This Useful Post: | btstarcher (08-06-2013), Little John (08-06-2013) |
![]() | | #691 | ![]() |
Groans: 112
| Not Ranked : 0 score You're very cool @Micha;! Any ideas what happened with the other one?
| The Following User Says Thank You to btstarcher For This Useful Post: | Micha (08-06-2013) |
![]() | | #692 | ![]() |
![]() Join Date: Feb 2012 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,815
Groans: 255
| Not Ranked : 0 score Well 75% is a passing grade in college. ![]() Sent via blown passenger side speakers.
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress |
| The Following User Says Thank You to himurax13 For This Useful Post: | Micha (08-06-2013) |
![]() | | #693 | ![]() |
![]() Join Date: Jul 2010 Location: Las Vegas, NV
Rep Power: 523 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,061
__________________ 2007 MS3: BNRs3 PPT Tuned 350hp/360tq Stocked out and SOLD 2016 CX-5 GT AWD | |
![]() | | #694 | ![]() |
![]() Join Date: Feb 2009 Location: Salt Lake City, Utah
Rep Power: 427 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 626
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score First compression check ever, 83.xxx miles BT 3071, 415whp 12.0 quarter mile. 165 167 165 167 The car has been running flawless until the last week when there is oil coming out of the valve cover breather. I have a little filter on it that came with my cp-e kit. Saikou catch can hooked up the old school way with two check valves. I know a leak down test is the next step but in the mean time I am going to go over the catch can and pcv system.
__________________ ![]() 417whp 428tq 12.037@117.2mph |
![]() | | #695 | ![]() |
Groans: 255
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress | |
| The Following User Says Thank You to himurax13 For This Useful Post: | Snyeed (08-16-2013) |
![]() | | #696 | ![]() |
![]() Join Date: Feb 2011 Location: Germany
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29
| The Following User Says Thank You to MPS_Fan For This Useful Post: | Snyeed (08-16-2013) |
![]() | | #697 | ![]() |
![]() Join Date: Feb 2010 Location: SLC, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,720
| Not Ranked : 0 score @Snyeed; was telling me altitude will mess with compression numbers. I looked it up briefly and people seemed to concur. If usual is 180, and we are at 4500ft would that be accurate for a healthy motor? He runs 25ish, but is on 18psi for the winter months. bt has been in for 2 years?
__________________ GTX 2867/ JBR OG 3.5 WP/ Snail Ported IM/ ITV-22/ DAMOND RMM EBAY DP wCAT/ HKS BPV/ CP-E FP/ COBB EBCS/ PG FMIC W/ TR8 STOPTECH/ EBC YELLOW/ GOODRIDGE LINES/ MOTUL RBF 600 [443/409]SAE CORRECTED -------------245 DZ102 / 245 NT01 |
| The Following User Says Thank You to snailD For This Useful Post: | Snyeed (08-16-2013) |
![]() | | #698 | ![]() |
![]() Join Date: Mar 2012 Location: Middletown, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 84
Groaned at 7 Times in 5 Posts
The compressions look reasonable....and more importantly, even. Last edited by Mandinca; 08-15-2013 at 05:50 PM. Reason: MSF Database - Automerged Doublepost | ||
| The Following User Says Thank You to Mandinca For This Useful Post: | Snyeed (08-16-2013) |
![]() | | #699 | ![]() |
![]() | | #700 | ![]() |
Groans: 255
![]() | | #701 | ![]() |
I changed the pcv and the turbo and still get through the same amount of oil so it must be rings, ringlands or valves. Low compression in cylinder 4 will be checked with leak down this weekend. | |
![]() | | #702 | ![]() |
![]() Join Date: Sep 2011 Location: St. Johns, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,014
Groans: 56
Groaned at 6 Times in 6 Posts
__________________ 2008.5 CWP: GTX 3071//Rapebuilt EM//Relentless pnp IM//JBR 3.5" WP//TurboXS DP/RP//TR8C/Cobb FMIC//GFS bpv//JBR 88/70/70a//Eibach Pro Kit//Koni Yellows//JBR RSB//RX8's Awaiting Install: DO Stage 2//3 Bar MAP//CPe Safeseals Winter Beater: 96 GMC K1500 5 speed 4x4 Needed: Driver mod [SIGPIC][/SIGPIC] | |
![]() | | #703 | ![]() |
![]() | | #704 | ![]() |
Groans: 56
| Not Ranked : 0 score Gotcha... Just putting it out there. IF your head were good you could get a block built with upgraded rods and OEM pistons; should be completely reliable and have good power potential for the future. Of course if your head isn't good that doesn't matter.
![]() | | #705 | ![]() |
| Not Ranked : 0 score Thanks. I'll keep it in mind. Hopefully the leak down will reveal all this weekend. A qt of oil every 200 miles is getting to be a bit much, plus I have CEL P0401 now which will fail CT emissions when the time comes. Anyway, if I have a cracked piston, ringland etc I imagine it's only a matter of time before Zoom Zoom Boom. I've already done about 20,000 miles or more with it burning oil like this, I magine the cats are toast by now. |
| The Following User Says Thank You to Mandinca For This Useful Post: | atvfreek (08-16-2013) |
![]() | | #706 | ![]() |
![]() Join Date: Mar 2012 Location: Waterford, MI - America's High Five
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,451
| Not Ranked : 0 score @maisonvi;
__________________ Silver 2007 Speed3 GT Xona Rotor 6156, Port Injection w/ E85...Bunch of other stuff. I make some power. Titanium Grey Mazdaspeed6 GTX3071, DD |
![]() | | #707 | ![]() |
Groans: 255
![]() | | #708 | ![]() |
I boost here and there and usually when I do I get a cloud of black smoke and misfires. I attended an install meet with the CT Nator guys a few weeks ago and we pulled the plugs, they were caked with white deposits. So, we put new plugs in and this weekend I pulled them to do compression tests and they were almost as bad again – maybe 4 thousand miles on them. So, I’m totally stock, have a rebuilt KO4 in it as well as a new PCV valve. I burn a quart of oil every 200 miles. I did compression tests yesterday at a Nator BBQ and got the following results…..cylinder, dry test, wet test. 1 / 180 / 200 2 / 180 / 210 3 / 185 / 200 4 / 200 / 205 We tried to do leakdown tests but for some reason the tester wouldn’t work properly…..either that or it was operator fail ;-) One thing we did notice was that the plug in cylinder 4 came out very easily…it was loose. Also, the end of the plug socket had about a 1/8” wide ring of oil on it. One of the guys also said he saw a lot of junk on top of the piston. My guess looking at the numbers is that 4 is already seeing a lot of oil so the wet test made no difference. One of the guys from the NY Nator who was at the BBQ suggested a catch can to see how quickly it filled up. I had another thought on this and wanted your opinion. Rather than buying a catch can could I just disconnect the hose that connects the PCV to the IM, block the IM hole and see what pukes out of the PCV ? With the oil consumption I’m seeing I doubt it would be long before it was obvious that I was pushing oil through the PCV (if that’s what my issue is). If I didn’t see evidence of that then I could switch my attention to the valves. Thoughts ? | |
![]() | | #709 | ![]() |
![]() Join Date: Jan 2010 Location: charles co, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,295
| Not Ranked : 0 score I assume your valve cover gasket is ok.....I havent taken the valve cover off in a while but i think you have a gasket that goes around the spark plug holes in the valve cover.
__________________ Best time is 12.28@112 with a 1.68 60ft "GONE HUNTING BE BACK IN 11 SECS" ![]() 365HP and 333 TQ AT 20Psi gt3076 7 blade track weight 3220 street weight 3370 fully built motor//carrilo rods//cp pistons//ACT 6 puck//all mounts//gt3582 turbo//CPE manifold//ported intake//h&r coils//brembo brakes//tr10 I/C//accessport |
![]() | | #710 | ![]() |
![]() Join Date: Jun 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,512
Groans: 157
| Not Ranked : 0 score New dry test yesterday on warmed up engine when replacing spark plugs. #1 - 193 #2 - 192 #3 - 180 #4 - 195 If you look at my older post in this thread, these numbers are about 10 psi HIGHER than my last test. In August of last year the numbers were: #1 - 180 #2 - 180 #3 - 172 #4 - 180 No change in engine mods. Same compression gauge used. Same testing technique of testing with all four plugs removed and cranking engine until needle stopped rising, same differential on #3 cylinder. The only explanations I can offer is that I am now running Rotella T6 5w-40 oil instead of Mobil 1 5w-30 and perhaps I had the engine warmer this time. Maybe someone else has an opinion. I know the car did not magically get better compression, ha ha.
__________________ 2017 Audi Q5 3.0 T (supercharged) Stage 2+ EPL tune, JHM overdrive crank pulley, EPL supercharger pulley, ZF8 TCU tune, aFe/034 intake, modified air box. 480 hp. Sunlight Silver '08 MS3 GT Mods: (Sold 1/25/2019 after 10+ years of ownership) BNR Stage 1 (to fix smoking K04 turbo), TurboXS 3" Catless DP/RP "Stealthback" into stock CBE, Vibrant 3 inch Ultra Quiet Resonator in RP section, Magnaflow 3 1/2" exhaust tip, Mazdaspeed CAI w/air straightener and K&N conical filter, NGK 6510 Iridium IX one step colder plugs, Hypertech tune, Autotech HPFP internals, Stock BPV (works perfectly), Yokohama Advan Neova AD08R's (stock size on stock rims); Hawk HPS pads; SURE RMM; Grimmspeed EBCS (2 port mode), Bilstein B6's, SPC rear camber arms. |
![]() | | #711 | ![]() |
Last edited by Mandinca; 08-19-2013 at 11:31 AM. Reason: MSF Database - Automerged Doublepost | ||
![]() | | #712 | ![]() |
Groans: 112
| Not Ranked : 0 score How many of you guys actually pull the fuel pump relay and wait for the car to die before checking compression?
![]() | | #713 | ![]() |
Groans: 255
| Not Ranked : 0 score Never did that once.
| The Following User Says Thank You to himurax13 For This Useful Post: | atvfreek (08-19-2013) |
![]() | | #714 | ![]() |
| Not Ranked : 0 score Me neither. Just push and hold the gas pedal to the floor - that disables the injectors. Apparently it's a built in system to clear flooded engines but it works for compression tests as well. |
![]() | | #715 | ![]() |
| Not Ranked : 0 score ^^ Exactly.. I once did it by pulling the fuel pump relay, now I just slam the gas pedal.
![]() | | #716 | ![]() |
Groans: 793
__________________ ![]() ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals | |
![]() | | #717 | ![]() |
Carbon buildup = smaller combustion chamber = higher compression?
__________________ ![]() "I only do what the voices in my wife’s head tell her to tell me to do" | |
| The Following 2 Users Say Thank You to CosmicArkie For This Useful Post: | btstarcher (08-19-2013), MSMS3 (08-19-2013) |
![]() | | #718 | ![]() |
Groans: 157
| Not Ranked : 0 score Maybe. Did not think of that and would have thought that any changes in carbon deposits in the combustion chamber or on top of the pistons would not be enough to account for that. Dunno. I just think it may be the built in margin of error in the cheap Actron compression gauge I have. If I checked it again tomorrow, it might be somewhere between the two readings above. I guess the important thing is to compare cylinder-to-cylinder on the same day. Both sets of numbers are pretty good. I need to continue to watch cylinder #3 , which is a bit lower than the others, as so many other people are experiencing. Down maybe what 6-8% compared to the average of the others?
![]() | | #719 | ![]() |
Groans: 112
| Not Ranked : 0 score When Omar checked my compression right after it was built, he got around 180-190 across the board; when he referred to the manual it directed him to pull the relay, etc. When he did that he got 210 on all four.
![]() | | #720 | ![]() |
Unless ya'll cranked it longer/harder.
| The Following User Says Thank You to CosmicArkie For This Useful Post: | btstarcher (08-19-2013) |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/disi-compression-results-43395/ | ||||
| Random MS3 Chat Thread - Page 171 | This thread | Refback | 04-20-2013 05:45 PM | |
| Anyone measure compression on stock motor? - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum | Post #12 | Pingback | 03-12-2010 09:06 AM | |
| Compression test on built motor | SharkDiver | MazdaSpeed 3 - Engine, Transmission & Driveline | 5 | 10-22-2009 03:48 PM |
| Compression check on Laloosh's motor | gsrtype1 | MazdaSpeed 3 - Engine, Transmission & Driveline | 27 | 09-06-2009 07:25 PM |
| engine build with stock compression | Jessed87 | MazdaSpeed 3 - Engine, Transmission & Driveline | 8 | 06-12-2009 11:55 PM |
| Compression test done.. | SharkDiver | MazdaSpeed 3 - Engine, Transmission & Driveline | 3 | 03-25-2009 04:28 PM |
| engine compression? | bombdotcom | Mazdaspeed3/6 General Discussion | 12 | 09-23-2008 04:06 AM |
