Like Tree41Likes
 Old 08-19-2013, 05:26 PM   #721
Black Metal's Avatar
Posts: 699   (View Stats)
Black Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the world
Groans: 78
Groaned at 6 Times in 6 Posts
Threw P0302 CEL which is cylinder 2 misfire. Pulled and replaced plugs, swapped coil packs and did a compression test. Got the following
125
80
155
155
I'm looking for a used block to build I knew it was coming just thought it would take a little longer.
- 2006 Black Mica MS6 -
- GT3071R - CP-e CAI - CP-e BT TIP - ATP Catted DP - JBR RMM - Corksport TMIC - Cobb AP -
- Autotech Internals - Turbo XS 50/50 - DSS Rear Axle - Sure Juggernaught & Dreadnaught -
- GS EBCS - H&R Springs - Sure TIG's - PNP'D Intake Manifold - EGR Delete -
12.89 @ 104.9 1.82 60' 4500' ASL on K04 20 PSI E30
12.01 @ 113.9 1.80 60' 4500' ASL on 3071 22 PSI E20
- 2004 Silver Sunlight Metallic RX-8 -
- 6MT - Stock -
Black Metal is offline   Reply With Quote
 Old 08-19-2013, 05:48 PM   #722
btstarcher's Avatar
Posts: 4,852   (View Stats)
Groans: 112
Originally Posted by CosmicArkie View Post
I'd be interested in an explanation for that....
Unless ya'll cranked it longer/harder.
He told me that he didn't know why it was higher....but that the procedure clearly states to pull the relay and let it die before performing the test. Makes no sense to me either. I don't understand how it would be higher, but he said it was.
SnailTune in progress
CosmicArkie (08-20-2013)
 Old 08-20-2013, 01:03 AM   #723
CosmicArkie's Avatar
Posts: 1,332   (View Stats)
CosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the worldCosmicArkie is the leader of the world
125
80
155
155
Just doesn't seem right to hit the "like" or "thank" button. Kinda that awkward situation. We feels for ya, butt, ya gotta pay when you wanna play.
"I only do what the voices in my wife’s head tell her to tell me to do"
CosmicArkie is offline   Reply With Quote
 Old 08-20-2013, 04:10 AM   #724
MPS_Fan's Avatar
Posts: 436   (View Stats)
MPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the world
I would say its better to have low compression than a hole in the block and messed up head much less $$$ needed for rebuild
MPS_Fan is offline   Reply With Quote
 Old 08-20-2013, 04:20 AM   #725
btstarcher's Avatar
Groans: 112
I plan on trying to reproduce his results when I get a chance. I also can't see what the purpose is, or how it would produce higher compression. The only thing I can think of is that it prevents fuel from entering the combustion chamber, but so does putting the pedal to the floor.
 Old 08-20-2013, 09:52 AM   #726
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
125
80
155
155
Do a leak test because you also COULD have a leaking injector seal that causes compression lose... If you hear air coming from under the intake then that might be your issue and not a blown motor...
track weight 3220
street weight 3370
Last edited by qtrmile beast; 08-20-2013 at 09:52 AM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to qtrmile beast For This Useful Post:
Black Metal (08-20-2013), Tokay444 (08-20-2013)
 Old 08-20-2013, 10:08 AM   #727
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
take it from me guys. ALWAYS pair a leak down test withy our compression tests. that way you know you're seeing the big picture.
"Exclusivity" - CP-enis
Demodded.
The Seals
Black Metal (08-20-2013), btstarcher (08-20-2013), qtrmile beast (08-20-2013)
 Old 08-20-2013, 10:09 AM   #728
Mandinca's Avatar
Posts: 1,700   (View Stats)
Mandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the world
Groaned at 7 Times in 5 Posts
We tried to on my MS6 this weekend but for some reason we couldn't get it working. I'm planning on trying again with another tester.
Mandinca is offline   Reply With Quote
 Old 08-20-2013, 10:25 AM   #729
MSMS3's Avatar
Posts: 2,834   (View Stats)
Groans: 157
"We don't pull no stinking relays." Just hold the go pedal all the way down to the floor and it cuts off fuel flow to the cylinders.
 Old 08-20-2013, 10:31 AM   #730
Dizzy Turbo's Avatar
Posts: 2,173   (View Stats)
Dizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the world
What's the name of that movie? Badges? We don't need no stinking badges!
Edit: blazing saddles haha love it
Dizzy Turbo is offline   Reply With Quote
The Following 2 Users Say Thank You to Dizzy Turbo For This Useful Post:
MSMS3 (08-20-2013), qtrmile beast (08-20-2013)
 Old 08-20-2013, 10:47 AM   #731
MSMS3 and Dizzy Turbo like this.
track weight 3220
street weight 3370
Dizzy Turbo (08-21-2013), MSMS3 (08-20-2013)
 Old 08-20-2013, 09:14 PM   #732
Groans: 78
A little more back story. The car idles fine, fresh oil (rotella) smells like fuel after less than 200 miles, No smoke unless I load the engine up. I am going to buy a leak down tester tomorrow. I was thinking maybe my head gasket cracked between the 1 & 2 Cylinders?
- 6MT - Stock -
The Following User Says Thank You to Black Metal For This Useful Post:
snailD (08-20-2013)
 Old 09-17-2013, 05:04 PM   #733
Pseudonym's Avatar
Posts: 1,429   (View Stats)
Pseudonym is the leader of the worldPseudonym is the leader of the worldPseudonym is the leader of the worldPseudonym is the leader of the worldPseudonym is the leader of the worldPseudonym is the leader of the worldPseudonym is the leader of the worldPseudonym is the leader of the worldPseudonym is the leader of the worldPseudonym is the leader of the worldPseudonym is the leader of the world
just got mine back from the shop with these results...
170
165
150
177
opinions? im looking to tune the car asap but want things running as well as i can get it before.
Cobb AP JBR SSP/SSB's
AWR PMM/RMM Autotech Internals
Sonic Tuning Coilovers ETS TMIC
HTP 3 Incher Forge V2 BPV
eBay Test Pipe
SCUBA TUNED
Pseudonym is offline   Reply With Quote
 Old 09-17-2013, 05:37 PM   #734
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
170
165
150
177
I would do another test with the engine hot and do a wet test to see if that 150 goes back up, especially if it is #3 . 27 PSI difference is more than 10% and is cause for concern.
Pickles Tune in progress
shopety2012 (09-19-2013)
 Old 09-17-2013, 11:11 PM   #735
Pseudonym's Avatar
fuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu
eBay Test Pipe
SCUBA TUNED
 Old 09-17-2013, 11:36 PM   #736
himurax13's Avatar
Groans: 255
I highly reccomend a proper leakdown test as well.
Sent via blown passenger side speakers.
 Old 09-17-2013, 11:43 PM   #737
xtasy's Avatar
Posts: 685   (View Stats)
xtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the world
Groans: 98
Groaned at 6 Times in 4 Posts
Compression test last year was 180 on all 4 cylinders. Did anyone 2 days ago and got
180,180,150,180.
Add a teaspoon of oil in cylinder 3 and it popped back up to 180.
That's pretty much a sign of cylinder ring right? I'm guessing theres no way it's the injector seal =\
Mazdaspeed3 E85 ~ Sold 333/383
Mazdaspeed6 #10018 TiGrey
Forged Internals, PTE5858.
2015' Freektuned on 93Octane 322/337 (stock top mount and BPV)
2016' Freektuned on e85/93 480/444 (maxed out 3bar map sensor)
2017' Freektuned on e85/93 525/497 (maxed out pte5858 @ 35/36psi & fueling)
Mazda CX-5 AWD Daily
xtasy is offline   Reply With Quote
 Old 09-18-2013, 12:50 AM   #738
himurax13's Avatar
Groans: 255
180,180,150,180.
That does appear to be a fried ring or cracked ringland.
 Old 09-18-2013, 04:27 AM   #739
Tokay444's Avatar
Groans: 793
Stop doing comp tests without leak downs!
Demodded.
The Seals
Easter Bunny (09-18-2013), jdmage_mx5 (09-19-2013), phate (09-18-2013)
 Old 09-18-2013, 09:32 AM   #740
JTMS3's Avatar
Posts: 2,306   (View Stats)
JTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the world
Groaned at 21 Times in 15 Posts
Since we did one on my PU this weekend as it has burned a qt of 5w 30 in 2500 miles I figured I throw up our findings. Compression test was done with two different testers for accuracy and right after driving 100+ miles to @silvapain;s house so plenty warm.
First test:
Cyl 1= 192
Cyl 2= 192
Cyl 3= 195
Cyl 4= 195
Second test: (within 5 mins of first test)
Cyl 1= 190
Cyl 2= 186
Cyl 3= 190
Cyl 4= 190
So my concerns went down somewhat but when i went to put the hotpipe (fmic) back oil residue was present with the finger test but not visible at first glance. Poor ko4.... Also after spending some time yesterday looking at shit underneath I found a small amount of buildup at the crankcase but nothing on the undertray. RMS leaking was the diagnoses from my fellow Nator IL gearheads.
Figured data is data, whether good or bad but internals seem healthy with just under 47K of miles put on them.
Sent using stupid fucking Swype!
Mazdaspeed 3 2010 w/ tech package - Celestial Blah Blah Blah
4/15/12 dynojet results: 305whp / 355 tq
JTMS3 is offline   Reply With Quote
The Following 2 Users Say Thank You to JTMS3 For This Useful Post:
Nliiitend1 (09-18-2013), silvapain (09-18-2013)
 Old 09-18-2013, 09:55 AM   #741
180,180,150,180.
Do you have oil in your intake from the valve cover vent tube?
 Old 09-18-2013, 10:44 AM   #742
Pseudonym's Avatar
id originally took the car in to get a leak down test but they didnt do it saying it was pointless since i had a compression test done. fuuuuuuuuuu
also, the car was running very lean according to the mechanic after inspecting the spark plug. they found that the gasket around the bpv was fucked and replaced it. could any of this help in me getting that 150 in cyl 3?
eBay Test Pipe
SCUBA TUNED
 Old 09-18-2013, 10:51 AM   #743
OG Prostitute
shopety2012's Avatar
Posts: 1,055   (View Stats)
shopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the world
Groaned at 68 Times in 40 Posts
Who is "they"?
stock as fuck gay blue pu, still haz juan tranny and evox wheels in shocker yellow tho
currently forging a monster sr20det LS swap killer... brb
used to be the "best looking life partner blue ive seen" - Voltron
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
TEAM Dad -- FYCN
shopety2012 is offline   Reply With Quote
 Old 09-19-2013, 10:41 AM   #744
Pseudonym's Avatar
Originally Posted by shopety2012 View Post
Who is "they"?
the shop i took it to to have the tests done.
eBay Test Pipe
SCUBA TUNED
 Old 09-19-2013, 10:54 AM   #745
OG Prostitute
like your average mechanic? or a performance shop? or like service department of a dealer?
TEAM Dad -- FYCN
 Old 09-19-2013, 11:06 AM   #746
Pseudonym's Avatar
efi logics. performance shop that caters to subarus mostly.
eBay Test Pipe
SCUBA TUNED
 Old 09-19-2013, 11:59 AM   #747
Tokay444's Avatar
Groans: 793
So in others words they've never done a compression test before, since those subby guys never take their plugs out.
Demodded.
The Seals
The Following 4 Users Say Thank You to Tokay444 For This Useful Post:
atvfreek (09-27-2013), himurax13 (09-22-2013), Realgib3 (09-25-2013), shopety2012 (09-19-2013)
 Old 09-25-2013, 11:42 AM   #748
[R]usty's Avatar
Posts: 2,204   (View Stats)
[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world
Groans: 79
Did my first compression test with a brand new craftsman compression tester (old one doesn't seal). I beat the shit out of this car and I currently have 42000 hard earned miles. I've been wanting to do one for a while now but I've been busy.
Car was not 100% warm so I'm expecting slightly higher numbers on a warmer car.
Dry only
1 - 175
2 - 174
3 - 175
4 - 172
Very happy with the results. Car runs perfect so I expected no less. Also checked the plugs (they have 10K on them) and they're very clean and gap is spot on.
I gotta say this MZR engine is holding up damn well.
SpeedThrizzle likes this.
2010 Mazdaspeed3 w/tech
Cobb AP V3JBR Tru 3" Wide PathJBR Boost Tubes & BPV HoseCobb XLE BPVCP-E TMIC ║ UR Racepipe ║ Magnaflow CBEAutoTech InternalsGrimmSpeed EBCS ║ JBR RSBSPC Camber ArmsKW V3 CoiloversJBR IM+TB TIGs & TB BypassJBR SSPE - Focus RMMStopTech Slotted Rotors and EBC Yellow Stuff PadsTechna-Fit SS Brake Lines
[R]usty is offline   Reply With Quote
 Old 09-26-2013, 02:57 PM   #749
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
Got out of class and did a compression test after going to get gas and back to my dorm. Pretty satisfied with my numbers at 15k running Pennzoil Ultra 5w-30.
1= 180
2= 175
3= 179
4= 180
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
Nliiitend1 (09-28-2013)
 Old 09-26-2013, 03:13 PM   #750
Little John's Avatar
Posts: 494   (View Stats)
Little John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the world
Groans: 55
Just did a test on my motor after finishing my break in.(1000) miles!
It wasnt very warm.
1=180
2=180
3=180
4=180
Will do another test when i have the motor warm
Little John is offline   Reply With Quote
The Following User Says Thank You to Little John For This Useful Post:
 Old 09-27-2013, 04:01 AM   #751
Tokay444's Avatar
Groans: 793
1= 180
2= 175
3= 179
4= 180
What did the leak down say?
It wasnt very warm.
1=180
2=180
3=180
4=180
Demodded.
The Seals
Easter Bunny (09-28-2013), Realgib3 (09-27-2013)
 Old 09-27-2013, 06:39 AM   #752
I don't have a leak down tester but I'll try to go somewhere this week to get a test done.
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 09-27-2013, 08:13 AM   #753
If the compression numbers are good, there is no oil in the intake and no smoking/oil consumption on startup, accel, decel then I wouldn't jump on a leakdown.
mazdas4me (04-22-2014), Mazdazilla6 (09-27-2013), slikr (09-27-2013)
 Old 09-27-2013, 10:11 AM   #754
Tokay444's Avatar
Groans: 793
knowing what i know now, with my motor, i honestly would only do a compression test SECONDARY to a leak down from now on. So much more vital information to be had from a leak test.
Demodded.
The Seals
 Old 09-28-2013, 09:14 AM   #755
mtosofsky's Avatar
Posts: 543   (View Stats)
mtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the world
Figure i'd throw in my numbers. Did a test yesterday just to see how healthy the car is. Car is a 2008 with 60200 miles and fully bolted with e85 and meth. Car has been raced a bunch of times and driven aggressively sometimes but i baby it plenty and maintain it well. Numbers were 188-183-183-190.
2008 MS3 GT GTX//Relentless Customs//Voltron Approved//Nishan Tuned
mtosofsky is offline   Reply With Quote
 Old 09-28-2013, 09:30 AM   #756
atvfreek's Avatar
Posts: 7,787   (View Stats)
I agree with this. Leak down does tell a lot, but of the car isn't using oil or blowing oil out the dipstick, valve cover etc, you can trust the compression test is accurate.
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
 Old 09-28-2013, 01:18 PM   #757
nycMS3's Avatar
Posts: 1,067   (View Stats)
nycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the world
Groans: 129
09 MS3 with 50k miles
195 - 192 - 190 - 190
Mods:
SRI, OCC, EGR Delete, Injector Seals, AP + Nishan tune
NATOR NJ/NY/FL
09 MS3 tuned by Nishan
nycMS3 is offline   Reply With Quote
 Old 10-11-2013, 11:44 AM   #758
[R]usty's Avatar
Groans: 79
Swapped plugs this morning so I decided to do a compression test while I'm at it. Car was at operating temperature.
1 - 182
2 - 180
3 - 181
4 - 180
 Old 10-11-2013, 11:46 AM   #759
theurgy's Avatar
Posts: 2,580   (View Stats)
Nice numbers!
BNR s3, CoolingMist CMGS Meth, Damond TB Plate, JBR FMIC Undermount w/ TR8, JBR 3" Fullpath, Steedspeed EM, Cobb AP v3, Stratified Tuned, Autotech HPFP Internals, CP-e Catted Downpipe, Port and Polished IM with VTCS & Full EGR Delete, Grimmspeed EBCS, 3 BAR MAP Sensor, Turbosmart Dual-port BPV, Koni Sport Yellows, Eibach Prokits, SPC Camber Arms, Cobb FSB and RSB, AWR Front Endlinks, JBR Trilogy Mounts 70a Duro, KX-F3 Full Chassis Braces, Denso Iridium ITV-22, CP-e Safe Seals, SURE TIG IM and TB, Cobb Shift Weight, TWM SS w/Bushings and Specter Hybrid knob.
To be installed: SS Brake Lines.
theurgy is offline   Reply With Quote
The Following User Says Thank You to theurgy For This Useful Post:
[R]usty (10-11-2013)
 Old 10-11-2013, 12:05 PM   #760
maisonvi's Avatar
Posts: 3,490   (View Stats)
maisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the world
Groans: 75
08.5 MS3 with 84K on the clock.
135
137
135
135
Thinking the gauge was off. (cheap one I borrowed) Car runs like a champ, so I figure its ok. I would like to do a leak down at some point.
Franken Turbo, built motor, meth.
DIY parts: Shift Knob, Shift Plate, Shift Bushings, Battery Tray, EBCS, RSB, probably more.
"Your signature should just say, I'm the shit." -LynzeC
maisonvi is offline   Reply With Quote
The Following User Says Thank You to maisonvi For This Useful Post:
Turbo4banger (01-08-2014)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/disi-compression-results-43395/
Random MS3 Chat Thread - Page 171 This thread Refback 04-20-2013 05:45 PM
Anyone measure compression on stock motor? - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum Post #12 Pingback 03-12-2010 09:06 AM
Compression test on built motor SharkDiver MazdaSpeed 3 - Engine, Transmission & Driveline 5 10-22-2009 03:48 PM
Compression check on Laloosh's motor gsrtype1 MazdaSpeed 3 - Engine, Transmission & Driveline 27 09-06-2009 07:25 PM
engine build with stock compression Jessed87 MazdaSpeed 3 - Engine, Transmission & Driveline 8 06-12-2009 11:55 PM
Compression test done.. SharkDiver MazdaSpeed 3 - Engine, Transmission & Driveline 3 03-25-2009 04:28 PM
engine compression? bombdotcom Mazdaspeed3/6 General Discussion 12 09-23-2008 04:06 AM
Page generated in 0.62856 seconds with 43 queries
