![]() | | #801 | ![]() |
![]() Join Date: Apr 2009 Location: Connecticut
Rep Power: 0 ![]() ![]() Thanks: 1
| Not Ranked : 0 score |
![]() | | #802 | ![]() |
![]() Join Date: Feb 2011 Location: Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,098
Groans: 78
Groaned at 6 Times in 6 Posts
| Not Ranked : 0 score Finally got my MS6 put back together. Used mostly factory new parts. Cold compression on the refreshed motor was 150 across the board prior to the first start. After 700 miles it is now 170 across the board at operating temp.
__________________ - 2006 Black Mica MS6 - - GT3071R - CP-e CAI - CP-e BT TIP - ATP Catted DP - JBR RMM - Corksport TMIC - Cobb AP - - Autotech Internals - Turbo XS 50/50 - DSS Rear Axle - Sure Juggernaught & Dreadnaught - - GS EBCS - H&R Springs - Sure TIG's - PNP'D Intake Manifold - EGR Delete - 12.89 @ 104.9 1.82 60' 4500' ASL on K04 20 PSI E30 12.01 @ 113.9 1.80 60' 4500' ASL on 3071 22 PSI E20 - 2004 Silver Sunlight Metallic RX-8 - - 6MT - Stock - |
| The Following User Says Thank You to Black Metal For This Useful Post: | snailD (06-20-2014) |
![]() | | #803 | ![]() |
![]() Join Date: Nov 2010 Location: Kaunas, Lithuania
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 144
| Not Ranked : 0 score what did you do? |
![]() | | #804 | ![]() |
Groans: 78
| Not Ranked : 0 score I had two cracked ringlands. I posted my compression results earlier in the thread. Ended up installing new rings, headbolts, headgasket, set of used genone pistons, and Toyota injector seals.
![]() | | #805 | ![]() |
| Not Ranked : 0 score Hm, how much miles did you have? Did you do any honing at all? Did the ringlands scratch the walls at all? |
![]() | | #806 | ![]() |
Groans: 78
| Not Ranked : 0 score Have 85k, about 17k on the 3071. Did a hone with fine stones only. There was a very light visual scratch on one of the cylinder walls but I couldn't feel it. After the hone it was gone.
| The Following 2 Users Say Thank You to Black Metal For This Useful Post: | CosmicArkie (04-06-2014), snailD (06-20-2014) |
![]() | | #807 | ![]() |
![]() Join Date: May 2011 Location: Naperville, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28
| Not Ranked : 0 score Well did mine today... 110,000 MS6 From driver side to passenger. 172 159 163 170 |
![]() | | #808 | ![]() |
| Not Ranked : 0 score it's not even that bad |
| The Following User Says Thank You to mrQQ For This Useful Post: | Vansquish (06-20-2014) |
![]() | | #809 | ![]() |
![]() Join Date: Jul 2013 Location: Ventura County, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,661
Groans: 36
| Not Ranked : 0 score seems about right for 110,000 miles
__________________ 2007 MAZDASPEED6 VELOCITY RED MICA Built motor GTX3071 Meth 6th Port |
![]() | | #810 | ![]() |
![]() Join Date: Jun 2008 Location: Midwest
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 477
Yeah you're golden. I'm at 184000 with pressures around 150. Still life left in it. Going through a quart about every 4000 miles , but she runs smooth.
__________________ 2007 Sunlight Silver MazdaSpeed3 Sport | BNR S3v2 | Autotech Internals | Cobb TIH | 3BAR MAP Sensor | Denso itv-22's | MSCAI | ETS 3.5" TMIC | Synchronic DV | Stratified EBCS | Guardian Angel | UR Test Pipe | Cobb AP | Koni Yellows | JBR RMM | CORN YEAH! | 265,000m | Tuned by STRATIFIED!!! To install: CPE SafeSeals 2012 Velocity Red MazdaSpeed3 w/Tech | Autotech Internals | Sure Aeros V2 | 98,000m | |
![]() | | #811 | ![]() |
| Not Ranked : 0 score Thanks for the confidence guys. I know the numbers are ok, it's just getting over the fact that she is getting old and stuff needs to be fixed. I'm noticing that the car Is louder when idling. Had the vvt timing chain replace 10k Ago Sent from my HTC6525LVW using Tapatalk Last edited by slowspd; 04-14-2014 at 09:31 AM. |
![]() | | #812 | ![]() |
| Not Ranked : 0 score Photos For Grins. |
![]() | | #813 | ![]() |
Groans: 793
| Not Ranked : 0 score There are some brand new killah builds with less compression than that.
| The Following 2 Users Say Thank You to Tokay444 For This Useful Post: | btstarcher (04-14-2014), slowspd (04-14-2014) |
![]() | | #814 | ![]() |
![]() Join Date: Dec 2008 Location: Tempe, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
| Not Ranked : 0 score really? Then I dont feel so bad about my results. I guess I could call my "matrix built" hah
__________________ Eric Schlaht - Arizona Phoenix Photographer http://www.esimaging.net - http://www.facebook.com/esimaging [SIGPIC][/SIGPIC] 2007 MS3 Sport, gtx3071r, Full-Race Exhaust Manifold, SP PNP Intake Manifold, SP 88mm Pistons 9:5:1, Manley H Beam Rods, 10mm H11 Head Studs, ARP Main Studs, 4" HTP TIP + Small Battery Tray, 3 Bar MAP, Grimmspeed ECBS, CP-E FMIC, CP-E DP, CP-E Nexus CBE, Tokay Injector Seals, CP-E RMM, SU PMM, TRZ TMM, PTP FP Internals, DCR VVT, JBrone Shift Plate, SU Shifter Bushings, HKS SSQV, ITV22, DIY Perm Plate with dual OCC, Corksport Radiator Shroud, Southbend Stage 3 Clutch, DO Stage 2 Meth D10, Evo X Wheels, 245/40-18 Nitto NT05, Koni Sports + H&R Springs **463whp/409lb-ft via Mustang Dyno as of 3/28/14** **9/19/13** Zoom Zoom Boom ** Currently Rebuilding with goal of 475whp **11/19/13** Forged engine built and started up the car for the first time, success! **3/28/14** Dyno results from build 463whp / 409lb-ft Mustang Dyno **6/24/15** Sold the Mazdaspeed 3 **7/4/15** Purchased 2015 F150 Ecoboost Lariat FX4 with Sport Package |
| The Following User Says Thank You to Matrix311 For This Useful Post: | Tokay444 (04-14-2014) |
![]() | | #815 | ![]() |
![]() Join Date: Sep 2012 Location: West Palm Beach, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 115
| Not Ranked : 0 score Update for my car. Last results were on September 27th, 2013 @56,000 miles. Fully bolted, e85, and meth...188, 183, 183, 190. Test done today with the addition of a gtx3076 and cpe manifold tuned to 416whp @ 22psi and 71,600 miles...205, 205, 195, 205. Needless to say, even if the gauge reads a bit high my compression is absolutely on point because of my tuner @ms3blackmica;
__________________ 2008 MS3 GT GTX//Relentless Customs//Voltron Approved//Nishan Tuned [SIGPIC][/SIGPIC] |
| The Following 3 Users Say Thank You to mtosofsky For This Useful Post: |
![]() | | #816 | ![]() |
![]() Join Date: Jul 2011 Location: Santa Clara, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 426
Groans: 51
Groaned at 154 Times in 61 Posts
| Not Ranked : 0 score Finally did a compression test on my 09 Speed3. It had 45K when I bought it, 78K now. 190 187 190 190 Also the Autolite XP plugs looked GREAT after 28K! So good, I put die electric grease on boots, and re-installed them. No oil in intercooler. I have been worried after all the stories here, but decided I needed to know! Happy I checked! Runs solid, and uses zero oil in-between changes.
__________________ 05 Mazda 3 Hatch soon to be FULLY converted to a Mazdaspeed 3 - COBB APv2, SRI, TIH, RSB - WMI - Race Pipe - FMIC - Autotech Internals - CPE X-Flex RMM - CPE Injector Seals - S.W.A.S. Disable Switch - Infiniti 18x8 -235/40 - Body Braces - KYB Shocks, Struts - Solid Shifter Bushings Last edited by mazdas4me; 04-22-2014 at 08:37 PM. |
![]() | | #817 | ![]() |
![]() Join Date: Jul 2012 Location: Vista, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 128
sent while granny shifting and not double clutching like I should.
__________________ 07 Cosmic Blue Mica MS3 GT: Cobb AP, Torq R3 Street; Sure CounterWeight; Corksport CAI/TIP; Cobb Shift Knob on Stratified extension w/ TWM shortshifter; Corksport Internals; Custom straight 3 inch catback exhaust by RPM | |
![]() | | #818 | ![]() |
Groans: 78
| Not Ranked : 0 score About $375 but I got the pistons for free
![]() | | #819 | ![]() |
| Not Ranked : 0 score @Familyguy427; think I can get away with this being that my rings are bad? sent while granny shifting and not double clutching like I should.
![]() | | #820 | ![]() |
![]() Join Date: Sep 2012 Location: Los Angeles, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,205
Groans: 79
| Not Ranked : 0 score Had time to test this morning after changing my motor mount. Car was only driven for 5 minutes before the test so it wasn't completely warm. I'm about to roll past 50,000 miles. This is also my first compression test after my etune with @Lex; that was about 2000-3000 miles ago. Since then I've been enjoying the WOT life. 1 - 175 2 - 175 3 - 175 4 - 173 Good stuff.
__________________ 2010 Mazdaspeed3 w/tech Cobb AP V3 ║ JBR Tru 3" Wide Path ║ JBR Boost Tubes & BPV Hose ║ Cobb XLE BPV ║ CP-E TMIC ║ UR Racepipe ║ Magnaflow CBE ║ AutoTech Internals ║ GrimmSpeed EBCS ║ JBR RSB ║ SPC Camber Arms ║ KW V3 Coilovers ║ JBR IM+TB TIGs & TB Bypass ║ JBR SSP ║ E - Focus RMM ║ StopTech Slotted Rotors and EBC Yellow Stuff Pads ║ Techna-Fit SS Brake Lines |
| The Following 2 Users Say Thank You to [R]usty For This Useful Post: | btstarcher (06-19-2014), Lex (06-19-2014) |
![]() | | #821 | ![]() |
![]() Join Date: Feb 2012 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,815
Groans: 255
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress | |
| The Following User Says Thank You to himurax13 For This Useful Post: | Hammology (06-19-2014) |
![]() | | #822 | ![]() |
![]() Join Date: Mar 2011 Location: Quebec, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,139
| Not Ranked : 0 score Just did mine last Friday. 2011 Pu with 90k kms (~56k miles). Mods: fully bolted k04 (minus DP). Stratified tune by @Lex; - 91 octane (no E85 in my part of Canuckstan). Dry: cyl 1 @ 180 cyl 2 @ 185 cyl 3 @ 187 cyl 4 @ 190 Wet: cyl 1 @ 195 cyl 2 @ 195 cyl 3 @ 192 cyl 4 @ 200 I've been getting some clutch vibes for the past few months. It happens as all other threads about this subject already explained (only whenever you press the clutch about an inch down). I only get the "vibes" while on throttle.. As soon as I release the throttle, vibes cease immediately. I therefore decided to also to a piston height test using a depth gauge. Cyl 1 @ 45.43mm and Cyl 4 @ 45.55mm (TDC) Cyl 2 @ 45.59mm and Cyl 3 @ 45.49mm (TDC) Now, I had measured with a steel rod first and all rods measured equally (1-4 and 2-3). When I measured with the depth gauge, as you can see, some little difference. But, I did notice that the .xxmm tenth of mm would not seem to ever stay the same as the gauge is very very sensitive. Would you think my vibrating clutch on throttle be rod related with these numbers???
__________________ 2011 Mazdaspeed3 Power Mods: JBR 3" intake//CP-e top mount IC//AT internals//CS testpipe//NGK step colder plugs Other mods: JBR 88 rmm//Swift springs//RA mud flaps//JBR ssp STRATIFIED TUNED by Lex |
![]() | | #823 | ![]() |
![]() Join Date: Jan 2013 Location: McKinney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,778
Groans: 29
| Not Ranked : 0 score 1:190 2: 190 3: 168 4: 186 - sigh Sent from my SAMSUNG-SGH-I777 using Tapatalk
__________________ 3rd rebuild on the way...maybe... |
| The Following User Says Thank You to Cheapspeed For This Useful Post: | himurax13 (06-19-2014) |
![]() | | #824 | ![]() |
Groans: 36
| Not Ranked : 0 score This
![]() | | #825 | ![]() |
![]() Join Date: Feb 2010 Location: SLC, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,720
| Not Ranked : 0 score i may be a fucking idiot, but which side is number 1 again? passenger or driver?
__________________ GTX 2867/ JBR OG 3.5 WP/ Snail Ported IM/ ITV-22/ DAMOND RMM EBAY DP wCAT/ HKS BPV/ CP-E FP/ COBB EBCS/ PG FMIC W/ TR8 STOPTECH/ EBC YELLOW/ GOODRIDGE LINES/ MOTUL RBF 600 [443/409]SAE CORRECTED -------------245 DZ102 / 245 NT01 |
![]() | | #826 | ![]() |
![]() Join Date: Apr 2011 Location: Chesapeake,VA
Rep Power: 901 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 672
| Not Ranked : 0 score passenger cyl 1 is closest to the crank pulley
__________________ |
| The Following User Says Thank You to 2.0t03speed For This Useful Post: | snailD (06-20-2014) |
![]() | | #827 | ![]() |
Groans: 79
| Not Ranked : 0 score Passenger side is 1
| The Following User Says Thank You to [R]usty For This Useful Post: | snailD (06-20-2014) |
![]() | | #828 | ![]() |
sent while Netflixing...
![]() | | #829 | ![]() |
Groans: 255
| Not Ranked : 0 score Well at the very least you should rehone the cylinder walls or the rings will not seat properly. Pulling the motor or tearing it apart on the car will cost a lot of money laborwise as it is.
| The Following User Says Thank You to himurax13 For This Useful Post: | btstarcher (06-20-2014) |
![]() | | #830 | ![]() |
![]() sent while Netflixing...
| The Following User Says Thank You to Fatpig78 For This Useful Post: | himurax13 (06-20-2014) |
![]() | | #831 | ![]() |
Groans: 29
| Not Ranked : 0 score Thats how I feel. I'm not really interested in breaking any records but im bummed my car can't push more than 280hp even on ethanol. 400hp safe would make me happy. Got lots of research and saving to do.
| The Following User Says Thank You to Cheapspeed For This Useful Post: | Fatpig78 (06-20-2014) |
![]() | | #832 | ![]() |
Groans: 255
![]() | | #833 | ![]() |
![]() | | #834 | ![]() |
![]() Join Date: Apr 2013 Location: Seattle, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,526
| Not Ranked : 0 score Finally did a compression test on my car. 115,400 miles, tested it while warm. 1- 180 2- 180 3- 185 4- 185 Rechecked a second time just to be sure. Only difference was 1 came up with 175. Pretty stoked right now.
__________________ SOLD: 2009 Metro Gray Mica Mazdaspeed 3 - CorkSport Stage II SRI - CorkSport High Flow Downpipe -CorkSport TMIC - CorkSport Short Shift Plate - CorkSport Shifter Bushings - CorkSport Rear Motor Mount - CorkSport Passenger Side Motor Mount -Cobb Accessport - CorkSport HPFP Max Flow Fuel Pump Internals - CorkSport LED Kit 1992 Red Mazda Miata - Flyin Miata Swaybars, Hard Dog Hard Bar, Koni Yellow Shocks, Flying Miata Springs, Spec Stage 1 Clutch, E-Code headlights Next?: 2016 Mazda Mx5? 2017 Mazdaspeed 3? [SIGPIC][/SIGPIC] |
![]() | | #835 | ![]() |
You are golden! Happy trails!
| The Following User Says Thank You to BackRoads For This Useful Post: | SpencerC (06-24-2014) |
![]() | | #836 | ![]() |
57k miles, no additional track time. 190-188-185-168 .................
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk | |
| The Following 7 Users Say Thank You to Ziggo For This Useful Post: | atvfreek (07-05-2014), Cheapspeed (07-02-2014), Dano (07-05-2014), himurax13 (07-10-2014), jack_hammer (07-05-2014), Micha (07-06-2014), sidekick (07-05-2014) |
![]() | | #837 | ![]() |
Groans: 29
| Not Ranked : 0 score Very similar to my numbers just swap 3 and 4.
![]() | | #838 | ![]() |
Youd need rings. On 2nd thought, for the heat of track use id go forged. I still believe the PU pistons would have been just fine in my motor for DD usage.
![]() | | #839 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,797
| Not Ranked : 0 score @Dano; those PU pistons are just as fragile as the gen1 pistons. They do not like heat and power. Every summer we see more and more ring land failures. And they far trump the amount of rod failures we used to see
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 |
![]() | | #840 | ![]() |
Any other symptoms? Leak down next? It does look like ring lands but would be good to confirm.
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/disi-compression-results-43395/ | ||||
| Random MS3 Chat Thread - Page 171 | This thread | Refback | 04-20-2013 05:45 PM | |
| Anyone measure compression on stock motor? - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum | Post #12 | Pingback | 03-12-2010 09:06 AM | |
| Compression test on built motor | SharkDiver | MazdaSpeed 3 - Engine, Transmission & Driveline | 5 | 10-22-2009 03:48 PM |
| Compression check on Laloosh's motor | gsrtype1 | MazdaSpeed 3 - Engine, Transmission & Driveline | 27 | 09-06-2009 07:25 PM |
| engine build with stock compression | Jessed87 | MazdaSpeed 3 - Engine, Transmission & Driveline | 8 | 06-12-2009 11:55 PM |
| Compression test done.. | SharkDiver | MazdaSpeed 3 - Engine, Transmission & Driveline | 3 | 03-25-2009 04:28 PM |
| engine compression? | bombdotcom | Mazdaspeed3/6 General Discussion | 12 | 09-23-2008 04:06 AM |
