![]() | | #841 | ![]() |
| Not Ranked : 0 score I don't have a leak down tester, maybe I will pick one up soon.
![]() | | #842 | ![]() |
| Not Ranked : 0 score I can send you my OTC tester if you want, PM me.
![]() | | #843 | ![]() |
Roger that. I was just thinking with aftermarket heat management like a fan controller, you might be able to stretch the useful HP range they can survive. Its a crap shoot for sure and not worth the gamble when rebuilding.
![]() | | #844 | ![]() |
![]() Join Date: Nov 2010 Location: Kaunas, Lithuania
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 144
| Not Ranked : 0 score I'm really not sure if one pull could do that. |
![]() | | #845 | ![]() |
![]() Join Date: Feb 2011 Location: Chicago
Rep Power: 366 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 183
Groans: 74
Groaned at 6 Times in 6 Posts
| Not Ranked : 0 score I've forgot to warm up the engine and it was too late because I had everything out so I ended up testing on cold engine. 80k/stock k04 some smoke after long idle. 1. 180 2. 180 3. 156 4. 165 Retested 3 & 4 wet and both were right on 180....FML ![]() I will redo again tomorrow on warm engine. |
![]() | | #846 | ![]() |
Groans: 793
| Not Ranked : 0 score 180 on a cold engine seems high.
![]() | | #847 | ![]() |
![]() Join Date: Jan 2011 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 311
Up your idle to 900 and say goodbye to that smoke
__________________ 08 MazdaSpeed3 | Cobb AP | MS Intake | CS TIP | CP-E FMIC | CNT Catless TBE | ITV22 | | AutoTech Internals | TurboSmart BOV | BC Racing Coilovers | CS RMM | CS TMM | | Black Powdercoated Stockers | Built Motor | | Mahle 88mm Pistons | Manley H-Beam Rods | ![]() | |
![]() | | #848 | ![]() |
Groans: 74
| Not Ranked : 0 score Did compression today again on a warm engine....numbers were exactly the same as cold. 1. 180 2. 180 3. 156 4. 165 Wet test brought the lower numbers to 180, however, I've discovered low coolant and a little milk on my oil cap. Last summer I had water pump and coolant replaced. I don't think it could be a headgasket since oil dramatically improved those bad cylinders. Thoughts? |
![]() | | #849 | ![]() |
Groans: 74
| Not Ranked : 0 score I posted this in local section and just figured I would share in case anyone is wondering. Performed a leak down test today. Cylinder/gauge1/gauge2/%between gauges 1. 90psi/88psi/2% leaking 2. 90psi/86psi/4% leaking 3. 90psi/46psi/ SHIT LOAD(abt 46%) LEAKING coming out of the PCV/Oil fill hole 4. 90psi/79psi/12% leaking My cylinder 3 is fucked. Most likely going forged. |
![]() | | #850 | ![]() |
![]() Join Date: Nov 2009 Location: Dallas, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,116
Groans: 549
__________________ it's fun to do bad things | |
![]() | | #851 | ![]() |
| Not Ranked : 0 score 900 miles after rebuild with SP63 10.5:1 pistons the compression is 195 in all 4 cylinders. |
| The Following 2 Users Say Thank You to mrQQ For This Useful Post: | btstarcher (07-18-2014), himurax13 (07-19-2014) |
![]() | | #852 | ![]() |
![]() Join Date: Aug 2010 Location: BC, CANADA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 305
| Not Ranked : 0 score Did a compression test today just to make sure everything is gonna be fine when I install my BNR S3. 84k kms on the motor. 1. 180 2. 180 3. 180 4. 180 Looks like I'm good to go.
__________________ 2008 Mazdaspeed3 | Cobb AP | Cobb DP | Cobb FMIC | Cobb RSB | Cobb RSB | SURE 3" MAF full intake | CP-E Stage 2 RMM | CP-E HPFP | H&R Springs | Koni Yellows | TWM FR | MD OCC | Dashhawk | DO Methanol Injection | JBR PMM & TMM | JBR EGR Plate | |
| The Following 4 Users Say Thank You to IMASA For This Useful Post: |
![]() | | #853 | ![]() |
![]() Join Date: Jul 2010 Location: Las Vegas, NV
Rep Power: 523 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,061
| Not Ranked : 0 score Just tested today again with a working gauge (previous HF gauges all read 120 across the board) Fully bolted (minus Ex/Int Mani) on BNRs3v1 for the last 20k miles...going forged next year Left to right 168, 165, 170, 173 with 118k Miles.
__________________ 2007 MS3: BNRs3 PPT Tuned 350hp/360tq Stocked out and SOLD 2016 CX-5 GT AWD |
![]() | | #854 | ![]() |
![]() Join Date: May 2012 Location: orlando, fl
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
| Not Ranked : 0 score Looking at everybody's number, I don't feel so bad now. At 120k I got: 1-170 2-181 3-175 4-170
__________________ ---------------------------------------- Building it from ground up: ![]() |
| The Following 2 Users Say Thank You to r3d For This Useful Post: | LatinKraze (07-20-2014), SpencerC (07-21-2014) |
![]() | | #855 | ![]() |
![]() Join Date: Jun 2011 Location: Tacoma Wa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20,346
| Not Ranked : 0 score @35700 1k on BT 1- 189 2- 185 3- 180 4- 186
__________________ Blacked Out 2010 Black Mica MazdaSpeed 3 Performance: Speed Performance 10.6:1 Built motor, CP-e Exhaust Mani, GTX3071, Tial MVR EWG, JBR 3.5" SRI, Cobb AP V3, Autotech HPFP, Guardian Angel, eBay Downpipe, CP-E Triton CBE, Treadstone TR8L Intercooler, CX Racing FMIC Piping Kit, JBR Crashbar, NGK Plugs, PNP Intake Manifold, CoolingMist WMI system w/failsafe, DM Throttle Body Spacer with Dual D07 Nozzles, |
| The Following User Says Thank You to England15j For This Useful Post: | SpencerC (07-21-2014) |
![]() | | #856 | ![]() |
![]() Join Date: Aug 2013 Location: Manitowoc, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,312
Groaned at 123 Times in 84 Posts
| Not Ranked : 0 score 100K miles, cold wet test 210 200 195 205 I'm thinking compression gauge is a piece of shit (vatozone) but the consistency is what matters anyway.
__________________ https://www.youtube.com/user/JustinBieberVEVO |
![]() | | #857 | ![]() |
![]() Join Date: Jun 2012 Location: San Jose, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,963
Groans: 47
| Not Ranked : 0 score Cold wet test as in engine cold and you added oil? Do a hot test with no oil to get a real idea of compression.
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() |
| The Following User Says Thank You to sidekick For This Useful Post: | roguemazda (11-03-2014) |
![]() | | #858 | ![]() |
| Not Ranked : 0 score Shouldn't the heat increase my compression reading? Correct me if I'm wrong.
![]() | | #859 | ![]() |
![]() Join Date: Jul 2012 Location: Oceanside, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,654
Groans: 52
| Not Ranked : 0 score 1: 150 2: 150 3: 145 4: 145 Yay.
__________________ 2010 Alternative Lifestyle Blue Mazdaspeed3 (sold)2008 Chevy Colorado. The only truck that comes with a lifetime guarantee... |
| The Following User Says Thank You to ABolewski For This Useful Post: | sidekick (07-23-2014) |
![]() | | #860 | ![]() |
![]() Join Date: Feb 2012 Location: Li ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,290
Groans: 74
| Not Ranked : 0 score Just got my otc comp tester in the mail. 32k tuned since 9k 201 199 199 197
__________________ MECP 2012 BM PTE 5858 Vband .82ar // Tial EWG // CPE Mani // 3" Turboback // JBR Under route hot pipe // MD ST mani+spacer with PI // Siemens 60lb Injectors // Splitsecond inj controller // JBR 88 duro RMM/TMM // MD PMM // TWM Full replacement shifter // JBR CC // Autotech FP Internals // SP63 SB/Manley rods SP63 pro pistons // Treadstone FMIC TR824 // FoMoCo Tranny Jizz // South Bend Clutch Stage 3 enduro// GFB Respons // FJ 4" intake // WMI 100% VPM1 // Air Lift 1000 in rear // N2MB WOT BOX Rfinkle tune in progress The Brooklyn beater: 2005 1.8 Auto Sentra |
![]() | | #861 | ![]() |
![]() Join Date: Oct 2012 Location: TAMPA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 962
| Not Ranked : 0 score 175 70 175 175... 24800 Miles in FL Car has been at he dealership for 2 weeks with a blown Cylinder #2 trying to get a replacement engine under warranty =(
__________________ 2013 VRM MS3\ BNR S3v2\ 4GL E85 TUNED\ |
![]() | | #862 | ![]() |
Groans: 47
| Not Ranked : 0 score Metal expands with heat. Under normal operating conditions, the engine is hot and piston rings only seal properly once the engine is warmed up. Doing a compression test right after driving will give you the best picture of what your compression looks like under normal operation. You add oil to low compression cylinders AFTER doing the test to see if the leakage is at the piston ring or elsewhere in the cylinder.
![]() | | #863 | ![]() |
I will redo the test next time I'm working on the car.
__________________ https://www.youtube.com/user/JustinBieberVEVO | |
![]() | | #864 | ![]() |
| Not Ranked : 0 score |
![]() | | #865 | ![]() |
Groans: 74
| Not Ranked : 0 score Yep but before that i had 196 with a matco tester so it is what it is. I do comp tests every few months.
![]() | | #866 | ![]() |
Groans: 793
You did it cold and wet. Big difference.
__________________ ![]() ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals | |
| The Following User Says Thank You to Tokay444 For This Useful Post: | btstarcher (07-26-2014) |
![]() | | #867 | ![]() |
![]() Join Date: Sep 2012 Location: Los Angeles, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,205
Groans: 79
| Not Ranked : 0 score Tested this morning to check if everything was okay after cleaning my intake valves 2 weeks ago. Car was completely warm. Each cylinder was cranked 7 times. 1 - 180 2 - 180 3 - 180 4 - 180 Most consistent numbers I've ever had.
__________________ 2010 Mazdaspeed3 w/tech Cobb AP V3 ║ JBR Tru 3" Wide Path ║ JBR Boost Tubes & BPV Hose ║ Cobb XLE BPV ║ CP-E TMIC ║ UR Racepipe ║ Magnaflow CBE ║ AutoTech Internals ║ GrimmSpeed EBCS ║ JBR RSB ║ SPC Camber Arms ║ KW V3 Coilovers ║ JBR IM+TB TIGs & TB Bypass ║ JBR SSP ║ E - Focus RMM ║ StopTech Slotted Rotors and EBC Yellow Stuff Pads ║ Techna-Fit SS Brake Lines |
![]() | | #868 | ![]() |
![]() Join Date: May 2012 Location: Austin TX
Rep Power: 342 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 343
| Not Ranked : 0 score Bump'd I started getting some nasty KR (over 5) on my tune which I have been running for about a year now. 3" intake, catted dp, cbe, fuel pump, forge v1, occ, had autolite step colder, switched to itv22, problem started, switched back to autolite, still persists. The car is a 2012, had about 25k when the issue arose. I threw my maf cal onto stage 2 ots and no more knock at wot (which I'm doing significantly less of since this all started), but when I tested comp, this is what I got... 195 170 (wet was 175) 195 190 What is interesting to me is that the plug on cylinder 2 was MUCH lighter than the other 3. So for some reason that cylinder is running low comp but also much hotter than the rest. Fwiw the engine, pedals, steering wheel all vibrate somewhat harshly at any given rpm/load/speed. I checked piston height with a 3/8" extension, and cylinders 2 and 3 are identical. So at this point I'm speculating that it could be a valve issue, or injector seals, possibly both. But I'm still trying to wrap my mind around what could be causing a lean condition in #2 (no CEL however) All were gapped at .026, and rechecked when I tested, still .026 Last edited by kidlifecrisis; 09-13-2014 at 08:58 PM. |
![]() | | #869 | ![]() |
| Not Ranked : 0 score I don't think that difference could cause knock. |
![]() | | #870 | ![]() |
![]() Join Date: Nov 2008 Location: Edmonton, Alberta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,648
| Neutral : +1 score Maybe an injector issue? causing too lean conditon and knock in cylinder. Last edited by speed23; 09-14-2014 at 12:16 PM. |
![]() | | #871 | ![]() |
| Not Ranked : 0 score I threw a half pint of seafoam in a 3/4 full tank this morning, it seems to be running a bit smoother but I'll see how it goes as I burn through this tank. Seems that the low comp could be a symptom of the knock, which itself is caused by a fuel issue Last edited by kidlifecrisis; 09-14-2014 at 06:30 PM. |
![]() | | #872 | ![]() |
![]() Join Date: Jun 2014 Location: Santa Cruz, ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 22
| Not Ranked : 0 score Doing my first test, 130 dry test on the nose across the board, tested at a temp of 165. 2008.5 45k miles, no CEL's, no smoke, not eating oil /and runs smooth. Bad gauge? |
![]() | | #873 | ![]() |
Groans: 793
| Not Ranked : 0 score Did you do a wet test? If there all exactly 130, I would bet the gauge is toast.
__________________ ![]() ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals Last edited by Tokay444; 09-20-2014 at 06:42 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #874 | ![]() |
Now that I think about it, the packaging of the tester was kind of sliced up near the extension and gauge, I'm going to go borrow one from Autozone tomorrow. Last edited by googlebutt; 09-20-2014 at 07:43 PM. | |
![]() | | #875 | ![]() |
![]() Join Date: Jun 2008 Location: Midwest
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 477
| Not Ranked : 0 score Did mine again today - dry test at 192,500 original miles on the engine: 155-150-150-160. There's life in her yet! Did a leak down test on 4, and got just a little coming through exhaust, nothing past the rings. Overall, pretty happy about it, as we are about to add E85 to my tune on the BNRS3.
__________________ 2007 Sunlight Silver MazdaSpeed3 Sport | BNR S3v2 | Autotech Internals | Cobb TIH | 3BAR MAP Sensor | Denso itv-22's | MSCAI | ETS 3.5" TMIC | Synchronic DV | Stratified EBCS | Guardian Angel | UR Test Pipe | Cobb AP | Koni Yellows | JBR RMM | CORN YEAH! | 265,000m | Tuned by STRATIFIED!!! To install: CPE SafeSeals 2012 Velocity Red MazdaSpeed3 w/Tech | Autotech Internals | Sure Aeros V2 | 98,000m |
![]() | | #876 | ![]() |
![]() Join Date: Apr 2012 Location: Temecula, CA
Rep Power: 5431 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,552
| Not Ranked : 0 score New OEM motor, 900 miles, warm (sat for ~30 mins after turned off). 176 - 176 -176 -176 This pleases me.
__________________ 2006 MS6 WWP Sport - 340whp/350wtq JBR 3"- BNRS3V2 - GS EBCS - CUSTOM FMIC - CS IM - LTR7IX - CMGS WMI & D07 GA - TURBOXS HEADER - FIDANZA FW - CP-E CATTED DP - 3" CATBACK BILSTEIN - H&R SPRINGS - 18x8.5 +48 ROTA SVN - 265/35R18 HTR ZIII MINI H1 6.0 - CAR LED TAILS SEE MORE USING !SHOUTTAG.COM - ENTER: !6SPEED6 Last edited by dale_gribble; 09-21-2014 at 12:00 PM. |
![]() | | #877 | ![]() |
Groans: 79
__________________ 2010 Mazdaspeed3 w/tech Cobb AP V3 ║ JBR Tru 3" Wide Path ║ JBR Boost Tubes & BPV Hose ║ Cobb XLE BPV ║ CP-E TMIC ║ UR Racepipe ║ Magnaflow CBE ║ AutoTech Internals ║ GrimmSpeed EBCS ║ JBR RSB ║ SPC Camber Arms ║ KW V3 Coilovers ║ JBR IM+TB TIGs & TB Bypass ║ JBR SSP ║ E - Focus RMM ║ StopTech Slotted Rotors and EBC Yellow Stuff Pads ║ Techna-Fit SS Brake Lines | |
![]() | | #878 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 64
| Not Ranked : 0 score Tested mine a few weeks ago 180 150 180 180 Rebuild in progress, cracked ringland on cyl 2.
__________________ 2012 Black Mazda 3 MPS ![]() CP-E Stage 2 Pistons - Manley Rods - BNR S3 - HTP 3" TIP + 3" BTM - Corksport Airbox - Cobb FMIC 2XS Exhaust Manifold - Snow Performance Meth Kit - HKS SSQIV - HPFP Internals - CPE Catted Downpipe - Perm PCV Plate OBX Catback - CPE Stage 2 RMM - JBR Side Mounts - SURE AGS Shiftknob + Shortcut + Anchors Cobb Accessport V3 - Saikou Michi OCC - Damond OCC - Corksport Springs - Bilstein B8 Shocks Versus Eurolace 19 x 8 +45 - Hankook RS3 Built & Tuned by Rob Track Setup - 18 x 8.5 Lenso Spec E - Nitto NT-01 245/40/18 DBA T3 Rotors - Carbotech XP10 Brake Pads |
![]() | | #879 | ![]() |
| Not Ranked : 0 score Scoped the cylinder in question, this is what it looked like. ![]() It looks like a hot spot on the piston? Or maybe some anti seize got in there from when I did the comp test, hard to tell and being the first time I've looked inside a motor I don't have much of a baseline |
![]() | | #880 | ![]() |
| Not Ranked : 0 score So I posted a while back that the brand new Innova (3614) gauge I used gave me a reading of 130psi across all cylinders. Ordered the Innova gauge with the solid rubber hose (3612) and just got 185 190 190 190. Beware if you buy that gauge. |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/disi-compression-results-43395/ | ||||
| Random MS3 Chat Thread - Page 171 | This thread | Refback | 04-20-2013 05:45 PM | |
| Anyone measure compression on stock motor? - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum | Post #12 | Pingback | 03-12-2010 09:06 AM | |
| Compression test on built motor | SharkDiver | MazdaSpeed 3 - Engine, Transmission & Driveline | 5 | 10-22-2009 03:48 PM |
| Compression check on Laloosh's motor | gsrtype1 | MazdaSpeed 3 - Engine, Transmission & Driveline | 27 | 09-06-2009 07:25 PM |
| engine build with stock compression | Jessed87 | MazdaSpeed 3 - Engine, Transmission & Driveline | 8 | 06-12-2009 11:55 PM |
| Compression test done.. | SharkDiver | MazdaSpeed 3 - Engine, Transmission & Driveline | 3 | 03-25-2009 04:28 PM |
| engine compression? | bombdotcom | Mazdaspeed3/6 General Discussion | 12 | 09-23-2008 04:06 AM |
