![]() | | #881 | ![]() |
Groans: 111
| Not Ranked : 0 score When the oil consumption started suddenly in May/June I said that if I have to open up the engine even only for replacing some valve seals, I will rebuild it completely. This is going to be a costly word keeping.
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI |
![]() | | #882 | ![]() |
![]() Join Date: Feb 2011 Location: Chicago
Rep Power: 366 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 183
Groans: 74
Groaned at 6 Times in 6 Posts
| Not Ranked : 0 score I posted a while back. Two of my cylinders were around 180. 3 was at 155 and 4 was slightly higher. Additionally, 3 leaked over 30% on leakdown. Engine ran ok but smoked real bad. It appears that the smoke was caused by the cylinder and the turbo. I've built the motor and get very little smoke, however, the turbo smokes here and there just not as bad as before. Also, I can smell burning oil out of the exhaust. I've pulled the turbo yesterday and it did in fact leak. I am replacing the CHRA with a rotomaster part and will report results. I haven't seen anyone use that CHRA yet. However, when I've pulled the old motor apart the rings looked fine. I think I could have probably gotten a little more out of it.
__________________ 2007 TR MazdaSpeed3:Autotech FP inernals, CorkSport Turbo, TR8 Front Mount w/CX piping, JBR 3" intake, COBB EBCS, Cobb AP, Toyota Injector Seals, FR stud mod, Fidanza flywheel/LUK clutch, Forge BPV v2, cp-e xFlex stage 2 RMM, Wiseco .20 Pistons/Manley Rods/BSD, Dual DM catch cans, Koni Yellows/H&R springs, FD wheels, eBay downpipe, stock CBE 2005 Mazda 3 SP23: mods include rusty quarter panels and grinding 3rd gear. It does have a fusion motor, so I guess that's a mod too. |
![]() | | #883 | ![]() |
![]() Join Date: Aug 2014 Location: Garland, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 122
| Not Ranked : 0 score 2008.5 with 72K miles I think the only mod is an ebay test pipe from the previous owner 150 155 152 148
__________________ Black Mica 2008.5 CS SRI+TIP • AT HPFP • TP |
![]() | | #884 | ![]() |
![]() Join Date: Mar 2012 Location: Waterford, MI - America's High Five
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,451
| Not Ranked : 0 score 2010 MS3 54k miles Running beaner for about 4k miles, always @rfinkle2; tuned. 190 across the board. Dry. Sent while granny shiftin' and not double clutching like I should
__________________ Silver 2007 Speed3 GT Xona Rotor 6156, Port Injection w/ E85...Bunch of other stuff. I make some power. Titanium Grey Mazdaspeed6 GTX3071, DD |
| The Following User Says Thank You to HawkeyeGeoff For This Useful Post: | rfinkle2 (11-06-2014) |
![]() | | #885 | ![]() |
![]() Join Date: Jun 2008 Location: Midwest
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 477
What kind of power are you making these days? Any E85 or meth?
__________________ 2007 Sunlight Silver MazdaSpeed3 Sport | BNR S3v2 | Autotech Internals | Cobb TIH | 3BAR MAP Sensor | Denso itv-22's | MSCAI | ETS 3.5" TMIC | Synchronic DV | Stratified EBCS | Guardian Angel | UR Test Pipe | Cobb AP | Koni Yellows | JBR RMM | CORN YEAH! | 265,000m | Tuned by STRATIFIED!!! To install: CPE SafeSeals 2012 Velocity Red MazdaSpeed3 w/Tech | Autotech Internals | Sure Aeros V2 | 98,000m | |
![]() | | #886 | ![]() |
![]() Join Date: Feb 2010 Location: SLC, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,720
| Not Ranked : 0 score tried to do a comp test, tester from vatozone was shit and broken. regardless pulled the plugs and they look healthy at least. 81k miles, gtx2867r went in at 50k.
__________________ GTX 2867/ JBR OG 3.5 WP/ Snail Ported IM/ ITV-22/ DAMOND RMM EBAY DP wCAT/ HKS BPV/ CP-E FP/ COBB EBCS/ PG FMIC W/ TR8 STOPTECH/ EBC YELLOW/ GOODRIDGE LINES/ MOTUL RBF 600 [443/409]SAE CORRECTED -------------245 DZ102 / 245 NT01 |
| The Following User Says Thank You to snailD For This Useful Post: | btstarcher (11-06-2014) |
![]() | | #887 | ![]() |
Groans: 111
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI | |
![]() | | #888 | ![]() |
| Not Ranked : 0 score About 340 on pump, 370 or so on a 4 gallon mix. I am still planning on doing meth once the spring comes! Sent while granny shiftin' and not double clutching like I should
![]() | | #889 | ![]() |
Sweet! You're about 10whp ahead of me on both counts. Interested to hear how your meth project turns out.
| The Following User Says Thank You to BackRoads For This Useful Post: | HawkeyeGeoff (11-06-2014) |
![]() | | #890 | ![]() |
![]() And I will for sure. @maisonvi; and myself are going to try a meth throttle body spacer and see how it turns out...it's just such an easy option.
__________________ Silver 2007 Speed3 GT Xona Rotor 6156, Port Injection w/ E85...Bunch of other stuff. I make some power. Titanium Grey Mazdaspeed6 GTX3071, DD | |
| The Following User Says Thank You to HawkeyeGeoff For This Useful Post: | BackRoads (11-06-2014) |
![]() | | #891 | ![]() |
My next mod is my clutch. I guess 154,000 miles was all the abuse she could take. Still trying to finalize my tune with Lex, but the clutch can't handle WOT in 4th anymore.
![]() | | #892 | ![]() |
GL man, make sure to post up how it all goes!
![]() | | #893 | ![]() |
Fer sher!!
![]() | | #894 | ![]() |
![]() Join Date: May 2014
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 58
| Not Ranked : 0 score I did a compression test at the dealership yesterday as I had other things to do, results all accross the board was 205. He suspects the engine needs a good cleaning but it's in good shape. 2010 with 74 000 miles |
![]() | | #895 | ![]() |
That's way too high. You need to take that car out and drive it hard RIGHT NOW! It's like blood pressure - your car needs more exertion!
| The Following User Says Thank You to BackRoads For This Useful Post: | HawkeyeGeoff (11-08-2014) |
![]() | | #896 | ![]() |
![]() Join Date: Aug 2008 Location: Pittsburgh, PA
Rep Power: 637 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,048
| Not Ranked : 0 score Just tested 180's across the board. 100k on the clock. Self tuned since about 50k. 3071 has only been on for about 2k. |
![]() | | #897 | ![]() |
![]() Join Date: Sep 2012 Location: Los Angeles, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,205
Groans: 79
| Not Ranked : 0 score Did a quick compression test last night after I noticed the clamp on my turbo inlet had lost the tightening nut. The turbo had some dirt on one of the corners from a big air leak . Luckily no damage done to the turbo or the motor, compression still sitting at a perfect 180 across the board @53600 miles.
__________________ 2010 Mazdaspeed3 w/tech Cobb AP V3 ║ JBR Tru 3" Wide Path ║ JBR Boost Tubes & BPV Hose ║ Cobb XLE BPV ║ CP-E TMIC ║ UR Racepipe ║ Magnaflow CBE ║ AutoTech Internals ║ GrimmSpeed EBCS ║ JBR RSB ║ SPC Camber Arms ║ KW V3 Coilovers ║ JBR IM+TB TIGs & TB Bypass ║ JBR SSP ║ E - Focus RMM ║ StopTech Slotted Rotors and EBC Yellow Stuff Pads ║ Techna-Fit SS Brake Lines |
![]() | | #898 | ![]() |
![]() Join Date: Nov 2012 Location: Chaplin, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 66
Groaned at 3 Times in 1 Post
| Not Ranked : 0 score My compression was 180-180-180-zero. 138,XXX on motor. stage 1 93 ots for 20K. Burnt valve. |
![]() | | #899 | ![]() |
Groans: 793
| Not Ranked : 0 score That's a good one.
![]() | | #900 | ![]() |
![]() Join Date: Nov 2010 Location: Kaunas, Lithuania
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 144
| Not Ranked : 0 score what caused it? |
![]() | | #901 | ![]() |
Groans: 111
| Not Ranked : 0 score too much boost and too low timing.
![]() | | #902 | ![]() |
![]() Join Date: Feb 2009 Location: Tampa, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 503
| Not Ranked : 0 score back in may, after I hydrolocked, I got these numbers with HF gauge 160/165/140/160 dry 175/170/150/165 wet wood dowel and sharp pencil showed no badly bent rod no vibes in clutch been driven relatively easy for 3K since then I have some fresh plugs on the way, I plan to use my caliper to get more exact with the rod check, and redo comp test and do the leakdown thing. might be I popped ringlands?
__________________ A democracy, in its purest form, is well represented by a group consisting of 2 wolves and 1 rabbit. Voting on what to have for lunch |
![]() | | #903 | ![]() |
Groans: 793
| Not Ranked : 0 score Do a leak down.
![]() | | #904 | ![]() |
| Not Ranked : 0 score buying the HF tester today dry, and warm for the test?
![]() | | #905 | ![]() |
Groans: 793
| Not Ranked : 0 score Dry for sure. I would give it about 20 minutes after shut down. I usually let it sit for ten, and then start tearing it down.
![]() | | #906 | ![]() |
| Not Ranked : 0 score done, well done friday, after the plugs show up
![]() | | #907 | ![]() |
Groans: 79
| Not Ranked : 0 score Had a bit of time this weekend so I did some boost leak testing and a compression test. Car has 57300 and was completely cold. 1-180 2-180 3-179 4-179
| The Following 2 Users Say Thank You to [R]usty For This Useful Post: | dale_gribble (04-27-2015), Justin@Freektune (04-30-2015) |
![]() | | #908 | ![]() |
| Not Ranked : 0 score i did a comp test in utah (roughly 4500ft asl) at 90,000 miles every cylinder was 162. ill take it
| The Following User Says Thank You to snailD For This Useful Post: | Justin@Freektune (04-30-2015) |
![]() | | #909 | ![]() |
![]() Join Date: Oct 2012 Location: TAMPA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 962
| Not Ranked : 0 score Two months ago I did a compression test with a autozone gauge... I got 165 in all 4 Cylinders, 14K on a new engine, Needless to say I was dissapointed, but hey at least numbers were consistent, so finally today i got a brand new gauge and decided to try this again... really happy with the new results, Numbers are DRY on a somewhat warm engine, didn't do a wet test
__________________ 2013 VRM MS3\ BNR S3v2\ 4GL E85 TUNED\ |
| The Following User Says Thank You to Cevaes_64 For This Useful Post: | dale_gribble (05-08-2015) |
![]() | | #910 | ![]() |
![]() Join Date: Sep 2014 Location: Arlington, Texas
Rep Power: 0 ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score So I did mine after I experience a cylinder 2 misfire. Did compression test and it said fuck off. 150,30,150,150 tested warm . |
![]() | | #911 | ![]() |
![]() Join Date: Dec 2012 Location: Myrtle Beach, SC
Rep Power: 0 ![]() ![]() ![]() Thanks: 36
| Not Ranked : 0 score Did the test on Sunday. Been wanting to do it for future references. Have almost 90k miles on the slow thing. Did the test about 10 minutes after I parked, drove around for about 20 minutes before. I want to believe the numbers but not sure, I might get another tester and see what it reads. Should I maybe consider a cold test? Only got to page 13, going to read rest later. Top left: passenger Top right: passenger middle Bottom left: driver middle Bottom right: driver
__________________ __________________ 08.5 Crystal White Pearl MS3 Rotors StopTech Drilled and Slotted / Pads EBC Reds / ISC coilovers Cobb AP / Cobb SRI / Cobb TIH / Cobb FMIC / Corksport Downpipe / HPFP Internals / Forge BPV V3 |
![]() | | #912 | ![]() |
You're golden.
| The Following 2 Users Say Thank You to BackRoads For This Useful Post: | FreshAsWoodie (06-09-2015), MD1032 (06-11-2015) |
![]() | | #913 | ![]() |
| Not Ranked : 0 score Yeah I hope so haha. Kind of a dead thread too. But I still wanted to post my info. Sent from my iPhone using Tapatalk
![]() | | #914 | ![]() |
| Not Ranked : 0 score this thread is never dead. it just slowly accumulates info
![]() | | #915 | ![]() |
| Not Ranked : 0 score Well I've gotten the block and head back from the machine shop now I'm just waiting on my bearings to come in the mail then i'll begin the assembly process. I never got around to showing the problem with cylinder 2 but the picture below will explain all.
__________________ 88mm Wiseco pistons_Manley H- beam rods_CPE Injector seals_Clevite Bearings_Autotech Internals_HKS SSQV_Cobb SRI/TIP_COBB V3_JBR 88 duro pmm_JBR rmm_Turbine Tech FMM_CxRacing FMIC_TurboXs Catless DP/TP_South Bend Stage 3 DD_That Corn Shit_FREEKTUNE! |
| The Following User Says Thank You to myspeed90 For This Useful Post: | MD1032 (06-11-2015) |
![]() | | #916 | ![]() |
Groans: 111
| Not Ranked : 0 score Yeah... same cylinders (2, 3 or both), same spot (the end towards the exhaust valves).
![]() | | #917 | ![]() |
![]() Join Date: Feb 2010 Location: FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 324
| Not Ranked : 0 score cyl one 195 cyl two 198 cyl three 195 cyl four 200 Test was last month at 96,000 mi. Used Craftsman tester. This was prior to installing FMIC and going from stage 2 to stage 3 cobb OTS map. See sig for other mods. Live in Florida. Drive it like I stole it almost every day, but always take it easy on warm up and cool down. Change oil every 5K mi, always synthetic, 5w-40 Rotella T as of late. I was absolutely thrilled! Especially since I'd like to get at least another 100K mi and/or five more glorious years out of this wonderful car.
__________________ 2010 Liquid Silver Mazdaspeed 3 Cobb AP v3, tuning by Stratified Automotive Controls, Autotech HPFP internals, one step colder NGK Iridium plugs, Cobb DP, Magnaflow 3" CBE, Corksport SRI/TIP, Corksport Race RMM 80A, Synapse Synchronic DV in push mode A+B, Treadstone TR6 FMIC, JBR FMIC piping kit, JBR Silicone recirc hose, JBR rear sway bar, Bilstein B14 coilovers, SPC adjustable rear camber arms, Stoptech SS brake lines and brake pads, 17x9" et+45mm Enkei Racing RPF1's, 245/40/17 Hankook RS3's, JBR 5mm hub/wheel spacers in front. |
| The Following User Says Thank You to GregScuba For This Useful Post: | BackRoads (06-11-2015) |
![]() | | #918 | ![]() |
![]() Join Date: Jul 2013 Location: Ventura County, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,661
Groans: 36
| Not Ranked : 0 score If you wanna keep that compression the way it is, I suggest you get a real tune.
__________________ 2007 MAZDASPEED6 VELOCITY RED MICA Built motor GTX3071 Meth 6th Port |
| The Following User Says Thank You to Hammology For This Useful Post: | GregScuba (06-11-2015) |
![]() | | #919 | ![]() |
Edit: Just wonder if I should clean the intake valves before getting a tune? Perhaps @Lex; can chime in? 100K miles, and never cleaned the valves. Already have an air compressor, just would need the walnut media and the blaster tool.
__________________ 2010 Liquid Silver Mazdaspeed 3 Cobb AP v3, tuning by Stratified Automotive Controls, Autotech HPFP internals, one step colder NGK Iridium plugs, Cobb DP, Magnaflow 3" CBE, Corksport SRI/TIP, Corksport Race RMM 80A, Synapse Synchronic DV in push mode A+B, Treadstone TR6 FMIC, JBR FMIC piping kit, JBR Silicone recirc hose, JBR rear sway bar, Bilstein B14 coilovers, SPC adjustable rear camber arms, Stoptech SS brake lines and brake pads, 17x9" et+45mm Enkei Racing RPF1's, 245/40/17 Hankook RS3's, JBR 5mm hub/wheel spacers in front. Last edited by GregScuba; 06-11-2015 at 04:42 AM. | |
![]() | | #920 | ![]() |
__________________ GTX 2867/ JBR OG 3.5 WP/ Snail Ported IM/ ITV-22/ DAMOND RMM EBAY DP wCAT/ HKS BPV/ CP-E FP/ COBB EBCS/ PG FMIC W/ TR8 STOPTECH/ EBC YELLOW/ GOODRIDGE LINES/ MOTUL RBF 600 [443/409]SAE CORRECTED -------------245 DZ102 / 245 NT01 | |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/disi-compression-results-43395/ | ||||
| Random MS3 Chat Thread - Page 171 | This thread | Refback | 04-20-2013 05:45 PM | |
| Anyone measure compression on stock motor? - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum | Post #12 | Pingback | 03-12-2010 09:06 AM | |
| Compression test on built motor | SharkDiver | MazdaSpeed 3 - Engine, Transmission & Driveline | 5 | 10-22-2009 03:48 PM |
| Compression check on Laloosh's motor | gsrtype1 | MazdaSpeed 3 - Engine, Transmission & Driveline | 27 | 09-06-2009 07:25 PM |
| engine build with stock compression | Jessed87 | MazdaSpeed 3 - Engine, Transmission & Driveline | 8 | 06-12-2009 11:55 PM |
| Compression test done.. | SharkDiver | MazdaSpeed 3 - Engine, Transmission & Driveline | 3 | 03-25-2009 04:28 PM |
| engine compression? | bombdotcom | Mazdaspeed3/6 General Discussion | 12 | 09-23-2008 04:06 AM |
