Like Tree40Likes
 Old 06-11-2015, 09:33 AM   #921
Posts: 9,484   (View Stats)
Originally Posted by GregScuba View Post
That is the next thing I plan on doing. Don't want to take any chances. Plan on going with Stratified @Lex;. Def won't do any track days or anything too crazy until then. Been trying to keep the revs below ~5K in the mean time.
Edit: Just wonder if I should clean the intake valves before getting a tune? Perhaps @Lex; can chime in? 100K miles, and never cleaned the valves. Already have an air compressor, just would need the walnut media and the blaster tool.
your intake valves will be HORRIBLE, just a common issue with any DISI, Mazda, BMW, Audi, VW, etc.
Yes clean them before investing in a tune if feasible. It will run like a new car.
I personally bought Walnut media and a blaster on Amazon, made a plate out of 1x4 MDF using the IM gasket as a template, put two holes in each runner location (one for the blaster another for vacuum) and went to work with each cylinder at TDC. Just like the dealerships clean them.
BackRoads (06-11-2015)
 Old 06-11-2015, 09:36 AM   #922
BackRoads's Avatar
Posts: 575   (View Stats)
BackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the world
Interested - about how much did the parts/media cost you, and how much time to do it?
I had this done at 100k miles, with great results. Been thinking of it again as I am at 206k.
2007 Sunlight Silver MazdaSpeed3 Sport | BNR S3v2 | Autotech Internals | Cobb TIH | 3BAR MAP Sensor | Denso itv-22's | MSCAI | ETS 3.5" TMIC | Synchronic DV | Stratified EBCS | Guardian Angel | UR Test Pipe | Cobb AP | Koni Yellows | JBR RMM | CORN YEAH! | 265,000m | Tuned by STRATIFIED!!!
To install: CPE SafeSeals
2012 Velocity Red MazdaSpeed3 w/Tech | Autotech Internals | Sure Aeros V2 | 98,000m
Last edited by BackRoads; 06-11-2015 at 09:36 AM. Reason: MSF Database - Automerged Doublepost
BackRoads is offline   Reply With Quote
 Old 06-11-2015, 09:47 AM   #923
let me amazon that for you
media..I got a larger bag but this lil guy would be plenty for a number of valve cleaning jobs.
Amazon.com : Frankford Arsenal 881538 Arsenal Brass Cleaning Walnut Media : Hunting Cleaning And Maintenance Products : Sports & OutdoorsAmazon.com : Frankford Arsenal 881538 Arsenal Brass Cleaning Walnut Media : Hunting Cleaning And Maintenance Products : Sports & Outdoors
blaster
Amazon.com: Campbell Hausfeld AT1226 Sandblasting Kit: Home ImprovementAmazon.com: Campbell Hausfeld AT1226 Sandblasting Kit: Home Improvement
intake removal/install is the most time consuming part maybe 2 hours total. blasting only took about 30 minutes. So +- 2.5 hours.
BackRoads (06-11-2015), Ferdball (06-14-2015), FreshAsWoodie (06-15-2015)
 Old 06-11-2015, 09:55 AM   #924
BackRoads's Avatar
Thanks - not bad. If A person was pulling the IM anyway, seems smart.
 Old 06-21-2015, 08:40 PM   #925
jpopcorn's Avatar
Posts: 25   (View Stats)
jpopcorn is a jewel in the roughjpopcorn is a jewel in the roughjpopcorn is a jewel in the rough
Well this wasn't exactly how I was hoping my first post would play out but here we are. I've been navigating around the forums just taking all the info in since buying the car last Novemberish, investing in an ap shortly after. Six months later I'm here with compression and leak down numbers..
Cyl 1: 175, 11% leakage
Cyl 2: 176, 6% leakage
Cyl 3: 155, 27% leakage past the rings
Cyl 4: 175, 7% leakage
Dont worry, I'll see myself over to the build diaries..
jpopcorn is offline   Reply With Quote
The Following 2 Users Say Thank You to jpopcorn For This Useful Post:
Hammology (06-22-2015), JgamB (06-21-2015)
 Old 06-21-2015, 11:01 PM   #926
JgamB's Avatar
Posts: 2,566   (View Stats)
At least you're paying attention. Odds are good you can recoup with minimal expense since you've caught it early, just plan for .020 over with the parts and research reputable machine shops near you.
The Following User Says Thank You to JgamB For This Useful Post:
jpopcorn (06-22-2015)
 Old 06-22-2015, 09:53 AM   #927
jpopcorn's Avatar
Do most end up needing to bore? I've been hoping to get away with just honing as I'm looking to stay away from forged pistons with what I'm looking to get out of the car reliability and power wise.
From what I've read it seems sticking with the stock rods is a bad idea though.
 Old 06-22-2015, 11:56 AM   #928
mituc's Avatar
Posts: 3,504   (View Stats)
Groans: 111
At these compression values I'm 100% sure you will not have to bore. However, expect to have cracked ring lands so do not buy just rings, get pistons and eventually (why not?!) rods as well.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
The Following 2 Users Say Thank You to mituc For This Useful Post:
JgamB (06-22-2015), jpopcorn (06-23-2015)
 Old 06-22-2015, 09:54 PM   #929
JgamB's Avatar
Your rods aren't what got you into this situation - it's your ring lands (most likely, possibly a filthy valve not fully closing, didn't read the rest of this thread), and if you want more substantial ring lands, you will want forged pistons as well.
Your best bet if you want to get by on the cheap is a buy a reman from Edge and sell your long block. It's worth (a lot) more to the used market than it would be for the $450 core refund. They have a $50 option for a 3 year unlimited warranty, a no brainer if you go that route.
 Old 07-05-2015, 05:15 PM   #930
Police
InkedInspector's Avatar
InkedInspector is the leader of the worldInkedInspector is the leader of the worldInkedInspector is the leader of the worldInkedInspector is the leader of the worldInkedInspector is the leader of the worldInkedInspector is the leader of the worldInkedInspector is the leader of the worldInkedInspector is the leader of the worldInkedInspector is the leader of the worldInkedInspector is the leader of the worldInkedInspector is the leader of the world
Groans: 312
Groaned at 43 Times in 19 Posts
2013-56k miles
SRI (Stock size), Catless DP, CPe Triton CBE, Autotechs, Freek OTS+, Original Spark Plugs, Roughly 90% of miles highway. T6 for it's lifetime.
Cylinder 1- 180
Cylinder 2- 175
Cylinder 3- 180
Cylinder 4- 175
I started losing oil a few weeks back, seems the K04 is not liking the catless DP. CPe TMIC, JBR 3" Intake, BNR S3, and CPe Manifold are on the way. Gonna let Mr. Hypnotic do a full tune on it.
JgamB likes this.
InkedInspector is offline   Reply With Quote
 Old 07-17-2015, 07:21 AM   #931
GregScuba's Avatar
Posts: 92   (View Stats)
GregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the world
Originally Posted by Hammology View Post
If you wanna keep that compression the way it is, I suggest you get a real tune.
Cleaned the intake valves since my last compression test, and boy what a difference it made in performance and drivability!
I am currently on the first version of my pro tune with Stratified Automotive Controls, so decided to do another compression test today:
195
198
198
196
Once again, I'm thrilled with the results. All the while I was running the Cobb OTS map I never really saw any KR over 2, and trust me, I watched that shit like a hawk. There was only one exception when I got a bad tank of gas from a mom and pop station while traveling in the mountains, and my KR went up to 5.3, so I just took it easy until the next fill up, and sure enough, it went right back down.
Now that I'm running the first iteration of my stratified map, my KR has been below 0.8 so far. I know the tunes start out fairly conservative initially, but that is still pretty impressive, none the less. Kudos to Stan, @Lex; and everyone else at Stratified!
2010 Liquid Silver Mazdaspeed 3
Cobb AP v3, tuning by Stratified Automotive Controls, Autotech HPFP internals, one step colder NGK Iridium plugs, Cobb DP, Magnaflow 3" CBE, Corksport SRI/TIP, Corksport Race RMM 80A, Synapse Synchronic DV in push mode A+B, Treadstone TR6 FMIC, JBR FMIC piping kit, JBR Silicone recirc hose, JBR rear sway bar, Bilstein B14 coilovers, SPC adjustable rear camber arms, Stoptech SS brake lines and brake pads, 17x9" et+45mm Enkei Racing RPF1's, 245/40/17 Hankook RS3's, JBR 5mm hub/wheel spacers in front.
GregScuba is offline   Reply With Quote
The Following 2 Users Say Thank You to GregScuba For This Useful Post:
Hammology (07-17-2015), theurgy (07-17-2015)
 Old 07-18-2015, 04:07 AM   #932
HaXiR's Avatar
Posts: 303   (View Stats)
HaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud of
Within the past month or so I finally got around to upgrading my smoking K04 to a BNR s3. Prior to install we cleaned the intake valves and they were dirty as hell. Did the injector seals and all that jazz. Got it all back together and before I really started tuning I wanted to get a comp test since I have 87k miles on the car. Did the test and my numbers were pretty shit. 170,150,150,170. So I took it in for a Leakdown yesterday. His numbers were 160,150,135,160 with leaks coming from the intake valves. Said I need to have my head machines and reseat the valves. But after talking with some people here it's possible my valves are still dirty where they actually seat since you can only really clean when the valves are down. I'm just trying to figure out what to do exactly... On one hand is to start saving for rods and pistons and machine work. I have people here that will help me build, but the machine process and parts is $ I just don't have at the moment. That damn cylinder 3 is such a pain. Looking into what I can find about porting/machining the stock mani to try to avoid this issue in the future as well as meth. But that aquamist kit is looking pretty infeasible at the moment if I have to sell my first born to build this motor. But I guess the good news was it wasn't showing leak at the ringlands?
Edit: How can one safely clean intake valves while open to clean where they actually seat and from a seal?
2008 Ms3 Black Mica R.I.P. March 2008 - March 2016. MODS: HTP 3" intake, CX Racing FMIC with TR8 core, BNR S3, AP V3, Kozmic EGR delete, Matt Damond OCC, JBR short shift plate with bushings, HIDS, CP-E injector seals, TIG, 1 step colder plugs, Grimspeed EBCS, CS RMM, JBR passenger MM, motor craft tranny fluid, Autotech Internals
Current:
08.5 Ms3 cwp GT: Built block (sp63 4032 pistons, eagle h beams, CA625+ rod bolts/head studs, arp main studs, key'd crank, supertech 55lb valve springs, bsd delete, Block/pistons/rings/bearings WPC treated), HTP 4" intake, bnr S5 turbo (when it comes out), HTP hotside under route pipes, TR8 core, custom made cold pipes, ST intake mani, TIG, CP-E downpipe, CNT CBE, autotech hpfp, AP V3, grimmspeed ebcs, GA v3, TWM short shift assembly, JBR short shift plate, HFS-4 Meth kit, HTP front mount custom meth tank, damond motor mount trilogy, damond 3 port pcv plate, dual damond catch cans (one vented), step colder plugs, corksport injector seals, GFB bov, 51r battery, Bilstein B8 shocks, OZ ultralegga rims, custom oem clutch with Kevlar, Gen 2 trans.
2003 Mazdaspeed protégé (spicy orange); pope E manifold and DP, injen cai, PoS fmic kit, Twisted motion gt2871 turbo, aem fic-6.
HaXiR is offline   Reply With Quote
 Old 07-19-2015, 10:37 AM   #933
mituc's Avatar
Groans: 111
Cylinder #3 being lower is quite consistent with what we've seen so far in these engines. The heat either indicates more wear in the rings on #2 and #3 or even leads to ring lands cracking for those two (usually starting with #3 ).
So I'd say, if the car runs good currently leave it as is and don't do any more work to it as you can invite more problems in the game. Save for pistons and rods and have the head cleaned up when you pull the engine for the rebuild.
 Old 07-19-2015, 11:12 AM   #934
csmaan12's Avatar
Posts: 325   (View Stats)
csmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond repute
70k on the clock mine tested out to be 180, 180, 178, 180. Funny enough it's #3 that's misfiring as well. Only problem is I can't remember if the 178 was on 2 or 3. Numbers are dry, didn't test wet.
Might have the valves cleaned at the dealer once I salve up some cash, no time to do it myself.
2011 Mazdaspeed3 Mod List:
FREEKTUNED
ETS TMIC
Autotech HPFP Internals
CS Stage II SRI + TIP
Tial QR
UR Catback
UR Catless Test Pipe
Damond RMM
Damond SSP
csmaan12 is offline   Reply With Quote
 Old 07-20-2015, 06:09 AM   #935
jpopcorn's Avatar
Now that I've finally got around to tearing the motor down after seeing 27% leakage past cylinder 3, I don't notice anything too dramatic. I was expecting a cracked ringland but it doesn't look to be the case (at least without a closer look).
Is that kind of leakage possible with just bad rings? Being my first go at a rebuild I'm not sure if there's anything I'd be able to see that would be a telltale sign for the bad compression.
 Old 07-20-2015, 07:18 AM   #936
Eth Fiend
phate's Avatar
Posts: 6,930   (View Stats)
Was the car running funny at all? It could just be a worn engine if you don't find anything suspect. Maybe check ring end gap if you feel like it, check if the cylinder is out of round.
-06 MS6
-Corn fed 07 MS3 - Sold
jpopcorn (07-20-2015)
 Old 07-20-2015, 07:42 AM   #937
jpopcorn's Avatar
Everything was running fine, I wouldn't have even known there was a problem if I didn't do a compression and leakdown test. I did start getting some knock at higher rpms shortly after, though it could be unrelated as I didn't see any knock prior to running the tests. I guess I just figured with the usual cylinder 3 issues I'd see something obvious.
 Old 07-20-2015, 07:51 AM   #938
Eth Fiend
phate's Avatar
Was it all leaking down through the crank case? Could injector seals have been a cause? Even at 30%, I probably wouldn't rebuild unless there were other problems. Did it burn oil?
-06 MS6
 Old 07-20-2015, 09:03 AM   #939
jpopcorn's Avatar
Yeah there was a swift breeze coming from the oil cap haha. Injector seals looked fine but I'm replacing them regardless so we shall see. It didn't really burn oil, just needed topped off once between changes. As far as it really needing to be rebuilt I'm not sure, but it needed the timing components, valve cleaning, and downpipe so pulling the head was convenient enough with the extra pistons and rods I have.
 Old 08-31-2015, 06:52 PM   #940
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
HawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the world
Addin' to the madness finally.
Mods are in Sig.
Cyl 1: 180
Cyl 2: 170
Cyl 3: 180
Cyl 4: 185
Ran immediately after getting the vehicle up to temperature. I'm thinking about doing a leakdown.
Silver 2007 Speed3 GT
Xona Rotor 6156, Port Injection w/ E85...Bunch of other stuff. I make some power.
Titanium Grey Mazdaspeed6 GTX3071, DD
HawkeyeGeoff is offline   Reply With Quote
 Old 09-01-2015, 08:15 PM   #941
Did another tonight after an oil change (and another warm up)
Got:
Cyl 1: 182
Cyl 2: 175/178 (2 tries)
Cyl 3: 182
Cyl 4: 185
I did a couple extra cranks on all of these this time. Interesting.
 Old 09-01-2015, 09:20 PM   #942
BackRoads's Avatar
You are golden. How many miles on your engine?
asho225 likes this.
 Old 09-02-2015, 06:31 AM   #943
There's about 40-45k on the engine build. 60k on the whole car.
Edit; I want your bumper, in and around my mouth. lol done jacked mine up on the track.
AND Also going to do a leakdown once I get it from @maisonvi; I'll report back.
 Old 09-02-2015, 06:37 AM   #944
BackRoads's Avatar
Whaaaa??
 Old 09-02-2015, 06:39 AM   #945
Whaaaa??
You saying WHAAA to the length of the build or that I want to lick your non-jacked up bumper?
 Old 09-16-2015, 03:11 PM   #946
Design's Avatar
Posts: 1,885   (View Stats)
Groaned at 9 Times in 5 Posts
1 month ago:
1: 155 / 10%
2: 155 / 10%
3: 150 / 10%
4: 155 / 10%
Compression numbers are obviously low due to not engaging the gas pedal during startup.
09 CWP MS3 GT
Ownership & Build Thread
Design is offline   Reply With Quote
 Old 09-23-2015, 05:41 PM   #947
[R]usty's Avatar
Posts: 2,198   (View Stats)
[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world
Groans: 79
Tested this morning. 60500 miles. Engine was completely cold.
1 - 181
2 - 180
3 - 180
4 - 180
Crazy, I've only driven 3000 miles in the last 5 months.
2010 Mazdaspeed3 w/tech
Cobb AP V3JBR Tru 3" Wide PathJBR Boost Tubes & BPV HoseCobb XLE BPVCP-E TMIC ║ UR Racepipe ║ Magnaflow CBEAutoTech InternalsGrimmSpeed EBCS ║ JBR RSBSPC Camber ArmsKW V3 CoiloversJBR IM+TB TIGs & TB BypassJBR SSPE - Focus RMMStopTech Slotted Rotors and EBC Yellow Stuff PadsTechna-Fit SS Brake Lines
[R]usty is offline   Reply With Quote
 Old 09-23-2015, 05:43 PM   #948
Design's Avatar
One update on mine - still getting oil consumption despite strong numbers. We're pretty sure it's worn oil control rings.
09 CWP MS3 GT
 Old 09-23-2015, 06:35 PM   #949
sho
sho's Avatar
Posts: 537   (View Stats)
sho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the world
Stock motor at 145k miles. I retired it at 161.5k and it had seen 22psi from a 5858 from 124k to the day it was pulled out. (still ran great)
Built motor at 3k miles
2007 ms3 GT, sunlight silver
Manley platinum series 88mm pistons, Manley h beam rods, L19 head studs, custom cometic mlx head gasket, massive speed balance shaft delete, massive speed oil pan baffle, OEM Rod and Main bearings, vband pte 5862 .82AR journal bearing turbo, Cp-e exhaust manifold, custom 3" vband downpipe, 3" cnt Catback, pw46 ewg, tr1235 fmic, tial Q BOV on hotside pipe, 3" cold side piping, JMF V2 w/ PI, CS big TB, PERM pcv plate with jbr sealed can and ebay VTA can, custom VC vent with VTA can, SP63 gen 1 vc breather cap, Cp-e injector seals, mazdaspeed accessory coilovers, Hotchkis 32mm fsb and rsb, Damond Motorsports RMM, TMM & PMM.
FD wheels
E48 mix
Tuned by Realgib3
Purchased 8/3/12 - 25,314 miles on chassis and motor
6/21/18- 234,700 miles on chassis, 73,200 on built motor
Last edited by sho; 09-23-2015 at 09:02 PM. Reason: MSF Database - Automerged Doublepost
sho is offline   Reply With Quote
The Following 2 Users Say Thank You to sho For This Useful Post:
HawkeyeGeoff (09-23-2015), snailD (09-25-2015)
 Old 10-06-2015, 08:57 AM   #950
riflex's Avatar
Posts: 53   (View Stats)
riflex is a splendid one to beholdriflex is a splendid one to beholdriflex is a splendid one to beholdriflex is a splendid one to beholdriflex is a splendid one to beholdriflex is a splendid one to behold
Stock motor, simple bolt ons with hpfp internals and Catless dp. 75k currently on motor. Had dp and internals on car for about 5k miles. Did my compression test yesterday while car was still warm. Pulled necessary fuses and all Spark plugs. Held down Clutch and gas while cranking.
1 - 188
2 - 190
3 - 189
4 - 188
Sent from my SAMSUNG-SM-G900A using Tapatalk
riflex is offline   Reply With Quote
 Old 10-06-2015, 12:10 PM   #951
SNOW_QN's Avatar
Posts: 383   (View Stats)
SNOW_QN is the leader of the worldSNOW_QN is the leader of the worldSNOW_QN is the leader of the worldSNOW_QN is the leader of the worldSNOW_QN is the leader of the worldSNOW_QN is the leader of the worldSNOW_QN is the leader of the worldSNOW_QN is the leader of the worldSNOW_QN is the leader of the worldSNOW_QN is the leader of the worldSNOW_QN is the leader of the world
Stock motor and turbo @ 95k. Hpfp internals, gutted cats, Cai and tip,
Dry: (130) (120) (110) (130)
Wet: (150) (150) (140) (140)
Leak down results
Cylinder 1 = 28%
Cylinder 2 = 33%
Cylinder 3 = 36%
Cylinder 4 = 32%
Sent from my SCH-I545 using Tapatalk
06 MS6: Stocked out and trying to find her a new family.
SNOW_QN is offline   Reply With Quote
 Old 10-06-2015, 12:35 PM   #952
blackms3_71's Avatar
Posts: 2,250   (View Stats)
blackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the world
Leak down results
Cylinder 1 = 28%
Cylinder 2 = 33%
Cylinder 3 = 36%
Cylinder 4 = 32%
Damn
Just did mine it april and had
1-180
2-180
3-180
4-180
Car has 77k with all bolt ons and meth
SNOW_QN likes this.
COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned
Last edited by blackms3_71; 10-06-2015 at 12:35 PM. Reason: MSF Database - Automerged Doublepost
blackms3_71 is offline   Reply With Quote
 Old 10-07-2015, 10:32 AM   #953
SNOW_QN's Avatar
I'm sure the last guy that owned this car raped the shit out of it. It's all good though.... "We will rebuild".
 Old 10-09-2015, 03:20 AM   #954
HaXiR's Avatar
Leak down results
Cylinder 1 = 28%
Cylinder 2 = 33%
Cylinder 3 = 36%
Cylinder 4 = 32%
Is that motor leak or valve leak?
Current:
 Old 10-09-2015, 04:21 AM   #955
SNOW_QN's Avatar
It was leaking into the crank case.
 Old 10-25-2015, 03:48 PM   #956
lolwrx's Avatar
Posts: 217   (View Stats)
lolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the world
2010 with 81k mods in sig. Stage 2 since 65k and bnr since 75k. First time testing.
Looks pretty consistent around 190 in every cylinder. Performed the test at operating temp.
BNR s3, Freek 3.5", Autotech internals, depo racing catless dp, TR6, JBR FMIC piping, 80a rmm, OCC, TIGs, EGR delete and Coolant bypass
FREEKTUNED
lolwrx is offline   Reply With Quote
The Following User Says Thank You to lolwrx For This Useful Post:
BackRoads (10-25-2015)
 Old 12-02-2015, 06:28 AM   #957
5doorsoffury's Avatar
Posts: 1,070   (View Stats)
Groans: 74
Sitting at 46 k drivin hard highway miles. Tuned at 9k on e85.
196,197,200,200
MECP
2012 BM
Rfinkle tune in progress
 Old 01-03-2016, 04:48 PM   #958
everton99's Avatar
Posts: 1,044   (View Stats)
everton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the world
Groaned at 8 Times in 7 Posts
Did this today.
GTX2871, CPE TMIC, 3.5 intake, UR catless TBE, and EGR Delete. I'm switching to an S4 within the next month.
everton99 is offline   Reply With Quote
 Old 01-08-2016, 09:29 AM   #959
Rcimp's Avatar
Posts: 129   (View Stats)
Rcimp has a reputation beyond reputeRcimp has a reputation beyond reputeRcimp has a reputation beyond reputeRcimp has a reputation beyond reputeRcimp has a reputation beyond reputeRcimp has a reputation beyond reputeRcimp has a reputation beyond reputeRcimp has a reputation beyond reputeRcimp has a reputation beyond reputeRcimp has a reputation beyond reputeRcimp has a reputation beyond repute
With 157K miles
#1 = 180
#2 = 150
#3 = 125
#4 = 180
07 Cosmic Blue Speed 3,
BNR S2 Turbo
Cobb AP
BEGI SRI
CNT Catted Downpipe
Forge BOV
CorkSport Turbo Inlet Pipe / Silicone BPH / Boost Tubes / Dry Flow Air Filter
Fidanza Aluminum Flywheel
CPE Xflex Stage 2 Driver Side MM
CPE Xflex Stafge 2 Rear MM
AWR Passenger Mount 88 Duro
Power Slot Rotors
Rcimp is offline   Reply With Quote
 Old 01-15-2016, 03:57 PM   #960
brandon96's Avatar
Posts: 1   (View Stats)
brandon96 is an unknown quantity at this point
2010 speed3 stock at 85k km..
Dry
cyl 1 - 170
cyl 2 - 150
cyl 3 - 160
cy 4 - 190
wet
cyl 1 - 185
cyl 2 - 180
cyl 3 - 190
cy 4 - 190
brandon96 is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/disi-compression-results-43395/
Random MS3 Chat Thread - Page 171 This thread Refback 04-20-2013 05:45 PM
Anyone measure compression on stock motor? - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum Post #12 Pingback 03-12-2010 09:06 AM
Compression test on built motor SharkDiver MazdaSpeed 3 - Engine, Transmission & Driveline 5 10-22-2009 03:48 PM
Compression check on Laloosh's motor gsrtype1 MazdaSpeed 3 - Engine, Transmission & Driveline 27 09-06-2009 07:25 PM
engine build with stock compression Jessed87 MazdaSpeed 3 - Engine, Transmission & Driveline 8 06-12-2009 11:55 PM
Compression test done.. SharkDiver MazdaSpeed 3 - Engine, Transmission & Driveline 3 03-25-2009 04:28 PM
engine compression? bombdotcom Mazdaspeed3/6 General Discussion 12 09-23-2008 04:06 AM
Page generated in 0.64833 seconds with 42 queries
