Like Tree37Likes
 Old 01-21-2016, 11:37 PM   #961
NRBt's Avatar
Posts: 29   (View Stats)
NRBt is a splendid one to beholdNRBt is a splendid one to beholdNRBt is a splendid one to beholdNRBt is a splendid one to beholdNRBt is a splendid one to beholdNRBt is a splendid one to beholdNRBt is a splendid one to behold
2008 Mazda 3 MPS
The only power mod: Cobb SF + Cobb TIH + AP selftuned
134000km
~180 all across
195600km
PCV valve replaced, EGR cleaned. Manual intake valves cleaning with Wynn's stuff and cylinders/pistons/rings de-coking procedures for 6 hours. Different compression tester.
Compression before/after:
1 - 145 / 188
2 - 159 / 145
3 - 188 / 188
4 - 188 / 188
Leakdown test before/after:
1 - 75% / 7%(!)
2 - 65% / 70%
3 - 15% / 15%
4 - 17% / 14%
NRBt is offline   Reply With Quote
 Old 09-16-2016, 12:19 PM   #962
RoadTripSaloonGT's Avatar
Posts: 2   (View Stats)
RoadTripSaloonGT is an unknown quantity at this point
2008.5 MS3 GT
102,XXXmiles
No bolt ons (only mods; suspension, rmm.)
Dry: 175/174/174/170
Wet: 179/181/179/180
I was a happy, happy man today. Having the VVT and timing chain serviced, then tuning to head for 200K. Would love to keep this car for the long-haul. Always regretted selling my '03 SVT Focus, and I won't be making that same mistake again particularly since my motor seems solid.
Also, hello. I think this might be my first post.
BackRoads likes this.
RoadTripSaloonGT is offline   Reply With Quote
 Old 09-16-2016, 12:21 PM   #963
BackRoads's Avatar
Posts: 553   (View Stats)
BackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the world
Welcome - and congrats on having such a happy car!
2007 Sunlight Silver MazdaSpeed3 Sport | BNR S3v2 | Autotech Internals | Cobb TIH | 3BAR MAP Sensor | Denso itv-22's | MSCAI | ETS 3.5" TMIC | Synchronic DV | Stratified EBCS | Guardian Angel | UR Test Pipe | Cobb AP | Koni Yellows | JBR RMM | CORN YEAH! | 258,000m | Tuned by STRATIFIED!!!
To install: CPE SafeSeals
2012 Velocity Red MazdaSpeed3 w/Tech | Autotech Internals | Sure Aeros V2 | 92,000m
BackRoads is offline   Reply With Quote
 Old 03-02-2017, 11:45 AM   #964
[R]usty's Avatar
Posts: 2,196   (View Stats)
[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world
Groans: 78
Just hit 72,000 miles
1 - 180
2 - 180
3 - 180
4 - 180
She just won't quit.
BackRoads and himurax13 like this.
2010 Mazdaspeed3 w/tech
Cobb AP V3JBR Tru 3" Wide PathJBR Boost Tubes & BPV HoseCobb XLE BPVCP-E TMIC ║ UR Racepipe ║ Magnaflow CBEAutoTech InternalsGrimmSpeed EBCS ║ JBR RSBSPC Camber ArmsKW V3 CoiloversJBR IM+TB TIGs & TB BypassJBR SSPE - Focus RMMStopTech Slotted Rotors and EBC Yellow Stuff PadsTechna-Fit SS Brake Lines
[R]usty is offline   Reply With Quote
 Old 03-02-2017, 10:10 PM   #965
mituc's Avatar
Posts: 3,332   (View Stats)
Good! What oil are you using and how often the changes?
2008 Cosmic Blue Mazda 3MPS
Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PSS 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend ENduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit
JBR Tru-3" + CS CAI Box, SU TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071, CS 3.5BAR, Guardian Angel, CoolingMist WMI
StratiVersaTuned FTW
 Old 03-03-2017, 12:37 AM   #966
[R]usty's Avatar
Groans: 78
Since day one Mobil 1 10w30 with OEM Filters (sometimes Napa Gold). I change every 3,000 miles.
The Following User Says Thank You to [R]usty For This Useful Post:
mituc (03-03-2017)
 Old 03-20-2017, 10:30 AM   #967
Thor Hammer's Avatar
Posts: 1,232   (View Stats)
Groans: 84
2007 MS6 with 111K miles. Engine up to temp/ dry test.
My fairly new compression tester read:
Cyl 1: 180
Cyl 2: 180
Cyl 3: 180
Cyl 4: 180
Autozone rented shoddy compression tester read:
Cyl 1: 165
Cyl 2: 165
Cyl 3: 165
Cyl 4: 165
What would you believe? The autozone comp gauge or mine? Either way, I'm stoked.
Waiting for Install: Damond OCC/ CS Injector Seals/ WMI/
 Old 03-20-2017, 10:40 AM   #968
everton99's Avatar
Posts: 1,036   (View Stats)
everton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the worldeverton99 is the leader of the world
Groaned at 8 Times in 7 Posts
Yours.
everton99 is offline   Reply With Quote
The Following User Says Thank You to everton99 For This Useful Post:
Thor Hammer (03-20-2017)
 Old 03-20-2017, 11:41 AM   #969
mituc's Avatar
Even if you believe both and compute an average, 172PSI across the board is an awesome number for this mileage.
So the usual question: what oil, how often?
 Old 03-20-2017, 12:51 PM   #970
Groans: 84
Got the car July 2015 at 80K miles from original owner. Older family man that drove it for work and took great care of it. Clearly. I've never launched, drag raced (ok once against a cobra mustang F body and won) or beat on it.
I took it home and put in Rotella T6 5W-30. Changed with same every 3K-4K miles.
Saturday when I did the test I put in Penzoil Platinum Euro 5W-40.
My turbo seals are leaking into the intake and exhaust at the moment. Just bought a 70K mile K04 to replace it with. Can't afford the BNR S4/V2 with supporting mods right now.
 Old 08-01-2017, 07:49 AM   #971
ddt23's Avatar
Posts: 24   (View Stats)
ddt23 is a glorious beacon of lightddt23 is a glorious beacon of lightddt23 is a glorious beacon of lightddt23 is a glorious beacon of lightddt23 is a glorious beacon of lightddt23 is a glorious beacon of light
2006 MS6 with 96k, 27k fully bolted with an S3. Engine wasn't quite to temp and did a dry test.
Cyl 1: 148
Cyl 2: 148
Cyl 3: 148
Cyl 4: 148
ddt23 is offline   Reply With Quote
 Old 10-15-2017, 07:14 PM   #972
Rotareez's Avatar
Posts: 9   (View Stats)
Rotareez will become famous soon enough
06 MS6 62K on motor. Stock, besides TurboSmart BOV.
170 - 0 -175 - 185
Currently troubleshooting and praying for a burnt valve
Rotareez is offline   Reply With Quote
 Old 10-15-2017, 07:56 PM   #973
Djohns's Avatar
Posts: 3,751   (View Stats)
Groaned at 7 Times in 6 Posts
2010, 60k miles, full bolt ones, big turbo and meth. 195-195-195-195
2010 black mica speed3
Soon:built motor
 Old 10-16-2017, 08:12 AM   #974
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
190 across all 4 with all of the mods in my signature. E85 50/50 tuned by RichTune since 7k miles and E85 all I have ever run.
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
 Old 11-25-2017, 03:38 PM   #975
Shadley's Avatar
Posts: 14   (View Stats)
Shadley will become famous soon enough
155 for all four, warm + dry. No mods.
138k miles gen1 MS3. Autozone compression tester. Seems a bit low, but I'm wondering if that could be the gauge???
Shadley is offline   Reply With Quote
 Old 11-26-2017, 02:34 AM   #976
mituc's Avatar
Could be the gauge, altitude (what altitude are you at?) or the compression itself. The consistency is what matters in this case.
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/disi-compression-results-43395/
Random MS3 Chat Thread - Page 171 This thread Refback 04-20-2013 05:45 PM
Anyone measure compression on stock motor? - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum Post #12 Pingback 03-12-2010 09:06 AM
Compression test on built motor SharkDiver MazdaSpeed 3 - Engine, Transmission & Driveline 5 10-22-2009 03:48 PM
Compression check on Laloosh's motor gsrtype1 MazdaSpeed 3 - Engine, Transmission & Driveline 27 09-06-2009 07:25 PM
engine build with stock compression Jessed87 MazdaSpeed 3 - Engine, Transmission & Driveline 8 06-12-2009 11:55 PM
Compression test done.. SharkDiver MazdaSpeed 3 - Engine, Transmission & Driveline 3 03-25-2009 04:28 PM
engine compression? bombdotcom Mazdaspeed3/6 General Discussion 12 09-23-2008 04:06 AM
Page generated in 0.36658 seconds with 32 queries
