Like Tree37Likes
 Old 04-13-2010, 08:10 AM   #81
cpolly69's Avatar
Posts: 2,116   (View Stats)
Groans: 27
I am
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
 Old 04-13-2010, 08:11 AM   #82
shpankey's Avatar
Posts: 496   (View Stats)
So if I'm understanding you guys right, I should be smoking pretty bad? I mean, if my rings are so worn or whatever that I can only produce 130 psi in each cylinder, would that mean a lot of oil blowby and therefore smoking?
Which if that's the case, then I'm really stumped as I have VERY minimal smoking only at idle and it's actually pretty hard to see. Most times I can't see it, but can smell it some. The thing is though, even that smoke didn't start until I installed the OCC just recently. Other than that I have never smoked and even with that, it's so light you can't really see it most of the time.
Also if I'm understanding you right, I should be consuming oil? That is something I can say definitively that doesn't happen. I do not use a single drop of oil! I also use very high quality synthetics. Currently have a fill of Redline 10w40 synthetic in it.
Knowing all of this, anyone have any ideas what might be causing me the super low 130psi [150 wet] compression on all cylinders?
09 Speed 3 GT
 Old 04-13-2010, 08:11 AM   #83
aaronc7's Avatar
Posts: 8,038   (View Stats)
Groans: 370
I just am still surprised as to why my cylinder 3 was the highest compression- if I labeled cylinders 1/4 the way other way around, then 3 would be my lowest... just double checking.
 Old 04-13-2010, 10:23 AM   #84
Posts: 12,649   (View Stats)
shpankey, yours is a very odd case. Do you have a catless exhaust? Do you have oil residue in the valvacover vent going to your intake?
 Old 04-13-2010, 10:36 AM   #85
shpankey's Avatar
I did put a test pipe in, which removed one cat. But that's as far as I've changed the exhaust. No other changes to it other than that.
I'll check again but I haven't noticed any oil there Lex.
09 Speed 3 GT
 Old 04-13-2010, 10:51 AM   #86
I have an 08.5 and I've had a test pipe for .... well ever ... and it has never smoked with 16k miles on the clock now.
Also never had any oil in the intake but the motor's still young. Only bolt-on I don't have is the DP and I plan on keeping it that way on the stock turbo.
djuosnteisn (04-13-2010)
 Old 04-13-2010, 12:38 PM   #87
cpolly69's Avatar
Groans: 27
meh get a catted full dp - you will be ok - i went 2 times around and have this now - i'm happy with it and no smoke.... and that's still on the same turbo that was smoking before from the extreme pcv imbalance
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
 Old 04-13-2010, 12:45 PM   #88
shpankey's Avatar
My car doesn't always smoke and when it does it's barely. I have to bend down to the pipe and get real close to tell if it even is. But I can smell it sometimes when in the garage. But it didn't even start smoking like that until I put on the OCC. I've had the test pipe on since the beginning and it never caused any smoke issues.
p.s. I meant to mention this earlier. But my oil dipstick smells like gas BAD BAD. Like I'm sniffing straight fuel. I just put this oil in last weekend. Redline 10w40. Should it smell like fuel this bad already? Maybe this has something to do with my cars issues.
09 Speed 3 GT
 Old 04-13-2010, 01:19 PM   #89
cpolly69's Avatar
Groans: 27
unfortunately you are describing compression leaking from the combustion chamber into the other areas of the engine that hold oil - when compression gases are getting mixed in with the oil the oil will change colors very quickly after a change & can smell like gas..
what strikes me as odd about your situation is the way that you have low numbers across the board - usually when it's fail it's just 1 that is much lower then the rest.... that's usually what happens when you have a head gasket leak...
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
 Old 04-13-2010, 11:38 PM   #90
awd>fwd
jwdp54's Avatar
Posts: 627   (View Stats)
jwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the world
Groans: 27
my post from 12/19/09
car at the time had 22k fully bolted, meth and stock ecu
Originally Posted by jwdp54 View Post
i got mine checked on sat. not sure what to think about the results..
1-145
2-145
3-140
4-145
i had mine done again today
car now has 27k, have been stock since 23k
145 145 140 145
MS3 310whp/320tq- SOLD finally(5/5/10)
evo 8-tuned to E85
jwdp54 is offline   Reply With Quote
 Old 04-14-2010, 06:53 AM   #91
shpankey's Avatar
Did you have them do a wet test too?
09 Speed 3 GT
 Old 04-14-2010, 03:14 PM   #92
awd>fwd
jwdp54's Avatar
Groans: 27
all i did was warm up the car then pulled the plugs and came up with the same numbers from 4 months ago. not sure what you mean by wet test.
evo 8-tuned to E85
 Old 04-15-2010, 09:29 AM   #93
shpankey's Avatar
After you do your test like you did normally. Add a teaspoon of some 30 weight oil into the plug hole and restest. If you are having leakdown issues, your number will go up a fair amount (for instance my normal test was 130, when I added the oil it was 150, which indicates a real problem).
09 Speed 3 GT
 Old 04-15-2010, 12:03 PM   #94
turboneil's Avatar
Posts: 248   (View Stats)
turboneil has a reputation beyond reputeturboneil has a reputation beyond reputeturboneil has a reputation beyond reputeturboneil has a reputation beyond reputeturboneil has a reputation beyond reputeturboneil has a reputation beyond reputeturboneil has a reputation beyond reputeturboneil has a reputation beyond reputeturboneil has a reputation beyond reputeturboneil has a reputation beyond reputeturboneil has a reputation beyond repute
Default Re: DISI Compression Results
just did mine and it was 185 for all 4.... and thats with 21k hard miles.
Sent from my Droid using Tapatalk
turboneil is offline   Reply With Quote
 Old 04-15-2010, 12:25 PM   #95
what kind of compression loss should one see from a leaking injector seal? just how much is missing?
 Old 04-15-2010, 01:17 PM   #96
Probably not much. Combustion pressure is MUCH higher than just compression. If the seal was leaking under just compression, you'd hear/feel it all the time with the motor on. Did you ever get around to testing your motor?
 Old 04-15-2010, 01:29 PM   #97
right before i went BT i tested 180's across the board. i thought my friends injector seals were done but his compression was low on all cylinders so i wasent sure exactly how that would be affected by injector seals. doesent the piston rise up above the injector or no?
 Old 04-15-2010, 02:19 PM   #98
Nope, piston is always below the injector.
 Old 04-15-2010, 08:52 PM   #99
aspiring turbo guru
08_ms3_gt's Avatar
Posts: 1,040   (View Stats)
did a compression test tonight;
2008.5 mazdaspeed3, 35,000 miles (literally)
cylinder pressures:
(pass side)
cyl 1 - 182psi
cyl 2 - 177psi
cyl 3 - 175psi
cyl 4 - 178psi
(driver side)
b/c i was doing the test alone, i'm actually pretty sure all of the pressures were around 180-185. the reading was declining before i even got from the inside of the car to the engine.
01.5 S4 6MT Stage 3
02 S6 6MT swap
93 S4 project
[sold - 90 Miata - summer/project car, turbo w/ goodies, DIYPNP, springs/struts, etc.]
[sold - 08 MS3 GT - intake/downpipe/tuning/fuel pump/TMIC/springs/struts/etc.]
The Following 2 Users Say Thank You to 08_ms3_gt For This Useful Post:
FreeFlyFreak (04-18-2010), Lex (04-17-2010)
 Old 04-17-2010, 09:17 PM   #100
Qwik6's Avatar
Posts: 695   (View Stats)
Qwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the world
Originally Posted by aaronc7 View Post
Pull all plugs... connect gauge to one cylinder. turn car on. push ghes and clutch all the way in...crank until the gauge is not rising anymore. you can have a friend check it or set it so you can see it from inside the car, then read the number, release the pressure in the gauge to reset it...and repeat.
My battery sucks so I hooked up jumper cables to another run that was idling while I did it. Or hook up a battery charger or something.
Thanks. trying this tomorrow
2006 MAZDASPEED6
FREEKTUNED @ 20PSI // COBB AP V3 // CPE TMIC // COBB SF // PG TIH // DENSO ITV22s // AUTOTECH INTERNALS // SURE TP // MAGNAFLOW CATBACK // JBR OCC // JBR IM SPACER // JBR PASSENGER & TRANNY MOUNT // SURE RMM // H&R SPRINGS // XXR 530 18X8.75 +35 // CAR LED TAILS // CPE REAR DIF MOUNT // TURBINE TECH FRONT DIF MOUNT // CPE TOW HOOK // 35% TINT // 3M DINOC WRAPPED ROOF // AUTOEXE CARBON FIBER BADGELESS GRILL
Qwik6 is offline   Reply With Quote
The Following User Says Thank You to Qwik6 For This Useful Post:
djuosnteisn (04-18-2010)
 Old 04-17-2010, 09:53 PM   #101
Originally Posted by 08_ms3_gt View Post
did a compression test tonight:
pass side
cyl 1 - 182psi
cyl 2 - 177psi
cyl 3 - 175psi
cyl 4 - 178psi
driver side
Post year of car and miles as well.
 Old 04-17-2010, 10:00 PM   #102
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,155   (View Stats)
Groans: 754
Post year of car.
Apparently Lex's detective skillz are not as sharp as I may have thought.......
Let me give a clue:
08_ms3_gt
Suspension:
 Old 04-17-2010, 10:03 PM   #103
Let me give a clue:
08_ms3_gt
Still no mileage and could be an 08.5 Mr. FreeFly
This was also a general comment as I think there's value in knowing the age of the motor when looking at compression.
 Old 04-17-2010, 10:09 PM   #104
aspiring turbo guru
08_ms3_gt's Avatar
thanks for noting that - i've updated it. see above.
01.5 S4 6MT Stage 3
02 S6 6MT swap
93 S4 project
 Old 04-21-2010, 06:58 AM   #105
DaleNixon's Avatar
Posts: 2,079   (View Stats)
Groans: 91
Sorry for the OT, but what is this COBB fix for the PCV? Are you talking about installing an OCC? Or did Cobb come up with something else?
 Old 04-21-2010, 07:06 AM   #106
8.5MS3's Avatar
Posts: 4,636   (View Stats)
Groans: 326
Originally Posted by Mikey95hd View Post
That's not good...zoom-zoom boom...
go away, he was sarcastic and is pushing almost 400 on the stock bottom end
 Old 04-21-2010, 07:25 AM   #107
You really have no idea what you're talking about. So just do everyone a favor and move on or stop posting before you do some reading.
I'll give you a hint. In DI applications, the gas does not come into contact with the back of the valves where the "deposits" form as is the case with your 1997 T-bird. If you hate this car so much, go back to driving your T-bird because right now you're really starting things on the wrong foot.
Try running Chevron gas, it has a cleaner techtron that will help get rid of deposits on the valves, my old 97 T-Bird, passes smog with 130,000 miles, don't run ARCO gas, that stuff is crap, and COSTCO gas is good too, love that sweet crude...
8.5MS3 (04-21-2010), djuosnteisn (04-21-2010), FreeFlyFreak (04-21-2010)
 Old 04-21-2010, 07:31 AM   #108
8.5MS3's Avatar
Groans: 326
^^wow^^
 Old 04-21-2010, 07:37 AM   #109
If you can't figure it out do some reading. It's one of the most documented issues here. Now GTFO of my thread.
Just seems the gas you use cause deposits, I love my MS3 just can't figure out why my 2007 smoked for 6,000 mile before they finally replaced my TURBO, isn't this a known problem on the first model year? A friend had his replaced at 18,000 miles, and now has 68,000 with a cam problem, he and a few others work for Lexus.
 Old 04-21-2010, 08:06 AM   #110
Doc
Doc's Avatar
Posts: 526   (View Stats)
Doc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the world
Groans: 35
go and have a read mate, and stop cluttering up this thread........
Doc is offline   Reply With Quote
 Old 04-21-2010, 08:08 AM   #111
8.5MS3's Avatar
Groans: 326
sigh, go read some fuckin threads and stop clogging up good ones.
POWERTRAIN is 5yrs/60k
you cant clean the back of the valves with fuel injector cleaner if theres no fuel in the air when it goes past. please stop bitching and go do some reading.
 Old 04-21-2010, 08:11 AM   #112
Doc
Doc's Avatar
Groans: 35
thread cleaned up...
The Following 2 Users Say Thank You to Doc For This Useful Post:
djuosnteisn (04-21-2010), Lex (04-21-2010)
 Old 04-21-2010, 08:11 AM   #113
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 04-21-2010, 02:36 PM   #114
JumpingJackson's Avatar
Posts: 967   (View Stats)
JumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the world
How big of an effect would popped injector seals have on a compression test / leak down test?
JumpingJackson is offline   Reply With Quote
 Old 04-21-2010, 03:25 PM   #115
aaronc7's Avatar
Groans: 370
probably not much since mine only leaked at 15psi or above... it depends on bad the leak is i guess, but unless its a huge leak, its probably not enough pressure to affect results.
 Old 04-21-2010, 03:26 PM   #116
If they leak under dry compression they will definitely give you issues while driving.
 Old 04-28-2010, 10:34 PM   #117
Qwik6's Avatar
Got around to testing mine this morning when I changed spark plugs.
2006 Mazdaspeed 6
Close to sea level. 30 feet I believe.
72,000 miles
19psi daily driver. Damn near fully bolted. Synthetic oil since 32k miles.
Cyl 1 - 192psi
Cyl 2 - 192psi
Cyl 3 - 192psi
Cyl 4 - 192psi
All were 192psi dead on. Engine was heated up. Actually drove the car 10 miles before I came home to pull it apart.
2006 MAZDASPEED6
The Following 2 Users Say Thank You to Qwik6 For This Useful Post:
djuosnteisn (04-29-2010), Lex (04-29-2010)
 Old 04-29-2010, 06:48 AM   #118
shpankey's Avatar
wow. lucky dogs!!
09 Speed 3 GT
 Old 04-29-2010, 07:30 AM   #119
Great compression for the mileage. Must take care of it well!
2006 Mazdaspeed 6
72,000 miles
Cyl 1 - 192psi
Cyl 2 - 192psi
Cyl 3 - 192psi
Cyl 4 - 192psi
djuosnteisn (04-29-2010), Qwik6 (04-29-2010)
 Old 04-29-2010, 08:53 AM   #120
Jarods7920's Avatar
Posts: 1,415   (View Stats)
190
190
190
11k built engine. Minor boltons for another week. 440 ASL. Engine was warm.
Jarods7920 is offline   Reply With Quote
The Following User Says Thank You to Jarods7920 For This Useful Post:
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/disi-compression-results-43395/
Random MS3 Chat Thread - Page 171 This thread Refback 04-20-2013 04:45 PM
Anyone measure compression on stock motor? - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum Post #12 Pingback 03-12-2010 08:06 AM
Compression test on built motor SharkDiver MazdaSpeed 3 - Engine, Transmission & Driveline 5 10-22-2009 02:48 PM
Compression check on Laloosh's motor gsrtype1 MazdaSpeed 3 - Engine, Transmission & Driveline 27 09-06-2009 06:25 PM
engine build with stock compression Jessed87 MazdaSpeed 3 - Engine, Transmission & Driveline 8 06-12-2009 10:55 PM
Compression test done.. SharkDiver MazdaSpeed 3 - Engine, Transmission & Driveline 3 03-25-2009 03:28 PM
engine compression? bombdotcom Mazdaspeed3/6 General Discussion 12 09-23-2008 03:06 AM
Page generated in 0.57511 seconds with 36 queries
